 GQ-4X and Motorola TMS2716C
stangbat Posted - 01/03/2012 : 17:10:13
Will the GQ-4X program a Motorola TMS2716C? The datasheet is here, although the C version is not specifically mentioned:
www.datasheetarchive.com/dl/Datasheets-110/DSAP0010008.pdf
I've tried the generic 2716B at different speeds but it always stops at 9%. I'm hesitant to try the 21v or 25v VPP devices because I don't want to damage the EPROM. Any tips are appreciated.
grantb5 Posted - 07/11/2015 : 14:14:21
Any thought to adding it to the device list with a Message= to indicate DEVICE NOT SUPPORTED?
Or add an unsupporteddevices.txt. I dunno, just something to save us some time and hair pulling. Spent quite a few hours on this before I realized it was a triple supply issue. Had a variety of 2716s and it took a while to see that pattern of the ones that would always fail.
ZLM Posted - 01/03/2012 : 23:34:37
The GQ-4X does not supports TMS2716C. The TMS2716C needs a +/-5 dual power.
2716B should be OK. Erase the EPROM a bit longer and see if it works. Try to write multiple times if the first try fail.
The chip problem will let programming fail too.
I do not recommand your to try 21V, 25V VPP. The 2716B is 12.7V indeed.
