 24g16
yoseph Posted - 03/13/2019 : 05:32:19
This model IC 24g16 not included in the device list is there any other means to add this device
If any one knows please
anniel Posted - 04/04/2019 : 02:55:41
The GQ-4x4 is a SPI programmer (Serial Peripheral Interface), the chip you are trying to program uses the i2c bus interface. I do not think the programmer supports both programming interfaces.
All 24 series EEPROM use I2C and thus supported by the GQ-4X.
Are you 100% sure because I2C and SPI are two different communication methods and no where can i find if the GQ-4X supports I2C.
Just look at any 24 series datasheet… Never found one that didn't work on the GQ-4X.
Keep in mind it can be called I²C, I2C, IIC, TWI, TWSI, Two-Wire Interface, Two-Wire Serial Interface or simply 2 wire.
laptech Posted - 04/04/2019 : 01:56:39
anniel Posted - 04/03/2019 : 04:52:42
laptech Posted - 04/01/2019 : 05:33:14
anniel Posted - 03/30/2019 : 11:21:59
Originally posted by yoseph
I tried but when it check ID it displays the function not supported by this device
I don't think those chips support ID.
yoseph Posted - 03/30/2019 : 05:29:24
anniel Posted - 03/14/2019 : 03:02:34
Im sure that the model IC is ROHM BR24G16 if any one knows please
Try this. Name="BR24G16",ID="XXXX",Class="24C16",Category="SERIAL_EPROM",MFG="ROHM",VCC="3.6V";
yoseph Posted - 03/13/2019 : 23:29:34
anniel Posted - 03/13/2019 : 06:10:34
My device is GQ 4X4
Good choice.
anniel Posted - 03/13/2019 : 06:10:06
Are you sure it is a "g" and not a "c" on the chip or is it a ROHM BR24G16?
yoseph Posted - 03/13/2019 : 05:34:55
My device is GQ 4X4
