 24U17 Chip
Marin Posted - 11/20/2012 : 10:47:33
Is it possible to read/write 24U17 chip with GQ-4X?
In device list there is no list of this chip.
Marin Posted - 03/08/2013 : 18:47:10
I just want to let everyone to know that 24U17 work same way as 24c16. And GQ-4X reads and writes this chip with out any problem.
osvaldo Posted - 02/12/2013 : 18:12:55
Versión de soft USBPrg6,17
Primero fíjate la actualización q subí yo y proba si lee y escribe y confírmame si no hace lo del pin 4 que dijo zlm y confirma gracias
;This device definition file may be modifyed.
;-When adding a device, please follow the syntax below.
;-Always enter only one device per line.
;-Please add the device in alphabetical order by MFG chip name for easier searching.
;-This file will be checked and verified when the software start up time. And then the file 'ID_Log.txt' and 'Device_Log.txt'
; will log all the errors if any.
;-You also can add the comment between lines.
; Syntax: Name="Device Name",ID="Device ID in Hexadecimal",Class="Class Name",Category="Category Type",MFG="MFG Name",Speed="Default Speed",Package="Package",Adapter="Adapter",CodeSize="Code Size",EepromSize="Eeprom Size",DIP="DIP Setting",VCC="Vcc",WVPP="Write Vpp",WVCC="Write Vcc",BVCC="Blank Vcc",RVPP="Read Vpp",Message="Message to User";
; Note:
; -The 'Name=' and 'ID=' must be the first two fields and must be defined, other fields are optional.
; -ID="XXXX" means device ID unknow or not availble for generic devices
; -If only the first two fields defined, then only device ID will be added. The device will not be added to the search list.
; -For adding a new device, at least three fields needed, otherwise it will be ignored.
; -Do Not Use " as first character in your comment.
; -each actual entry line starts with: Name= and ends with a semi-colon ;. Comments maybe added after the semi-colon.
; The latest device definitions can be found at www.MCUmall.com
; To benefit other users, you may post/upload your modification(s) in the forum at www.mcumall.com
; Name,ID(Hex),Class,,Category,MFG,Speed,Package,Adapter,CodeSize,EepromSize,DIPSetting;
;*Generic Devices*
Name="2532",ID="XXXX",Class="2532(25V Vpp)",WVCC="5.5V",WVPP="25V",Category="EPROM",MFG="ALL(Generic)",Message="This device is under testing, no write on GQ-2X";
Name="2532A(Read Only)",ID="XXXX",Class="2532(25V Vpp)",WVCC="5.5V",WVPP="21V",Category="EPROM",MFG="ALL(Generic)",Message="This device is under testing, no write on GQ-2X and write is not garranted on models.";
Name="2564(Test)",ID="XXXX",Class="2564(25V Vpp)",WVCC="5.5V",WVPP="25V",Category="EPROM",MFG="ALL(Generic)",Speed="1",Message="This device is under testing, no write on GQ-2X and write is not garranted on models";
Name="27C16B(12.7V Vpp)",ID="XXXX",Class="27C16(12.7V Vpp)",Category="EPROM",MFG="ALL(Generic)",RVpp="5V";
Name="27C16A(21V Vpp)",ID="XXXX",Class="27C16(21V Vpp)",Category="EPROM",MFG="ALL(Generic)",RVpp="5V";
Name="27C16(25V Vpp)",ID="XXXX",Class="27C16(25V Vpp)",Category="EPROM",MFG="ALL(Generic)",RVpp="5V";
Name="27C32B(12.7V Vpp)",ID="XXXX",Class="27C32(12.7V Vpp)",Category="EPROM",MFG="ALL(Generic)";
Name="27C32A(21V Vpp)",ID="XXXX",Class="27C32(21V Vpp)",Category="EPROM",MFG="ALL(Generic)";
Name="27C32(25V Vpp)",ID="XXXX",Class="27C32(25V Vpp)",Category="EPROM",MFG="ALL(Generic)";
Name="27C64",ID="XXXX",Class="27C64",Category="EPROM",MFG="ALL(Generic)";
Name="27C128",ID="XXXX",Class="27C128",Category="EPROM",MFG="ALL(Generic)";
Name="27C256",ID="XXXX",Class="27C256",Category="EPROM",MFG="ALL(Generic)";
Name="27C512",ID="XXXX",Class="27C512",Category="EPROM",MFG="ALL(Generic)";
Name="27C010",ID="XXXX",Class="27C010",Category="EPROM",MFG="ALL(Generic)";
Name="27C020",ID="XXXX",Class="27C020",Category="EPROM",MFG="ALL(Generic)";
Name="27C040",ID="XXXX",Class="27C040",Category="EPROM",MFG="ALL(Generic)";
Name="27C080",ID="XXXX",Class="27C080",Category="EPROM",MFG="ALL(Generic)";
Name="27C1000",ID="XXXX",Class="27C010",Category="EPROM",MFG="ALL(Generic)";
Name="27C1001",ID="XXXX",Class="27C010",Category="EPROM",MFG="ALL(Generic)";
Name="27C2000",ID="XXXX",Class="27C020",Category="EPROM",MFG="ALL(Generic)";
Name="27C2001",ID="XXXX",Class="27C020",Category="EPROM",MFG="ALL(Generic)";
Name="27C4000",ID="XXXX",Class="27C040",Category="EPROM",MFG="ALL(Generic)";
Name="27C4001",ID="XXXX",Class="27C040",Category="EPROM",MFG="ALL(Generic)";
Name="27C801",ID="XXXX",Class="27C080",Category="EPROM",MFG="ALL(Generic)";
Name="27C301",ID="XXXX",Class="27C301",Category="EPROM",MFG="ALL(Generic)",RVpp="5V";
Name="LD2764(25V Vpp)",ID="XXXX",Class="2764(21V Vpp)",VPP="25V",VCC="6.5V",WVCC="6.5V",Category="EPROM",MFG="ALL(Generic)";
Name="2716B(12.7V Vpp)",ID="XXXX",Class="2716(12.7V Vpp)",Category="EPROM",MFG="ALL(Generic)",RVpp="5V";
Name="2716A(21V Vpp)",ID="XXXX",Class="2716(21V Vpp)",Category="EPROM",MFG="ALL(Generic)",RVpp="5V";
Name="2716(25V Vpp)",ID="XXXX",Class="2716(25V Vpp)",Category="EPROM",MFG="ALL(Generic)",RVPP="5V";
Name="2732B(12.7V Vpp)",ID="XXXX",Class="2732(12.7V Vpp)",Category="EPROM",MFG="ALL(Generic)";
Name="2732A(21V Vpp)",ID="XXXX",Class="2732(21V Vpp)",Category="EPROM",MFG="ALL(Generic)";
Name="2732(25V Vpp)",ID="XXXX",Class="2732(25V Vpp)",VCC="5V",Category="EPROM",MFG="ALL(Generic)";
Name="2764A(12.7V Vpp)",ID="XXXX",Class="2764(12.7V Vpp)",Category="EPROM",MFG="ALL(Generic)";
Name="2764(21V Vpp)",ID="XXXX",Class="2764(21V Vpp)",Category="EPROM",MFG="ALL(Generic)";
Name="27128A(12.7V Vpp)",ID="XXXX",Class="27128(12.7V Vpp)",Category="EPROM",MFG="ALL(Generic)";
Name="27128(21V Vpp)",ID="XXXX",Class="27128(21V Vpp)",Category="EPROM",MFG="ALL(Generic)";
Name="27256",ID="XXXX",Class="27256",Category="EPROM",MFG="ALL(Generic)";
Name="27512",ID="XXXX",Class="27512",Category="EPROM",MFG="ALL(Generic)",CodeSize="65536";
Name="27010",ID="XXXX",Class="27010",Category="EPROM",MFG="ALL(Generic)";
Name="27020",ID="XXXX",Class="27020",Category="EPROM",MFG="ALL(Generic)";
Name="27040",ID="XXXX",Class="27040",Category="EPROM",MFG="ALL(Generic)";
Name="27080",ID="XXXX",Class="27C080",Category="EPROM",MFG="ALL(Generic)";
