 25Q128JVFQ Support
bkrios Posted - 04/09/2019 : 07:51:19
I'm trying to read from a Winbond 25Q128JVFQ SOIC-16. I'm using the ADP-098 adapter, but my reads result in FFFFFF for device ID and the contents read as FF.
The datasheet for this device can be found here: https://www.winbond.com/resource-files/w25q128jv%20spi%20revc%2011162016.pdf
Any suggestions?
anniel Posted - 04/13/2019 : 03:49:58
Originally posted by bkrios
I'll check!
Keep in mind that if you tried a 5V device definition you may have fried your chip.
bkrios Posted - 04/12/2019 : 18:17:29
I'll check!
anniel Posted - 04/12/2019 : 09:08:06
I've tried a few. I guessed that "W25Q128BV*SOIC16 would be close enough, but I still can't get it to read.
I think it should work. Any flux residues left on the pins from unsoldering?
bkrios Posted - 04/12/2019 : 08:00:16
anniel Posted - 04/09/2019 : 08:10:08
Any suggestions?
Which device did you select in the software?
