 29f033 failes to verify
pivot94 Posted - 03/11/2017 : 08:11:26
Ok so I an trying to program 29f033 chip.
ID is ok
wipe is ok
write is ok
verify always has an error!
This is the code I used the add the chip to devices:
Name="MBM29F033C*TSOP40",ID="04D4",Class="29F040B",Category="FLASH",MFG="FUJITSU",CodeSize="4194304",DIP="100011110101",Adapter="TSOP40B-DIP32(ADP-077 and ADP-082)";
programmer gq-4x
software ref 6.38
OS win XP
What am I doing wrong!
Ice Man Posted - 03/15/2017 : 06:02:53
I have the solution:
To program 29F033C use an external 9V DC power supply as well while programming! It worked fine for me.
Program OK, Verify OK.
Ice Man Posted - 03/13/2017 : 03:05:20
ebay, aliexpress. There's alot of sites.
h**p://www.ebay.de/itm/Tl866cs-Programmer-8-Adapters-Tsop32-Tsop40-Tsop48-Adapters-Bios-51-Flash-Epro-F-/232248722153?hash=item36131a42e9:g:oBkAAOSwo4pYH0sw
pivot94 Posted - 03/12/2017 : 13:55:38
The TL866 supports 29f033?
Where can I get a TL866 and TSOP adapter?
If I find a way to use the GQ-4X I will let you know asap. :)
Ice Man Posted - 03/12/2017 : 05:20:55
29F032 is usually more expensive. TL866 can programm all of them them with adapter just fine. I have been using it all the time for those until I can program them with GQ-4X.
But if you remember your way of programming them on GQ-4X. Please let me know. :D
pivot94 Posted - 03/12/2017 : 00:57:57
gq-4x can program them as I program successfully a few days ago.
I don't know what I did but it just worked.
Someone must have some idea?
If not does anyone know where I can buy 29f032?
Or a programmer that will write to a 29f033 with any problems.
Ice Man Posted - 03/12/2017 : 00:22:17
I have the same problem and no solution so far.
h**p://www.mcumall.com/forum/topic.asp?TOPIC_ID=7580
