 Clone failure K9GAG08U0E.
napalico Posted - 12/05/2016 : 11:28:26
According to the video: https://youtu.be/qeV3GRiXQKI
I have new K9GAG08U0E. For more that I follow all the steps of the video, arriving at step 6 this ends and is recorded correctly but do not do the verification of the data. After this, I do the verification and it always gives me the message "Compare data Failed address ...." so that none of the clones work and fail again. Could be missing some step in the video ?.
With the last update to V1.05 the problem continues and 10 memories that I recorded according to the steps of the video, all give me error in the verification.
Please, any guidance? I am new at this. Thank you
326   L A T E S T    R E P L I E S    (Newest First)
anniel Posted - 02/21/2020 : 08:05:09
Hello guys,
Can any one help me please?
I have a BIN file for PN..D6500/7000. I use new version 1.09
After I wright BIN file on NAND, it works fine unless I start a SmartHub. As soon as I agreed to all the terms and conditions, it starts to update apps. The first app "Your Video" is deleting half way and my TV shuts off and restarts. After I'll do the same thing second time, TV will shuts off and start cycling ON-OFF with samsung logo. At this point I have to reprogram my chip and it will be the same.
I tried multiple chips (brand new and used). At this point I think that my BIN file is bad.
Any idea? Does anyone can share their BIN file? I can send my BIN file as well.
Please let me know.
Thank you
I guess no one have any info on my question. Even GQ SUPPORT can't tell us what is going on with programming K9GAG08U0E.
From the time I post above question, I tried many different chips and couple of different BIN files. It is ALL THE SAME.
Just please STOP telling me to RESET TV, USE NEW VERSION etc.
***** I HAVE DONE IT ALL*****
I spent SO-MUCH-TIME that I'm ready to BRAKE this GQ-5X with a rock and post it on youtube.
Some chips by some reason worked, but 2-5 month later my customers are calling back with the same problem. NONE of the chips workd from the first time. After SmartHub test they eather DIE or shuts off after SmartHub test.
GQ SUPPORT - please let us know what is wrong with this programmer. Could it be the device itself? Maybe some units are good and some are not. What I can tell you for sure that I tried around 50-60 different ICs (30-40 new and the rest used ones) and 4-5 different BIN files that was purchased as IC and couple from working TVs
*******GQ SUPPORT - I (we) NEED YOUR HELP********
Did you ever take action with the rock or did you eventually understand how to follow the instructions provided in the other topic?
Yes your customers will call you back if you do not fix the defective Samsung firmware.
skdaddy69 Posted - 06/05/2018 : 18:21:30
Hello guys,
Please let me know.
Thank you
anniel Posted - 12/28/2017 : 06:26:11
www.univ-st-etienne.fr/salware/Bibliography_Salware/IC%20Counterfeiting/Article/Guin2013.pdf
www.utdallas.edu/~gxm112130/papers/pieee14.pdf
h**p://www.pdfserv.maximintegrated.com/en/an/TUT5458.pdf
www.aeri.com/counterfeit-electronic-component-detection/
https://atadiat.com/en/articles/e-introduction-counterfeit-ics-counterfeiting-detection-avoidance-methods/
anniel Posted - 12/25/2017 : 13:52:46
Originally posted by Willyxr
this programmer not work correctly.
in tv samsung UNxx5500 the smart function none works.
fail with any manufacturer of memories
this programmer are a scam.
i lost my time, my money in this.
this programmer keep contiunes sold and offering as a support for samsung tv with memories k9gag08u0e, and that is NOT TRUE !!!
Yes it works correctly with all supported devices and then some.
You are a scam. A real technician would be able to operate such a simple apparatus.
Willyxr Posted - 12/24/2017 : 18:14:00
eduardo48 Posted - 11/04/2017 : 16:01:30
Hello guys,
Please let me know.
Thank you
You are always testing with the same main plate
skdaddy69 Posted - 10/12/2017 : 15:38:05
Hello guys,
Please let me know.
Thank you
anniel Posted - 10/04/2017 : 03:08:24
Originally posted by dorus
Works perfectly with win10-64,
software version: GQBlaster 1.09
The driver: SignedUSBDriver2.01
When loading the BIN will output bad blocks
Also when erasing the NAND output bad blocks
This is normal because of the characteristics of NAND-s: (they are not perfect)
Ignore those bad blocks
To program use the SMART button (all automatic will be done)
and will not make mistakes
Model:
UE40D5500
UE37D5700
UE40D5700
UE46D5700
Chassis: BN41-01660A/B
Version firmware: 001027
Nice testimony! Thank you.
dorus Posted - 10/04/2017 : 01:49:22
Model:
UE40D5500
UE37D5700
UE40D5700
UE46D5700
I have recorded nand-s for both samsung ue40d5500 and 5700 and they work perfect. The same ones that I unsoldered from the original plate
15363 bytes
14191 bytes
18695 bytes
19416 bytes
15913 bytes
17360 bytes
anniel Posted - 09/20/2017 : 02:37:28
Originally posted by thetan76
ne plus ultra...
Could you guys speak English, please...
Yes we can.
thetan76 Posted - 09/19/2017 : 23:35:49
ne plus ultra...
anniel Posted - 09/15/2017 : 03:42:42
si le doy al boton de write chip me sale esto
-program
Size does not match
como si el .bin fuera mas grande que la memoria, puede ser?
estoy usando la version 1.08
Utilice la última versión.
Willyxr Posted - 08/11/2017 : 08:59:44
-program
Size does not match
Willyxr Posted - 08/11/2017 : 08:56:49
ayuda por favor.
es la primera vez que lo voy a usar.
hago como me dijeron, coloco la memo k9gag08uoe nueva virgen, cargo el .bin que pesa 2.13gb, le doy a erase chip y luego smart copy
pero me dice "make sure the proper source file is loaded"
ya probe con 2 .bin diferentes, uno se que esta hecho con tnm5000, el otro no se con que lo levantaron.
ayuda por favor
supervizeur Posted - 08/03/2017 : 06:46:28
Originally posted by eduardo48
Funciona bien
Gracias Eduardo,
Un par de consultas mas,
Sabes de algun tuto o video actualizado para grabar las memos k9gag?
Y entre este programador y el tnm5000 cual recomendas? O rinden identicos para grabar estas memos?
Muy amable
TNM5000 tiene cero soporte.
+1
supervizeur Posted - 08/03/2017 : 06:45:07
Hola, venia siguiendo el tema pero me perdi en un mar de discusiones en frances.
Les pido una ayudita a mis colegas de habla hispana, si me pueden confirmar que con la ultima version 1.08 creo que es, ahora se pueden grabar sin problemas las memos k9gag para los samsung unxx5500
Quisiera comprar este programador en la version que ya viene con tsop48 incluido en el pcb.
Las grabaciones las haria desde un dump nuevo limpio, no tomado de una tv usada.
Hacia memos nuevas tambien.
Funciona bien hoy dia?
Gracias
Sí, buen conjunto de trabajo.
Está de vuelta con sus gemidos.
anniel Posted - 07/13/2017 : 07:32:13
Gracias
Sí, así foncionne.
+1
anniel Posted - 07/13/2017 : 07:31:39
Originally posted by MANN France
ISP programming pour un investissement de moins de 10 euros (frais de port en sus).
https://en.wikipedia.org/wiki/In-system_programming
Aussi en Français.
https://fr.wikipedia.org/wiki/Programmation_in-situ
donc je branche le système de "In-system_programming" , sur la carte BN41-01660 , et je lance la programmation in-situ de la mémoire soudée en BGA , qui contient le firmware dégradé . Superbe idée .
MAIS , pratiquement , je le branche où?? sur le fichier ethernet , sur l'USB , sur la carte dite "commun interface" CN1801_CI) , et je dis au processeur central ( SAMSUNG SEM21 / 1732A) d'aller modifier le contenu de la mémoire IC1301 (KFG1GN6W2D) avec le fichier binaire du firmware d'origine.facile , n'est ce pas !! mais qui va me donner la procédure et le fichier ?? Vous ??Mr le "professeur d'université" , je suppose ??ou SAMSUNG contre l'achat d'une licence de dépanneur "4 ème échelon" ( 4ème échelon = niveau de maintenance avancé , de dépannage au niveau du composant d'une carte de sous ensemble ) . J'ai 3 cartes en panne = je vous les envoie au Canada , et vous vous chargez de la procédure pratique ?? c'est très sympatique . je vous les envoie par courrier postal ; mais où ??
Are you really a repairman? Wanting to send out your repairs to be done by a third party, seriously?
A board swapper, at best.
Exactly.
Lots of them around.
I deal with a few of those.
Yes, here also.
True.
anniel Posted - 07/13/2017 : 07:30:44
No hace falta tutorial es muy fácil, borrar la memoria, cargar el archivo y darle al botón Smart copy el software hace todo solo, yo personalmente no use el tnm tiene un costo mucho mas elevado, asi que no puedo hacer la comparación, seria tu elección, gq5x tuvo inconveniente de software al comienzo, pero ahora parece que va bien con la versión 1.08, igualmente yo lo utilice con la versión 1.05 en copia directa.
Parece que al francés le funcionó porque no se quejo mas.
+1
anniel Posted - 07/13/2017 : 07:26:43
Funciona bien
Gracias Eduardo,
Muy amable
anniel Posted - 07/13/2017 : 07:22:12
Funciona bien
+1
anniel Posted - 07/13/2017 : 07:21:30
Gracias
supervizeur Posted - 07/09/2017 : 09:01:45
+1
supervizeur Posted - 07/09/2017 : 08:59:26
Funciona bien
+1
supervizeur Posted - 07/09/2017 : 08:58:35
Gracias
Sí, así foncionne.
supervizeur Posted - 07/09/2017 : 08:55:15
Aussi en Français.
Exactly.
Yes, here also.
supervizeur Posted - 07/09/2017 : 08:48:11
Uy que bueno estaba aburrido el foro, no pago mas netflix veo la novela por aca
Serie web gratuito.
Lleno de giros y giros!
Lleno de giros y vueltas!
Sin interrupciones.
¡Eso esperamos!
Parece que ha desaparecido.
¿Para bien?
¿Quién sabe?
+1
Willyxr Posted - 07/07/2017 : 14:40:17
Muchas gracias.
eduardo48 Posted - 07/07/2017 : 10:34:44
Willyxr Posted - 07/06/2017 : 22:18:24
Funciona bien
Gracias Eduardo,
Muy amable
eduardo48 Posted - 07/06/2017 : 05:39:32
Funciona bien
Willyxr Posted - 07/05/2017 : 22:49:02
Gracias
anniel Posted - 06/27/2017 : 10:42:13
Aussi en Français.
Exactly.
Yes, here also.
anniel Posted - 06/27/2017 : 10:40:31
Serie web gratuito.
Sin interrupciones.
¡Eso esperamos!
¿Para bien?
¿Quién sabe?
anniel Posted - 06/27/2017 : 10:35:17
YOU =
.........I think we're not dealing with a blockhead but with a thick headed Besserwisser.
merci de traduire en français = google traduction ne connait pas "Besserwisser"!!
le droit français ne s'applique pas en droit international =c'est VRAI ; et c'est dommage! .
Si c'était le cas , nous avons un organisme de répression des fraudes et des traitement des publicités mensongères .....
Quant à vos propos , je ne connait pas la culture NORD - AMERICAINE , ni la forme d'humour que vous pratiquez .GOOGLE TRADUCTION , NON PLUS .
je vous invite donc , à lire le mail d'hier au support produit MCU Mall , dont voici un extrait.La culture française est réputée mondialement pour sa subtilité et sa précision ....( moins pour le commerce ! )
( il est vrai qu'un anglo-saxon aura du mal à en saisir toutes nuances ,; ni GOOGLE TRADUCTION ! ) =
EXTRAIT du mail =
......par contre , il serait bien de modérer les propos des personnes qui n'ont pas d'arguments techniques sur ces forums !! Du temps de LAFAYETTE , ils n'étaient pas dans la galère ; mais dans les salons du ROI LOUIS XIV à VERSAILLES ; en train de discuter de banalités , mais incapables d'agir et de mettre "les mains dans le cambouis" ( google traduction = ??? ) . CQFD ......
....je perds beaucoup de temps pour tout ces tests !!
faut il revenir aux anciennes versions ???.......
.....réponse ( ci dessous) à la cour du ROI LOUIS XIV , dans les salon du château de VERSAILLES =
(avant hier = en 2017= visite de Vladimir POUTINNE avec Mr Emmanuel MACRON ;notre nouveau président de la République Française ) .....
.....ET ALORS !!!!=
EN 1789 , il y a eu une révolution en FRANCE = on en a mis dans l'échafaud pour moins que cela !!! CQFD ...
CQFD = Ce Q'il Fallait Démontrer = This Q'il Shall Demonstrate
What's that french politics mumbo jumbo all about? What has it to do on a technical forum like this one? You are really deranged!
Free french history lessons.
From a nutcase?
That way you only get the best highlights.
Yeah, it cuts on the chitchat.
I should introduce him to one of my good friends; Arlette Farge.
I bet she would be flabbergasted, in fact even a child would be.
[/quote]
+1
anniel Posted - 06/27/2017 : 10:33:53
What makes you think I'm in Canada?
You smell maple syrup bacon.
Hmmm maple syrup bacon.
I thought it was because of my red-and-green suspenders and my secret weapon: duct tape.
You spotted me.
supervizeur Posted - 06/20/2017 : 03:53:54
Mr , Hors votre capacité à répondre complètement hors des questions techniques , et votre fuite devant toute démarche positive , je pense que la société MCU Mall devrait bien réfléchir avant de continuer à vous tolérer sur ce forum .
Votre attitude méprisante et insultante ne peut pas servir les intérêts commerciaux ,où la politesse et la courtoisie sont un minimum pour ne pas être licencié illico pour faute grave. Mais ce n'est pas mon problème !
To whom are you addressing this? Or are you self reflecting on your own actions?
Donne à manger à un cochon, y viendra chier sur ton perron.
Pour vous illustrer ceci , et en référence à notre histoire passée , du temps des Rois de FRANCE , nous aurions réglé votre façon de vous conduire , demain matin, à l'aube , et avec 2 témoins = l'épée à la main , et ce serait votre fin .
Still giving free history lessons.
Et plus tu le nourris, plus qu'il chie.
Mais on est en 2017 , et maintenant vous franchissez la ligne ultra-rouge une fois de plus . Une seule réponse peut vous convenir = vous ignorer définitivement , car je n'ai jamais vu une telle attitude ( un traitement en Hopit... Psych...... me semble approprié) .
So, you're going to the crazyhouse?
À force de se prendre pour le centre du monde, certaines personnes devraient s'étouffer avec son noyau.
je vous dit donc "ADIEU" , ou plus exactement ce serait " AU DIABLE" ( c'est un jeu de maux !( mots) ...votre psychologie me semble incapable de comprendre cette subtilité )
Yet another farewell from the Phoenix!
Ha, you also noted him posting his email publicly...
je vous joins en P.J des recopies d'écran ( voir mes messages sur Ebay = PB d'envoi de photos = souvent erreur serveur !! )
--- Message d'origine ----
De : support@mcumall.com
À : superphenix@numericable.fr
Objet : Re: photo QG-5X
Date : 31/03/2017 06:47:33 CEST
Et bon débarras !!!
Yes, he also posted his phone number in another topic, must be badly in need of publicity.
cdt jean pierrre MANN 33170 GRADIGNAN / Bordeaux . France métropolitaine
(00) (33) (0) 6 58 45 08 72
http://www.mcumall.com/forum/topic.asp?TOPIC_ID=8045 Reply #4.
