 no red light on JDM enhanced programmer
Bobino36 Posted - 09/26/2007 : 17:02:24
Hi!
My enhanced JDM programmer works well on my pc (can read, write, erase, both light green and red, are working)with a 16f628a.
But when I try with my laptop, it's a no-go. I know voltages in serial port on laptop are lower that's why I put an external voltage supply (+12Vcc). I double-checked polarity and it's ok. The green light is on only when I do a read command but no red light when trying to write. I can read but that's all. I use ICprog. I thought this programmer would work with any laptop with an external source???
I also checked VCC and VPP on the ICSP connector when reading and it shows 4.4V and 11.5V
Any hints???????
Thanks.
Bobino36 Posted - 10/01/2007 : 17:39:40
I tried your suggestion but it seems to be working normally even if I let the supply voltage always on!?!?! I don't understand why and I did no change.... Altough the red light only blinks 2 small shots, the pic 16f628a is correctly programmed. It is strange because on my desktop, the red light goes on for much longer time...
Do you provide the schematics of this board? I wonder what is driving the RED "program" led to see why it's missing voltage and to see if I would be able to find something to fix this...
Thanks.
ZLM Posted - 09/30/2007 : 19:57:17
Try to connect the 12V external VPP only before hit the read/write button. and disconnect it after finished read/write.
Bobino36 Posted - 09/29/2007 : 05:09:02
Vpp = 9.21V
Vcc = 4.43V
While using JP2 2-3 (internal Vpp)
Any suggestion would be appreciated.
Thanks.
ZLM Posted - 09/27/2007 : 09:31:16
If you can read, then you should be able to write. The read and write have same voltage requirment and only software commands are different.
The external Vpp will not let red LED on. It only applied on chip.
How about the voltage measurment without external Vpp?