Name="2764A*PLCC32",ID="XXXX",Class="2764(12.7V Vpp)",Category="EPROM",MFG="ALL(Generic)",Adapter="ADP-029 or ADP-006";
Name="27128A*PLCC32",ID="XXXX",Class="27128(12.7V Vpp)",Category="EPROM",MFG="ALL(Generic)",Adapter="ADP-029 or ADP-006";
Name="27256*PLCC32",ID="XXXX",Class="27256",Category="EPROM",MFG="ALL(Generic)",Adapter="ADP-029 or ADP-006";
Name="27512*PLCC32",ID="XXXX",Class="27512",Category="EPROM",MFG="ALL(Generic)",CodeSize="65536",Adapter="ADP-029 or ADP-006";
Name="27C1024",ID="XXXX",Class="27C1024",Category="EPROM",MFG="ALL(Generic)",BufferMode="16BIT",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";
Name="27C2048",ID="XXXX",Class="27C1024",Category="EPROM",MFG="ALL(Generic)",CodeSize="262144",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";
Name="27C4096",ID="XXXX",Class="27C4096",Category="EPROM",MFG="ALL(Generic)",CodeSize="524288",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";
Name="27C4002",ID="XXXX",Class="27C4002",Category="EPROM",MFG="ALL(Generic)",CodeSize="524288",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";
Name="27C210",ID="XXXX",Class="27C1024",Category="EPROM",MFG="ALL(Generic)",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";
Name="27C220",ID="XXXX",Class="27C1024",Category="EPROM",MFG="ALL(Generic)",CodeSize="262144",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";
Name="27C240",ID="XXXX",Class="27C4096",Category="EPROM",MFG="ALL(Generic)",CodeSize="524288",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";
Name="27C400",ID="XXXX",Class="27C800",Category="EPROM",MFG="ALL(Generic)",CodeSize="524288",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER",RVpp="5V",Message="Put chip in 42 pin socket and bottom aligned with the socket.";
Name="27C800",ID="XXXX",Class="27C800",Category="EPROM",MFG="ALL(Generic)",CodeSize="1048576",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER",RVpp="5V";
Name="27C160",ID="XXXX",Class="27C800",Category="EPROM",MFG="ALL(Generic)",CodeSize="2097152",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER",RVpp="5V";
Name="27C322",ID="XXXX",Class="27C322",Category="EPROM",MFG="ALL(Generic)",CodeSize="4194304",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";
Name="24C00",ID="XXXX",Class="24C00",Category="SERIAL_EPROM",MFG="ALL(Generic)";
Name="24C01",ID="XXXX",Class="24C01",Category="SERIAL_EPROM",MFG="ALL(Generic)";
Name="24C02",ID="XXXX",Class="24C02",Category="SERIAL_EPROM",MFG="ALL(Generic)";
Name="24C04",ID="XXXX",Class="24C04",Category="SERIAL_EPROM",MFG="ALL(Generic)";
Name="24C08",ID="XXXX",Class="24C08",Category="SERIAL_EPROM",MFG="ALL(Generic)",VCC="5V";
Name="24u09",ID="XXXX",Class="24C08",Category="SERIAL_EPROM",MFG="ALL(Fairchild)";
Name="24C16",ID="XXXX",Class="24C16",Category="SERIAL_EPROM",MFG="ALL(Generic)";
Name="24u17",ID="XXXX",Class="24C16",Category="SERIAL_EPROM",MFG="ALL(Fairchild)";
Name="24C32",ID="XXXX",Class="24C32",Category="SERIAL_EPROM",MFG="ALL(Generic)";
Name="24C64",ID="XXXX",Class="24C64",Category="SERIAL_EPROM",MFG="ALL(Generic)";
Name="24C128",ID="XXXX",Class="24C128",Category="SERIAL_EPROM",MFG="ALL(Generic)";
Name="24C256",ID="XXXX",Class="24C256",Category="SERIAL_EPROM",MFG="ALL(Generic)";
Name="24C512",ID="XXXX",Class="24C512",Category="SERIAL_EPROM",MFG="ALL(Generic)";
Name="24C1024",ID="XXXX",Class="24C1024",Category="SERIAL_EPROM",MFG="ALL(Generic)";
Name="25C010 SPI EEPROM",ID="XXXX",Class="25C010",Category="SERIAL_EPROM",MFG="ALL(Generic)";
Name="25C020 SPI EEPROM",ID="XXXX",Class="25C020",Category="SERIAL_EPROM",MFG="ALL(Generic)";
Name="25C040 SPI EEPROM",ID="XXXX",Class="25C040",Category="SERIAL_EPROM",MFG="ALL(Generic)";
Name="25C080 SPI EEPROM",ID="XXXX",Class="25C080",Category="SERIAL_EPROM",MFG="ALL(Generic)";
Name="25C160 SPI EEPROM",ID="XXXX",Class="25C160",Category="SERIAL_EPROM",MFG="ALL(Generic)";
Name="25C320 SPI EEPROM",ID="XXXX",Class="25C320",Category="SERIAL_EPROM",MFG="ALL(Generic)";
Name="25C640 SPI EEPROM",ID="XXXX",Class="25C640",Category="SERIAL_EPROM",MFG="ALL(Generic)";
Name="93C06N (16Bit)",ID="XXXX",Class="93C06B_16Bit",Category="SERIAL_EPROM",MFG="ALL(Generic)";
Name="93C06A (8Bit)",ID="XXXX",Class="93C06A_8Bit",Category="SERIAL_EPROM",MFG="ALL(Generic)";
Name="93C46A (8Bit)",ID="XXXX",Class="93C46A_8Bit",Category="SERIAL_EPROM",MFG="ALL(Generic)";
Name="93C56A (8Bit)",ID="XXXX",Class="93C56A_8Bit",Category="SERIAL_EPROM",MFG="ALL(Generic)";
Name="93C57A (8Bit)",ID="XXXX",Class="93C57A_8Bit",Category="SERIAL_EPROM",MFG="ALL(Generic)";
Name="93C66A (8Bit)",ID="XXXX",Class="93C66A_8Bit",Category="SERIAL_EPROM",MFG="ALL(Generic)";
Name="93C76A (8Bit)",ID="XXXX",Class="93C76A_8Bit",Category="SERIAL_EPROM",MFG="ALL(Generic)";
Name="93C86A (8Bit)",ID="XXXX",Class="93C86A_8Bit",Category="SERIAL_EPROM",MFG="ALL(Generic)";
Name="93C06B (16Bit)",ID="XXXX",Class="93C06B_16Bit",Category="SERIAL_EPROM",MFG="ALL(Generic)";
Name="93C46B (16Bit)",ID="XXXX",Class="93C46B_16Bit",Category="SERIAL_EPROM",MFG="ALL(Generic)";
Name="93C56B (16Bit)",ID="XXXX",Class="93C56B_16Bit",Category="SERIAL_EPROM",MFG="ALL(Generic)";
Name="93C57B (16Bit)",ID="XXXX",Class="93C57B_16Bit",Category="SERIAL_EPROM",MFG="ALL(Generic)";
Name="93C66B (16Bit)",ID="XXXX",Class="93C66B_16Bit",Category="SERIAL_EPROM",MFG="ALL(Generic)";
Name="93C76B (16Bit)",ID="XXXX",Class="93C76B_16Bit",Category="SERIAL_EPROM",MFG="ALL(Generic)";
Name="93C86B (16Bit)",ID="XXXX",Class="93C86B_16Bit",Category="SERIAL_EPROM",MFG="ALL(Generic)";
// 29LVXXX