Or too much time on his hands.
+1
supervizeur Posted - 06/20/2017 : 03:52:10
Aussi en Français.
Exactly.
supervizeur Posted - 06/20/2017 : 03:49:55
vous auriez peut-être pu comprendre la parabole
Ce n'est pas en parlant en paraboles que vous serez clair sur un forum technique.
Maybe his goal is to render this forum and this thread hard to understand and denigrate MCU Mall and the GQ-5X So he can keep the monopoly?
What would that make him?
The difference between stupidity and genius is that genius has its limits.
I fear the day that technology will surpass our human interaction. The world will have a generation of idiots.
And he's the leader of the pack.
+1
supervizeur Posted - 06/20/2017 : 03:48:52
Serie web gratuito.
Sin interrupciones.
¡Eso esperamos!
¿Para bien?
supervizeur Posted - 06/20/2017 : 03:44:36
YOU =
EXTRAIT du mail =
.....ET ALORS !!!!=
From a nutcase?
[/quote]
supervizeur Posted - 06/20/2017 : 03:32:26
You spotted me.
anniel Posted - 06/15/2017 : 16:27:40
décidement , je dois être idoit!!
Or do you mean IDIOT?
Maybe we're dealing with a newfie posting as a frenchie.
Or maybe he's simply a crazy frenchie.
https://www.google.com/search?q=crazy+frenchie&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwiHnp70-bjUAhWD7D4KHb_HBzMQsAQINQ&biw=814&bih=369
anniel Posted - 06/15/2017 : 16:26:18
Et bon débarras !!!
anniel Posted - 06/15/2017 : 16:24:50
Soyons sérieux !! voici une autre façon de faire = c'est une vidéo RUSSE postée il y a moins d'une heure !!
https://www.youtube.com/watch?v=SOv0ekthDHc
#1047;#1072;#1084;#1077;#1085;#1072; OneNand KFG1GN6W2D - SAMSUNG UE32D5500
comment remettre des billes de soudure , avec un pochoir sur le circuit dessoudé KFG1GN6W2D , puis le resouder sur la carte BN41_01660 ( et oui , cela n'est pas du "baratin de salon! " ) .
So, you found out one of the ultra secret technique to reball a BGA? Exclusively featured in thousand and thousand of YouTube vids.
That was hard to find knowledge.
Knowledge is learning something new every day. Wisdom is letting go of something every day.
mais le programmateur GQ-5X ne supporte pas les boitiers FBGA !!
Yes it does, remember, you can add any devices to it.
+1
et s'il c'etait le cas , faudrait t_il avoir le fichier binaire pour programmer le firmware .
Simply pull it from a known good board, like everyone else does.
+1
ensuite , un jeu d'enfant , n'est ce pas = acheter les NANDS sur = https://fr.aliexpress.com/store/product/New-and-original-KFG1GN6W2D-HIB6-BGA-spot-play/1607003_32254270862.html à 16 euros le lot de 5 , ou demander à LUCIFER de nous en donner contre la vente de notre "âme"
Or just leave the NAND on the board, proceed with ISP and save your soul.
Don't give cherries to pigs or advice to fools.
I am thankful for all those difficult people in my life, they have shown me exactly who I do not want to be.
+1
anniel Posted - 06/15/2017 : 16:23:30
Aussi en Français.
Exactly.
anniel Posted - 06/15/2017 : 16:22:24
[quote]Originally posted by MANN France
Je compte sur "ANIEL" ou le "superviseur" pour me proposer une meilleure solution.
ISP programming
[réponse totalement stupide !! il s'agit de trouver un procédé autre que la refusion pour dessouder un boitier type "BGA" ( rangées de billes d'étain) ; puis de le reprogrammer, et de le ressouder sur le circuit imprimé . c'est je pense , hors de portée d'un électronicien moyen , car cela exige des machines spécialisées .Si la programmation de la NAND a mal été faite , il est possible que lors d'une mise à jour du FIRMWARE , celle ci se bloque et la carte mère est bonne pour la poubelle .
j'en ai deux dans ce cas et est ce que j'envoie la facture au service commercial d MCU MALL pour me dédommager ??
Ma foie, vous êtes totalement borné!
Je vous offre la solution à votre problème et vous continuez d'argumenter sans raison?
Yes, it adds to the drama.
That must be it, fits with the persona.
Or he has dain bramage.
That he has certainly.
anniel Posted - 06/15/2017 : 16:21:19
ISP programming
You really read all his ravings? I concur, ISP is what I use most.
I'm starting to loose interest in all his blabbering.
All his confusion is still entertaining.
Yes it is.
anniel Posted - 06/15/2017 : 16:20:16
Espero impaciente el próximo capitulo
Siempre es bueno tener un poco de acción en un foro como este.
je ne sais si ton "déconomètre "est bloqué "out off range " , ni si le GOOGLE TRADUCTION , ve ta donner la vraie signification . Tans PIS ! en tout cas "si j"ai les doigts trop grands pour l"écran tactile" ( ce que a traduit "GOOGLE made in Donald TRUMP" ) ,mais il est aussi un autre usage ( bien connu des GRECS) , que la politesse ne me permet pas d'expliciter ici . CQFD & BDC .
¿Qué tiene que ver Trump con este delirio?
Cada historia necesita un chico malo.
Sí, toda buena historia tiene una.
+1
anniel Posted - 06/15/2017 : 14:40:42
Sí, nos relaja del trabajo duro.
Una buena distracción humorística.
Sí, trae un poco de relajación después del trabajo duro.
+1
anniel Posted - 06/15/2017 : 14:39:09
NO .Ahora , para mi, el circo ha terminado, amigo !( aunque con faltas de ortografía) ...Si quiere saber un poco más ,tiene que llamar al teléfono de "TINO DxxZ apodo de" nicolasitor " en en español . nos conocemos bien, y también en este foro solo se rió.,es el vendidor de las ilas cannarias , y le pregunta lo que piensa En el programador (el que se utiliza con éxito)TNM 5000 .Y tambien de los mierdas y basuras del UExxD5700 de SAMSUNG.
Su segunda despedida.
Usted lleva a cabo la cuenta?
¡Eso lo es que me pagan lo!
anniel Posted - 06/15/2017 : 14:38:04
anniel Posted - 06/15/2017 : 14:35:49
Serie web gratuito.
Sin interrupciones.
¡Eso esperamos!
anniel Posted - 06/15/2017 : 14:33:52
La culture française est réputée mondialement pour sa subtilité et sa précision .... Mr Emmanuel MACRON ;notre nouveau président de la République Française ) .....
Your new president Emmanuel Macron said there is no such thing as french culture!
Totally true.
It made the news but in fact it was old news.
https://www.youtube.com/watch?v=qpAt-ayf7yE
Uh, yeah, okay, that's world-renowned french culture. So Emmanuel Macron was wrong?
+1
anniel Posted - 06/15/2017 : 14:33:00
YOU =
EXTRAIT du mail =
.....ET ALORS !!!!=
From a nutcase?
[/quote]
anniel Posted - 06/15/2017 : 14:23:42
anniel Posted - 06/15/2017 : 14:18:30
idoit?
https://www.urbandictionary.com/define.php?term=idoit
supervizeur Posted - 06/12/2017 : 10:43:55
supervizeur Posted - 06/12/2017 : 10:35:31
vous avez déjà vu le QG-5X ?? il est équipé d'un support de TSOP48 et pas d'un support de FBGA on ne peut pas changer le support du composant à programmer ,sans intervenir à l'intérieur avec un fer à souder !! La sté MCU Mall , interdit cette modification , et annulerait toute garantie !!"
alors "
No, you don't need a soldering iron to change the top socket and no warranty would be void in any way. In case you haven't notice, you can purchase the ISP top module and install it yourself.
Maybe not you given your incapacity to do hands-on technical work but all of the average GQ-5X users should be able to succeed.
True, no skills required.
http://www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=4603
+1
supervizeur Posted - 06/12/2017 : 10:33:12
Et bon débarras !!!
supervizeur Posted - 06/12/2017 : 10:18:35
+1
+1
supervizeur Posted - 06/12/2017 : 10:07:37
Aussi en Français.
Exactly.
supervizeur Posted - 06/12/2017 : 10:06:40
ISP programming
supervizeur Posted - 06/12/2017 : 10:02:27
ISP programming
supervizeur Posted - 06/12/2017 : 09:59:53
MANN France no te enojes, gracias a tu reclamo esta la versión 1.08. Espero que sigas en el foro, seria mejor que no seas tan energico en tus comentarios.
Yo probe 5 memorias usadas 3 funcionan bien, 2 el tv funciono bien pero al actualizar fallo, pero pienso que es falla de la memoria.
Proximamente voy a recibir nuevas para probar.
Me gustaría que comentaras como te fue con la versión 1.08 con UEXXD5700, en mi país UNXXD5500, como tu dices gracias a estas basuras tenemos trabajo.
Saludos colega
bonjour camarade EDUARDO de culture latine ( ESPAGNOL en Amérique du SUD ) !!
je laisse google te traduire mon "mauvais français" ( si j'écris en espagnol , c'est pire !)
revenons donc aux problèmes techniques ( et laissons les 2 ânes dans leur pré , manger leurs sarcasmes et autres stupidités ) = voir mon topic:
http://www.mcumall.com/forum/topic.asp?TOPIC_ID=8170
clonage K9F1G08U0D-SCBO et E ( new desing)
Si tu parles à "TINO DxxZ " des iles canarias , il te donnera aussi des informations " confidentielles " , car rien n'est parfaitement blanc ou noir ( j'en dit pas plus) .Si j'ai "retiré mon annonce sur "le bon coin.fr" , c'est pour des motifs personnels et un très mauvais "rendement" des copies des NANDs 1 Gocts ( environ 25% de réussite).
Si un problème se déclare pour la K9GAGU08UOE , lors de la mise à jour du firmware , la carte BN41_01660 risque d'être irrécupérable = le composant contenant le FIRMWARE est un boitier à billes ( BGA) et il ne peut être changé que par refusion = 60 billes d'étain . Je compte sur "ANIEL" ou le "superviseur" pour me proposer une meilleure solution.
Mais les cartes BN41_01747 ( TV séries UExxD5000 ; pas smart TV = même châssis ; compatibles mécaniquement et électriquement ) , n'ont pas ce vilain défaut .le firmware est contenu sur la NAND K9F1G08U0D = donc facilement modifiable .
j'attends des K9F1G08U0D et pas les 5 K9F1G08U0E ( pas supportées pas le QG-5X , pour l'instant) , avant de "mettre les pieds dans le plat " avec le service commercial de MCU Mall. =une commande en cours sur aliexpress ( le vendeur en CHINE , recherche des anciennes versions "D" 5 ème géneration = 13 euros le lot de 10 ! )
Mais la version 1.08 ne fonctionne toujours pas aussi , bien que la mémoire K9F1G08U0E que j'ai testée ( 128 Mocts) N'A PAS DE BAD BLOCK .( ou le logiciel ne les voit pas ?? )
il faut savoir que les circuits imprimés sont identiques pour l'ensemble du Monde , mais que une "customisation" des composants câblés et des logiciels programmés dans les mémoires des cartes varient selon les continents .
La référence en BN41_xxxx désigne le circuit imprimé de base . Selon son équipement , il devient BN94_XXXC ( sur une étiquette papier) =
Avec les UX xx D5000 on peut en changeant le firmware (sur la NAND 128 Mocts) transformer un UA xx D5000 ( séries ASIATIQUES) ou en su país UNXXD5000 ( amérique du sud) en UE xx D5000 ( Européen) = et réciproquement : mais avec une programation qui fonctionnerait ( mais pas encore , hélas) , et avec un fer à souder , pour les composants spécifiques ..
Si tu le désire , je peux t'envoyer 2 cartes BN41_01660 , en panne ( le firmware est HS) gratuitement , comme "régalo" .
Saludos colega
I dont think Google can make something out of your gibberish.
Maybe his special version can.
+1
supervizeur Posted - 06/12/2017 : 09:58:58
supervizeur Posted - 06/12/2017 : 09:56:11
supervizeur Posted - 06/12/2017 : 09:51:00
supervizeur Posted - 06/12/2017 : 09:46:08
supervizeur Posted - 06/12/2017 : 09:39:41
Algunos sin sentido no puede ser ignorado!
Me alegro de ver que nadie lo toma demasiado en serio.
¿Quién podría tomar en serio él y sus desvaríos?
Nadie uno, supongo.
¿Tal vez otro dingo?
O un "idoit".
+1
supervizeur Posted - 06/12/2017 : 09:38:39
Serie web gratuito.
Sin interrupciones.
¡Eso esperamos!
supervizeur Posted - 06/12/2017 : 09:37:03
Totally true.
supervizeur Posted - 06/12/2017 : 09:32:23
YOU =
EXTRAIT du mail =
.....ET ALORS !!!!=
From a nutcase?
[/quote]
supervizeur Posted - 06/12/2017 : 09:29:49
supervizeur Posted - 06/12/2017 : 09:15:53
idoit?
supervizeur Posted - 06/12/2017 : 09:13:55
Vu les problèmes avec la "Clone failure K9GAG08U0E." , j'en doute fortement . Mais je ne demande qu'a changer d'avis , après des tests concluants .
Insanity: doing the same thing over and over again and expecting different results.
OK = vous m'en envoyer un , en FRANCE , GRATUITEMENT, et je vous fais tous les essais nécessaires
Still wants freebies!
+1
anniel Posted - 06/09/2017 : 06:20:47
anniel Posted - 06/09/2017 : 06:01:16
alors "
Pourquoi le GQ-5X ne supporterai pas les boitiers BGA svp?" = Qui peut vous prendre au sérieux ???
Anyone bright enough to take a look at all the BGA sockets and adapters available, but then again, clearly not your case.
+1
"Le fichier est facilement copiable d'une télé fonctionnelle.
OUI, à condition de le copier avec un programmateur équipé d'un support de FBGA , ET que le logiciel fonctionne bien !!
et aussi ttps://www.youtube.com/watch?v=SOv0ekthDHc
Or simply use ISP, remember?
+1
Given the success rate you achieved and your track record, I suspect that no one would dare send you something to test. More so, by your own admission, given your lack of basic knowledge and tools.
+1
anniel Posted - 06/09/2017 : 05:38:11
Et bon débarras !!!
anniel Posted - 06/09/2017 : 05:12:20
Mais c'est incroyable une telle incompétence, même pour un bricoleur du dimanche!
N'avez-vous jamais tenu une de ces cartes dans vos mains, ne serait-ce qu'une seule fois?
Est-ce généralisé au Français ou particulier à vous d'avoir une incapacité à faire quoi que ce soit de façon autonome?
Stop it, you're gonna make me die.
At your service.
anniel Posted - 06/09/2017 : 05:10:37
+1
+1
anniel Posted - 06/09/2017 : 05:02:20
Aussi en Français.
anniel Posted - 06/09/2017 : 04:43:33
ISP programming
anniel Posted - 06/09/2017 : 04:41:14
ISP programming
Why would that be stupid? That's how it's done in the first place.
ISP
If you don't have basic tools, yes, it's out of reach.
Trash? You simply need to start over.
Why should MCU mall compensate you for your errors?
All true.
anniel Posted - 06/09/2017 : 04:39:45
ISP programming
anniel Posted - 06/09/2017 : 04:36:15
Saludos colega
Saludos colega
anniel Posted - 06/09/2017 : 04:34:57
I really do not understand you.
