 K9GAG08UOE
CARLOSMONFER Posted - 03/06/2017 : 09:30:25
Hello
I have a problem with the copy of a nand -K9GAG08UOE that on a samsung tv works correctly and try to record on a new chip K9GAG08UOE and once on the tv does not work (reboots).
It has been recorded in different ways and at different speeds ..also with the new tab smart copy (always with the same results) .. the nand is considered by the tv as bad .. and restart.
The programmer I use is GQ-5X with the latest version of soft 1.07
They have been tested with more nand chips but always the same
Checking the recorded memory gives verification errors
What is the problem? .. this programmer does not allow cloning nand memories?
REGARDS
30   L A T E S T    R E P L I E S    (Newest First)
anniel Posted - 12/25/2017 : 13:52:09
Originally posted by Willyxr
this programmer not work correctly.
in tv samsung UNxx5500 the smart function none works.
fail with any manufacturer of memories
this programmer are a scam.
i lost my time, my money in this.
this programmer keep contiunes sold and offering as a support for samsung tv with memories k9gag08u0e, and that is NOT TRUE !!!
Yes it works correctly with all supported devices and then some.
You are a scam. A real technician would be able to operate such a simple apparatus.
Willyxr Posted - 12/24/2017 : 18:15:59
anniel Posted - 09/20/2017 : 02:38:45
Now I need a socket for BGA63 and BGA169
Good ones are expensive.
Yes, and it is a request to the manufacturer. We need to move forward.
Yes, smaller and smaller packages for bigger and bigger TVs.
thetan76 Posted - 09/19/2017 : 23:33:39
anniel Posted - 09/15/2017 : 03:54:37
thetan76 Posted - 08/31/2017 : 20:44:45
Nop, MT29F2G08ABAEAH4, for example.
eduardo48 Posted - 08/30/2017 : 12:40:01
Hi thetan76. Bga socket for the onenand kfg1gn6w20?
thetan76 Posted - 08/30/2017 : 09:52:43
thetan76 Posted - 08/30/2017 : 09:51:17
Dear All,
I can confess that I successfully programmed 3 K9GAG08U0E for BN41-01661 Samsung MB. All three work and gave back to my clients. And it paid off all my expenses plus a good margin. :) Thanks for the product.
skdaddy69 Posted - 08/29/2017 : 13:56:01
I'm using version 1.09 to program K9GAG08U0E.
I took a good programed IC and "READ" using speed 10. Saved the file and inserted a new empty chip and programed on speed 10. - DIDN'T WORK.
After, I did the same on speed 5 (READ and WRITE)and had a better results.
Total of 3 ICs were programed and work good, but 2 still a problem.
I'll have to order couple of new chips and see if it is a problem with ICs or .....????
GQ5XSupport Posted - 08/26/2017 : 03:42:25
Have you tried 1.09? In previous version, the definition of the chip was wrong.
marquitos550b Posted - 08/25/2017 : 13:56:18
Hi Carlos, I do not think gq5x is a fraud. I agree that software lacks a lot and that sometimes we lose a lot of time.
Could you comment on how you did to program the memories with the ProMan? Did you copy from a working TV, reused the chips or are they new chips ?. Please comment.
Regards
Marcos.
CARLOSMONFER Posted - 08/25/2017 : 09:49:35
Hello
I have come to the conclusion after much time lost that this programmer is not worth it and it is a fraud and a failure
I have tested this Chinese and it goes well ..ProAND NAND NAND PROGRAMMER Professional / NI TSOP48 FLASH NAND PROGRAMMER TL866 PLUS PROGRAMMER / HIGH SPEED PROGRAMMING --- for 100 €
regards
MANN France Posted - 03/27/2017 : 15:43:46
Originally posted by monster
Hello,
i tried 1.5 version but problems are the same....i can't dump K9GAG08U0E nand...
