 Programming SPI EEPROMS
rickhunter Posted - 07/19/2007 : 18:26:58
I am having issues programming 25c040's using the willem enhanced programmer. Is there anything in particular to these? I'm using 0.97ja
I cannot get it to write correctly, it will read correctly, but not write. Incidentally if I select 25c020 it will program the first 256 bytes with no problems, but it won't do it correctly using 25c040.
ZLM Posted - 07/20/2007 : 16:37:25
True-USB willem supports 25040 SPI EEPROM too.
rickhunter Posted - 07/20/2007 : 09:38:02
I have already tried that, even older versions. I need to progam these, but I'm afraid of buying another willem programmer if the issue is with the software.
backbiter17 Posted - 07/20/2007 : 08:05:21
try older version 0.97g
br,a
rickhunter Posted - 07/20/2007 : 04:52:04
So is there a fix, or a version that works?
ZLM Posted - 07/19/2007 : 18:40:20
It seems the software bug.