+1
+1
anniel Posted - 06/09/2017 : 04:34:07
anniel Posted - 06/09/2017 : 04:32:21
anniel Posted - 06/09/2017 : 04:29:12
anniel Posted - 06/09/2017 : 04:24:11
Sí, Samsung es uno de los mejores para dar de trabajo a los técnicos.
Cierto.
anniel Posted - 06/09/2017 : 04:22:07
Me pregunto qué inventará a continuación.
Quién sabe.
anniel Posted - 06/09/2017 : 04:20:07
je vous ai sous estimé , et j'en suis confus . Au CANADA , vous connaissez aussi le "Schmilblick" ?? bien . mais a t il le même sens qu'en FRANCE METROPOLITAINNE ??
Vous parlez de l'expression <faire avancer le schmilblick> ou du <Schmilblick> lui même?
Pour mon Espagnol ,vous avez raison , il n'est pas très bon et je fais encore plus de fautes d'orthographe qu'en français .
Et c'est peu dire.
Quand à vos remarques adjointes , je vous plains franchement : Si votre façon de vivre est à l'image de vos réflexions blessantes , je vous conseille de faire une PSYCHANALYSE complète pour traiter votre comportement associal . J'en ai fait une , et le résultat est vraiment fantastique . Je suis toujours malade car c'est intrinsèque à ma nature humaine ,( quand je serais mort, je serais guéri) mais , maintenant, je m'en fout = tout va donc très bien , pour moi; mais je renonce à tenter de traiter les autres , dont vous !!!
Ce chemin intérieur est bien plus complexe ,croyez moi, que de résoudre des questions techniques de programmation de composants électroniques , but , "quand même" de ce Forum.
Dans votre cerveau , doivent se cacher bien plus de "bad block" que vous n'imaginez et votre "processeur principal" ne peut pas les "traiter" =>le "remapping est impossible => cela est caché dans des zones inaccessibles pour lui ( H.S.R.A ) = c'est l'INCONSCIENT .Il n'existe pas d'antivirus . Dommage
La saga continue...
The show must go on.
Yes.
anniel Posted - 06/09/2017 : 04:18:55
SCHEMILEKBLICKH
"SCHEMILEKBLICKH"??? Still inventing crazy words or do you mean Schmilblick?
No, he's Papy Mougeot of Cajarc.
Colucci, a fine humorist!
+1
anniel Posted - 06/09/2017 : 04:18:14
anniel Posted - 06/09/2017 : 04:14:46
Nadie uno, supongo.
O un "idoit".
anniel Posted - 06/09/2017 : 04:11:59
Serie web gratuito.
Sin interrupciones.
anniel Posted - 06/09/2017 : 04:09:21
Totally true.
anniel Posted - 06/09/2017 : 03:50:29
YOU =
EXTRAIT du mail =
.....ET ALORS !!!!=
From a nutcase?
[/quote]
anniel Posted - 06/09/2017 : 03:46:41
anniel Posted - 06/09/2017 : 03:44:00
idoit?
anniel Posted - 06/09/2017 : 03:32:54
supervizeur Posted - 06/04/2017 : 06:31:27
supervizeur Posted - 06/04/2017 : 06:28:49
alors "
supervizeur Posted - 06/04/2017 : 05:47:42
Mais on est en 2017 , et maintenant vous franchissez la ligne ultra-rouge une fois de plus . Une seule réponse peut vous convenir = vous ignorer définitivement , car je n'ai jamais vu une telle attitude ( un traitement en Hopit... Psych...... me semble approprié) . je vous dit donc "ADIEU" , ou plus exactement ce serait " AU DIABLE" ( c'est un jeu de maux !( mots) ...votre psychologie me semble incapable de comprendre cette subtilité )
Oui, belle projection. Quant à l'hôpital, je n'ai aucune difficulté à croire que votre place y est réservée.
+1
supervizeur Posted - 06/04/2017 : 05:46:25
supervizeur Posted - 06/04/2017 : 05:25:48
Aussi en Français.
mais le programmateur GQ-5X ne supporte pas les boitiers FBGA !! et s'il c'etait le cas , faudrait t_il avoir le fichier binaire pour programmer le firmware . ensuite , un jeu d'enfant , n'est ce pas = acheter les NANDS sur = https://fr.aliexpress.com/store/product/New-and-original-KFG1GN6W2D-HIB6-BGA-spot-play/1607003_32254270862.html à 16 euros le lot de 5 , ou demander à LUCIFER de nous en donner contre la vente de notre "âme"
Oui, c'est très facile et très courant de faire du reballing BGA, même chez les amateurs. Surtout en utilisant des billes pré-formées et non de la pate comme c'est le cas des professionnels de l'industrie. Mais, plus tot, vous nous avouez ne pas posséder les outils les plus rudimentaires du technicien ce que vous nommez "machines spécialisées".
Le plus simple et le plus sécuritaire reste l'ISP étant donné l'inutilité de dessouder un chip parfaitement bon.
True.
supervizeur Posted - 06/04/2017 : 05:22:36
supervizeur Posted - 06/04/2017 : 05:18:29
supervizeur Posted - 06/04/2017 : 05:04:36
Aussi en Français.
supervizeur Posted - 06/04/2017 : 04:59:15
il s'agit bien d'un problème technique , n'est ce pas ??
Je n'en suis plus si sur.
[/quote]
ROFL
supervizeur Posted - 06/04/2017 : 04:57:10
expliquez moi "je vous offre la solution à votre problème"??
il s'agit bien d'un problème technique , n'est ce pas ?? Alors , expliquez vous clairement . je suis un peu difficile pour comprendre rapidement .A vous la parole . Je vous en remercie vivement.
ISP = In System Programming
Is that clear enough?
supervizeur Posted - 06/04/2017 : 04:53:23
ISP programming
supervizeur Posted - 06/04/2017 : 04:51:54
ISP programming
ISP
supervizeur Posted - 06/04/2017 : 04:34:53
ISP programming
supervizeur Posted - 06/04/2017 : 04:30:18
You're not alone.
No estas solo.
+1
supervizeur Posted - 06/04/2017 : 04:23:25
C'est à ne plus rien y comprendre!
No way to understand anything!
No hay manera de entender!
+1
supervizeur Posted - 06/04/2017 : 04:22:26
Saludos colega
Saludos colega
supervizeur Posted - 06/04/2017 : 04:16:42
+1
supervizeur Posted - 06/04/2017 : 04:15:44
supervizeur Posted - 06/04/2017 : 04:10:32
supervizeur Posted - 06/04/2017 : 04:07:24
supervizeur Posted - 06/04/2017 : 04:00:49
supervizeur Posted - 06/04/2017 : 03:55:33
supervizeur Posted - 06/04/2017 : 03:53:02
Et c'est peu dire.
La saga continue...
supervizeur Posted - 06/04/2017 : 03:51:00
SCHEMILEKBLICKH
supervizeur Posted - 06/04/2017 : 03:48:14
supervizeur Posted - 06/04/2017 : 03:39:14
Nadie uno, supongo.
supervizeur Posted - 06/04/2017 : 03:35:42
Serie web gratuito.
supervizeur Posted - 06/04/2017 : 03:32:22
Totally true.
supervizeur Posted - 06/04/2017 : 03:30:20
YOU =
EXTRAIT du mail =
.....ET ALORS !!!!=
[/quote]
From a nutcase?
supervizeur Posted - 06/04/2017 : 03:27:49
Everything jostles in your head, heh.
GOOGLE TRADUCTION = Tout se bouscule dans votre tête, heh.
réponse = en droit français on appelle cela un propos insultant . C'est passible de poursuites en justice ; Mais je ne suis pas de ceux qui les engageraient . C'est tolalement inproductif ,inutile et perte de temps . La seule réponse "intélligente" est d'ignorer ces propos " dégradants et déplacés " . les lecteurs du forum feront leur propre opinion sur l'opportunité et la valeur de vos commentaires . Cela ne peut que nuire à votre propre image , mais je ne sais pas si vous en êtes vraiement conscient .
SUE ME!
[/quote]
[/quote]
Ho no!
supervizeur Posted - 06/04/2017 : 03:26:44
SCHEMILEKBLICKH
" NETFLIX gratuito"
"free NETFLIX"??? Is your Spanish so bad or is your head worse than you let it show?
MANN France Posted - 06/03/2017 : 00:47:45
Étant donné ma nature charitable, même avec les incapables, voici les points de branchement qui sont pourtant bien indiqués.
201694 bytes
[/quote]
votre image ne correspond pas à la carte BN41_01660 .
C'est quoi ???
MANN France Posted - 06/03/2017 : 00:45:34
...... ( un traitement en Hopit... Psych...... me semble approprié) . ......
et c'est bien VRAI , je vous y invite à m'y rejoindre .A deux on pourra parler technique ; et se demander pourquoi il y a tant de personnes à l'extérieur , alors qu'a l'intérieur on y est si bien !. ( voir HP de CADILLAC en GIRONDE = ttp://www.ch-cadillac.fr/ ). j'ai fait une demande pour y rentrer , mais il y a une grande liste d'attente , et mon cas n'est pas encore assez désespéré;hélas. je travaille pour le devenir ( FOU) = vous pouvez m'y aider par vos judicieux conseils
Quand à "Mais c'est incroyable une telle incompétence, même pour un bricoleur du dimanche!
N'avez-vous jamais tenu une de ces cartes dans vos mains, ne serait-ce qu'une seule fois?" , ici c'est "l'hopital qui se fout de la charité" ( expression française qui veut dire que c'est un comble" ) . C'est a en mourir de rire = vous avez déjà vu le QG-5X ?? il est équipé d'un support de TSOP48 et pas d'un support de FBGA on ne peut pas changer le support du composant à programmer ,sans intervenir à l'intérieur avec un fer à souder !! La sté MCU Mall , interdit cette modification , et annulerait toute garantie !!"
alors " Pourquoi le GQ-5X ne supporterai pas les boitiers BGA svp?" = Qui peut vous prendre au sérieux ???
anniel Posted - 06/02/2017 : 16:26:01
MANN France Posted - 06/02/2017 : 14:11:33
201694 bytes
[/quote]
anniel Posted - 06/02/2017 : 14:00:09
Aussi en Français.
anniel Posted - 06/02/2017 : 13:42:54
201694 bytes
MANN France Posted - 06/02/2017 : 13:19:51
Aussi en Français.
MANN France Posted - 06/02/2017 : 12:57:32
Aussi en Français.
anniel Posted - 06/02/2017 : 11:43:47
En fait je parlais du problème que vous avez causé a la carte que vous dites être "bonne pour la poubelle".
A vous la parole .
Aussi en Français.
Pas de quoi.
MANN France Posted - 06/02/2017 : 11:24:23
[/quote]
[/quote]
anniel Posted - 06/02/2017 : 10:09:36
ISP programming
MANN France Posted - 06/02/2017 : 09:45:57
ISP programming
anniel Posted - 06/02/2017 : 06:48:33
ISP programming
anniel Posted - 06/02/2017 : 06:34:58
You're not alone.
No estas solo.
anniel Posted - 06/02/2017 : 06:32:57
MANN France Posted - 06/02/2017 : 05:25:00
Saludos colega
Saludos colega
eduardo48 Posted - 06/02/2017 : 05:16:35
I really do not understand you. Will be by language
MANN France Posted - 06/02/2017 : 04:41:38
anniel Posted - 06/02/2017 : 03:15:45
eduardo48 Posted - 06/01/2017 : 17:25:18
Saludos colega
MANN France Posted - 06/01/2017 : 11:58:05
eduardo48 Posted - 06/01/2017 : 10:40:40
anniel Posted - 06/01/2017 : 05:17:13
Et c'est peu dire.
La saga continue...
anniel Posted - 06/01/2017 : 05:07:35
SCHEMILEKBLICKH
anniel Posted - 06/01/2017 : 05:01:24
"pour faire avancer le SCHEMILEKBLICKH"
Papy Mougeot, c'est bien toi?
" NETFLIX gratuito"
NETFLIX gratuit?
ADIOS amigos
Q.E.P.D.
anniel Posted - 06/01/2017 : 04:33:48
Nadie uno, supongo.
anniel Posted - 06/01/2017 : 04:28:59
Serie web gratuito.
anniel Posted - 06/01/2017 : 04:24:55
Totally true.
anniel Posted - 06/01/2017 : 04:22:58
YOU =
EXTRAIT du mail =
.....ET ALORS !!!!=
[/quote]
anniel Posted - 06/01/2017 : 04:19:38
[/quote]
SUE ME!
[/quote]
MANN France Posted - 05/31/2017 : 23:17:23
SCHEMILEKBLICKH
" NETFLIX gratuito"
supervizeur Posted - 05/31/2017 : 12:24:05
SCHEMILEKBLICKH
" NETFLIX gratuito"
MANN France Posted - 05/31/2017 : 11:52:58
bueno ; bueno !!
je vous l'avais dit ; messieurs les "YANKEES" , votre culture n'est pas la Nôtre , et il est normal que vous ne puissiez pas comprendre les subtilités de la langue française car que ce n'est pas GOOGLE TRADUCTION qui va vous y aider .C'est vrai : la politique n'a pas a être dans ce forum = mais ce n'était "qu'un clin d'oeil d'humour" de notre histoire du temps de LAFAYETTE, des ROIS louis XIV ,puis louis XVI qui termina la tête tranchée par la révolution en 1789 " => vous auriez peut-être pu comprendre la parabole et à quoi je faisais allusion => mais c'est tout a fait normal .(et , c'est pas grave = vous pouvez dormir sur vos deux oreilles B.D.C !)
Quant au contenu technique des derniers post , c'est de la "littérature de salon" et cela ne sert à rien "pour faire avancer le SCHEMILEKBLICKH" ....( venez en FRANCE , et je vous expliquerais de visu ! ) .FIN
Es aqui el Final de " NETFLIX gratuito" compagnéros !! ADIOS amigos , y con my muchos salutationes ...
supervizeur Posted - 05/31/2017 : 09:10:24
supervizeur Posted - 05/31/2017 : 09:02:24
Serie web gratuito.
supervizeur Posted - 05/31/2017 : 08:59:33
supervizeur Posted - 05/31/2017 : 08:55:08
Vous venez encore vous plaindre de votre incapacité à utiliser des outils simples?
Google traduction connaît Besserwisser et fonctionne très bien.
https://translate.google.com/?hl=fr#auto/fr/Besserwisser
C'est pourquoi votre publicité est retirée de sur leboncoin?
Pour votre gouverne Google est en Amérique du Nord.
Mail qui n'a absolument rien à voir avec le support technique du GQ-5X ou MCU Mall
D'où tenez vous cela?
Surtout avec votre dysgraphie dyslexique!
Oui vous seriez le premier à voir vos commentaires disparaître.
.....ET ALORS !!!!=
Seulement des jérémiades ne concernant que la politique française!
Vous semblez inapte à utiliser la technologie en général, vous devriez rester loin de l'ordinateur avant de vous blesser gravement.
ALL true!
supervizeur Posted - 05/31/2017 : 08:53:05
YOU =
EXTRAIT du mail =
.....ET ALORS !!!!=
[/quote]
supervizeur Posted - 05/31/2017 : 08:47:10
en droit français
Votre droit français n'a aucune valeur juridique internationale.
ignorer ces propos
Mais faites donc mon cher.
Well said!
supervizeur Posted - 05/31/2017 : 08:46:04
l' "emmerdeur est de retour"
That it is right. Bringing absolutely nothing useful to help others.
Never heard about community.
