 trying to write a simple .bin file
mathewbeall Posted - 11/07/2017 : 01:08:00
Hi Folks - new to the whole eprom scene. I have a 512kbyte .bin I need to write to a 27C4096 eprom.
I am not entirely certain how to fit the adapter onto the GQ-4x4. When I have the bottom pins touch the bottom of the adapter (leaving the top two empty) writes fail immediately.
When I have it in the middle - the write works, but then fails to verify.
if I have it at the very top (leaving the bottom two open) also fails to write.
Any ideas? This is the second computer I have tried this on as well - just in case it was the first computer.
Matt
anniel Posted - 11/17/2017 : 07:11:44
Originally posted by mathewbeall
Great - what about how the adapter sits in the main socket? There are 3 positions it can be. I assume that pin 1 is the upper right and I align it to the top, but not sure.
Matt
Generally adapters align with the bottom pins of the programmer unless otherwise noted in the adapter or device location section.
mathewbeall Posted - 11/08/2017 : 01:08:37
Matt
ZLM Posted - 11/07/2017 : 15:52:47
This is the location for your chip:
http://www.mcumall.com/forum/uploaded/zlm/201251512716_M27C1024_2048_4096.jpg
mathewbeall Posted - 11/07/2017 : 15:01:32
So the eproms i got were Hitach 4mbit ones - and it seems like lots of people have problems with those - so I just bought some AMD ones.... hopefully those work better.
But - I still have the question - how does the adapter sit in the ZIF socket? It can sit three ways - all the way at the top (top=lever), in the middle, or all the way at the bottom.
This is probably very self evident to other folks - but I can't find any documentation on this!
Thanks,
Matt
mathewbeall Posted - 11/07/2017 : 01:25:56
Actually - it looks like when i load the .bin file - it won't write in any of the three positions... so - what position is correct, and any idea why writes fail completely?
