 USB PROGRAMMER PIC16f917
Twistx77 Posted - 05/12/2008 : 13:02:03
Hi, I recently bought a k149 USB programmer from MCUMALL and I got a couple PIC16f917 but when i tried to program them I found out that the software I downloaded from MCU for my k149 doesn't have the pic16f917 in the chip selector list and in the k149 specs from MCU it said that pic16f917 could be programmed with the k149. Could I choose another 40 pin pic in the ship selector to program mine 16f917? a 16f877A for example?
ZLM Posted - 03/06/2010 : 01:19:07
ok
Lainus Posted - 03/05/2010 : 17:31:07
This is already running
I answer myself:
I have changed chipinfo.cid
It is okay?
CHIPname=18F1330
INCLUDE=Y
SocketImage=18pin
EraseMode=4
FlashChip=Y
PowerSequence=VccVpp2
ProgramDelay=10
ProgramTries=1
OverProgram=1
CoreType=bit16_B
ROMsize=001000
EEPROMsize=00000080
FUSEblank=CF00 1F1F 890E 00F1 C003 E003 4003
CPwarn=N
CALword=N
BandGap=N
ICSPonly=Y
ChipID=1E20
LIST1 FUSE1 "IE Switchover" "Enabled"=FFFF "Disabled"=7FFF
LIST2 FUSE1 "Fail Safe Clock Mon" "Enabled"=FFFF "Disabled"=BFFF
LIST3 FUSE1 "Oscillator" "ExRC OSC1 CO OSC2"=FFFF "IRC O1RA7 CO OSC2"=F9FF "IRC O1RA7 O2RA6"=F8FF "ExRC OSC2 RA6"=F7FF "HS+PLL"=F6FF "ExOSC1 CO RA6"=F5FF "ExOSC1 CO OSC2"=F4FF "HS"=F2FF "XT"=F1FF "LP"=F0FF
LIST4 FUSE2 "Brownout Voltage" "2.0V"=FFFF "2.7V"=FFFB "4.2V"=FFF7 "4.5V"=FFF3
LIST5 FUSE2 "Brownout Detect" "Enabled"=FFFF "Disabled"=FFFD
LIST6 FUSE2 "Powerup Timer" "Disabled"=FFFF "Enabled"=FFFE
LIST7 FUSE2 "Watchdog Timer" "Enabled"=FFFF "Disabled"=FEFF
LIST8 FUSE2 "Watchdog Postscale" "1:32768"=FFFF "1:16384"=FEFF "1:8192"=FDFF "1:4096"=FCFF "1:2048"=FBFF "1:1024"=FAFF "1:512"=F9FF "1:256"=F8FF "1:128"=F7FF "1:64"=F6FF "1:32"=F5FF "1:16"=F4FF "1:8"=F3FF "1:4"=F2FF "1:2"=F1FF "1:1"=F0FF
LIST9 FUSE3 "MCLRE" "Enabled"=FFFF "Disabled"=7FFF
LIST10 FUSE4 "Background Debug" "Disabled"=FFFF "Enabled"=FF7F
LIST11 FUSE4 "Low Voltage Program" "Enabled"=FFFF "Disabled"=FFFB
LIST12 FUSE4 "Stack Overflow Reset" "Enabled"=FFFF "Disabled"=FFFE
LIST13 FUSE5 "BOOT ROM Protect" "0000-01FF Disabled"=FFFF "0000-01FF Enabled"=BFFF
LIST14 FUSE5 "ROM Protect" "0200-0FFF Disabled"=FFFF "0200-0FFF Enabled"=FFFE
LIST15 FUSE5 "ROM Protect" "1000-1FFF Disabled"=FFFF "1000-1FFF Enabled"=FFFD
LIST16 FUSE5 "EEPROM Protect" "Disabled"=FFFF "Enabled"=7FFF
LIST17 FUSE6 "BOOT Table Write Protect" "0000-01FF Disabled"=FFFF "0000-01FF Enabled"=BFFF
LIST18 FUSE6 "ROM Table Write Protect" "0200-0FFF Disabled"=FFFF "0200-0FFF Enabled"=FFFE
LIST19 FUSE6 "ROM Table Write Protect" "1000-1FFF Disabled"=FFFF "1000-1FFF Enabled"=FFFD
LIST20 FUSE6 "EEPROM Table Write Protect" "Disabled"=FFFF "Enabled"=7FFF
LIST21 FUSE6 "CONFIG Table Write Protect" "Disabled"=FFFF "Enabled"=DFFF
LIST22 FUSE7 "BOOT Table Read Protect" "0000-01FF Disabled"=FFFF "0000-01FF Enabled"=BFFF
LIST23 FUSE7 "ROM Table Read Protect" "0200-0FFF Disabled"=FFFF "0200-0FFF Enabled"=FFFE
LIST24 FUSE7 "ROM Table Read Protect" "1000-1FFF Disabled"=FFFF "1000-1FFF Enabled"=FFFD
ZLM Posted - 05/13/2008 : 23:17:55
Add following section into file CHIPINFO.cid:
CHIPname=16F917
INCLUDE=Y
SocketImage=40pin
EraseMode=2
FlashChip=Y
PowerSequence=VccVpp1
ProgramDelay=40
ProgramTries=1
OverProgram=1
CoreType=bit14_B
ROMsize=002000
EEPROMsize=00000100
FUSEblank=3FFF
CPwarn=N
CALword=N
BandGap=N
ICSPonly=N
ChipID=1380
LIST1 FUSE1 "WDT" "Enabled"=3FFF "Disabled"=3FF7
LIST2 FUSE1 "PWRTE" "Disabled"=3FFF "Enabled"=3FEF
LIST3 FUSE1 "BODEN" "BODon SBODENoff"=3FFF "BODrun SBODENoff"=3EFF "SBODEN=PCON"=3DFF "BODoff SBODENoff"=3CFF
LIST4 FUSE1 "InEx Switch Over" "Enabled"=3FFF "Disabled"=3BFF
LIST5 FUSE1 "Fail Clock Mon" "Enabled"=3FFF "Disabled"=37FF
LIST6 FUSE1 "CPD" "Disabled"=3FFF "Enabled"=3F7F
LIST7 FUSE1 "MCLRE" "Disabled"=3FDF "Enabled"=3FFF
LIST8 FUSE1 "DEBUG" "Disabled"=3FFF "Enabled"=2FFF
LIST9 FUSE1 "Oscillator" "EXTRC_CLKOUT"=3FFF "EXTRC_IO"=3FFE "INTRC_CLKOUT"=3FFD "INTRC_IO"=3FFC "EC"=3FFB "HS"=3FFA "XT"=3FF9 "LP"=3FF8
LIST10 FUSE1 "Code Protect" "Disabled"=3FFF "Enabled"=3FBF