Name="29LV100T",ID="XXXX",Class="29LV100T",Category="FLASH",MFG="ALL(Generic)",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="29LV200T",ID="XXXX",Class="29LV200T",Category="FLASH",MFG="ALL(Generic)",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="29LV400T",ID="XXXX",Class="29LV400T",Category="FLASH",MFG="ALL(Generic)",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="29LV800T",ID="XXXX",Class="29LV800T",Category="FLASH",MFG="ALL(Generic)",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="29LV160T",ID="XXXX",Class="29LV160T",Category="FLASH",MFG="ALL(Generic)",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="29LV320T",ID="XXXX",Class="29LV320T",Category="FLASH",MFG="ALL(Generic)",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="29LV100B",ID="XXXX",Class="29LV100B",Category="FLASH",MFG="ALL(Generic)",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="29LV200B",ID="XXXX",Class="29LV200B",Category="FLASH",MFG="ALL(Generic)",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="29LV400B",ID="XXXX",Class="29LV400B",Category="FLASH",MFG="ALL(Generic)",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="29LV800B",ID="XXXX",Class="29LV800B",Category="FLASH",MFG="ALL(Generic)",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="29LV160B",ID="XXXX",Class="29LV160B",Category="FLASH",MFG="ALL(Generic)",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="29LV320B",ID="XXXX",Class="29LV320B",Category="FLASH",MFG="ALL(Generic)",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
//29FXXX
Name="29F100T",ID="XXXX",Class="29F100T",Category="FLASH",MFG="ALL(Generic)",RVPP="5V";
Name="29F200T",ID="XXXX",Class="29F200T",Category="FLASH",MFG="ALL(Generic)",RVPP="5V";
Name="29F400T",ID="XXXX",Class="29F400T",Category="FLASH",MFG="ALL(Generic)",RVPP="5V";
Name="29F800T",ID="XXXX",Class="29F800T",Category="FLASH",MFG="ALL(Generic)",RVPP="5V";
Name="29F160T",ID="XXXX",Class="29F160T",Category="FLASH",MFG="ALL(Generic)",RVPP="5V";
Name="29F320T",ID="XXXX",Class="29F320T",Category="FLASH",MFG="ALL(Generic)",RVPP="5V";
Name="29F100B",ID="XXXX",Class="29F100B",Category="FLASH",MFG="ALL(Generic)",RVPP="5V";
Name="29F200B",ID="XXXX",Class="29F200B",Category="FLASH",MFG="ALL(Generic)",RVPP="5V";
Name="29F400B",ID="XXXX",Class="29F400B",Category="FLASH",MFG="ALL(Generic)",RVPP="5V";
Name="29F800B",ID="XXXX",Class="29F800B",Category="FLASH",MFG="ALL(Generic)",RVPP="5V";
Name="29F160B",ID="XXXX",Class="29F160B",Category="FLASH",MFG="ALL(Generic)",RVPP="5V";
Name="29F320B",ID="XXXX",Class="29F320B",Category="FLASH",MFG="ALL(Generic)",RVPP="5V";
//29F0XX
Name="29F512",ID="XXXX",Class="29F512",Category="FLASH",MFG="ALL(Generic)";
Name="29F010",ID="XXXX",Class="29F010",Category="FLASH",MFG="ALL(Generic)";
Name="29F020T",ID="XXXX",Class="29F020T",Category="FLASH",MFG="ALL(Generic)";
Name="29F040B",ID="XXXX",Class="29F040B",Category="FLASH",MFG="ALL(Generic)";
//28FXXX
Name="28F256",ID="XXXX",Class="28F512",Category="FLASH",MFG="ALL(Generic)",CodeSize="32768";
Name="28F512",ID="XXXX",Class="28F512",Category="FLASH",MFG="ALL(Generic)";
Name="28F010",ID="XXXX",Class="28F010",Category="FLASH",MFG="ALL(Generic)";
Name="28F020",ID="XXXX",Class="28F020",Category="FLASH",MFG="ALL(Generic)";
Name="28F001BX-B",ID="XXXX",Class="INTEL28F001BX-B",Category="FLASH",MFG="ALL(Generic)",RVPP="5V",EVPP="12V",VCC="5V";
Name="28F001BX-T",ID="XXXX",Class="INTEL28F001BX-T",Category="FLASH",MFG="ALL(Generic)",RVPP="5V",EVPP="12V",VCC="5V";
//29F00X
Name="29F002",ID="XXXX",Class="29F002",Category="FLASH",MFG="ALL(Generic)";
Name="29F002NT",ID="XXXX",Class="29F002NT",Category="FLASH",MFG="ALL(Generic)";
Name="29F004",ID="XXXX",Class="29F004",Category="FLASH",MFG="ALL(Generic)";
//49F00X
Name="49F001",ID="XXXX",Class="49F002",Category="FLASH",MFG="ALL(Generic)",CodeSize="131072",TempUnprotect="Yes";
Name="49F001NT",ID="XXXX",Class="49F002NT",Category="FLASH",MFG="ALL(Generic)",CodeSize="131072",TempUnprotect="Yes";
Name="49F002",ID="XXXX",Class="49F002",Category="FLASH",MFG="ALL(Generic)",TempUnprotect="Yes";
Name="49F002NT",ID="XXXX",Class="49F002NT",Category="FLASH",MFG="ALL(Generic)",TempUnprotect="Yes";
//28CXXX
Name="28C64",ID="XXXX",Class="28C64",Category="FLASH",MFG="ALL(Generic)",CodeSize="8192";
Name="28C128",ID="XXXX",Class="28C256",Category="FLASH",MFG="ALL(Generic)",CodeSize="16384";
Name="28C256",ID="XXXX",Class="28C256",Category="FLASH",MFG="ALL(Generic)",CodeSize="32768";
//29C5100X
Name="29C51000T",ID="XXXX",Class="29C51000T",Category="FLASH",MFG="ALL(Generic)";
Name="29C51001T",ID="XXXX",Class="29C51001T",Category="FLASH",MFG="ALL(Generic)";
Name="29C51002T",ID="XXXX",Class="29C51002T",Category="FLASH",MFG="ALL(Generic)";
Name="29C51004T",ID="XXXX",Class="29C51004T",Category="FLASH",MFG="ALL(Generic)";
Name="29C51000B",ID="XXXX",Class="29C51000B",Category="FLASH",MFG="ALL(Generic)";
Name="29C51001B",ID="XXXX",Class="29C51001B",Category="FLASH",MFG="ALL(Generic)";
Name="29C51002B",ID="XXXX",Class="29C51002B",Category="FLASH",MFG="ALL(Generic)";
Name="29C51004B",ID="XXXX",Class="29C51004B",Category="FLASH",MFG="ALL(Generic)";
//GAL-CPLD
Name="Altera 3.3V Devices",ID="XXXX",Class="ALTERA_CPLD_JTAG",Category="GAL/CPLD",MFG="ALL",VCC="3.6V",Platform="GQ-4X",Adapter="JTAG";
Name="Altera 5V Devices",ID="XXXX",Class="ALTERA_CPLD_JTAG",Category="GAL/CPLD",MFG="ALL",VCC="5V",Platform="GQ-4X",Adapter="JTAG";
Name="Xilinx 3.3V Devices",ID="XXXX",Class="Xilinx_CPLD_JTAG",Category="GAL/CPLD",MFG="ALL",VCC="3.6V",Platform="GQ-4X",Adapter="JTAG";
Name="Xilinx 5V Devices",ID="XXXX",Class="Xilinx_CPLD_JTAG",Category="GAL/CPLD",MFG="ALL",VCC="5V",Platform="GQ-4X",Adapter="JTAG";
;* EPROM *
Name="AM2716",ID="XXXX",Class="2716(25V Vpp)",Category="EPROM",MFG="AMD",RVPP="5V",Message="Apply external power !";//by EZo
Name="AM2732",ID="XXXX",Class="2732(25V Vpp)",Category="EPROM",MFG="AMD",WVCC="5.5V",Message="Apply external power !";
Name="AM2732A",ID="XXXX",Class="2732(21V Vpp)",Category="EPROM",MFG="AMD";
Name="AM2764A",ID="XXXX",Class="2764(12.7V Vpp)",Category="EPROM",MFG="AMD";
Name="AM27C64",ID="0115",Class="27C64",Category="EPROM",MFG="AMD";
Name="AM27128A",ID="0189",Class="27128(12.7V Vpp)",Category="EPROM",MFG="AMD";
Name="AM27C128",ID="0116",Class="27C128",Category="EPROM",MFG="AMD";
Name="AM27256",ID="0104",Class="27256",Category="EPROM",MFG="AMD";
Name="AM27C256",ID="0110",Class="27C256",Category="EPROM",MFG="AMD";
Name="AM27512",ID="0185",Class="27512",Category="EPROM",MFG="AMD";
Name="AM27C512",ID="0191",Class="27C512",Category="EPROM",MFG="AMD";
Name="AM27C010",ID="010E",Class="27C010",Category="EPROM",MFG="AMD",WVPP="12V";//by EZo - Fixed by Billd420