Always error on the verification step. I despair :-((((
je suis nouveau dans ce forum ( achat il y a un mois , pour cloner les k9gag08U0E de cartes mères de tv UExxD5500 et 5700 ). échec à tout les coups de la vérification après programmation!!
je pense que le logiciel est incomplet , pour faire une copie bonne à tout les coup = voir mes post sur =
Clone failure K9GAG08U0E.
de plus les mémoires SAMSUNG me sembles instables pour les bad block et peu fiables en répétitivité . la solution serait que le logiciel fasse un mapping des données utiles à écrire , et refuse la copie si il y a des bad block au même endroit dans la mémoire "dite vierge" ...sinon sur la Tv il y a disfonctionnement par rebouclage indéfiniment du logo "smart TV"
monster Posted - 03/17/2017 : 22:55:26
Hello,
eduardo48 Posted - 03/17/2017 : 04:27:00
Hola ez, si se puede añadir nand 8 bit, tenes que buscar el datasheet tomar los valores, hacer algunos cálculos, y convertirlos a hex, son el tamaño de la memoria, cantidad de bloques y tamaño de pagina, el soft 1.07 reconoce los valores ID.
Por el tema de verificación estoy probando nand nuevas luego comento.
ez Posted - 03/16/2017 : 18:27:44
hola , estoy por adquirir un gq-5x pero aun tengo inseguridades sobre la compatibilidad con las memorias samsung y los problemas que comentaron.
Hay que usar el soft 1.05 ?
En caso de que quiera leer un memoria que no figura en la lista del programa, como se añade?.
desde ya muchas gracias
monster Posted - 03/16/2017 : 08:29:04
thanks !! i'll try it and i'll be back for results
eduardo48 Posted - 03/14/2017 : 16:59:07
Ver si puede bajar
https://drive.google.com/file/d/0B0B06KCMBQynZHZjNFFkVW9NQm8/view?usp=sharing
monster Posted - 03/14/2017 : 10:41:04
Hello,
Somebody can give me a link to download the older version of GQblaster 1.05 please ?
monster Posted - 03/11/2017 : 11:29:41
my primary problem is to dump firmware of K9GAG08UOE nand. I can read it but the verification fail all the time.
I tried all the speed and 3 x K9GAG08UOE different source nand. I also try to add an external supply but results are
always the same : many errors during verification (and differents errors on every verification...)
eduardo48 Posted - 03/11/2017 : 09:31:34
Seguro que a este software le falta correcciones, pero te digo que graba bien la k9gag08uoe, uso en tv Samsung unxxd5500
Yo escribi, en chip nuevos sin botón Smart, ok
También tuve resultados buenos, con algunos chip del tv (usado)pero con botón Smart copy, pero no todos han funcionado.
Cual es tu problema exactamente.
monster Posted - 03/11/2017 : 07:18:38
thanks you for this explanation. So i don't understand why this nand make error reading during his dump....
GQ-5X reader indicated that K9GAG08UOE nand is fully compatible and i bought it mainly for this.....
eduardo48 Posted - 03/10/2017 : 17:22:04
Hola, Yo tengo las versiones, pero creo que la base del software es la misma, lo único agregado en versión 5 y 6 es no escribir en sectores defectuosos y en la 7 agregaron el botón Smart que hace todo automatico.
Tu puedes utilizar la versión 7 como si fuera la versión 5 sin el botón Smart, de esta manera erase, cargar archivo, write y verificar, pero si en el chip destino tenes sectores defectuosos la verificación es errónea.
monster Posted - 03/09/2017 : 23:45:42
Hello,
i try read nand chip with an additional supply but i got same issue...
Somebody can give me a link to download the older version of GQblaster (1.05 or 1.06) please ?
marck3 Posted - 03/08/2017 : 06:48:44
I think I'm not sure but it may be the speed of reading and writing that is high.
The only one that can record without problem and at tnm5000 no other can, I do not know why.
marck3 Posted - 03/08/2017 : 06:42:11
I have this same problem, I have already tested with several new and used chipcs.Ja I did reading and writing at various speeds. The only one that recorded more or less, but on TV is restarting and at speed 9.
monster Posted - 03/08/2017 : 03:20:19
Hello,
i would like to test old versions of the GQblaster because i have the latest 1.07. Maybe old version work....but i can't find link for downloaded it.
CARLOSMONFER Posted - 03/07/2017 : 10:35:23
Hello
When the programmer loses and its soft are not up to the height that the client needs
Hopefully a quick solution by this company or we will begin to distrust the quality of the product
Thanks for your interest
monster Posted - 03/07/2017 : 02:29:18
Hello,
I have the same problem with the same nand chip
Try every speed on 3 different computer and always errors on verification.
Generated in 0.36 sec. Snitz Forums 2000
