| T O P I C R E V I E W |
| Bad_Ad84 |
Posted - 06/02/2009 : 14:49:21 which adapter would i need for this? in tsop-32 package?
as im having difficulty and want to make sure its the right adapter before i start trouble shooting. thanks |
| 9 L A T E S T R E P L I E S (Newest First) |
| Bad_Ad84 |
Posted - 06/04/2009 : 16:03:01 i put the chip back into the xbox and flashed it in the machine.
i will try to get my hands on some for testing and send one your way. |
| ZLM |
Posted - 06/04/2009 : 15:45:16 If the chip ID gone, then the programmer may not be able to erase and write the chip. |
| Bad_Ad84 |
Posted - 06/04/2009 : 14:20:07 right, the chip was from an xbox and it seems theres issues with this chip and ID'ing even in the xbox, you need to solder a wire on the bottom of the board for THIS BRAND ONLY... other makes of chip work fine.
seems like something weird this chip is doing? |
| Bad_Ad84 |
Posted - 06/04/2009 : 01:31:12 Chip works perfectly as it's back in the original device and still works. |
| ZLM |
Posted - 06/03/2009 : 22:32:59 a dead chip? |
| Bad_Ad84 |
Posted - 06/03/2009 : 14:25:05 ID comes back as FFFF, which is obviously wrong.
also, doesnt read. |
| ZLM |
Posted - 06/03/2009 : 07:36:31 Both should work.
Check your chip pin 1 position in ZIF. Pin contact.
What ID you got?
Can you try to read the chip? Erase, and the write? |
| Bad_Ad84 |
Posted - 06/03/2009 : 03:06:03 well theres...
http://www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=3153
or
http://www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=4224
i have both, but i dont seem to be ID'ing the chip with either. |
| ZLM |
Posted - 06/02/2009 : 21:26:45 If it is TSOP32 chip, then it needs the TSOP32 adapter. |