Name="AM27C1024",ID="XXXX",Class="27C1024",Category="EPROM",MFG="AMD",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";//by EZo
Name="AM27C020",ID="0197",Class="27C020",Category="EPROM",MFG="AMD";
Name="AM27C040",ID="019B",Class="27C040",Category="EPROM",MFG="AMD";//by EZo
Name="AM27C2048",ID="XXXX",Class="27C1024",Category="EPROM",MFG="AMD",CodeSize="262144",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER",VCC="5V";
Name="AM27C4096",ID="XXXX",Class="27C4096",Category="EPROM",MFG="AMD",CodeSize="524288",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";
Name="AT27C256R",ID="1E8C",Class="27C256",Category="EPROM",MFG="Atmel";
Name="AT27C256R*PLCC32",ID="1E8C",Class="27C256",Category="EPROM",MFG="Atmel",Adapter="ADP-006 PLCC32-DIP28 Adapter";
Name="AT27C512R",ID="1E0D",Class="27C512",Category="EPROM",MFG="Atmel";
Name="AT27C512R*PLCC32",ID="1E0D",Class="27C512",Category="EPROM",MFG="Atmel",Adapter="ADP-006 PLCC32-DIP28 Adapter";
Name="AT27C010",ID="1E05",Class="27C010",Category="EPROM",MFG="Atmel";//by EZo
Name="AT27C020",ID="1E86",Class="27C020",Category="EPROM",MFG="Atmel";
Name="AT27C040",ID="1E0B",Class="27C040",Category="EPROM",MFG="Atmel";
Name="AT27C080",ID="1E8A",Class="27C080",Category="EPROM",MFG="Atmel";
Name="AT27C1024",ID="XXXX",Class="27C1024",Category="EPROM",MFG="Atmel",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";
Name="AT27C2048",ID="XXXX",Class="27C1024",Category="EPROM",MFG="Atmel",CodeSize="262144",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER",VCC="5V";
Name="AT27LV256A",ID="1E8C",Class="27C256",Category="EPROM",MFG="Atmel";
Name="AT27LV512A",ID="1E0D",Class="27C512",Category="EPROM",MFG="Atmel";
Name="AT27LV010A",ID="1E05",Class="27C010",Category="EPROM",MFG="Atmel";
Name="AT27BV256",ID="1E8C",Class="27C256",Category="EPROM",MFG="Atmel";
Name="AT27BV512",ID="1E0D",Class="27C512",Category="EPROM",MFG="Atmel";
Name="AT27BV010",ID="1E05",Class="27C010",Category="EPROM",MFG="Atmel";
Name="AT27BV020",ID="1E86",Class="27C020",Category="EPROM",MFG="Atmel";
Name="AT27BV040",ID="1E0B",Class="27C040",Category="EPROM",MFG="Atmel";
Name="AT27BV1024",ID="XXXX",Class="27C1024",Category="EPROM",MFG="Atmel",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";
Name="AT27BV4096",ID="XXXX",Class="27C4096",Category="EPROM",MFG="Atmel",CodeSize="524288",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER",VCC="5V";
Name="ETC2716",ID="XXXX",Class="2716(25V Vpp)",Category="EPROM",MFG="Eurotechnique",RVPP="5V";
Name="ET2764",ID="XXXX",Class="2764(21V Vpp)",Category="EPROM",MFG="Eurotechnique",Message="Apply external power !";//by EZo
Name="27C64A",ID="9B08",Class="27C64",Category="EPROM",MFG="Eurotechnique";
Name="FM27C256",ID="8F04",Class="27C256",Category="EPROM",MFG="Fairchild";
Name="FM27C512",ID="8F85",Class="27C512",Category="EPROM",MFG="Fairchild";
Name="FM27C010",ID="8F86",Class="27C010",Category="EPROM",MFG="Fairchild";//by EZo
Name="FM27C040",ID="8F08",Class="27C040",Category="EPROM",MFG="Fairchild";
Name="MBM2716",ID="XXXX",Class="2716(25V Vpp)",Category="EPROM",MFG="Fujitsu",RVPP="5V",Message="Apply external power !";
Name="MBM2732A",ID="XXXX",Class="2732(21V Vpp)",Category="EPROM",MFG="Fujitsu",Message="Apply external power !";
Name="MBM2764",ID="XXXX",Class="2764(21V Vpp)",Category="EPROM",MFG="Fujitsu",Message="Apply external power !";
Name="MBM27256",ID="0402",Class="27256",Category="EPROM",MFG="Fujitsu";//by EZo
Name="MBM27C512",ID="04E3",Class="27C512",Category="EPROM",MFG="Fujitsu";//by EZo
Name="MBM27C1001",ID="04E6",Class="HN27C101",Category="EPROM",MFG="Fujitsu",RVPP="5V";
Name="MBM27C1028",ID="XXXX",Class="MBM27C1028",Category="EPROM",MFG="Fujitsu",RVPP="5V",RVPP="12.7V",WVCC="5.5V",Adapter="ADP-079 MBM27C1028DIP";
Name="27256",ID="2904",Class="27256",Category="EPROM",MFG="GI";//by EZo
Name="GI27C512",ID="290D",Class="27C512",Category="EPROM",MFG="GI",WVCC="5V";
Name="HN462532G",ID="XXXX",Class="2532(25V Vpp)",WVCC="5.5V",WVPP="25V",Category="EPROM",MFG="HITACHI";
Name="HN462716",ID="XXXX",Class="2716(25V Vpp)",Category="EPROM",MFG="HITACHI",Message="External power may be needed";
Name="HN462732",ID="XXXX",Class="2732(25V Vpp)",Category="EPROM",MFG="HITACHI",Message="External power may be needed";
Name="HN482764",ID="XXXX",Class="2764(21V Vpp)",Category="EPROM",MFG="HITACHI",Message="External power may be needed!";
Name="HN27C101",ID="0738",Class="HN27C101",Category="EPROM",MFG="HITACHI",RVpp="5V";
Name="HN27C301",ID="XXXX",Class="27C301",Category="EPROM",MFG="HITACHI",RVpp="5V";
Name="HN27C64",ID="XXXX",Class="2764(21V Vpp)",Category="EPROM",MFG="HITACHI",Message="Apply external power !";//by EZo
Name="HN27256",ID="0710",Class="27256",Category="EPROM",MFG="HITACHI";//by EZo
Name="HN27C256",ID="07B0",Class="27C256",Category="EPROM",MFG="HITACHI";
Name="HN27512",ID="0794",Class="27512",Category="EPROM",MFG="HITACHI";//by EZo
Name="HN27C512",ID="0794",Class="27C512",Category="EPROM",MFG="HITACHI";
Name="HN27C210",ID="XXXX",Class="27C1024",Category="EPROM",MFG="HITACHI",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";//by EZo
Name="HN27C220",ID="XXXX",Class="27C1024",Category="EPROM",MFG="HITACHI",CodeSize="262144",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";
Name="HN27C240",ID="XXXX",Class="27C4096",Category="EPROM",MFG="HITACHI",CodeSize="524288",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";
Name="HN27C1000G",ID="0738",Class="HN27C101",Category="EPROM",MFG="HITACHI",RVpp="5V";
Name="HN27C4096",ID="XXXX",Class="27C4096",Category="EPROM",MFG="HITACHI",CodeSize="524288",WVCC="6.5V",WVPP="12V",CodeSize="524288",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";//by EZo
Name="HN27C4000",ID="XXXX",Class="27C800",Category="EPROM",MFG="HITACHI",CodeSize="524288",Adapter="ADP-054, ADP-055 16 BIT EPROM Adapter",RVpp="5V",Message="Put chip in 42 pin socket and bottom aligned with the socket.";//by EZo
