 error when programming AT29C256
drummerdude Posted - 06/23/2007 : 11:45:51
whenevr I try to program my chip I get ERROR:WRITE SECTOR ZERO
ZLM Posted - 07/07/2007 : 12:34:35
can you give a picture of your programmer with chip on it? so that I can take a close look.
drummerdude Posted - 07/06/2007 : 20:07:00
when I try to verify it shows, error at 0X000000.....
ZLM Posted - 06/25/2007 : 19:43:08
If the software verified OK, then it should be programmed correctly. Otherwise the verification will fail.
drummerdude Posted - 06/25/2007 : 16:26:40
I had to change computers, but now when I burn the chip, and then read it, it is not what I burned on there.
ZLM Posted - 06/25/2007 : 08:19:54
See:
http://www.mcumall.com/forum/topic.asp?TOPIC_ID=97
drummerdude Posted - 06/24/2007 : 10:10:46
what should they be set at, all the jumper that are shown in the softwar window (when AT29C256 is chosen) I have them set to that, but it doesn't show all the jumpers?
ZLM Posted - 06/24/2007 : 00:03:20
Check jumper settings.