He must not.
supervizeur Posted - 05/31/2017 : 08:44:47
/www.xeltek.com/resources/programmer-buying-guide/
/www.tnmelectronics.com/downloads/List5000.TXT
K9GAG08U0A
K9GAG08U0B
K9GAG08U0C
K9GAG08U0D
K9GAG08U0M
K9GAG08U0E
K9GAG08U0F
K9F1G08U0A
K9F1G08U0B
K9F1G08U0C
K9F1G08U0D
K9F1G08U0E
What a blockhead!
Did you even read the documentation you point to?
https://www.xeltek.com/resources/programmer-buying-guide/device-count-by-variants/
K9GAG08U0A K9GAG08U0B K9GAG08U0C K9GAG08U0D K9GAG08U0M K9GAG08U0E K9GAG08U0F are all variants of the same chip thus all fully supported by the GQ5X.
Same for K9F1G08U0A K9F1G08U0B K9F1G08U0C K9F1G08U0D K9F1G08U0E
Stop wasting your breath, I think we're not dealing with a blockhead but with a thick headed Besserwisser.
Could be, he's so nonsensical.
supervizeur Posted - 05/31/2017 : 08:42:40
[/quote]
[/quote]
SUE ME!
anniel Posted - 05/31/2017 : 04:58:49
eduardo48 Posted - 05/31/2017 : 04:36:10
anniel Posted - 05/31/2017 : 04:04:57
.....ET ALORS !!!!=
MANN France Posted - 05/31/2017 : 01:09:56
YOU =
[/quote]
EXTRAIT du mail =
.....ET ALORS !!!!=
anniel Posted - 05/30/2017 : 15:36:18
en droit français
ignorer ces propos
anniel Posted - 05/30/2017 : 15:30:35
anniel Posted - 05/30/2017 : 15:28:24
K9GAG08U0A
K9GAG08U0B
K9GAG08U0C
K9GAG08U0D
K9GAG08U0M
K9GAG08U0E
K9GAG08U0F
K9F1G08U0A
K9F1G08U0B
K9F1G08U0C
K9F1G08U0D
K9F1G08U0E
What a blockhead!
MANN France Posted - 05/30/2017 : 13:38:21
[/quote]
[/quote]
supervizeur Posted - 05/30/2017 : 09:02:30
It is possible to modify the software so that the user chooses how to deal with bad sectors.
Like this?
GQ5XSupport should be able to implement something like this with the right algorithms.
Je pensais que faire de la publicité pour des concurents n'était pas bien sur ce FORUM , mais comme ce n'ai pas moi qui ai commencé , je vais continuer pour l'information de tous !!
vous avez dit "XELTEK" ?? /www.xeltek.com/resources/programmer-buying-guide/
c'est vrai que ce n'est pas le prix du QG-5X !!!
alors je dit = ( pour 100 euros de plus) =
Ordinateur portable/Notebook IO Programmeur TNM5000 USB Eprom Programmeur + TSOP48, 48pin drive ZIF socket, Atmel AVR ISP Programmer, SPI soutien
/fr.aliexpress.com/item/TNM5000-USB-Universal-Programmer-with-ADP548T2-adapter/2045457701.html?spm=2114.13010308.0.0.vbTFAQ
sinon /my.aliexpress.com/wishlist/wish_item_similar_product_list.htm?productId=2045457701
Description de l'article
como usar o gravador TNM5000:
/www.youtube.com/watch?v=zdojQ0sLmdc&feature=youtu.be
TNM5000 Périphériques pris en charge Liste:
les esprits chagrins vont me faire un discours sur le support produit en CHINE , etc etc !!
problèmes = Ce programmateur fonctionne bien , et supporte beaucoup plus de composants !!
DONT les K9GAG08U0A
K9GAG08U0B
K9GAG08U0C
K9GAG08U0D
K9GAG08U0M
K9GAG08U0E
K9GAG08U0F
et aussi les =K9F1G08U0A
K9F1G08U0B
K9F1G08U0C
K9F1G08U0D
K9F1G08U0E
ceci inclus les dernières générations (' 6 èmes) xxxxxxxE ( ce qui n'est pas encore le cas du QG-5X .
QUI l'a testé ?? pas moi !! mais "TINO" en ESPAGNE ( islas CANNARIAS) = c'est lui qui m'a donné cette information "secrête" !! voir sur /www.ebay.fr/itm/NANDprogramed-K9GAG0E8UO-FORtv-SAMSUNG-UE46D5500-UE40D5500-UE37D5500-UE32D5500-/122511840054?hash=item1c86465336:g:vBgAAOSw53NY-kCY
NANDprogramed-K9GAG0E8UO FORtv SAMSUNG UE46D5500 UE40D5500 UE37D5500 UE32D5500
Lieu où se trouve l'objet :
Arona, Espagne
si necesssaire , j'ai ses coordonnées postales ; N° de TEL et mail =me les demandes en message privé .
supervizeur Posted - 05/30/2017 : 06:23:37
supervizeur Posted - 05/30/2017 : 06:15:44
Oui un Xeltek est mieux qu'un GQ-5X, personne le niera.
Un TNM5000 plus cher qu'un GQ-5X? Qui paierai plus pour un produit moindre?
Aucun discours sur le support produit en CHINE n'est nécessaire étant donné son inexistence.
Toute les composantes énumérées sont supportées par le GQ-5X.
Qui, ayant un GQ-5X, voudrait acheter des chips déjà programmés sur eBay?
Votre message complet est donc totalement nul et non avenu.
All true!
supervizeur Posted - 05/30/2017 : 06:14:17
K9GAG08U0A
K9GAG08U0B
K9GAG08U0C
K9GAG08U0D
K9GAG08U0M
K9GAG08U0E
K9GAG08U0F
K9F1G08U0A
K9F1G08U0B
K9F1G08U0C
K9F1G08U0D
K9F1G08U0E
What a blockhead!
anniel Posted - 05/30/2017 : 04:27:32
MANN France Posted - 05/29/2017 : 23:22:22
Like this?
DONT les K9GAG08U0A
K9GAG08U0B
K9GAG08U0C
K9GAG08U0D
K9GAG08U0M
K9GAG08U0E
K9GAG08U0F
K9F1G08U0B
K9F1G08U0C
K9F1G08U0D
K9F1G08U0E
Arona, Espagne
MANN France Posted - 05/29/2017 : 13:57:49
buenos dias !! OK = ver un novella topic = clonage K9F1G08U0D-SCBO et E ( new desing)
NAND 100 Mocts y no 2 Gocts sobre UExxD5000 ( buenos ) y no UExxD5700 ( Basuras y mierdas !! )
And he's back for more whining!
Yes !!Yes les vacances sont finies , et l' "emmerdeur est de retour" = je vois que d'autres avaient pris le relais , ce qui me réjouis un peu !!!
aujourd'hui : j'ai testé la version 1.08 = cela ne fonctionne toujours pas != ni sur les 2 NANDS SAMSUNg 2 Gocts ni sur la 100 Mocts ( version E ; 6 ème génération = pas encore supportée dans la version 1.08 !! j'ai pas reçu des versions D , de la part des "contre-facteurs de CHINE", seulement en version "E" = 5 pièces )
version 1.08 = merci ; ENFIN une double présentation à deux fenêtres! = Style Xtree , NORTON COMMANDER ou PC TOOLS ( pour les VIEUX , qui ont connu DOS 3.3 jusqu'au DOS 6.2 comme moi !! et qui n'ont toujours rien compris aux pseudo améliorations de WINDOWS ) = à quand une version DOS ???
bien = le double tableau des BAD BLOCKS ( 1.08 = c'est mieux)mais il manque le mapping des DES DONNES UTILES de la source et de la cible ?? ) = j'en parle avec le développeur prochainnement .....
anniel Posted - 05/29/2017 : 09:17:20
¤GRILL¤
supervizeur Posted - 05/29/2017 : 05:38:15
MANN France Posted - 05/29/2017 : 04:28:33
Originally posted by monster
Bonjour,
la copie de ces nand particulièrement n'est pas fonctionnelle j'en suis également la preuve et j'ai 2 autres connaissances dépanneurs de TV qui se sont, comme moi, fait "enjoliver" par la belle plaquette commerciale de ce programmateur qui promettait une copie rapide et parfaite de ces nand...
J'ai contacté à de nombreuses reprises le support technique en expliquant ce problème, envoyé des copies d'écran des messages d'erreur, donné précisément toutes les étapes/tests/vérification effectuées et n'ai toujours pas eu de réponse de leur part....
Mes collègues ont fait de même et ont obtenu le même silence radio....ça commence à faire beaucoup de "cas isolé" vous ne croyez pas ?
anniel Posted - 05/18/2017 : 03:34:59
Yes, you are correct. MCUMALL is the best for service in general.
ZLM Posted - 05/17/2017 : 21:30:17
I mean MCUamll did the best to improve its software. No other providers can do the same.
anniel Posted - 05/17/2017 : 14:52:21
It is normal if a software has bugs. Just like Microsoft Windows, it has many bugs too. Here it is good to see MCUmall software developer work closely with its customer to fix the bugs. It is hard to see from other same price range programmer provider.
Try GQBlaster Re1.08.
Hi ZLM, You mean there is no bug remediation with other providers.
ZLM Posted - 05/17/2017 : 13:34:07
anniel Posted - 05/12/2017 : 09:27:29
Con los nuevos tienes más tiempo antes del fracaso pero todavía es ineluctable...
eduardo48 Posted - 05/12/2017 : 09:03:26
Yo tengo el GQ5x desde la versión 1.01 y pude grabar bien a partir de la versión 1.03, desde ese momento repare muchas placas, siempre con nand nuevas, al dia de hoy no a retornado ninguna, de todas formas yo tengo conocimiento de la degradacion que me comentas, por esto yo doy 6 meses de garantía solo por la falla de reinicio que produce esta nand.
Comento que probé con una tercera nand usada, salio en funcionando en forma correcta pero al actualizar via internet falló, supongo que debe estar mal esta nand aunque tenia solo 3 bloques malos.
anniel Posted - 05/12/2017 : 07:14:13
No, porque cuanto más FLASH se utiliza, más se degrada. Además, los sistemas de archivos específicos de Samsung no gestionan correctamente esta degradación.
eduardo48 Posted - 05/12/2017 : 05:06:07
LO dices porque son memorias usadas?
anniel Posted - 05/12/2017 : 02:50:30
No te olvides que la corrupción de la memoria volverá.
eduardo48 Posted - 05/11/2017 : 20:33:09
No se para mierda renegar tanto a partir de julio YouTube deja de funcionar en los Smart del 2012 para atrás.Estos Samsung que en realidad son una cagada de elefante se quedan sin YouTube.
eduardo48 Posted - 05/11/2017 : 19:10:09
Bueno podría ser,,, grabe dos memorias originales usadas, sacadas de las placas, coloque las mismas memorias en estas placas, y funciona en forma correcta. Tiempo de grabación 6.28 minutos, verificación OK en 3.26 minutos(solo grabación sin contar la creación de la fila temporal)).
Parece que estamos en buen camino.
MANN FRANCE prueba y comenta resultados.
Mañana seguire probando con mas placas
GQ5XSupport Posted - 05/11/2017 : 11:27:24
Please download 1.08 and have a try.
anniel Posted - 05/11/2017 : 02:48:57
Algo así o varias copias del mismo dispositivo en la lista con diferentes opciones también funcionaría.
Me alegra si pudiera ayudarte a entender mejor.
eduardo48 Posted - 05/10/2017 : 14:14:31
Ok, seria bueno poder seleccionar en el software el método de grabación. Gracias por su repuesta.
anniel Posted - 05/10/2017 : 11:58:22
Depende si los algoritmos usan el método Skip Block o el método Reserve Block o alguna otra variante y si el sistema de archivos conoce la nueva ubicación de la tabla Bad Block.
Si puede encontrar un documento en español que explique el funcionamiento interno de FLASH NAND y la gestión de Bad Block, todo se hará claro para usted...
eduardo48 Posted - 05/10/2017 : 09:55:03
Anniel, yo estoy de acuerdo con tu comentario. Yo escribi sobre esto a algunos colegas.
Me confunde esta frase de QG5XSUPPORT en una nueva version( I copy the bad block to the target and this may work for Samsung.
Te comento que yo tengo el bin no tiene mal bloque , pero si tiene mal bloque la nand destino, aqui debería trabajar el software como grabar evitando estos bloque malos para no perjudicar el buen funcionamiento del tv.
Posiblemente colegas copien o respladen el bin de nand falladas con las consecuencias mencionadas en este foro.
Yo pienso que debe haber algo mas en estas memorias porque he hecho muchísimas pruebas con nand nuevas y nand extraidas de tv que al borrarlas tienen menos bloques malos que nand nuevas, pero aun asi no han funcionado, espero me entiendas por el idioma
anniel Posted - 05/10/2017 : 07:22:36
Bonjour,
Vous confondez NAND et TV, vous savez, ces K9GAG08U0E ne sont pas uniquement présents dans des téléviseurs Samsung.
anniel Posted - 05/10/2017 : 07:17:05
eduardo48
En Samsung TV funciona bien con 1.05 porque los bloques malos permanecen donde el sistema de archivos piensa que son. El algoritmo de "copia inteligente" de 1.07 remapea los bloques defectuosos en el chip, pero la tabla de bloqueo del sistema de archivos defectuosos de la TV no se actualiza con este cambio.
eduardo48 Posted - 05/10/2017 : 06:25:28
Yo puedo probar, nunca entendí el mal bloque en el archivo fuente, como sabe el software que hay un mal bloque en un archivo backup, o Usted refiere a un clonado.
Porque observo que grabar con versión 1.05 copia directa funciona bien, pero al utilizar versión 1.07 no trabaja en forma correcta sobre el tv
GQ5XSupport Posted - 05/09/2017 : 17:08:01
I have implemented a new algorithm, anyone want to have a try to see if it works on Samsung TV?
In 1.07, the source bad block is skipped and the data is readjust on target, this might not be the right algorithm for Samsung since it has its own file system and simply adjust the block might not work.
In the newer software, I copy the bad block to the target and this may work for Samsung.
monster Posted - 05/08/2017 : 23:53:11
Bonjour,
anniel Posted - 05/07/2017 : 10:06:13
What all this frenchie's politics has to do with this forum's technical aspect?
Maybe he thinks he works for Cointelpro?
anniel Posted - 05/07/2017 : 10:02:23
The GQ5X also works fine on K9GAG08U0E used in FLASH drives.
True!
anniel Posted - 05/07/2017 : 10:00:58
So you want this device removed from the supported list for others because YOU can't understand how to use it?
Quite foolish...
anniel Posted - 05/07/2017 : 09:59:40
Given the hourly salary of a software developer, what would not be profitable is if MCU Mall would assign one for your personal venue!
Also true!
anniel Posted - 05/07/2017 : 09:58:21
Nobody is going to buy you toys to play around. Even more so from a competitor and for a self admitted unskilled handyman!
True!
anniel Posted - 05/07/2017 : 09:57:07
At this price point there is none that comes close to MCU Mall.
Amen to that also!
anniel Posted - 05/07/2017 : 09:55:27
Try to get service on Chinese programmers, let alone good and useful replies not in chinglish if you ever get some.
Amen!
anniel Posted - 05/07/2017 : 09:53:00
QUE répondre ?? sinon appeler le modérateur du FORUM pour lui demander son avis !!je ne sais pas si vous savez qu'en FRANCE , il y a les élections présidentielles après demain !et aussi , si vous avez vu les débats sur la TV en FRANCE ( avant hier ) , vous comprendriez peut_être , pourquoi et comment on manipule les argumentations !. Mais c'est de la politique ,car ici , sur ce forum , les arguments sont , à priori d'ordre technique !! je commence à en douter !.CQFD = vos propos seraient à examiner sous un autre angle , mais je n'ai que peu de temps à y consacrer .