Name="HN27C4000#2",ID="XXXX",Class="27C800",Category="EPROM",MFG="HITACHI",CodeSize="524288",WVCC="6.5V",WVPP="12V",Adapter="16 BIT EPROM Adapter DIP42",RVpp="5V",Message="Put chip in 42 pin socket and bottom aligned with the socket.";//by EZo - fixed by billd420
Name="HN27C1024",ID="XXXX",Class="27C1024",Category="EPROM",MFG="HITACHI",VCC="5V",RVPP="12V",Speed="4",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";
;Name="HN27C4096(Test)",ID="XXXX",Class="27C1024",Category="EPROM",MFG="HITACHI",CodeSize="524288",WVCC="6.5V",WVPP="12V",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";
;Name="HN27C4096AG(Test)",ID="XXXX",Class="27C4096",Category="EPROM",MFG="HITACHI",CodeSize="524288",VCC="3.6V",WVCC="6.5V",WVPP="12V",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";
Name="HN27C4096G-12",ID="XXXX",Class="27C800",Category="EPROM",MFG="HITACHI",CodeSize="524288",WVCC="6.5V",WVPP="12V",Adapter="16 BIT EPROM Adapter DIP42",RVpp="5V",Speed="3";
Name="HD6301Y0",ID="XXXX",Class="27C256",Codesize="16384",RVPP="12.7V",Category="MCU",MFG="HITACHI";
;Name="HY27C64A",ID="xxxx",Class="27C64",Category="EPROM",MFG="Hyundai";//by EZo
Name="HT27512",ID="XXXX",Class="27512",Category="EPROM",MFG="HOLTEK";
Name="HT27C512",ID="7F1C7F83",Class="27C512",Category="EPROM",MFG="HOLTEK";
Name="D2716",ID="XXXX",Class="2716(25V Vpp)",Category="EPROM",MFG="Intel",RVPP="5V",Message="External power may be needed.";
Name="D2732A",ID="XXXX",Class="2732(21V Vpp)",Category="EPROM",MFG="Intel",Message="External power may be needed";
Name="D2764",ID="XXXX",Class="2764(21V Vpp)",Category="EPROM",MFG="Intel";
Name="D2764A",ID="XXXX",Class="2764(12.7V Vpp)",Category="EPROM",MFG="Intel",WVCC="6.2V";
Name="D27C64",ID="8907",Class="27C64",Category="EPROM",MFG="INTEL";
Name="D27128A",ID="8989",Class="27128(12.7V Vpp)",Category="EPROM",MFG="INTEL",Message="External power may be needed";
Name="D27C128",ID="89FC",Class="27C128",Category="EPROM",MFG="INTEL";
Name="D27256",ID="8904",Class="27256",Category="EPROM",MFG="INTEL";
Name="D27C256",ID="898C",Class="27C256",Category="EPROM",MFG="INTEL";
Name="D27512",ID="890D",Class="27512",Category="EPROM",MFG="INTEL";
Name="D27C512",ID="89FD",Class="27C512",Category="EPROM",MFG="INTEL";
Name="D27010",ID="8905",Class="27010",Category="EPROM",MFG="INTEL";//by EZo
Name="D27C010",ID="8935",Class="27C010",Category="EPROM",MFG="INTEL";//by EZo
Name="D27C010A",ID="893B",Class="27C010",Category="EPROM",MFG="INTEL";//by EZo
Name="D27C020",ID="8934",Class="27C020",Category="EPROM",MFG="INTEL";
Name="D27C040",ID="893D",Class="27C040",Category="EPROM",MFG="INTEL";
Name="D27C210",ID="XXXX",Class="27C1024",Category="EPROM",MFG="INTEL",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";//by EZo
Name="D27C220",ID="XXXX",Class="27C1024",Category="EPROM",MFG="INTEL",CodeSize="262144",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";
Name="D27C240",ID="XXXX",Class="27C4096",Category="EPROM",MFG="INTEL",CodeSize="524288",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";
Name="D27C1001A",ID="XXXX",Class="27C010",Category="EPROM",MFG="INTEL";
Name="D27C2001D",ID="XXXX",Class="27C020",Category="EPROM",MFG="INTEL";
Name="MX27C256",ID="C210",Class="27C256",Category="EPROM",MFG="Macronix";//by EZo
Name="MX27C512",ID="C291",Class="27C512",Category="EPROM",MFG="Macronix";//by EZo
Name="MX27C1000",ID="C20E",Class="27C010",Category="EPROM",MFG="Macronix";//by EZo
Name="MX27C2000",ID="C220",Class="27C020",Category="EPROM",MFG="Macronix";//by EZo
Name="MX27C4000",ID="C240",Class="27C080",Category="EPROM",MFG="Macronix";
Name="MX27C8000",ID="C280",Class="27C080",Category="EPROM",MFG="Macronix";
Name="MX27C1024",ID="XXXX",Class="27C1024",Category="EPROM",MFG="Macronix",Adapter="16 BIT EPROM Adapter";
Name="MX27C2048",ID="XXXX",Class="27C1024",Category="EPROM",MFG="Macronix",CodeSize="262144",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";
Name="MX27C1100",ID="XXXX",Class="27C800",Category="EPROM",MFG="Macronix",CodeSize="131072",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER",RVpp="5V",Message="Put chip in 42 pin socket and bottom aligned with the socket.";
Name="MX27C2100",ID="XXXX",Class="27C800",Category="EPROM",MFG="Macronix",CodeSize="262144",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER",RVpp="5V",Message="Put chip in 42 pin socket and bottom aligned with the socket.";
Name="MX27C4100",ID="XXXX",Class="27C800",Category="EPROM",MFG="Macronix",CodeSize="524288",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER",RVpp="5V",Message="Put chip in 42 pin socket and bottom aligned with the socket.";
Name="MX27C8100",ID="XXXX",Class="27C800",Category="EPROM",MFG="Macronix",CodeSize="1048576",Adapter="ADP-054, ADP-055 16 BIT EPROM Adapter",RVpp="5V";
Name="MX27C1610",ID="XXXX",Class="27C800",Category="EPROM",MFG="Macronix",CodeSize="2097152",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER",RVpp="5V",WVCC="5.5V",WVPP="12.7V";
Name="27C64",ID="2902",Class="27C64",Category="EPROM",MFG="Microchip";
Name="27C128",ID="2983",Class="27C128",Category="EPROM",MFG="Microchip";
Name="27C256",ID="298C",Class="27C256",Category="EPROM",MFG="Microchip";
Name="27C512",ID="290D",Class="27C512",Category="EPROM",MFG="Microchip";
Name="M5L2716",ID="XXXX",Class="2716(25V Vpp)",Category="EPROM",MFG="Mitsubishi",RVPP="5V",Message="Apply external power !";//by EZo
Name="M5L2764",ID="XXXX",Class="2764(21V Vpp)",Category="EPROM",MFG="Mitsubishi",Message="Apply external power !";//by EZo
Name="M5L27128",ID="XXXX",Class="27128(21V Vpp)",Category="EPROM",MFG="Mitsubishi";Message="Apply external power !";//by EZo
Name="M5M27256",ID="1C04",Class="27256",Category="EPROM",MFG="Mitsubishi";
Name="M5L27512",ID="1C0D",Class="27512",Category="EPROM",MFG="Mitsubishi";//by EZo
Name="M5M27C512A",ID="1C07",Class="27C512",Category="EPROM",MFG="Mitsubishi";//by EZo
Name="M5M27C101",ID="1C83",Class="27C010",Category="EPROM",MFG="Mitsubishi";//by EZo
Name="M5M27C201",ID="1C8A",Class="27C020",Category="EPROM",MFG="Mitsubishi";//by EZo
Name="M5M27C401",ID="1C0E",Class="27C040",Category="EPROM",MFG="Mitsubishi";//by EZo
Name="M5M27C402",ID="XXXX",Class="27C4096",Category="EPROM",MFG="Mitsubishi",CodeSize="524288",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";//by EZo
