 Immo ECU Fiat
Becoacamba Posted - 04/14/2009 : 10:01:39
Hi fiends I have a problem with the immo of this ecu fiat that I want to remove it. someone could guide me to say which component has stored in the immo ecu this is fiat siena palio 1.6 TBI injection to gasoline model ecu 1G7.
68.18 KB
thx
angmar Posted - 03/13/2011 : 16:19:35
Hello this micro is hc11f1, you can read with motorola programmer in circuit to internal eprom and remove inmo very easy
billlikecar Posted - 12/02/2010 : 23:20:39
I have seen the same product in www.eobd2.com/wholesale/ecu-chip-tunning/ before,I advise you to contact with the enginneer,perhaps you will get help.
ZLM Posted - 04/17/2009 : 23:29:25
It should be small 8 pin SOIC EEPROM chip. But I do not know which one from your picture. All those chips are not standard EEPROM chip type.
