 problem with chip 64a1 Splatterhouse
kyoXIII Posted - 07/21/2018 : 05:52:08
Good evening community, I present to you about a problem that has been presented to me when I recorded this "custom" chip or security key of the jamma splatterhouse, it turns out that it is a subject that I have been investigated and well, I am a novice in this topic. dumpear roms, then encourage me to buy a chip recorder and encourage me to fix this wonderful jamma. The issue is that I realized that the chip that is failing is a "64a1", a Hitachi HD HD63701, then I bought a quartz chip to be able to re-record that rom, but when recording that rom, it shows me that message of error that I do not understand what it is? Now, seeing the theme of pages, in order to record that rom I need an HD63701VOC chip to record it, but the software of my GQ-4x4 does not offer that chip, but another one of HD6301Y0 of the Hitachi series, so my question is error appears because I am using a device (which offers my program) that does not correspond and I get that error message? Is there other software better than this? Or the error is from the file that is mcu extension? Thank you
ZLM Posted - 07/28/2018 : 08:52:22
This chip is CPU chip and it needs a special adapter to map the pin.
Currently there is no adapter for it.
See:
http://www.mcumall.com/forum/topic.asp?TOPIC_ID=6375
kyoXIII Posted - 07/21/2018 : 15:28:03
Welcome kyoXIII.
What is your error message?
Would you have the datasheet of the chip?
the message says write failed, address =0X000000, Buffer =0X43 Device = 0xFF, and i think it's older, because the news usb programmer not supported this chip
anniel Posted - 07/21/2018 : 14:20:43
Welcome kyoXIII.