Appeler le modérateur du forum pour lui demander son avis sur les élections présidentielles en France?
supervizeur Posted - 05/05/2017 : 08:45:45
Je n'ai que faire d'un banc de test bricolé et spécifique à une série particulière de télés Samsung qui est vouée de toute façon au même problèmes en boucle. Une bonne source de revenus pour vous, il me semble.
Je ne crois pas que de censurer des commentaires fasse partie du code d'éthique de MCUMall sinon il aurait supprimé vos jérémiades il y a longtemps.
actionnaire de cette société? J'aimerais bien, compte tenu de leur excellents produits et leur service de qualité exceptionnelle.
Pourquoi la fonction de copie des NANDS K9GAG08UEO devrait elle être abandonnée quand elle fonctionne parfaitement bien, si vous voulez bien parler des K9GAG08U0E?
supervizeur Posted - 05/05/2017 : 08:37:24
MANN France Posted - 05/05/2017 : 08:03:43
anniel Posted - 05/05/2017 : 05:17:25
Sí eduardo48, bien está lo que bien acaba.
anniel Posted - 05/05/2017 : 05:14:22
MANN France Posted - 05/05/2017 : 04:14:31
Pourquoi MCU Mall achèterait quelque chose pour un "bricoleur" non qualifié?
Tout simplement parce que le "bricoleur non qualifié " a fabriqué un banc de test de carte mère BN41-01660 qui permet de tester en conditions réelles la bonne ou mauvaise copie de la NAND . Autant que je sache , vous n'avez pas ce moyen de test chez vous !! Alors , comme le marché est concurentiel , et que sur INTERNET ,il y a "aussi" d'autres programmateurs , la Société MCUMall devrait réfléchir à votre réflexion qui me parrait quelque peu "irréfléchie " ?? ( vous faire un rappel à l'ordre ! ) Ne seriez vous pas , sous votre pseudo , actionnaire de cette société ??
Vu le prix horaire d'un développeur de logiciel , ne serait alors plus "rentable" d'abandonner la fonction de copie des NANDS K9GAG08UEO qui est spécifié dans le titre du produit en vente sur EBAY ? En France , ceci est du ressort de la répression des fraudes pour publicité mensongères et peut entrainner des poursuite en justice !! Au Canada , je ne connait pas votre législation !!
google traduction =
Simply because the "unskilled handyman" has manufactured a motherboard test bench BN41-01660 which allows to test in real conditions the good or bad copy of the NAND. As far as I know, you do not have this means of testing at home !! So, as the market is competitive, and that on the INTERNET, there are "also" other programmers, the MCUMall company should think about your reflection that would seem somewhat "unreflected" ?? (You make a call to order!) Would not you, under your pseudo, shareholder of this company ??
Given the hourly price of a software developer, would not it be "profitable" to abandon the copy function of NANDS K9GAG08UEO which is specified in the title of the product for sale on EBAY? In France, this is the responsibility of the repression of false advertising frauds and can lead to legal proceedings !! In Canada, I do not know your legislation !!
eduardo48 Posted - 05/04/2017 : 18:52:36
Napalico que lio armaste, por ahí tiene un buen fin
anniel Posted - 05/04/2017 : 12:46:34
MANN France Posted - 05/04/2017 : 04:58:35
[quote]Originally posted by napalico
Hola, contesto luego de unas merecidas vacaciones. Descargue la version 1.06 y al usar la funcion "smart copy" sucede lo siguiente:
-smtcpy
Create temporary file
Y asi se queda el programa por mas de una hora, llega a un 50% aproximadamente sin avanzar y tengo que cortar el proceso.
¿Es normal este tiempo de demora?
Marquitos550b, ¿pudiste efectuar la copia con esta funcion?. En mi caso, con las versiones anteriores, siempre me dio fallo en la verificacion con las K9GAG08UOE.
Buenos dias compagneros !!
voici recopie des mails du développeur de MCUMall electronics = in extenso =
14/04/2017=
Can you directly work with our software Engineer who developed the software?
If you ware willing to do test more, then I can let you know the contact.
Best Regards.
sales@mcumall.com
15/04/2017 =
I may not understand your issue correctly.
Basically GQ-5X can do raw copy of NAND flash. The smart copy of the flash is just ONE algorithm used to do smart analyze of the source of the target. (Only skip the bad block for source and target). So far we find it worked in a lot of TV applications.
As of the NAND flash, it is only in the definition of NAND.txt.
I do not own the TV board you have, I can ask you.
1. Do you think your flash is different than what is defined? Can you provide the datasheet?
2. Can you read back the original flash and erase your target chip and read back.
English is my second language but I hope we can use English to communicate. The existing hardware should be sufficient to handle your case, It is only the algorithm to deal with bad block.
23/04/2017=
Maybe it is related to the algorithem we used to #147;erase#148; and program the first block.!
#147;Any intentional erasure of the initial invalid block information is prohibited #147;
24/04/2017=
Do you think if I make a test build for you to NOT program and erase the first block and you can have a try? It will be option by default is ON and first block will not be changed.
26/04/2017=
After carefully study the case you want, it is not the first block, we need to understand the Samsung NAND file system used for TV. I need to study source code from Samsung.
lien ...p://opensource.samsung.com/reception/receptionSub.do?method=sub&sub=T&menu_item=tv_n_video
Which model is your TV?
I think there is no such thing as of “Copy” a working NAND chip. If the bad block is not the same we need to CREATE a image for the NAND.
Disable the erase/write of first block will NOT work in this case.
The file system used in Samsung TV is called FST_STL.
26/04/2017=
OK I got your point about the value of the item you shipped to me.
Did you get my other email about the issue regarding “copy” Nand chip.
The NAND chip in Samsung TV has a file system of its own and the only way to make the copy to work is to properly make the file system (FSR_STL).
So far I do not see anyone can do it for now. Not as easy as you think to COPY from one chip to another chip. You need to MAKE the chip based on the bad block.
So far I found this is only on Samsung TV. We have customer that can work on other TVs without issue.
27/04/2017=
1.The save button works for SPI flash. Yes I can take it our for NAND.
2. The one bit error (one bit can be fixed by the software). Bad block is not compared and will not shown. (I can remove the one bit error, actually verify has no use for NAND and even verify function can be removed)
3. Smart copy will not write data on bad block.
4. We have to create temp files on hard disk since NAND chip has huge memory and if we do not use hard disk, we may not have enough memory.
For example, quite often the NAND chip has 4GB of memory, if we do not create file on hard disk, then 4GB will be used on the PC. I know a lot of laptops only have 4GB RAM and that is not enough to use the software.
03/05/2017 =
I have received you item.
I have started to looking into issues.
I also started to write 1.08 software.
Changes so far
1. Remove the save button.
2. Verify memory will not print out the error of 1 bit since it will be fixed by the software.
3. Temporary file will be removed after software exits.
More changes to come. I will send you files to test when I think it might fix your issue.
et vous saurez tout pour aujourd'hui = voici ma dernière réponse =
cela confirme ce que je constate =
This confirms what I see = = ( BUT it's FALSE = exit the software and disconnect the programmer. Then reload the software and programmer = test smart copy phase 6 on N ° V and test smart copy phase 7 on N ° V =
Verification failure. CQFD)= sur tous les NANDS testés !!!ECHEC TOTAL
Je ne pense pas que cela suffira !! vous devez faire un mapping des données de l'étalon , et vérifier qu'aucun bad block soit en correspondance physique , sans "bricolage" des adresses physiques .Sinon le processeur de la carte mère n'y comprends plus rien ( il doit se "souvenir" de la position des bad blocks , dans la mémoire ; sinon il "plante" ) . Mais je ne suis pas un spécialiste du fonctionnement du FIRMWARE du TV SAMSUNG =
désassemblez le fichier xxx.Bin ( voir sur la carte SD)
achetez un TNM5000 si nécessaire (et faites des tests avec !... ) . Moi, je ne vais pas encore investir 300 euros , sur mon argent personnel !!
OU BIEN , la société MCU Mall m'en achète un pour moi !! et je le teste avec mon matériel de test !!!
MANN France Posted - 05/04/2017 : 04:41:14
I really understand half, but if it works I like it, it will be version 1.08 or 2 and we are all happy.
My job is electronica, but I'll put a day with the nand
OK , moi je ne comprends rien à ""Voici pourquoi.
https://wikileaks.org/ciav7p1/cms/page_12353643.html ""; mais cela devrait intéresser , je pense le développeur logiciel de MCUmall Electronics , qui travaille en ce moment sur une nouvelle version de logiciel.1.08 et ++ ( mais je ne sais pas si il lit ce FORUM ? ) Je lui ai fait parvenir de FRANCE , des NANDS déssoudées; des NANDS neuves, mais que j'ai tenté de programmer, et une carte SD de 16 Gocts avec mes fichiers xxx.bin, recopies d'écran; photos de matériel et documentations . la lettre est arrivée au CANADA ( BURNABY BC VSA 3W2) cette semaine. IL travaille dessus ; mais je ne suis pas d'accord avec ses premières observations . Ce qui est sûr, est que le programmateur TNM5000 fonctionnerait mieux .il est utilisé en ESPAGNE ( Islas Cannarias) , par un vendeur de NANDs qu'il programme avec celui-ci. ( et je suis en liaison avec lui !).Je viens aussi de proposer à la Société MCUmall de m'offrir un TNM5000 gratuitement pour essais gracieux ( j'ai un banc de carte mère de BN41_01660 que j'ai fabriqué moi-même , pour tester les NANds en conditions réelles sur un banc de TV Samsung UExxD5800 = fabrique moi-même ).En 10 minutes , je teste une NAND programmée et le verdict est sans appel = Il est évident que la gestion des BAD BLOCK de ces NANDS est primordial .Comment est fait le logiciel du TNM5000 ?, je l'ignore , car je ne suis pas développeur , mais "bricoleur" électronicien.!
voici des liens que je viens d'envoyer au développeur logiciel =
//www.youtube.com/watch?v=rfSkOVsQL0I
//www.ebay.fr/itm/NAND-K9GAG08U0E-UE-32D5700-37D5700-40D5700-46D5700-D5720-samsung-/192163296496?hash=item2cbdd334f0:g:jMwAAOSwImRYZXZi
//fr.aliexpress.com/item/TNM5000-USB-Universal-Programmer-with-ADP548T2-adapter/2045457701.html?spm=2114.13010308.0.0.JWxhUG
//www.youtube.com/watch?v=zdojQ0sLmdc&feature=youtu.be
eduardo48 Posted - 04/26/2017 : 12:57:35
anniel Posted - 04/26/2017 : 12:41:12
Like this?
anniel Posted - 04/26/2017 : 12:15:00
The Skip Block Method or the Reserve Block Method supervizeur talks about is selected in and controlled by the BBM module implemented in the HAL software (some manufacturers put it in the FTL).
eduardo48 Posted - 04/26/2017 : 10:17:07
You can explain the difference of recording that you comment
  It is possible to choose by software different ways to treat bad blocks.
Using the smart copy, the problem of cloning with the tv nand series unxxd5500 and other similar is real.
  I am aware that the tnm5000, does not cause these problems
anniel Posted - 04/26/2017 : 10:16:30
@supervizeur
No, he previously clearly stated he has no interest in learning.
moi, la littérature ne m'intéresse pas !
anniel Posted - 04/26/2017 : 10:10:57
on se demande pourquoi une telle capacité dans un smart TV !!
Voici pourquoi.
supervizeur Posted - 04/25/2017 : 12:05:42
I wonder if he ever got to read the passage concerning the Skip Block Method versus the Reserve Block Method?
anniel Posted - 04/15/2017 : 06:31:48
@supervizeur
Good one!
anniel Posted - 04/15/2017 : 06:30:33
@MANN France
En effet, vouloir essayer de satisfaire ses clients sans accepter d'assimiler les connaissances requise n'est pas très productif.
supervizeur Posted - 04/11/2017 : 17:50:35
le chargement des images ne fonctionne pas
141284 bytes
MANN France Posted - 04/11/2017 : 13:31:09
Contrefaçon = counterfeit, recycled, remarked, overproduced, cloned,
out-of-spec, defective, forged documentation, pulls, fakes, repackaged, forged changelogs, copy and for the most part they all come from China.
Your 2nd answer on Ebay messaging (following request of return of my purchase) =
This chip is supported by Re1.07.
Please EXACTLY follow the steps in the video:
https://www.youtube.com/watch?v=7KTYrj_pgbA&t=78s
f it still does not work, please send us the video your did, so that we can check it for you. Thanks.
je vous ai répondu ceci ( pour information aux membres du Forum), avec des recopies d'écran que je ne peux pas joindre sur le forum ( le chargement des images ne fonctionne pas) =
"" Cela fait la deuxième fois que vous me répondez de voir votre vidéo. votre réponse n'apporte rien de nouveau
votre logiciel ne fonctionne pas avec un étalon qui a des bad block , et aussi avec une cible qui a des bad block = ce n'est pas le cas avec votre vidéo ( pas de bad block sur la cible !!c'est alors facile ) .Si on utilise la copie SMART COPy, la comparaison montre des différences entre la mémoire programmée et celle du PC , puis généralement c'est OK ( mes essais = 12 bonnes sur 16 mémoiress ; 2 échecs ). mais ceci est un mirage , car si on refait une vérification ensuite , hors processus de 'smart copy" , il y a un échec systématique = c'est aussi l'échec si on procède comme votre vidéo ,
je pense que vous n'avez JAMAIS testé votre logiciel avec des Q9GAG08UEO -SCBO ( celles utilisées sur les cartes TV SAMSUNG BN41_01660 des séries UExxD5700 ) . Pour être constructif ,je peux vous envoyer par courrier un DVD comportant des étalons ( fichiers xx.bin) fonctionnant =dont 2 ont été achetés en ESPAGNE ( iles Cannaries = programmateur inconnu ,) ; et aussi quelques mémoires neuves en cadeau ( ne fonctionnent pas bien sur carte mère ) . vous pourriez ainsi faire des essais dans vos laboratoires . vous pouvez aussi acheter des mémoires neuves sur E bay et aliexpress ( voir les liens que j'ai donné sur le forum) .
je vous signale que 5 nouvelles mémoires sont en transit de Chine vers la France , et que je testerais à leur arrivée prochaine avec votre matériel . Celui ci est sous garantie ( E bay et garantie constructeur ) .
je suis désolé de recopier cette réponse dans le forum, car cela commence à devenir critique pour mes clients qui me demandent quand je pourrais les satisfaire . si je leur annonce que je ne puis pas faire des copies à cause de votre matériel défaillant (et alors être obligé d'acheter les mémoires programmées en ESPAGNE ! ) , je pense que ce ne sera pas bon pour votre société ( peu de personnes en FRANCE Métropolitaine proposent la réparation des cartes mères !.
MANN France Posted - 04/11/2017 : 04:53:04
voici les mémoires achetées en ESPAGNE ( iles Canaries) , qui fonctionnent bien (avec des bad block ), pour une trentaine d'euros =
.ebay.fr/itm/NAND-K9GAG08U0E-UE-32D5500-37D5500-40D5500-46D5500-D5520-samsung-/192143380875?