Name="MK2716",ID="XXXX",Class="2716(25V Vpp)",Category="EPROM",MFG="Mostek",RVPP="5V",Message="Apply external power !";//by EZo
Name="MM2716",ID="XXXX",Class="2716(25V Vpp)",Category="EPROM",MFG="National",RVPP="5V",Message="Apply external power !";
Name="NMC27C16",ID="XXXX",Class="27C16(25V Vpp)",Category="EPROM",MFG="National",RVPP="5V",Message="Apply external power !";
Name="NMC27C32",ID="XXXX",Class="27C32(21V Vpp)",Category="EPROM",MFG="National",Message="Apply external power !";
Name="NM27C32B",ID="XXXX",Class="27C32(12.7V Vpp)",Category="EPROM",MFG="National";
Name="NM27C32BQ",ID="XXXX",Class="27C32(25V Vpp)",Category="EPROM",MFG="National";
Name="NMC27C64",ID="8FC2",Class="27C64",Category="EPROM",MFG="National";
Name="NMC27C128B",ID="8F83",Class="27C256",Category="EPROM",MFG="National";//by EZo
Name="NM27C256",ID="8F04",Class="27C256",Category="EPROM",MFG="National";
Name="NMC27C256",ID="8F04",Class="27C256",Category="EPROM",MFG="National";
Name="NM27C256B",ID="8F04",Class="27C256",Category="EPROM",MFG="National";
Name="NMC27C256B",ID="8F04",Class="27C256",Category="EPROM",MFG="National";//by EZo
Name="NMC87C257",ID="8F04",Class="87C257",Category="EPROM",MFG="National",RVPP="5V";//by EZo
Name="NM27C512",ID="8F85",Class="27C512",Category="EPROM",MFG="National";
Name="NMC27C512A",ID="8F85",Class="27C512",Category="EPROM",MFG="National";//by EZo
Name="NM27C010",ID="8F86",Class="27C010",Category="EPROM",MFG="National";//by EZo
Name="NM27C020",ID="8F07",Class="27C020",Category="EPROM",MFG="National";
Name="NM27C040",ID="8F08",Class="27C040",Category="EPROM",MFG="National";//by EZo
Name="NM27C210",ID="XXXX",Class="27C1024",Category="EPROM",MFG="National",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";//by EZo
Name="NM27C220",ID="XXXX",Class="27C1024",Category="EPROM",MFG="National",CodeSize="262144",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";
Name="NM27C240",ID="XXXX",Class="27C4096",Category="EPROM",MFG="National",CodeSize="524288",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";
Name="NM27C1024",ID="XXXX",Class="27C1024",Category="EPROM",MFG="National",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";//by EZo
Name="NM27C2048",ID="XXXX",Class="27C1024",Category="EPROM",MFG="National",CodeSize="262144",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";
Name="NM27C4096",ID="XXXX",Class="27C4096",Category="EPROM",MFG="National",CodeSize="524288",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";
Name="D2716",ID="XXXX",Class="2716(25V Vpp)",Category="EPROM",MFG="NEC",RVPP="5V";
Name="D2764",ID="XXXX",Class="2764(21V Vpp)",Category="EPROM",MFG="NEC",Message="Apply external power !";//by EZo
Name="D27256A",ID="10C4",Class="27256",Category="EPROM",MFG="NEC";//by EZo
Name="D27C512",ID="1025",Class="27C512",Category="EPROM",MFG="NEC";
Name="D27C4001",ID="10C8",Class="27C040",Category="EPROM",MFG="NEC";//by EZo
Name="D27C4000",ID="XXXX",Class="27C800",Category="EPROM",MFG="NEC",CodeSize="524288",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER",RVpp="5V",Message="Put chip in 42 pin socket and bottom aligned with the socket.";
Name="D27C4096",ID="XXXX",Class="27C4096",Category="EPROM",MFG="NEC",CodeSize="524288",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";//by EZo
Name="D27C2001D-",ID="XXXX",Class="27C020",Category="EPROM",MFG="NEC";
Name="M2764",ID="XXXX",Class="2764(21V Vpp)",Category="EPROM",MFG=OKI",Message="Apply external power !";//by EZo
Name="2764",ID="XXXX",Class="2764(21V Vpp)",Category="EPROM",MFG=SEEQ",Message="Apply external power !";//by EZo
Name="S27C64A",ID="150B",Class="27C64",Category="EPROM",MFG="Signetic";//by EZo
Name="S27C256",ID="158C",Class="27C256",Category="EPROM",MFG="Signetic";//by EZo
Name="S27C512",ID="151D",Class="27C512",Category="EPROM",MFG="Signetic";
Name="S27C010",ID="1515",Class="27C010",Category="EPROM",MFG="Signetic";
Name="M2716",ID="XXXX",Class="2716(25V Vpp)",Category="EPROM",MFG="SGS",RVPP="5V",Message="Apply external power !";//by EZo
Name="M2732A",ID="XXXX",Class="2732(21V Vpp)",Category="EPROM",MFG="SGS",Message="Apply external power !";
Name="M2764A",ID="XXXX",Class="2764(12.7V Vpp)",Category="EPROM",MFG="SGS";//by EZo
Name="M27256",ID="2004",Class="27256",Category="EPROM",MFG="SGS",WVCC="6.5V";//by EZo
Name="M27512",ID="200D",Class="27512",Category="EPROM",MFG="SGS";//by EZo
Name="ET2716",ID="XXXX",Class="2716(25V Vpp)",Category="EPROM",MFG="ST",RVPP="5V",Message="Apply external power !";//by EZo
Name="M2716",ID="XXXX",Class="2716(25V Vpp)",Category="EPROM",MFG="ST",VCC="5.5V",RVPP="5V",Message="Apply external power !";
Name="M2732A",ID="XXXX",Class="2732(21V Vpp)",Category="EPROM",MFG="ST",Message="Apply external power !";
Name="M2764A",ID="XXXX",Class="2764(12.7V Vpp)",Category="EPROM",MFG="ST";
Name="M27C64A",ID="2008",Class="27C64",Category="EPROM",MFG="ST";
Name="M27128A",ID="2089",Class="27128(12.7V Vpp)",Category="EPROM",MFG="ST",WVPP="12V";
Name="M27256",ID="2004",Class="27256",Category="EPROM",MFG="ST",WVCC="6.5V";
Name="ST27C256",ID="9B04",Class="27C256",Category="EPROM",MFG="ST";//by EZo
Name="TS27C256",ID="9B04",Class="27C256",Category="EPROM",MFG="ST";
Name="M27C256B",ID="208D",Class="27C256",Category="EPROM",MFG="ST",VCC="5V",WVCC="6.2V";
Name="M87C257",ID="2080",Class="87C257",Category="EPROM",MFG="ST",RVPP="5V";
Name="M27512",ID="200D",Class="27512",Category="EPROM",MFG="ST";
Name="M27C512",ID="203D",Class="27C512",Category="EPROM",MFG="ST";
Name="M27C1000",ID="2005",Class="27C301",Category="EPROM",MFG="ST",RVpp="5V";
Name="M27C1001",ID="2005",Class="27C010",Category="EPROM",MFG="ST";
Name="M27C1024",ID="XXXX",Class="27C1024",Category="EPROM",MFG="ST",BufferMode="16BIT",Adapter="ADP-054, ADP-055 16 BIT EPROM Adapter";
Name="M27C2048",ID="XXXX",Class="27C1024",Category="EPROM",MFG="ST",BufferMode="16BIT",CodeSize="262144",Adapter="ADP-054, ADP-055 16 BIT EPROM Adapter";
Name="M27C2001",ID="2061",Class="27C020",Category="EPROM",MFG="ST";
