 Pic 18F2620 with PCB50 problems
suli21an Posted - 04/15/2010 : 10:32:04
Hi I am having problems trying to write to my pic18F2620 chip.
I have connected my chip via ICSP to the appropriate pins on the chip.
I select the pic with in the programmer and load the Hex file I'm trying to write.
When I try to write to the chip I get the error
Error Program Memory at 0x000000
Any help would be Appreciated
Cheers
ZLM Posted - 04/24/2010 : 22:01:15
Try different software. eg. IC-prog
suli21an Posted - 04/24/2010 : 10:14:59
Thank you for the reply, but even when i erase and then program i get the same error.
i also tried another pic chip, and same problem.
ZLM Posted - 04/21/2010 : 09:42:32
you have to erase the chip first.