.ebay.fr/itm/122397653993?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
voici une commande ayant été remboursée pour 5 mémoires défectueuses ( ou pas ?? ) sur les 5 achetées =
.ebay.fr/itm/172473687987?_trksid=p2057872.m2748.l2649&ssPageName=STRK%3AMEBIDX%3AIT
5pcs K9GAG08U0E-SCB0 K9GAG08U0E K9GAGO8UOE-SCBO K9GAGO8UOE K9GAG08UOE-SCBO SOP48
Vendeur Top Fiabilité
adeleparts2010
.ebay.fr/itm/5pcs-K9GAG08U0E-SCB0-K9GAG08U0E-K9GAGO8UOE-SCBO-K9GAGO8UOE-K9GAG08UOE-SCBO-SOP48-/172473687987?hash=item28283b9fb3:g:tgEAAOSwawpXsr1H
commande totalement remboursée par le revendeur =
fr.aliexpress.com/item/K9GAG08U0E-SCB0-K9GAG08U0E-SCB0-K9GAG08UOE-SCBO-K9GAG08UOE-SCBO/32534576241.html?spm=2114.13010608.0.0.0RpmL4
commande en cours de litige ( 2 mémoires utilisables sur les 5 )=
fr.aliexpress.com/item/Free-shipping-5pcs-lot-K9GAG08U0E-K9GAG08UOE-SCBO-K9GAG08U0E-SCB0-TSOP-IC-Best-quality/32557898446.html?spm=2114.13010608.0.0.M8bGny
commande livrée ; objet du test en cours ( 10 pièces ) =
fr.aliexpress.com/item/Free-shipping-10pcs-lot-K9GAG08U0E-K9GAG08UOE-SCBO-K9GAG08U0E-SCB0-TSOP-IC-Best-quality/32467360553.html?spm=2114.13010608.0.0.M8bGny
Download Attachment:
138077
MANN France Posted - 04/11/2017 : 04:28:44
Originally posted by eduardo48
Mann yo trato de razonar, el bin Samsung no esta grabado en la memoria en forma consecutiva desde la dirección 0, esta en direcciones establecidas, el micro junto con el software uboot (que esta grabado en la otra nand) sabe donde ir a buscar esa información, si tu la cambias de lugar ahí se presentan fallas. Yo he comprobado esto con versión 1.07. Esto es una suposición mia.
Yo pregunto porque no he hecho la prueba, en un pen drive tienes un controlador y una nand, que pasaría si reemplazamos la nand, copiamos y grabamos los datos en la nueva nand y cambiamos los datos de lugar con el software 1.07, se podría leer esa información en el pen drive.
Si alguien conoce la repuesta es bien recibida la informacion
bonjour, moi je ne comprends rien aux gestions de mémoire , mais ce que je constate est que le logiciel 1.07 est inexploitable.
sur 16 mémoires neuves ( achetées sur Ebay & aliexpress.com) , en utilisant la fonction "SMART COPY" , un "miracle " est apparu !.
seules 2 mémoires ont échoué au test de vérification . C'était trop beau , hélas!j'ai voulu ensuite revérifier en rechargent le fichier bin "étalon = E/las palmas.bin , et refaire le test de controle = échec total sur les 14 mémoires ( les 2 anormales étant éliminées ). j'ai donc tout effacé , refait un "Smart copy" et rechargé le double du fichier étalon ( autre unité de disque dur) , relancé une lecture ( mémoire N°23) , et copié la lecture avec un autre nom .réussite de vérification avec ce nouveau fichier binaire ( de smart copy), mais échec total avec le fichier étalon " las palmas .bin" , ayant servi de source.
il est donc évident que la copie est inexploitable , les fichiers de source et de copie étant différents .
Un rechargement successif de plusieurs fichiers binaires "étalons "différents , mais valides , entraînnent systématiquement l'echec de la vérification de la programmation avec le fichier étalon initial.
en essayant les mémoires sur le banc de test de la carte mère BN41_01660 , seulement 3 ou 4 mémoires fonctionnent sur les 16 initiales ( et ce ne sont pas celles qui ont le moins de bad block !!) . le taux de réussite sur carte mère est donc de l'ordre de 25% seulement . Ce qui est grave est que l'on ne sait pas quelle part d'échec est dû au logiciel ou à la mauvaise qualité des mémoires ( contre-façons ? ou rebut de fabrication ?? ) ou la mauvaise gestion des Bad blocks du processeur de la carte mère !!
Il semble que le logiciel , avec son fichier temporaire , fasse une comparaison "arrangée" qui donne une vérification faussement bonne , alors que la réalité soit un échec "masqué" de celle ci = échec sur test de la carte mère , en conditions de fonctionnement réel.
ce qui est fortement désagréable est que cela a entraîne des litiges avec les fournisseurs ( Ebay & aliexpress ), dont certains sont en cours de traitement , et qu'il serait très fâcheux qu'il lisent ce forum ( en portant la responsabilité des retours de composants défectueux , sur le mauvais fonctionnement présumé du logiciel de programmation ) !!
104070
anniel Posted - 04/04/2017 : 03:40:00
Ok eduardo48 thank you.
eduardo48 Posted - 04/03/2017 : 19:44:24
eduardo48 Posted - 04/03/2017 : 18:58:47
Anniel I do not know capcom cpps2, I am not
anniel Posted - 04/03/2017 : 07:56:43
Bonne chance!
MANN France Posted - 04/03/2017 : 07:48:15
Well said Anniel! Some just don't read and ignore good advice like the one given by you and Eduardo48.
je viens de reçevoir 5 mémoires de HONG KONG ( via Swiss Post = très rapide ! ) = seulement 2 fonctionnent correctement sur le banc de test de carte mère BN41_01660 de TV UExxD5700.le logiciel V1.07 continue à faire n'importe quoi!! toujours des échecs de vérification.et curieusement , ce n'est pas les mémoires qui ont le maximum de bad block qui ne fonctionnent pas !!
anniel Posted - 04/03/2017 : 03:19:11
@eduardo48
¿Es usted el Eduardo detrás de la Capcom CPS2 revelar?
anniel Posted - 04/01/2017 : 16:22:27
Nobody's perfect!
supervizeur Posted - 04/01/2017 : 12:53:12
anniel Posted - 04/01/2017 : 05:31:16
pdfserv.maximintegrated.com/en/an/TUT5458.pdf
1) www.netcomponents.com/results.htm?t=f&r=1&d=1&pn1=K9GAG08U0E&submit1=Search
2) Vous n'avez qu'à relire et suivre les instructions données à plusieurs reprises plus haut!
Non, la mémoire SAMSUNG n'est pas de la merde plus que celle d'un autre manufacturier.
Si vous ne comprenez pas le fonctionnement de la mémoire FLASH NAND ce n'est pas la faute de SAMSUNG ni du GQ-5X! La simple lecture des documents devrait suffire à comprendre.
MANN France Posted - 04/01/2017 : 04:13:11
Quand aux contrefaçons, les rebuts de fabrication après tri en font aussi partie.
www.univ-st-etienne.fr/salware/Bibliography_Salware/IC%20Counterfeiting/Article/Guin2013.pdf
www.utdallas.edu/~gxm112130/papers/pieee14.pdf
www.pdfserv.maximintegrated.com/en/an/TUT5458.pdf
"je suis en attente de 5+5+5+10 mémoires SAMSUNG venant de Chinne" Étant donné que Samsung n'a pas de fonderie en Chine, la contrefaçon est assurée.
"je ne connais pas quel programmateur ils utilisent" Pourquoi ne pas leur poser la question?
"je doit satisfaire mes clients pour dépanner leur carte mère" N'oubliez pas de leur dire que c'est temporaire et que la corruption réapparaitra de toute façon.
le 3 ème lien précedent n'est pas valide; le premier est trop 'gouvernemental" = sans intéret pratique. le 2 ème est très intéressant ,et si j'avais le temps d'y passer le Week End , cela m'instruirait beaucoup . Je pourrais voir les professeurs de l'université" de TALENCE/ BORDEAUX pour leur faire un cours magistral sur les contrefaçons des composants ( et aussi celle de GRENOBLE , qui travaille avec ST microélectronics = j'ai des contacts la_bas !!) .
mais tout ceci n'est que connaissances universitaires , et ne me résoud pas mes questions pratiques !!
1)où acheter de bonnes mémoires SAMSUNG ( ou équivalents) , quel prix ???
2) résoudre le non fonctionnement du programmateur avec des mémoires source ( fonctionnant bien sur les Tv) et cibles ( neuves , contrefaçons ou pas !! ) qui ont des bad block
le reste est fort instructif , mais comme on dit en France = cela ne fait pas beaucoup avancer le "SCHMILBLICK" ! ( voir le professeur d'orthographe et attention à GOOGLE TRADUCTION pour les contre sens .)
como dice "eduardo48", las mémorias estan "mierdas" y tambien "basuras". qué malo !, compagnéros & amigos de AMERICA ( del Norte & del sud ) ... hasta la proxima vez en el forum ,
anniel Posted - 03/31/2017 : 17:11:25
Merci eduardo48 mais tout ceci a déjà été dit plus haut.
eduardo48 Posted - 03/31/2017 : 16:49:18
Mann France, la versión 1.07 no funciona, porque cambia la posición de los datos en la memoria, usa la versión 1.05 sin bbt copia directa sin importar la verificacion, pero cuidado, el firmware debe ser el original, si tu usas uno copiado de un tv este ya esta corrupto, ese es el secreto de grabar con qg-5x.
anniel Posted - 03/31/2017 : 11:47:19
You forgot a few but you are correct.
supervizeur Posted - 03/31/2017 : 10:54:15
anniel Posted - 03/31/2017 : 09:27:31
"If it still does not work, then record your software video and let us to check."
Vous êtes vous conformé à la demande d'envoyer un video de votre procédure affin de vérifier?
anniel Posted - 03/31/2017 : 09:22:42
Je ne peux pas vous confirmer si Chinne avec 2 N est en Asie mais il n'y a pas grand chose venant de Chine (sans passer par des revendeurs officiels) qui ne soit une contrefaçon (ce qui inclut bien des choses si vous avez lu la documentation).
Même les revendeurs officiels sont parfois contaminés par des contrefaçons.
SAMSUNG possède des fonderies de production uniquement en Corée du Sud (qui est également en Asie) et aux USA et ne vendent pas par l'intermédiaire d'Ali, eBay ou quelconque autre revendeurs douteux situé en Chine.
Oui ils sont de bonne foi en vous vendant des contrefaçon compte tenu la mentalité Chinoise qui diffère du reste.
"ils me répondent qu'ils utilisent un programmateur à 500 ou 1000 euros" Si vous n'y parvenez pas à l'aide du GQ-5X, vous serez alors fixé sur le programmeur à utiliser!
"Et dire aux clients que la réparation avec des mémoires de "M..." n'est pas fiable dans le temps , on fait quoi ??" Ça c'est à vous de voir selon votre code d'étique et conscience professionnelle! Dans des cas semblables je vous conseille d'être ouvert et honnête sous peine d'en être réduit à la même réputation que les instigateurs du problème.
Oui il y a aussi des faux GQ-4X qui viennent de Chine! La contrefaçon Chinoise est un fléau qui touch toute la planète!
MANN France Posted - 03/31/2017 : 08:37:41
Quand je dis de "Chinne" , c'est en ASIE ?? les composants sont marqués "SAMSUNG" ( et aussi sur les cartes mères d'origine !! ) , et tous les revendeurs sont à "ShenZhen" ; province de Guangdong China (Mainland). cela ne dit pas où ils achètent leurs composants , ni si c'est des contre-façons ou des "ratés de fabrication" , ni s'ils sont de bonne foi ou des receleurs !!
.Si je consulte les Espagnols ( 2 aux iles canaries , un en Catalogne et un à la Corrogne ) et qu'ils me répondent qu'ils utilisent un programmateur à 500 ou 1000 euros , je leur réponds quoi ?
Dans la vie , critiquer est facile , mais apporter des solutions efficaces , concrètes et constructives est plus difficile !!
alors voici un extrait d'un vendeur de NANDS programmées des Iles canaries en ESPAGNE =
" ok, si vous achetez sur aliexpress, soyez prudent avec des imitations.
lire où il est dit faux programmeur
BeeProg - Universal programmer | Elnec"
https://www.elnec.com/en/news/fake-beeprog/
Fake of the BeeProg programmer.
Let us inform you, that we encountered the fake of BeeProg programmer at some eBay sellers, for example: embeddedworld, accuni-express, e-lab-uk, ari-elk and wei68xin.
The manufacturer of the fake BeeProgs stole our logo and intellectual property by manufacturing fake copies of BeeProg programmer. This "product" uses also our software and users of this fake BeeProg are asking for our free technical support. Although the copy of the BeeProg programmer is done well, the manufactures of the fake BeeProg overlooked few details. Result is, the fake BeeProg unit differs from the original, visible for the software. We've used one of these differences - it is not a serial number - and our software could detect this fake hardware. If PG4UW software detects a fake hardware, it shows message "Fake programmer unit detected!" and programmer will no longer work.
If you're facing such situation, contact please the vendor, where from you bought the programmer, for full credit return. Or you can take this vendor to court for selling a fake products. We regret, we could not provide any assistance in this case.
Conclusion.
To avoid a disillusion from the not working programmer, we don't recommend to buy programmer from anonymous sellers. Elnec stopped selling of BeeProg programmer in the middle of 2007, some unit was available in stocks of Elnec resellers after few months too, but not today. Current selling of BeeProg is most likely fake unit, so avoid the problems by buying this product.
Note: I must highlight, neither Elnec, nor Elnec distributors, sell the BeeProg programmer through eBay. Elnec is not responsible for any losses caused by fake BeeProg programmer. Elnec don't provide any support to owners of fake units. Responsibility lies with manufacturer and resellers of fake products.
Elnec s.r.o.
Jan Puobis
Jana Bottu 5
Presov, Slovakia
anniel Posted - 03/31/2017 : 05:43:50
MANN France Posted - 03/31/2017 : 04:00:12
Oui le S signifie qu'il n'y a aucun bad block lors de la fabrication (ça reste à voir si ça existe réellement ailleurs qu'en contrefaçons Chinoise) mais inévitablement des bad blocks apparaissent à l'usage de là le "Garbage
Collection" et le "Wear Leveling" des Flash.
14. Customer Bad Block
B : Include Bad Block
D : Daisychain Sample
K : Special Handling
L : 1~5 Bad Block
N : ini. 0 blk, add. 10 blk
S : All Good Block
0 : NONE (Containing Wafer, CHIP, BIZ, Exception
handling code)
Si le firmware de la TV n'est pas modifié la corruption réapparaitra de toute façon.
d'accord avec anniel = voici mes conclusions =
il y a un problème dans le logiciel de ces TV ( et SAMSUNG se garde bien de le rectifier = son intérêt est que les TV tombent en panne après la garantie , pour en vendre de nouveaux= "obsolescence programmée" .=> arnaque à la consommation , par "vice caché" =>action judiciaire possible en FRANCE , contre SAMSUNG )
Quand aux contrefaçons , ce n'est pas sûr , mais revente des rebuts de fabrication après tri , j'en suis maintenant persuadé .
mais si j'ai achète votre programmateur , c'est pour qu'il fonctionne correctement , bad block ou pas !!!
CQFD
voici le mail que je viens d'envoyer en réponse au support produit ( pour information à tous )
Bonjour ,
Votre vidéo utilise une NAND cible qui n'a pas de "bad block" .
Je procède de même façon que votre vidéo ( version 1.06), mais les NANDS que je reçoit ont toutes des "bad block" d'origine .vous envoyer une vidéo n'a aucun intérêt.
je vous ai envoyé des recopies d'écran avec des échecs de vérification. ( version 1.07) ( messages Ebay)
la seule vérification qui marche est celle de la source et sa lecture en fichier binaire sur le disque dur ( et c'est heureux !!)