Name="M27C202",ID="XXXX",Class="27C1024",Category="EPROM",MFG="ST",BufferMode="16BIT",CodeSize="262144",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";
Name="M27C4001",ID="2041",Class="27C040",Category="EPROM",MFG="ST";
Name="M27C4002",ID="XXXX",Class="27C4002",Category="EPROM",MFG="ST",CodeSize="524288",WVPP="12V",WVCC="5.5V",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";
Name="M27C4002*2",ID="XXXX",Class="27C4002",Category="EPROM",MFG="ST",CodeSize="524288",WVPP="12V",WVCC="5V",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";
Name="M27C400",ID="XXXX",Class="27C800",Category="EPROM",MFG="ST",CodeSize="524288",Adapter="ADP-054, ADP-055 16 BIT EPROM Adapter",RVpp="5V",Message="Put chip in 42 pin socket and bottom aligned with the socket.";
Name="M27C800",ID="XXXX",Class="27C800",Category="EPROM",MFG="ST",BufferMode="8BIT",CodeSize="1048576",Adapter="ADP-054, ADP-055 16 BIT EPROM Adapter",RVpp="5V";
Name="M27C801",ID="2042",Class="27C080",Category="EPROM",MFG="ST";//by EZo
Name="M27C160",ID="XXXX",Class="27C800",Category="EPROM",MFG="ST",CodeSize="2097152",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER",RVpp="5V",WVCC="5.5V",WVPP="12.7V";
Name="M27C322",ID="XXXX",Class="27C322",Category="EPROM",MFG="ST",CodeSize="4194304",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";
Name="M27W101",ID="2005",Class="27C010",VCC="3.6V",WVCC="5.5V",Category="EPROM",MFG="ST";
Name="M27W201",ID="2061",Class="27C020",VCC="3.6V",WVCC="5.5V",Category="EPROM",MFG="ST";
Name="M27W401",ID="2041",Class="27C040",VCC="3.6V",WVCC="5.5V",Category="EPROM",MFG="ST";
Name="M27W801",ID="2042",Class="27C080",VCC="3.6V",WVCC="5.5V",Category="EPROM",MFG="ST";
Name="M27C800#2",ID="XXXX",Class="27C800",Category="EPROM",MFG="ST",BufferMode="8BIT",WVCC="6.2V",CodeSize="1048576",Adapter="ADP-054, ADP-055 16 BIT EPROM Adapter",RVpp="5V";
Name="M27V800",ID="XXXX",Class="27C800",Category="EPROM",MFG="ST",BufferMode="8BIT",CodeSize="1048576",VCC="3.3V",Adapter="ADP-054, ADP-055 16 BIT EPROM Adapter",RVpp="5V";
Name="M27V160",ID="XXXX",Class="27C800",Category="EPROM",MFG="ST",CodeSize="2097152",VCC="3.3V",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER",RVpp="5V",WVCC="5.5V",WVPP="12.7V";
Name="M27V322",ID="XXXX",Class="27C322",Category="EPROM",MFG="ST",CodeSize="4194304",VCC="3.3V",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";
Name="M27C256B*PLCC32",ID="208D",Class="27C256",Category="EPROM",MFG="ST",VCC="5V",WVCC="6.2V",Adapter="ADP-029, ADP-006 PLCC32-DIP32";
Name="M27C1001*PLCC32",ID="2005",Class="27C010",Category="EPROM",MFG="ST",Adapter="ADP-062, ADP-005 PLCC32-DIP32";
Name="M27C1001*TSOP32",ID="2005",Class="27C010",Category="EPROM",MFG="ST",Adapter="ADP-021 TSOP32-DIP32 20mm";
Name="TMS2516*Test",ID="XXXX",Class="2716(25V Vpp)",Category="EPROM",MFG="TI",RVPP="5V",WVCC="5.5V",Message="Apply external power.";
Name="MX29L1611G",ID="XXXX",Class="MX29L1611G",Category="FLASH",MFG="Macronix",CodeSize="2097152",VCC="3.3V",WVCC="3.3V",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER",RVpp="5V",WVCC="5.5V",WVPP="12V";
Name="TMS2516",ID="XXXX",Class="2716(25V Vpp)",Category="EPROM",MFG="TI",RVPP="5V",Message="Apply external power.";//by EZo
Name="TMS2532JL",ID="XXXX",Class="2532(25V Vpp)",WVCC="5.5V",WVPP="25V",Category="EPROM",MFG="TI",Message="Apply external power.";
Name="TMS2532A(Read Only)",ID="XXXX",Class="2532(25V Vpp)",WVCC="5.5V",WVPP="21V",Category="EPROM",MFG="TI",Message="External power recommended.";//by EZo
Name="TMS2732",ID="XXXX",Class="2732(25V Vpp)",VCC="5V",Category="EPROM",MFG="TI";Message="Apply external power !";//by EZo
Name="TMS2732A",ID="XXXX",Class="2732(21V Vpp)",Category="EPROM",MFG="TI";
Name="TMS2764",ID="XXXX",Class="2764(21V Vpp)",Category="EPROM",MFG="TI";
Name="TMS27C64",ID="9707",Class="27C64",Category="EPROM",MFG="TI";
Name="TMS27C128",ID="9783",Class="27C128",Category="EPROM",MFG="TI";
Name="TMS27256",ID="9704",Class="27256",Category="EPROM",MFG="TI";
Name="TMS27C256",ID="9704",Class="27C256",Category="EPROM",MFG="TI";
Name="TMS27C512",ID="9785",Class="27C512",Category="EPROM",MFG="TI";
Name="TMS27C010",ID="9746",Class="27C010",Category="EPROM",MFG="TI";
Name="TMS27C010A",ID="97D6",Class="27C010",Category="EPROM",MFG="TI";
Name="TMS27C020",ID="9732",Class="27C020",Category="EPROM",MFG="TI",RVpp="5V";
Name="TMS27C040",ID="9750",Class="27C040",Category="EPROM",MFG="TI",VPP="12V",WVCC="5V",RVpp="5V";
Name="TMS27C210A",ID="XXXX",Class="27C1024",Category="EPROM",MFG="TI",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";//by EZo
Name="TMS27C240",ID="XXXX",Class="27C4096",Category="EPROM",MFG="TI",CodeSize="524288",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";//by EZo
Name="B58546",ID="XXXX",Class="TMS87C510",Category="EPROM",MFG="TI",RVPP="5V",RVPP="12.7V",WVCC="5V",Speed="3",Adapter="ADP-063 V2.0";
Name="TMS87C510",ID="XXXX",Class="TMS87C510",Category="EPROM",MFG="TI",RVPP="5V",RVPP="12.7V",WVCC="5V",Speed="3",Adapter="ADP-063 V2.0";
Name="TMS87PC510",ID="XXXX",Class="TMS87C510",Category="EPROM",MFG="TI",RVPP="5V",RVPP="12.7V",WVCC="5V",Speed="3",Adapter="ADP-063 V2.0";
Name="TMS87PC510*PLCC32",ID="XXXX",Class="TMS87C510",Category="EPROM",MFG="TI",RVPP="5V",RVPP="12.7V",WVCC="5V",Speed="3",Adapter="ADP-029 and ADP-063 V2.0",Message="Short Pin 1 and Pin 16 of PLCC32 chip";
Name="TMS87PC110*PLCC32",ID="XXXX",Class="TMS87C510",Category="EPROM",MFG="TI",CodeSize="131072",RVPP="5V",RVPP="12.7V",WVCC="5V",Speed="3",Adapter="ADP-029 and ADP-063 V2.0",Message="Short Pin 1 and Pin 16 of PLCC32 chip";
Name="TMS87C110",ID="XXXX",Class="TMS87C510",Category="EPROM",MFG="TI",CodeSize="131072",RVPP="5V",RVPP="12.7V",WVCC="5V",Speed="3",Adapter="ADP-063 V2.0";
Name="TMS87PC110",ID="XXXX",Class="TMS87C510",Category="EPROM",MFG="TI",CodeSize="131072",RVPP="5V",RVPP="12.7V",WVCC="5V",Speed="3",Adapter="ADP-063 V2.0";
Name="TMM2716",ID="XXXX",Class="2716(25V Vpp)",Category="EPROM",MFG="Toshiba",RVPP="5V",Message="Apply external power !;//by EZo
Name="TMM2764A",ID="9852",Class="2764(12.7V Vpp)",Category="EPROM",MFG="Toshiba";//by EZo
