 H27U4G8F2DTR-BC _ 4Gbit (512M x 8bit) NAND
dorus Posted - 12/18/2015 : 09:33:41
Hi, I just bought the GQ-5X and let me know if you can read and write a NAND, Hynix brand, H27U4G8F2DTR-BC model. Is a 4Gbit (512M x 8bit). In the menu of 1.03 GQBlaster this model is not listed
dorus Posted - 12/22/2015 : 01:36:38
I finally decided to record it with the dump read of it, and as I expected everything went perfect. TV NAND flash works OK. I've tried other NANDs, other chassis before, and even now performs well. Thanks again.
I can't use external links and the forum image uploader is not working so i'll just post the images like this:
h**p://www.mediafire.com/convkey/f79b/9rsd9a4sti4ghcozg.jpg
h**p://www.mediafire.com/convkey/cc55/iawegq3ucr2odhrzg.jpg
h**p://www.mediafire.com/convkey/96ec/60pif86pazv4ie0zg.jpg
h**p://www.mediafire.com/convkey/8c6a/j8wsl1lellic8uszg.jpg
h**p://www.mediafire.com/convkey/f201/6l95e65i5h7rprkzg.jpg
h**p://www.mediafire.com/convkey/1eec/b060u3kpc3u37a3zg.jpg
dorus Posted - 12/21/2015 : 03:42:25
Yesterday I was welding the NAND memory and if that correctly detects the programmer, and also reads it without any problem. The trouble is that I haven,t another virgin, to test if recorded properly. As the TV works ok with that NAND,
I prefer not to risk on overwrite the same file saved.I trust that records coorecto too.
Thank you for your time.
ZLM Posted - 12/20/2015 : 21:58:53
Yes. It should be supported.
Write email to activation@mcumall.com for help.