Votre logiciel 1.07 ne fonctionne pas avec des NAND qui ont des bad block en source ET en cible .
ce sont des K9GAGO8U0E-SCBO qui équipent les "smart TV" Samsung séries UExxD5700 et 5500. ( cartes mères BN41_01660 et BN41_01747)
Si les NAND étaient des K9GAGO8U0E-SCSO, le logiciel fonctionnerait , car elle n'auraient pas de bad block de fabrication. En effet SAMSUNG trie ses mémoires à la fabrication , avant de les vendre !! ( et à un prix , bien plus cher que ses "rebuts" , écoulés dans le marché et sur ses TV).
Si la mémoire a plus d'un seul bad block , il y a de fortes chances que la TV aura des problème en cours d'utilisation.( cela peut fonctionner des années , mais un jour , cela cesse, sans cause apparente . la TV reboucle indéfiniment avec apparition du logo "Smart TV" au démarrage . la télécommande n'agit plus , et il faut changer la carte mère , qui n'est plus fabriquée !! )
En conséquence , si vous m'améliorez pas votre logiciel , je , je me serais obligé de vous demander le renvoi de votre programmateur et le remboursement d'EBay. ( frais de retour , pris en charge par PAY PAL)
le titre de votre annonce précise clairement qu'il prends en charge les K9GAGO8U0E sans préciser l'extension = -SCBO ou SCSO ( voir datasheet SAMSUNG) .
voir aussi http://www.mcumall.com/forum/topic.asp?TOPIC_ID=7819
je vous joins en P.J des recopies d'écran ( voir mes messages sur Ebay = PB d'envoi de photos = souvent erreur serveur !! )
--- Message d'origine ----
De : support@mcumall.com
À : superphenix@numericable.fr
Objet : Re: photo QG-5X
Date : 31/03/2017 06:47:33 CEST
Checked with engineer, and I was told your may no followed the steps in the video.
Please make sure you followed the steps in following video.
https://www.youtube.com/watch?v=7KTYrj_pgbA&t=40s
Thank you.
Regards.
ouveau message à : eachstop
j'utilise votre programmateur sur un PC Helweth Packard ,sous WINDOW 7 professionnel.
je ne vois pas pourquoi vous désirez cette photo??
N° de série = NAND00001206 acheté le 20 Février 2017 logiciel GQBlaster 1.07
je vous signale que je ne suis pas le seul à avoir des problèmes de clonage avec votre programmateur qui est vendu pour fonctionner avec les Q9GAG08U0E = voir votre forum. je suis en attente de 5+5+5+10 mémoires SAMSUNG venant de Chinne . Elles ont toutes des "bad block" . Peu n'en ont qu'un seul !!
Si la situation ne s'améliore pas , je serais obligé de vous faire la demande de retour et le remboursement total ( garantie Ebay acheteur).
j'ai mis une annonce en FRANCE , pour la réparation de ces cartes "merde" de SAMSUNG ,parce que ces téléviseurs tombent en panne , subitement , comme des mouches ( un jour le processeur tombe sur un "bad blok" , et ça plante , en France , en Europe , en russie, en Amérique , etc ..)
https://www.leboncoin.fr/image_son/1092488713.htm?ca=12_s
Réparation carte mère BN41-01660 séries UE40D5700
car nos voisins Espagnols ont plusieurs offre identiques sur EBay exepmles =
http://www.ebay.fr/itm/252806537021?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
UE46D5500 UE46D5700 UE46D5520 UE46D5720 K9GAG08U0E Programada U66A IC302 Samsung
http://www.ebay.fr/itm/122397653993?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
http://www.ebay.fr/itm/192137772161?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
NAND K9GAG08U0E - UE 32D5500 / 37D5500 / 40D5500 /46D5500 / D5520 samsung
je ne connais pas quel programmateur ils utilisent , mais si je vous renvoie le vôtre , je serais contraint de leur acheter des mémoires programmées !! = qu'ils se débrouillent avec SAMSUNG.
cela ne m'arrange pas , mais je doit satisfaire mes clients pour dépanner leur carte mère !....
eduardo48 Posted - 03/30/2017 : 15:59:23
Hola,no hay memorias K9GAGO80E SCBO sin bloques defectuosos, yo en comprobado memorias originales Samsung sin ser colocadas en tv, grabadas por Samsung firmware original sin actualizar, al borrarlas y verificar siempre encontré sectores defectuosos.
Hello, there are no memories K9GAGO80E without defective blocks, I tested Samsung original memories without being placed on TV, recorded by Samsung original firmware without updating, erase them verify always found bad sectors
anniel Posted - 03/30/2017 : 13:03:24
L : 1~5 Bad Block
S : All Good Block
handling code)
MANN France Posted - 03/30/2017 : 12:25:53
De la mémoire Flash (incluant les clés USB)et des disques durs sans bad blocks (secteurs défectueux)n'existent pas.
Pour plus de détails concernant les FLASH NAND (comme le K9GAG08U0E) voir le lien.
www.micron.com/~/media/documents/products/technical-note/nand-flash/tn2959_bbm_in_nand_flash.pdf
Oui, Samsung a merdé (une fois de plus) avec un mauvais firmware qui brique les TV a cause d'une mauvaise gestion de la mémoire et peut-être même l'utilisation de chips de qualité douteuse.
Sûr que la qualité de ces NAND est douteuse !! Mais
ben sûr que si , sans bad block cela existe quand même !!!, mais cela doit être bien plus cher!! en consultant la data sheet , il faut voir l'extension des K9GAGO80E _ xxxx si le xxxx est SCBO , il y aura des bad block. si elle est SCSO il n'y aura pas de bad block , car SAMSUNG fait du tri à la fabrication!! ben sûr , que les mémoires d'origine sur les TV sont livrées en SCBO !!
OK , le firmware du TV n'est pas optimisé !!! cela doit être un "défaut caché" pour vendre de nouveaux téléviseurs ,en remplacement !
bref , bad block ou pas , il faut que je fasse des copies qui fonctionnent ( avec des CSBO ) !! sinon je demande le remboursement du programmateur .
anniel Posted - 03/28/2017 : 06:19:04
www.eetasia.com/ARTICLES/2004NOV/A/2004NOV29_MEM_AN06.PDF?SOURCES=DOWNLOAD
www.esatjournals.net/ijret/2013v02/i10/IJRET20130210042.pdf
anniel Posted - 03/28/2017 : 06:05:36
Le firmware corrige les erreurs (ECC) et marque les secteurs inutilisables (P-LIST, G-LIST, BBT etc.) et relocalise.
Quant à l'annonce vous pouvez vous adresser à eux pour plus de détails mais je ne crois pas que ce soit des réparateurs sérieux.
Vu les dommages flagrants causés lors du dessoudage on peut en conclure à l'oeuvre d'un pistolet décapant.
Le fait de qualifier le K9GAG08U0E d'EEPROM indique qu'ils ne se sont même pas donnés la peine de consulter la datasheet.
Il semble s'agir de bricoleurs amateurs au mieux ou d'arnaqueurs professionnels.
Bonne chance avec eux!
MANN France Posted - 03/28/2017 : 05:01:10
Autrement dit; Faire les recherches paramétriques à votre place?
Bonjour,
ce programmateur est vendu (sur ebay par exemple) explicitement pour ce type de mémoire or il ne rempli pas du tout son rôle...Dans le cas où cette mémoire devait être partiellement supportée il aurait été plus honnête pour le constructeur de le noter sur l’annonce et ne pas l'avancer comme principal argument de vente.
je l'ai acheté sur Ebay , un retour est possible avec remboursement total (garantie acheteur ; et en plus , les frais de retour sont pris en charge par PAY PAY = de la FRANCE vers le Canada) .Cependant , je pense que le logiciel peut être amélioré = je laisse donc actuellement une chance , parce que je suis aussi en attente de lots de mémoires (achat E bay et aliexpress.com) venant de CHINE .S'il faut faire du tri, je vais le faire au détriments des revendeur , qui sont quasiment forcés de rembourser ( car il y a risque de laisser une mauvaise appréciation sur les sites , et cela leur fait peur !!) .
je ne suis pas d'accord avec "anniel" , parce que avec une mémoire correcte ( sans bad block) , le TV fonctionne parfaitement.
Que penser d'un constructeur qui fournit un disque dur avec des secteurs défectueux , ou une clé USB ?? en France , on dit mal-poliment que c'est de la "M...." !!!
Quant à modifier le FIRMWARE de la TV , pour une gestion subtile des "bad block" , ce n'est pas l'intérêt de SAMSUNG , qui arnaque les consommateurs , pour qu'ils achètent de nouvelles TV ( avec plein fonctions " Smart TV " , que peu de personnes ont vraiement besoin = CQDF) .moi , j'essaie de réparer ces cartes !!
ht;;, tps://www.leboncoin.fr/image_son/1092488713.htm?ca=12_s
anniel Posted - 03/28/2017 : 02:29:14
Le problème semble plutôt relié à une série spécifique de télévisions.
monster Posted - 03/28/2017 : 01:45:29
Bonjour,
anniel Posted - 03/27/2017 : 15:33:33
MANN France Posted - 03/27/2017 : 15:14:57
La plupart des manufacturiers ont de la 16Gbx8b 3.3V en TSOP48.
OK ; il serait bien de dire , ici , dans ce forum, lesquels , les références ,etc et si ces mémoires sont identique et vraiement interchangeables avec les SAMSUNG ..et aussi si elles ont des "bad block" néfastes ??
anniel Posted - 03/27/2017 : 13:43:33
MANN France Posted - 03/27/2017 : 12:19:35
@MANN France
Pourquoi ne pas essayer une source réputable ou carrément un autre manufacturier?
oui, mais lequel serait compatible avec cette mémoire Samsung ??
d'ailleurs , le carte BN41_01661 n'a pas ce composant "maudit" !!donc pas de risque de panne de ce type = utilisée sur séries UExxD5000, très proche des EUxxD5700 : On peut monter cette carte sans problèmes tant mécaniquement que électriquement ( une seule entree tuner TNTHD , mais pas d(entrée câble /satellite ) .
voir sur fr.yoycart;;.com/ recherche = BN41_01661
voir fr.yoycart;;.com/Search?SearchText=bn41_01661&catId=0&catId=0
255 résultats trouvés pour rechercher bn41_01661
N.B : attention= éliminer les BN41_017417 qui ont aussi cette memoire "pourrie " ; choisir seulement les BN14_01161
il semblerait que sur ces cartes "chinoises" le fichier plat SCART/PERITEL ne soit pas câblé sur le CI , alors qu'il l'est sur les carte de l'EUROPE .j'en ai 2 en commande !!
anniel Posted - 03/27/2017 : 07:25:32
@MANN France
MANN France Posted - 03/27/2017 : 05:01:28
use GOOGLE translation if necessary !!
j'ai acheté le programmateur GQ-5X avec logiciel GQ Blaster 1.07.
j'ai de gros problème de clonage avec les mémoires SAMSUNG K9GAG08U0E , venant de Chine ( via Ebay ou www.aliexpress.com) .
Elles ont toutes des secteurs défectueux !!
Avec le logiciel GQ Blaster 1.07 , il y a bien les tables de "bad block" , mais ce n'est pas suffisant pour faire une bonne copie !!
j'envisage de laisser tomber , et de renvoyer le programmateur ( garantie Ebay)si le logiciel n'est pas complété , et est inefficace.
Il faudrait qu'in fasse un mapping du fichier binaire de la lecture de la mémoire étalon qui fonctionne bien! Mais celle ci n'est remplie qu'a environ 2,3 Gbits sur les 16 Gbits de capacité.
Comme elle a aussi des "Bad block" d'origine ( merci à SAMSUNG , pour la mauvaise qualité de leurs mémoires) , il faudrait que le logiciel génère aussi un mapping du fichier binaire de référence , qui avec en plus des "bad block" ,intègre celui des données utiles = celles qui diffèrent des données vierges ( "FF"). Ainsi , il faudrait que le logiciel compare le mapping de la mémoire vierge à programmer ( mais qui a des "bad block" de fabrication d'ogigine , avec celles de l'étalon.Si la correspondance fait que les "bad bock" tombent dans les données utiles de l'étalon , il faut refuser la copie =si malgré tout , il y a copie , automatiquement la vérification va échouer. Pour que la copie fonctionne sur la carte "merde" BN41_01660 de SAMSUNG montée sur les TV UExxD5700 et autres séries équivalentes , cette exigence est impérative.En effet , le processeur de la carte mère va tenter , d'écrire ou lire ( un jour ou un autre en fonction de l'utilisation de la TV )sur un bad block , dans une configuration particulière et aléatoire du fonctionnement de la TV . exemple = entrée USB , lectures des Vidéo = OK ; photos ou musique = plantage dans le recherche des dits fichiers dans la clé USB . il faut y passer des heures de test , pour tomber dessus ( si la mémoire n'a qu'un seul bad bloc pas exemple !!).j'ai fabrique un banc de test "bricolé" , pour tester ces mémoires "in situ" ..
cibernecio Posted - 01/19/2017 : 11:43:35
Hola Eduardo. Disculpa la demora... No me molesto. Para nada amigo. pero debe haber alguna manera de poder obtener esa información. Sería escelente que puedas apoyarnos si tienes una que funciona bien con la versión 1.5 y listo... gracias de antemano!
eduardo48 Posted - 01/14/2017 : 19:59:53
Cibernecio, no te molestes por mi repuesta, nos salimos del tema por el que fue creado el post, yo puedo aportar mi experiencia en el uso del programador, no utilizo el foro para vender, además el archivo no me pertenece, no me entiendas mal.
Puedes preguntarme lo que tu quieres como yo uso el programador y los resultado que tengo.
Siempre que hagas alguna pregunta, desde mi humilde lugar y si tengo conocimiento voy a aportar.
Saludos y un gran abrazo.
cibernecio Posted - 01/14/2017 : 14:13:11
Hola a cuanto me vendes la data nand flash que funciona con smart hub y actualiza? espero tu respuesta... podría pagar por paypal. gracias Eduardo.
eduardo48 Posted - 01/13/2017 : 18:57:15
No deja como respaldo el comprado sin actualizar.
cibernecio Posted - 01/13/2017 : 13:03:23
ok Eduardo, si compro un ic nuevo grabado y lo actualizo via on line y funciona bien, ese archivo podria compiarlo y asi ya sería actualizable?
eduardo48 Posted - 01/13/2017 : 11:40:52
Entonces no lo actualices, tienes problemas en la nand o el archivo bin que utilizas esta corrupto. Copia la nand de otro tv que no tenga la falla, antes de copiar hacer un Factory reset. Leer el post mas arriba reply 24 y 30 cambio de archivo y le funciona
Do not update it
You have problem in the nand or the bin,, file that you use this corrupt
cibernecio Posted - 01/13/2017 : 08:51:08
Gracias por tu respuesta Eduardo, no me refiero a la actualizacion del smarthub. me refiero a la actualizacion principal del software que esta en la zona de " servicio tecnico" en el menú. por que como te decía... cuando le doy en actualizar... se conecta con el server de samsung y cuando empieza en 0 a descargar la ultima actualización... se malogra nuevamente la nand flash...
eduardo48 Posted - 01/13/2017 : 04:43:57
You can not deactivate the smarthub update. Probe to do a factory reset before updating. I think your problem is the nand memory or bin
No se puede desactivar la actualización de smarthub, proba de hacer un reset en modo service power of mute, 1, 8,2 power on, yo no encuentro nada dentro del menú como para desactivar esa actualización, son aplicaciones de terceros que Samsung tiene licencia de uso, esas licencias en algunas aplicaciones se vencen y dejan de funcionar,por eso hay que actualizar
GQ5XSupport Posted - 01/12/2017 : 18:29:54
In order to have the support, please be more specific of the problem.
