T O P I C R E V I E W |
teamzr1 |
Posted - 10/17/2019 : 19:24:22 All the users manual says is :
Note: If you are using an un-powered USB hub or extension hub, it may not provide enough power to operate the USB programmer. In this case, you may need a 9V, 200mA (or greater) DC adapter with a center-positive, 2.1mm DC plug.
If plugging into the D/C connector or programmer and supplying 9 Vdc is there anything that has to be set so that programmer knows that being used and
Will that 9 Vdc effect the D/C that a USB port is supplying at same time ?
Also says 9 Vdc or greater, what is best voltage level to supply if using an adjustable power supply ?
Thanks |
anniel |
Posted - 10/18/2019 : 17:44:36 quote: Originally posted by teamzr1
OK thanks
Yes using a bench power supply that handle 400 mAmps and will set it to like 10 Vdc
That should be fine. |
teamzr1 |
Posted - 10/18/2019 : 16:19:11 OK thanks
Yes using a bench power supply that handle 400 mAmps and will set it to like 10 Vdc |
anniel |
Posted - 10/18/2019 : 03:30:03 quote: Originally posted by teamzr1
Nothing needs to be set, just plug i in and it will work without affecting your USB. If you are using a good lab supply 9V to 12V is fine. |
