 difference between hex files
vishaldotgupta Posted - 06/15/2008 : 22:53:26
dear all, please help me with file conversion. the file with 159.txt is meant of isp load on flash eeprom am29f400ab. the file 159.hex is read from atmel at27c4096. now i want to replace data of file 159.txt with 159.hex and load through isp way. the file 159.txt shows data starting with like "S32100.." what this means and how this can be done for other file. please advise.
69.7 KB
vishaldotgupta Posted - 06/21/2008 : 00:40:40
dear zlm, thanks for replying. i actualy need a hex to 32 bit motorola s record converter utility. the one available on suggested websited converts to s19 format. please advise
ZLM Posted - 06/19/2008 : 00:28:52
Searched from internet:
vishaldotgupta Posted - 06/16/2008 : 19:56:31
dear zlm, thanks for replying. can you please suggest me a utility to convert hex file to motorola.s format. regards vishal
ZLM Posted - 06/16/2008 : 08:29:00
All programmers supports .hex file. So, you do not have to do the conversion. The programmer will load the 159.hex correctly.
the 159.txt is Motorola .s format.
vishaldotgupta Posted - 06/16/2008 : 01:54:27
further, the isp load of the file will be through a motorola controller mc68306pv