1. Have you watched the video?
2. Give screen capture will greatly help.
3. Use plane English.
Send email to activation@mcumall.com to get faster response.
cibernecio Posted - 01/12/2017 : 18:26:37
Hola Eduardo, gracias por tus aportes.... como podríamos modificar la nand flash para que cuando se actualice via on line no se malogre? por que cuando le voy actualizar software on line. se malogra la memoria...
eduardo48 Posted - 01/12/2017 : 17:55:55
napalico "Build bad block table for source chip (file), Size does not match" Creo que esto te sale porque el largo del bin no coincide con la definición usada ir a tools edit device file y corregir el valor hex
cibernecio Posted - 01/12/2017 : 16:22:27
is same video 6 monts...
ZLM Posted - 01/12/2017 : 15:55:23
Use latest software Re1.07
For the detailed steps, see:
cibernecio Posted - 01/12/2017 : 13:46:59
tienes un bin que funcione perfecto con la version 1.05 ? por favor. muchas gracias de antemano. Las memorias que tengo son nuevas y originales.
eduardo48 Posted - 01/12/2017 : 12:42:11
Cibernecio, los d5500 no tenien actualización automática del firmware, si se actualiza smarthub es normal esto, si te produce algún error al actualizarce el Smart hub es por memoria fallada o el archivo bin no sirve.
cibernecio Posted - 01/12/2017 : 11:43:54
Gracias a todos, ya lo hice y funciona el smart hub. lo bueno sería poder dejar sin la opcion de actualizar al nand flash por que se avería nuevamente.
cibernecio Posted - 01/12/2017 : 10:34:45
Eduardo, habría alguna forma de limitar el chip para que ya no se actualice? por que cuando le das actualizar se malogra todo y hay que volver a grabarlo para que funcione... gracias por tu ayuda.
cibernecio Posted - 01/12/2017 : 10:31:45
Hola Napalico. por favor podrías copiar y pegar aqui los pasos para poder grabar correctamente en 1.05 ? tengo el archivo bin y el bbt source. gracias !!!
napalico Posted - 01/12/2017 : 10:19:22
En el caso de la K9GAG08UOE, consegui otro archivo de la serie XXD5500 y copiando con la version 1.05 me funciona todo normal incluido el SmartHub. Ahora, si intento hacerlo con la version 1.07, me sale el siguiente mensaje:
y no puedo cargar datos en el chip. Tuve que volver a la version 1.05 para hacerlo de la manera tradicional aunque me salga "error en la verificacion".
En definitiva, con otro archivo y copiado con la 1.05 me funciona normal el SmartHub y ya lo probe con tres chips nuevos. Supongo que la opinion de Eduardo es acertada.
In the case of the K9GAG08UOE, I got another file of the series XXD5500 and copying with the version 1.05 me everything works normal including the SmartHub. Now, if I try to do it with version 1.07, I get the following message:
"Build bad block for source file (file), Size does not match"
And I can not load data on the chip. I had to go back to version 1.05 to do it the traditional way although I get "error in verification".
In short, with another file and copied with 1.05 me the SmartHub works normal and I already try it with three new chips. I guess Eduardo's opinion is correct.
cibernecio Posted - 01/12/2017 : 09:33:16
Lo que me oilvide de decir es que con la version 1.5 del software grabe varias y todas funcionan el smarthub... ahora intento hacer lo mismo y no funciona.
pordrias darme los pasos para grabar nuevamente? algo me olvidé o no lo sé.
tengo la data del ic y el bbt source los dos archivos.
cibernecio Posted - 01/12/2017 : 09:30:47
Entonces con el software 1.7 se puede grabar normal pero no funciona smart hub pero funciona... ayer probe y no sale smarthub pero funciona normal todo lo demás.
eduardo48 Posted - 01/12/2017 : 08:46:47
Cibernio estoy comentando solo de K9GAG08UOE con bbt esta dando error
cibernecio Posted - 01/11/2017 : 16:10:18
Gracias Eduardo, osea que no es necesario subir el BBT SOURCE del ic madre o fuente? que pasos excactamente haces? por favor dame una mano. deseo que los ics funcionen con el smart hub aun que no actualicen.
eduardo48 Posted - 01/11/2017 : 15:54:32
Cibernecio yo lo hago asi con versión 1.05 erase carga datos y write
eduardo48 Posted - 01/11/2017 : 15:51:50
Napalico, ya lo baje, por lo que veo esta copiado con el gq5x porque el archivo esta creado con 86d00000h (este valor lo creo mcumall), el valor real de la memoria es 88A7D800h que es el que usan otros programadores
No creo que te funcione porque esta recargado de información seguro tomado de un tv de mucho tiempo de uso, pienso que estas pisando con información sectores defectuosos.
La falla seria como si esta corrupto el firmware.
Al clonar con gq5x Smart,salta sectores defectuosos cambia de lugar los datos, parece que al tv no le va bien.
El fin de semana lo grabo y pruebo en tv, y comento
cibernecio Posted - 01/11/2017 : 13:55:23
Hola, con que version del software recomiendan hacer las clonaciones de este chip? no funciona el smarthub
eduardo48 Posted - 01/10/2017 : 17:22:18
napalico, podes subir a google drive el archivo que tenes de la nand (el comprado que nombras mas arriba del post)y te lo pruebo
cibernecio Posted - 01/10/2017 : 15:53:58
Originally posted by GQ5XSupport
GQBlaster 1.06 is released. Please download and use it. Also watch video https://www.youtube.com/watch?v=7KTYrj_pgbA. The clone chip is much easier now.
After making three copies on new chips in the traditional way with version 1.05 the TV works normal but the same goes with the SmartHub and multimedia functions with the proviso that when giving these commands, the TV starts with the failure of the permanent restart and It no longer recovers.
Obviously there is a serious problem with the copying of data using the GQ-5X that the programmer's support may try to solve.
Luego de hacer tres copias en chips nuevos de la manera tradicional con la version 1.05 el tv funciona normal pero sigue pasando lo mismo con las funciones SmartHub y multimedia con la salvedad que al darle estas ordenes, el tv comienza con la falla del reinicio permanente y ya no se recupera.
Obviamente hay un serio problema con el copiado de datos usando el GQ-5X que quiza el soporte del programador pueda tratar de resolver.
Hello, you resolved problem? me buy same programmer.... thanks for you reply.
napalico Posted - 01/09/2017 : 12:53:35
napalico Posted - 01/07/2017 : 06:24:23
Graba directamente sin el proceso del saltar sectores, erase, cargar la fuente y write si verifica tenes error seguro
Gracias Eduardo48 por aportar tu experiencia. Cuando abri este post, hacia las copias con la version 1.05, pero con los pasos del video. Voy a hacer la copia de la manera que recomendas y comento resultados.
Thank you Eduardo48 for bringing your experience. When I opened this post, towards the copies with version 1.05, but with the steps of the video. I will make the copy the way you recommend and comment results.
eduardo48 Posted - 01/06/2017 : 20:11:27
eduardo48 Posted - 01/06/2017 : 19:54:58
Napalico, hoy probe en tv por primera vez la 1.07, solo había probado en grabar y verificar sin colocar en tv. Yo tenia memorias grabadas con la versión 1.05 y funcionaron sin problema.
Te comento la versión 1.07 produce el error que comentas, hay error con el dongle wifi y no inicia Smart, es fallo del software, opino que de la manera que salta los bloques defectuosos produce el mal funcionamiento del tv, esta nand trabaja con la otra que la maneja y escribe (uboot).
Creo que estamos al principio al menos con esta nand.
Yo te digo que pruebes con la 1.05 y no le des importancia a la verificación, si los datos del programa no caen en sectores defectuosos te va a funcionar.
Desintalé la 1.07 y volvi a la 1.05 grabé y el tv funciona correcto.
napalico Posted - 01/03/2017 : 12:58:01
Luego de probar la version 1.07 se soluciono el problema que reporte anteriormente y la verificacion de datos sale OK, esta prueba la hice en cuatro chips K9GAG08UOE nuevos.
Pero lamentablemente sigue el problema inicial con estos tv Samsung serie D5500, que con la memoria reprogramada no accede a las funciones SmartHub ni multimedia desde USB. Al parecer el GQ-5X no copia al 100% los datos del chip original, dado que con este, se accede a todas las funciones normalmente.
Alguien que trabaje con estos SmartTv, ¿ha podido comprobar esto?.
After testing version 1.07 solved the problem I reported earlier and the data verification comes out OK, this test was done on four new K9GAG08UOE chips.
But unfortunately the initial problem with these Samsung TV series D5500, which with the reprogrammed memory does not access the functions SmartHub or multimedia from USB. Apparently the GQ-5X does not 100% copy the data of the original chip, because with this, all functions are accessed normally.
Anyone working with these SmartTv, have you been able to verify this ?.
napalico Posted - 01/02/2017 : 06:34:01
-smtcpy
Hello, I answer after a well deserved vacation. Download version 1.06 and when using the "smart copy" function the following happens:
-smtcpy
And so the program stays for more than an hour, reaches about 50% without progress and I have to cut the process.
Is this delay time normal?
Marquitos550b, could you make the copy with this function ?. In my case, with the previous versions, I always gave failure in the verification with the K9GAG08UOE.
marquitos550b Posted - 12/21/2016 : 17:05:26
Hola, compre una K9GAG08UOE ya grabada y al leerla, y luego comparar los archivos, siempre me arroja distintos valores.
Con memorias de 1Gb y 2Gb funciona bien la lectura y la verificacion.
Es esto normal o es un problema de la K9GAG08UOE con el gq-5x?.
Saludos, Marcos.
Hello, buy a K9GAG08UOE already recorded and when reading it, and then compare the files, it always throws me different values.
With 1Gb and 2Gb memories, reading and verification works well.
Is this normal or is it a problem of the K9GAG08UOE with the gq-5x ?.
Greetings, Marcos
GQ5XSupport Posted - 12/16/2016 : 13:35:08
eduardo48 Posted - 12/16/2016 : 13:15:21
Ya subieron la versión 1.06 proba y comenta los resultados
napalico Posted - 12/16/2016 : 09:56:45
A los chips K9GAG08UOE virgenes los borro y al hacer " blank bbt" me aparecen solo 2 o 3 bloques dañados y luego sigo los pasos del video. De todas formas he realizado pruebas con otras memorias del tipo TC58 o H27 y me dan OK en la verificacion. Tendre que esperar la version 1.06 y ver que sucede.
eduardo48 Posted - 12/16/2016 : 08:21:46
Entonces tendrías que probar con otra memoria de 1gbit o 2gbit ej.TC58NVG1S3ETA00, H27U4G8F2DTR, K9F1G08UOD , leerla y copiarla en una virgen (sin sectores defectuosos), y verificarla la cual debe dar ok, con esto creo que descatarias un mal funcionamiento de gq5x.
Fijate en las memorias vírgenes que tenes hacerle erase, en el soft anda a new chip y hace el blank bbt fíjate cuantos badblock hay.
napalico Posted - 12/16/2016 : 07:22:38
Gracias eduardo. Lo verifique que el problema viene de la Nand clonada ya que en la misma main soldaba la comprada grabada y funciona internet muy bien, sin embargo con la copiada no el USB ni SmartHub. Tambien copie los datos de la manera comun y al verificar me salta el error, asi y todo la pruebo y otra vez no SmartHub ni USB. Estos pasos los hice con 3 memorias virgenes obteniendo siempre el mismo resultado, destaco que las demas funciones del tv funcionan bien y sin el reinicio.
eduardo48 Posted - 12/15/2016 : 19:57:00
Napalico esperemos la versión 1.06 para ver si corrige el saltear los bloques defectuosos.
eduardo48 Posted - 12/15/2016 : 19:52:08
Hola,me pasa igual, el soft con esta memoria no saltea los sectores dañados, por esto yo las grabo de la manera común, y asi me funciona,no la verifico porque se que va a dar error.
Cuando oprimis la tecla Smart te tiene que aparecer iniciando,luego aparecen los iconos mas comunes YouTube netflix qubit como recomendado, abajo se cargan las otras. Si seleccionas origen y tenes insertado un pen formateado en fat32 te va aparecer tv pc y el usb insertado, luego seleccionas video o fotos siempre en los formatos permitidos.
¿Esto te a pasado en una placa o en varias?, porque si es una podría ser la placa que ande mal
Hay pegada a esta nand otra nand mas chiquita KFG1GN6 los datos de esta no se pueden modificar las contraseñas quedan grabadas en esta nand chiquita, yo creo que al iniciar estas dos inter actúan.
Pienso que tu problema no es el soft, nunca me paso eso, te digo que funciona todo lo Smart el usb y también allshare
napalico Posted - 12/15/2016 : 12:28:43
Hola Eduardo. Con la version 1.05 la verificacion me falla siempre por mas que el soft detecta los sectores dañados y no se que puedo estar haciendo mal. Cuando sueldo el chip clonado y actualizo a la version 1017, lo hace sin problemas, la falla se presenta al intentar abrir la funcion SmartHub o multimedia desde un pendrive, no hace nada o se reinicia. Cabe aclarar que la memoria de las cuales he hecho las copias han sido compradas nuevas ya grabadas, las cuales al soldarlas funcionan al 100% y las que he usado para grabar son nuevas. Has tenido oportunidad de verificar estas funciones?
eduardo48 Posted - 12/13/2016 : 17:17:57
Hola, napalico, yo no tuve ese problema, las memorias han funcionado bien, aunque la verificación me a dado errónea con esta nand en especial.
Con otras nand la ultima versión del software detecta los bloques defectuosos y luego crea un archivo nuevo para saltear los bloques malos y la verificación de esta manera es correcta, yo creo que el soft trabaja asi, si no es asi Support me corrija.
Yo te recomendaría copiar una memoria de otro tv funcionando en forma correcta, lo que es difícil porque estos unxxd5500 ya tienen años de uso y la memoria se ido alterando, hasta que un dia deja de funcionar gracias dios.
Una vez que el tv te funciona en modo service proba de hacer un reset Factory y actualiza en línea esta la versión 1017 y siempre memorias nuevas no usar la del tv
GQ5XSupport Posted - 12/12/2016 : 14:26:39
@napalico, The new software will simplify the steps, but I am not sure if it will fully work in your case. I am testing this software with one tv repair technician.
napalico Posted - 12/12/2016 : 05:58:49
Each cloned chip I have soldered them and they work with limitations, that is to say, the multimedia functions or SmartHub of the tv do not work, whereas with the original chip if it does. The rest of the TV functions are normal.
GQ5XSupport Posted - 12/09/2016 : 09:16:18
After many remote support session, I am sure we have enough information to "clone" the chip properly.
I plan to release 1.06 to automate the process. The feature I plan to put in will be
Add "advance write" option for NAND (default on).
It will do
a. Erase chip.
b. Analyze the target for bad block.
c. Generate the bad block for source.
d. Generate the target data and program the target at the same time. No need to generate a target file.
e. Auto verify the data, when verify the data, ignore all data in the bad sector to avoid confusion.
For now I have created a script file that can semi auto the process using 1.05.
The expected release time would be end of the year.
GQ5XSupport Posted - 12/07/2016 : 15:52:00
Compare failed should be normal. Please solder back to the device and see if it works or not.
In case of the bad block, the compare will likely to give you error.
You need to get used to the compare failed for Nand device. Only perfect NAND chip can give you compare pass. Most of the NAND chip has bad sectors.
Generated in 0.95 sec. Snitz Forums 2000
