 programing an atf16v8 chip
migueli Posted - 06/18/2005 : 07:28:51
Hi:
i need to apply a dump .ABS file to a atmel ATF16V8 chip, I have seen .HEX and .BIN files but i never seen such file. how can you load this with topwinen.
thanks. Mike
usb Posted - 06/20/2005 : 15:33:40
I do not know the .ABS file format.
migueli Posted - 06/19/2005 : 17:57:49
i don,t know, but that file it,s suppose to be to flash a atf16v8 chip for a car diagnosis interface.
usb Posted - 06/19/2005 : 17:14:44
I have no idea what .ABS is.
What compiler produce the .ABS?
migueli Posted - 06/19/2005 : 14:14:03
could you tell what software to use to convert the file from ABS to
bin or hex?
thanks a lot for your help.
usb Posted - 06/19/2005 : 12:44:13
The software will not convert it for you. The software only ask you to confrim the data file format. You need convert it before open it.
migueli Posted - 06/18/2005 : 21:10:56
But when i try to open the file it will ask me in what format do i want it ( hex or bin, etc), does it make a diference in what format i flash the chip?
usb Posted - 06/18/2005 : 18:22:58
The TopWinEn accept .hex, .bin, .jed, .cds.
So you need convert your .abs to one of those format.
