 TTL/CMOS Testing
Elsid Posted - 02/16/2010 : 21:28:59
When will the TTL/CMOS testing function be added to the software?
If the answer is not for a long time, is it possible to give an example of how it may be implemented in the devices.txt file? Or is it more complex than this?
17   L A T E S T    R E P L I E S    (Newest First)
anniel Posted - 02/16/2018 : 07:38:09
Any news on this?
anniel Posted - 05/30/2017 : 14:35:01
A separate forum section should be devoted to new developments and recent devices additions.
+1
supervizeur Posted - 05/30/2017 : 06:53:32
anniel Posted - 05/29/2017 : 10:01:17
How long has this been on the back burner?
Something else we'll never know.
supervizeur Posted - 05/29/2017 : 06:39:39
anniel Posted - 05/07/2017 : 10:09:46
Any news?
supervizeur Posted - 05/06/2017 : 04:49:24
Hi ZLM, any update on TTL, CMOS and RAM testing on GQ4X or GQ-4X V4?
anniel Posted - 02/28/2017 : 04:33:44
"The current hardware need a adapter for this task."
Would it be easier to implement on the GQ-4X V4
supervizeur Posted - 10/19/2016 : 04:22:22
Any time frame?
anniel Posted - 04/06/2016 : 16:13:32
I support this!
supervizeur Posted - 11/17/2015 : 07:32:02
TTL/CMOS testing/identification would be nice to have on the GQ4X
ZLM Posted - 02/18/2010 : 07:53:32
If you only need to do the TTL/CMOS testing. Then the VP280 will be fine. If you need to do other programming job, then you can looked other model. It depends on your main task.
Elsid Posted - 02/18/2010 : 03:05:07
Given that situation,what would you recommed for TTL/CMOS testing?
I was thinking of one of the Wellon units.
ZLM Posted - 02/17/2010 : 22:22:46
Not decide yet. No time frame for that feature on GQ-4X.
Elsid Posted - 02/17/2010 : 13:52:39
OK.
When will the adapter and new software be available?
ZLM Posted - 02/17/2010 : 13:48:11
The current hardware need a adapter for this task. Not just software.
