 PIC18F26J50 issue
edsgarage08 Posted - 01/26/2017 : 20:31:07
I'm trying to program a PIC18F26J50.
I have a GQ4X older programmer.
H/W Re: GQ-4X Re-2.20(SW Re. 6.38)
USB Driver Re.2.0
Software Re. 6.38
I am unsure of the entry in the device.txt file to add for this.
I copied the one for the PIC18F26K20.
I get an ID check failed ("29FFFF") after trying to read or write to the chip and the software hangs after which I have to close the application and unplug the programmer.
This is the entry in the device.txt file
Name="PIC18F26J50*DIP28",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP28",VPP="9V",VCC="3.6V",WVPP="9V",WVCC="3.6V",Platform="GQ-4X (>Re1.30)",PINVCC="ZIF32_PIN28";
Any help you can give me is appreciated.
Thanks,
Ed
anniel Posted - 06/15/2017 : 19:17:46
This chip is not supported on GQ-4X.
It will be supported on GQ-4x4.
Will it be added to the devices list in the next release?
Good question.
supervizeur Posted - 06/12/2017 : 08:17:44
ZLM Posted - 02/05/2017 : 11:29:28
