 equivelent chips?
MikeHunt79 Posted - 12/03/2009 : 16:29:19
Is there a list of which chips are compatible? In terms of pinout and memory capacity?
I'm trying to orderan obselete part (sst39sf040) and am having no luck.
Is there a way I can find out an equivelent that will work, I may even have one lying around the house in an old computer motherboard!
How can I find if a chip is compatible? I'm guessing the pinout, voltage and capacity has to match.... Anything else?
Bad_Ad84 Posted - 01/22/2010 : 02:11:48
what package?
you can just lookup that device in devices.txt and find its class, then do a search for its class and find a chip in the same package/size and voltage etc.
Search "SST39LF/VF040" (54 hits in 1 files)
C:\Program Files\GQ USB Programmer\devices.txt (54 hits)
Line 642: Name="AM29LV004T*TSOP40",ID="01B5",Class="SST39LF/VF040",Category="FLASH",MFG="AMD",DIP="100011110101",Adapter="TSOP40A-DIP32",VCC="3.6V",Message="Connect A19 from Adapter to Programmer.";
Line 643: Name="AM29LV004B*TSOP40",ID="01B6",Class="SST39LF/VF040",Category="FLASH",MFG="AMD",DIP="100011110101",Adapter="TSOP40A-DIP32",VCC="3.6V",Message="Connect A19 from Adapter to Programmer.";
Line 644: Name="AM29LV008T*TSOP40",ID="013E",Class="SST39LF/VF040",Category="FLASH",MFG="AMD",CodeSize="1048576",DIP="100011110101",Adapter="TSOP40A-DIP32",VCC="3.6V",Message="Connect A19 from Adapter to Programmer.";
Line 645: Name="AM29LV008B*TSOP40",ID="0137",Class="SST39LF/VF040",Category="FLASH",MFG="AMD",CodeSize="1048576",DIP="100011110101",Adapter="TSOP40A-DIP32",VCC="3.6V",Message="Connect A19 from Adapter to Programmer.";
Line 646: Name="AM29LV008BT*TSOP40",ID="013E",Class="SST39LF/VF040",Category="FLASH",MFG="AMD",CodeSize="1048576",DIP="100011110101",Adapter="TSOP40A-DIP32",VCC="3.6V",Message="Connect A19 from Adapter to Programmer.";
Line 647: Name="AM29LV008BB*TSOP40",ID="0137",Class="SST39LF/VF040",Category="FLASH",MFG="AMD",CodeSize="1048576",DIP="100011110101",Adapter="TSOP40A-DIP32",VCC="3.6V",Message="Connect A19 from Adapter to Programmer.";
Line 673: Name="AM29LV081B*TSOP40",ID="0138",Class="SST39LF/VF040",Category="FLASH",MFG="AMD",CodeSize="1048576",DIP="100011110101",Adapter="TSOP40A-DIP32 adapter",VCC="3.6V",Speed="3",Message=" Set the adapter to 5V jumper position and connect A19 from adapter to programmer.";
Line 892: Name="AT49F040",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="5V";
Line 896: Name="AT49LV040*PLCC32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-062, PLCC32-DIP32";
Line 897: Name="AT49LV040T*PLCC32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-062, PLCC32-DIP32";
Line 898: Name="AT49LV040B*PLCC32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-062, PLCC32-DIP32";
Line 902: Name="AT49LV040*TSOP32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-021,TSOP32-DIP32";
Line 903: Name="AT49LV040T*TSOP32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-021,TSOP32-DIP32";
Line 904: Name="AT49LV040B*TSOP32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-021,TSOP32-DIP32";
Line 908: Name="AT49LV040*VSOP32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-022,TSOP32-DIP32(S)";
Line 909: Name="AT49LV040T*VSOP32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-022,TSOP32-DIP32(S)";
Line 910: Name="AT49LV040B*VSOP32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-022,TSOP32-DIP32(S)";
Line 914: Name="AT49BV040*PLCC32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-062, PLCC32-DIP32";
Line 915: Name="AT49BV040T*PLCC32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-062, PLCC32-DIP32";
Line 916: Name="AT49BV040B*PLCC32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-062, PLCC32-DIP32";
Line 920: Name="AT49BV040*TSOP32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-021,TSOP32-DIP32";
Line 921: Name="AT49BV040T*TSOP32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-021,TSOP32-DIP32";
Line 922: Name="AT49BV040B*TSOP32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-021,TSOP32-DIP32";
Line 926: Name="AT49BV040*VSOP32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-022,TSOP32-DIP32(S)";
Line 927: Name="AT49BV040T*VSOP32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-022,TSOP32-DIP32(S)";
