T O P I C R E V I E W |
lbaeza |
Posted - 06/13/2009 : 08:37:41 Hi
I bought a Dual power Willem eprom programmer from Mcumall several years ago, mainly for burning 2716/2732 eproms with no problem at all. Last week I wanted to burn a 27C512, so I set up the right Vpp and Vcc, but couldn't burn the eprom. After several tries, I started to check if everything was OK on the burner side. So I checked Vpp and values were off range. Then I went to my computer BIOS and set up the EPP printer port mode, but I had Vpp values off range too. So I started checking all possible combinations of Vpp and Printer port mode, and the results are in the attached picture (DMM = Values I got with my digital multimeter when checking Vpp values).
50.44 KB
Is there a problem with my EPROM programmer? What components should be replaced when I get these values for Vpp? Should I give it a try using another computer?
Regards |
ZLM |
Posted - 06/21/2009 : 06:43:44 Check U11, MC34063A output. See if it has a correct VPP voltage. |
lbaeza |
Posted - 06/19/2009 : 17:51:47 Hi
Thanks for your reply, ZLM. I have downloaded the schematics, but I am not very clear where to look at... any ideas what components in particular I must check?
Regards |
ZLM |
Posted - 06/13/2009 : 23:34:53 The printer port mode shoulde not change the VPP value. It seems the programmer Vpp circuit has some problem.
Check the schematic: http://www.mcumall.com/forum/topic.asp?TOPIC_ID=2028 |
