 Enhanced Willem + TSOP48 don't write high nibble
totti14 Posted - 12/27/2007 : 07:18:07
my only usb powered enhance programmer(part numbers sanded) with TSOP48(ADP-042)from mcu dont't write the high nibble on my TE28F320 with 4 different chips.
Read ID OK
Erase OK
Blank check OK
Programm = Error at 0x000080 Chip = 0x6060 buffer = 0x603C
other test:
I write AA 55 AA 55 to my device
Read Result AA 00 AA 00
Read Flash (programmed with my friends Willem) works fine.
Any Idea ?
any IC on adapter damage ?
81.41 KB
ZLM Posted - 01/19/2008 : 00:30:37
I could not find exact schematic of this adapter. But there is a similar one from EZoFlash. You may check the adapter if anything wrong.
http://www.ezoflash.com/adapters/tsop48d2/schematic.htm
totti14 Posted - 01/16/2008 : 17:13:42
Hello,
now i have change all IC's on TSOP48 adapter.
The result is the same
When i make H/W Test and turn on VCC1 only grenn led get on next turn on Vpp and turn off VCC1 both led get on ?
Results:
VCC ON Pin1 0V Pin32 5,0V
VPP ON Pin1 12V Pin32 5,0V (VCC OFF)
I remove J3 then light correct Led.
VCC1 and VPP only connect over D1 and SW12/2.
D1 is OK an SW12/2 is open.
Well then?
totti14
ZLM Posted - 12/29/2007 : 00:33:34
Seems adapter something wrong.
