 Tc97101b chip
Mafkins Posted - 12/10/2010 : 09:13:21
Hi everyone!
I have vw transporter (siemens digifant 1.72) ecu, is tc97101b eeprom reading/writing possible something my gq-4x programmer?
is this chip possible replace something else?
Thanks.
kbzaloka Posted - 10/13/2013 : 06:58:28
Originally posted by power1977
Some one cnow how to add this eeprom and where can i found datasheet?
is microwire equivalent 128x8 or 64x16
try it as 93x46 both readings , as x8 or x16 bits
it should work
power1977 Posted - 10/11/2013 : 14:51:10
ZLM Posted - 01/12/2011 : 00:32:43
The link items are not universal programmer. It works on specific vehicle model, those are vehicle model oriented products. GQ-4X is a universal programmer. It supports the the chip level programming. As long as your chip in the software suppored device list, then it will do the work.
See:
http://www.mcumall.com/comersus/store/mcumall_TrueUSBWillemsupportICs.asp
billlikecar Posted - 01/11/2011 : 23:31:52
i don't konw want you are talking about,maybe you can tell more details about it.click this www.eobd2.com/wholesale/ecu-chip-tunning to have a look and find you chip.maybe it will help you...
Originally posted by Mafkins
Hi everyone!
Thanks.
ZLM Posted - 01/08/2011 : 00:21:57
We need to know the partnumber from chip manufacturer. so that to confirm if the chip works with GQ-4X.
