T O P I C R E V I E W |
pb0ahx |
Posted - 12/02/2010 : 03:39:50 if i writing a program in to the chip then willem tel me that i have a writing error on ID area ( error writing pic id area ) this is mij firt writing to a pic wat do i rong can some body help me the programmer is brand new type pcb5.5c the 2 cabels are connected |
pb0ahx |
Posted - 12/15/2010 : 13:41:26 I found the error the software that i used was 5.5c en is not ok now i using 4.5 and now he is ok gl all from delft holland
pb0ahx |
Posted - 12/03/2010 : 04:19:49 the chip is empty if i do chek then he say divices is blank put i my .hex in the chip then he say the error but i think the dipswitsh 1-12 is not on the right position all the 12 switches stay on off |
ZLM |
Posted - 12/02/2010 : 11:15:29 Make sure you have erased the chip before write.
The ID area includes the user ID and CFG bits. Most likely you do not need the user ID. So, check the chip if the CFG bits are correct, then you can ignore the error. |