Line 928: Name="AT49BV040B*VSOP32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-022,TSOP32-DIP32(S)";
Line 970: Name="MTF39VF040",ID="XXXX",Class="SST39LF/VF040",Category="FLASH",MFG="CWI"
Line 971: Name="ID39SF040",ID="XXXX",Class="SST39LF/VF040",Category="FLASH",MFG="SSTT",VCC="5V";
Line 1013: Name="PM39LV040*PLCC32",ID="9D3E",Class="SST39LF/VF040",Category="FLASH",MFG="PMC",VCC="3.6V",Adapter="ADP-062, PLCC32-DIP32";
Line 1018: Name="PM39LV040*VSOP32",ID="9D3E",Class="SST39LF/VF040",Category="FLASH",MFG="PMC",VCC="3.6V",Adapter="ADP-022, TSOP32-DIP32(S)";
Line 1022: Name="PM39F040",ID="9D4E",Class="SST39LF/VF040",Category="FLASH",MFG="PMC",VCC="5V";
Line 1026: Name="PM39F040*PLCC32",ID="9D4E",Class="SST39LF/VF040",Category="FLASH",MFG="PMC",VCC="5V",Adapter="ADP-062, PLCC32-DIP32";
Line 1061: Name="MX29LV008B*TSOP40",ID="C237",Class="SST39LF/VF040",Category="FLASH",MFG="AMD",CodeSize="1048576",DIP="100011110101",Adapter="TSOP40A-DIP32",VCC="3.6V",Message="Connect A19 from Adapter to Programmer.";
Line 1062: Name="MX29LV008T*TSOP40",ID="C23E",Class="SST39LF/VF040",Category="FLASH",MFG="AMD",CodeSize="1048576",DIP="100011110101",Adapter="TSOP40A-DIP32",VCC="3.6V",Message="Connect A19 from Adapter to Programmer.";
Line 1093: Name="SST39LF040*PLCC32",ID="BFD7",Class="SST39LF/VF040",Category="FLASH",MFG="SST",Adapter="ADP-062, ADP005 PLCC32-DIP32";
Line 1094: Name="SST39VF040*PLCC32",ID="BFD7",Class="SST39LF/VF040",Category="FLASH",MFG="SST",Adapter="ADP-062, ADP005 PLCC32-DIP32";
Line 1102: Name="SST39LF040*TSOP32",ID="BFD7",Class="SST39LF/VF040",Category="FLASH",MFG="SST",Adapter="ADP-022, TSOP32-DIP32 14mm";
Line 1103: Name="SST39VF040*TSOP32",ID="BFD7",Class="SST39LF/VF040",Category="FLASH",MFG="SST",Adapter="ADP-022, TSOP32-DIP32 14mm";
Line 1111: Name="SST39LF040",ID="BFD7",Class="SST39LF/VF040",Category="FLASH",MFG="SST";
Line 1112: Name="SST39VF040",ID="BFD7",Class="SST39LF/VF040",Category="FLASH",MFG="SST";
Line 1113: Name="SST39VF080",ID="BFD8",Class="SST39LF/VF040",Category="FLASH",MFG="SST",CodeSize="1048576",DIP="100011110101",Adapter="TSOP40A-DIP32",VCC="5V",Speed="4",Message="Open adapter Vcc jumper to 3.3V and connect the A19 from adapter to programmer";
Line 1114: Name="SST39LF080",ID="BFD8",Class="SST39LF/VF040",Category="FLASH",MFG="SST",CodeSize="1048576",DIP="100011110101",Adapter="TSOP40A-DIP32",VCC="5V",Message="Open adapter Vcc jumper to 3.3V and connect the A19 from adapter to programmer";
Line 1115: Name="SST39VF016",ID="BFD9",Class="SST39LF/VF040",Category="FLASH",MFG="SST",CodeSize="2097152",Adapter="TSOP40A-DIP32";
Line 1116: Name="SST39LF016",ID="BFD9",Class="SST39LF/VF040",Category="FLASH",MFG="SST",CodeSize="2097152",Adapter="TSOP40A-DIP32";
Line 1120: Name="SST39SF040",ID="BFB7",Class="SST39LF/VF040",Category="FLASH",MFG="SST",VCC="5V";
Line 1127: Name="SST39SF040*PLCC32",ID="BFB7",Class="SST39LF/VF040",Category="FLASH",MFG="SST",VCC="5V",Adapter="ADP-062, PLCC32-DIP32";
Line 1129: Name="SST39SF040A*PLCC32",ID="BFB7",Class="SST39LF/VF040",Category="FLASH",MFG="SST",VCC="5V",Adapter="ADP-062, PLCC32-DIP32";
Line 1134: Name="SST39SF040*TSOP32",ID="BFB7",Class="SST39LF/VF040",Category="FLASH",MFG="SST",VCC="5V",Adapter="ADP-022, TSOP32-DIP32(S)";
Line 1136: Name="SST39SF040A*TSOP32",ID="BFB7",Class="SST39LF/VF040",Category="FLASH",MFG="SST",VCC="5V",Adapter="ADP-022, TSOP32-DIP32(S)";
Line 1205: Name="W39D040A",ID="DAD6",Class="SST39LF/VF040",Category="FLASH",MFG="WINBOND",VCC="3.6V";
Line 1206: Name="W39D040A*PLCC32",ID="DAD6",Class="SST39LF/VF040",Category="FLASH",MFG="WINBOND",VCC="3.6V",Adapter="ADP-062, ADP-005 PLCC32-DIP32";
Line 1207: Name="W39D040A*TSOP32",ID="DAD6",Class="SST39LF/VF040",Category="FLASH",MFG="WINBOND",VCC="3.6V",Adapter="ADP-022,TSOP32-DIP32(S)";
Line 1209: Name="W39L040",ID="DAB6",Class="SST39LF/VF040",Category="FLASH",MFG="WINBOND",VCC="3.6V";
Line 1212: ;Name="W49F040",ID="DA13",Class="SST39LF/VF040",Category="FLASH",MFG="Winbond",VCC="5V";
osvaldo Posted - 01/12/2010 : 19:36:59
en este linck podes enconyrar las equivalencias de los ic
www.alldatasheet.com/
Generated in 0.31 sec. Snitz Forums 2000
