 Bad block detection error
eduardo48 Posted - 03/12/2018 : 09:06:59
Support, you can verify, bad block detection, compare with another programmer I have different result, example gq5x 1293, 1373, 1542, rt809h 1292, 1372, 1541.
If there is an error, it could bring problems in smart copy
eduardo48 Posted - 03/15/2018 : 07:04:31
Originally posted by GQ5XSupport
There could be one off in report but smart copy does the right thing.
Thank you for responding, I would be calmer if the value informed by the software was correct.
I think you should correctly report the defective block
GQ5XSupport Posted - 03/14/2018 : 12:43:52
eduardo48 Posted - 03/13/2018 : 09:23:23
They have to be numbered in the same way, if the software incorrectly numbers the blocks, using smart copy can skip a good block.
For this I consult support if you can verify this.
Maybe some start counting at 0 and others start at 1...
Hello anniel,you are sure of what you tell me, you can check this, please read the link, where we had a flaw with this problem
http://www.mcumall.com/forum/topic.asp?TOPIC_ID=8292 reply 38
GQ5XSupport would need to look into this.
You say, that consult support, as I do
anniel Posted - 03/13/2018 : 07:36:41
eduardo48 Posted - 03/13/2018 : 06:01:57
anniel Posted - 03/13/2018 : 03:05:54
eduardo48 Posted - 03/12/2018 : 19:04:03
anniel Posted - 03/12/2018 : 16:44:42
Depends if they are not numbered the same or miss-identified.
