 LOW pin on ICSP header
Denis710 Posted - 02/19/2009 : 20:48:37
What is the purpose of the LOW pin on the ICSP header? Also when programming using ICSP do I need to power the chip externally or programmer will provide the power to Vcc and Vpp?
ZLM Posted - 02/20/2009 : 00:31:21
You do not need to use LOW pin. Connect the rest of pins will be fine.
The programmer will provide the VCC and VPP.
