 FROM WILLEM TO GQ-4X!!!!
phantom Posted - 02/15/2016 : 02:14:33
hi to all! i would like to upgrade from my willem programmer to a gq-4x
i use the programmer most exclusively to reprogram pc bios.
i would like to know if i can use the adapters that i have with the gq-4x
PLCC32 to DIP28 Adapter
SMD 24Cxx, 93Cxx Adapter
SOIC8 (Surface mount) to DIP8 Adapter
T01 Top - TSOP32, 40, 48 (with socket) Adapter
T12 - Base - TSOP40A and TSOP40B Adapter
[ PCB 10Fxxx Adapter SOIC 8 to DIP 8 Adapter
[ B02 ] - PLCC32 to DIP28 Adapter
[ B11 ] - MCS-51 / AVR + PLCC44 Adapter
SOIC 8 (Surface-mount 150,208 mil) to DIP 8 Adapter
if not, could you suggest me the most important adapters to buy to assure that i can reprogram all bios chips?
thank for the help and sorry for my english
P.S I'VE FOUND ON AN ASUS LAPTOP AN EEPROM THAT I CAN'T FLASH WITH THE WILLEM: 25LQ64CSIG
CAN I PROGRAM IT WITH YOUR PROGRAMMER?
anniel Posted - 02/15/2016 : 04:50:58
Yes most adapters should work on the GQ-4X.
The most useful adapter to work with BIOS is a FWH/LPC+.
http://www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=3202
or if you need chip adapters
http://www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=4317
For the 25LQ64CSIG you need ADP-099
http://www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=4630
