 DIP settings for a couple of chips need them Badly
Rippa_MD Posted - 01/02/2008 : 14:44:20
I having trouble finding the devices in the menu in the willem eprom program version 97ja.
Hopefully they are supported. I have four socketed PLCC chips:
The first chip came with the purchase I made on ebay seller not mcumall. The second chip I flashed with the wrong bios and is really the one I need reflashed!!!
Winbond: W29C020CP90B
SST MPF: 39SF20A
The last two I pulled from a dvd player and a hard drive but will like to know if they are reflashable and if so DIP switches.
ATMEL: AT27C010
EON: EN29F040
Also where do I find the chips on the actual willem program, don't I need them to be listed in order to program them?
Rippa_MD Posted - 01/05/2008 : 19:55:04
thank you and you are correct they are listed. I found the settings but the picture was not a PLCC device so it confused me the first time I found the device listed on the software.
Everything work. Saved my motherboard!!!
The best version was 97g. 97ja did not work properly.
ZLM Posted - 01/03/2008 : 19:59:57
All DIP are showing in the software after you select the device type.
W29C020, 39SF/49F020, 29F020
Generated in 0.29 sec. Snitz Forums 2000
