 Support 26LV800BTC-55 EN29LV160AT-70TCP S29AL016D7
elbronco Posted - 02/16/2018 : 12:51:55
I need add to NAND.TXT
-detect
Unknown device
ff,ff,ff,ff,ff,ff
14   L A T E S T    R E P L I E S    (Newest First)
anniel Posted - 04/08/2019 : 05:42:16
Originally posted by elbronco
I need the adapter and I do not have it, I do not get it either. I do not know where to buy it in Argentina.
MCUMall or eBay.
elbronco Posted - 04/07/2019 : 17:50:59
anniel Posted - 04/03/2019 : 03:31:37
I do not have the adapter to read these memories in GQ4. For this case, buy the GQ5 but it seems that it is not compatible.
Try with your GQ-4X.
elbronco Posted - 04/02/2019 : 15:11:48
anniel Posted - 11/12/2018 : 08:38:11
CMOS Flash Memory.
Did you succeed?
anniel Posted - 05/09/2018 : 02:58:22
So what can i do? I have to record that memory AND for that i bougth GQ5 tsop48. Help
Which one? EN29LV160AT and S29AL016D are supported on the GQ-4X.
elbronco Posted - 05/08/2018 : 20:24:27
CMOS Flash Memory.
elbronco Posted - 05/08/2018 : 06:46:04
anniel Posted - 03/18/2018 : 09:24:24
Originally posted by GQ5XSupport
This is not a Band device.
Band or NAND?
GQ5XSupport Posted - 03/17/2018 : 07:14:08
anniel Posted - 02/25/2018 : 05:31:13
Thanks support and thanks Anniel. That message comes with the three devices that I am trying to read.
You could tell me the valos to add in the NAND.txt file because they do not appear in the list. I hope the three components are not defective.
The values are taken from the datasheets.
elbronco Posted - 02/24/2018 : 12:54:42
anniel Posted - 02/24/2018 : 05:46:54
-detect
Unknown device
ff,ff,ff,ff,ff,ff
This means the flash is not properly seated.
You should get values other than all ffs.
Couldn't a bad chip also read as all FF?
GQ5XSupport Posted - 02/23/2018 : 14:40:38
[quote][i]Originally posted by elbronco[/i]
[br]I need add to NAND.TXT
-detect
Unknown device
ff,ff,ff,ff,ff,ff
[/quote]
