 usb
baka yaro Posted - 11/13/2007 : 09:58:42
Is it possible to use an usb port to read/write to an eprom? I'm using a newer laptop that has only usb ports to use. I have an adapter that is usb to parallel(db25). I have tried hooking the usb to parallel and I get the error message to check power and connection. All three lights are lite too(Vpp, program, power)
Thanks you
ZLM Posted - 11/14/2007 : 00:09:08
Yes.
baka yaro Posted - 11/13/2007 : 23:08:18
So in other words there is no possible way to use the board with a usb except buy a new board with usb capabilities??
ZLM Posted - 11/13/2007 : 20:04:14
The parallel port willem will not work on USB-LPT adapter.
The only USB version Willem is GQ-3X is available.
See:
www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=4225
pic Posted - 11/13/2007 : 13:56:23
iv got a serial to usb for a vellman kit
