 help pease, top 2048 with problems
motocarlos Posted - 05/06/2008 : 14:50:27
Hello,
i have a eprom programer top2048, about 9 months and he never work to whryte, he just can read the eproms.
I have try the company who i have bougth the top2048 but they dont whant to give me a guaranties and tell me there is the eprom damaged, but its not because i have try with some new eproms (27sf010plcc32, am29f800bt, am29f400bb psop44, ...) and always the same thing (error000000: error of (file=55 , device= ff).
So, i need to repair the programer, anyone can help me??
Thanks.
motocarlos Posted - 05/14/2008 : 13:58:17
thanks,
i go to check it out and try to do like you says and after that i will tell you something, ok.
Originally posted by simeon
did you download there latest software
www.top2048.com
with the 2049 i had to unplug the programmer first from usb
then update the software and load the driver and reboot
then once it power in first then plugged the programmer in
the driver loaded up and installed from winxp drivers
{no need to use there reload driver in start menu}
then start the software and test it again
i note on there site it only mentions fixing 256=>512k chips support
so maybe this latest version hasnt support to it yet for the bigger chips youve tried
simeon Posted - 05/08/2008 : 16:38:29
www.top2048.com
