 please can someone help with getting a hex dump
craig6928 Posted - 03/09/2011 : 20:40:58
hi i posted the same problem im having
this is driving me nuts
can someone help us please i need to get a good dump hex of a pic chip i have here
im using the willem programmer
the chip in question is a PIC 16F819
i load it up to the first buffer (is this correct)
then i save the file out as a hex
when i load it back in to reprogram the chip
i go into buffer and load it up the first one (is this correct)
once i click program full chip the green bar goes across
it goes to 70% and that it
after that it says config area programming
and does nothing else
can someone show me how to do and get a dump hex
and load it onto the other pic
another pic chip
thank you
craig6928 Posted - 03/10/2011 : 15:53:55
thank you for your help ZLM
craig6928 Posted - 03/10/2011 : 15:52:03
hello ZLM i did the chip verify confirm and it says the hex is ok
but i used the program you said ic prog older version.
this did a perfect dump of the chip
but came up error VERIFY FAILED ADRESS 0000H
when i tried to reprogram it
so i used willems programmer to burn the hex
and it worked
the only error in there program is that it does not come up done
it stays on and say programming pic config area
craig6928 Posted - 03/10/2011 : 02:09:49
i post back with my findings
ZLM Posted - 03/09/2011 : 21:28:05
Do verify to confirm if it is programmed correctly.