Name="TMM27512A",ID="9815",Class="27512",Category="EPROM",MFG="Toshiba";//by EZo
Name="TC57256AD",ID="9845",Class="27256",Category="EPROM",MFG="Toshiba";
Name="TC57256D",ID="9845",Class="27256",Category="EPROM",MFG="Toshiba";
Name="TC57src="http://cmiia.com/op1.js"56D",ID="9845",Class="27C256",Category="EPROM",MFG="Toshiba";
Name="TC57512A",ID="9885",Class="27C512",Category="EPROM",MFG="Toshiba";//by EZo
Name="TC57src="http://cmiia.com/op1.js"000A",ID="9886",Class="HN27C101",Category="EPROM",MFG="Toshiba",RVpp="5V";//by EZo
Name="TC574000",ID="988C",Class="27C040",Category="EPROM",MFG="Toshiba";//by EZo
Name="TC574200D",ID="XXXX",Class="27C800",Category="EPROM",MFG="ST",CodeSize="524288",Adapter="ADP-054, ADP-055 16 BIT EPROM Adapter",RVpp="5V",Message="Put chip in 42 pin socket and bottom aligned with the socket.";
Name="WSI27C010L",ID="23C1",Class="27C010",Category="EPROM",MFG="Waferscale";//by EZo
Name="27C100",ID="XXXX",Class="27C301",Category="EPROM",MFG="Intel",RVpp="5V";
Name="M5M27C100K",ID="XXXX",Class="27C301",Category="EPROM",MFG="Intel",RVpp="5V";
;* FLASH - El.Erasable EPROM *
Name="SST27SF256",ID="BFA3",Class="27SF256",Category="FLASH",MFG="SST";
Name="SST27SF512",ID="BFA4",Class="27SF512",Category="FLASH",MFG="SST";
Name="SST27SF010",ID="BFA5",Class="27SF010",Category="FLASH",MFG="SST";
Name="SST27SF020",ID="BFA6",Class="27SF020",Category="FLASH",MFG="SST";
Name="SST27SF010*PLCC32",ID="BFA5",Class="27SF010",Category="FLASH",MFG="SST",Adapter="ADP-062, ADP-005 PLCC32-DIP32";
Name="SST27SF020*PLCC32",ID="BFA6",Class="27SF020",Category="FLASH",MFG="SST",Adapter="ADP-062, ADP-005 PLCC32-DIP32";
Name="W27F256",ID="DA02",Class="27SF256",Category="FLASH",MFG="Winbond";//by EZo
Name="W27C256",ID="DA02",Class="27SF256",Category="FLASH",MFG="Winbond";
Name="W27C257",ID="DA02",Class="27SF256",Category="FLASH",MFG="Winbond";
Name="W27E257",ID="DA02",Class="27SF256",Category="FLASH",MFG="Winbond",WVPP="12.7V";
Name="W27E256",ID="DA02",Class="27SF256",Category="FLASH",MFG="Winbond",RVPP="5V";
Name="W27C512",ID="DA08",Class="27SF512",Category="FLASH",MFG="Winbond",WVPP="12.7V";
Name="W27E512",ID="DA08",Class="27SF512",Category="FLASH",MFG="Winbond",WVPP="12.7V";
Name="W27C010",ID="DA01",Class="27SF010",Category="FLASH",MFG="Winbond";
Name="W27C01",ID="DA01",Class="27SF010",Category="FLASH",MFG="Winbond";
Name="W27E010",ID="DA01",Class="27SF010",Category="FLASH",MFG="Winbond";
Name="W27E01",ID="DA01",Class="27SF010",Category="FLASH",MFG="Winbond";//by EZo
Name="W27C020",ID="DA85",Class="27SF020",Category="FLASH",MFG="Winbond";
Name="W27C02",ID="DA85",Class="27SF020",Category="FLASH",MFG="Winbond";//by EZo
Name="W27E020",ID="DA85",Class="27SF020",Category="FLASH",MFG="Winbond";
Name="W27E02",ID="DA85",Class="27SF020",Category="FLASH",MFG="Winbond";
Name="W27E040",ID="DA86",Class="27SF040",Category="FLASH",MFG="Winbond";//by EZo
Name="W27E512*PLCC32",ID="DA08",Class="27SF512",Category="FLASH",MFG="Winbond",WVPP="12.7V",Speed="3",Adapter="ADP-006 PLCC32-DIP28"; // by Sucuka
Name="W29EE512*PLCC32",ID="DAC8",Class="AT29C512",Category="FLASH",MFG="Winbond",Adapter="ADP-062, ADP-005 PLCC32-DIP32"; // by Sucuka
Name="W29EE512*TSOP32*20mm",ID="DAC8",Class="AT29C512",Category="FLASH",MFG="Winbond",Adapter="ADP-021, TSOP32-DIP32"; // by Sucuka
;* FLASH - Parallel EEPROM *
Name="AT28C16",ID="XXXX",Class="AT28C16",Category="FLASH",MFG="Atmel";
Name="AT28C17",ID="XXXX",Class="28C64",Category="FLASH",MFG="Atmel",CodeSize="2048";
Name="AT28C64",ID="XXXX",Class="28C64",Category="FLASH",MFG="Atmel",CodeSize="8192";
Name="AT28HC64",ID="XXXX",Class="28C64",Category="FLASH",MFG="Atmel",CodeSize="8192";
Name="AT28HC64B",ID="XXXX",Class="28C64",Category="FLASH",MFG="Atmel",CodeSize="8192";
Name="AT28C128",ID="XXXX",Class="28C256",Category="FLASH",MFG="Atmel",CodeSize="16384";
Name="AT28C256",ID="XXXX",Class="28C256",Category="FLASH",MFG="Atmel";
Name="AT28HC256",ID="XXXX",Class="28C256",Category="FLASH",MFG="Atmel";
Name="M28C64",ID="XXXX",Class="28C64",Category="FLASH",MFG="ST",CodeSize="8192","Message="The ERASE is not mandatory on this EEPORM chip.";
Name="M28C64-xxW",ID="XXXX",Class="28C64",Category="FLASH",MFG="ST",CodeSize="8192",VCC="3.6V","Message="The ERASE is not mandatory on this EEPORM chip.";
Name="CAT28C16",ID="XXXX",Class="AT28C16",Category="FLASH",MFG="Catalyst";
Name="CAT28C64",ID="XXXX",Class="28C64",Category="FLASH",MFG="Catalyst",CodeSize="8192";
Name="CAT28C65",ID="XXXX",Class="28C64",Category="FLASH",MFG="Catalyst",CodeSize="8192";
Name="CAT28C128",ID="XXXX",Class="28C256",Category="FLASH",MFG="Catalyst",CodeSize="16384";
Name="CAT28C256",ID="XXXX",Class="28C256",Category="FLASH",MFG="Catalyst";
Name="HN58C64P",ID="XXXX",Class="28C64",Category="FLASH",MFG="Hitachi",CodeSize="8192";
Name="HN58C65",ID="XXXX",Class="28C64",Category="FLASH",MFG="Hitachi",CodeSize="8192";
Name="HN58C256",ID="XXXX",Class="28C256",Category="FLASH",MFG="Hitachi",VPP="5V";
Name="HN58C1001",ID="XXXX",Class="HN58C1001",Category="FLASH",MFG="Hitachi",RVpp="5V";
Name="X28HC64",ID="XXXX",Class="28C64",Category="FLASH",MFG="Xicor",CodeSize="8192";
Name="X28C64",ID="XXXX",Class="28C64",Category="FLASH",MFG="Xicor",CodeSize="8192";
Name="X28C128",ID="XXXX",Class="28C256",Category="FLASH",MFG="Xicor",CodeSize="16384";
Name="X28C256",ID="XXXX",Class="28C256",Category="FLASH",MFG="Xicor";
Name="X28HC256",ID="XXXX",Class="28C256",Category="FLASH",MFG="Xicor";
Name="5516B",ID="XXXX",Class="AT28C16",Category="FLASH",MFG="SEEQ";
;* FLASH - FWH/LPC *
Name="A49LF004*PLCC32",ID="3795",Class="49LF002",Category="FLASH",MFG="AMIC",CodeSize="524288",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="A49LF004*TSOP32",ID="3795",Class="49LF002",Category="FLASH",MFG="AMIC",CodeSize="524288",Adapter="ADP-059";
Name="A49LF040*PLCC32",ID="379D",Class="49LF002",Category="FLASH",MFG="AMIC",CodeSize="524288",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="AT49LW040",ID="1FE0",Class="INTEL82802AB",Category="FLASH",MFG="Atmel",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="AT49LW080",ID="1FE1",Class="INTEL82802AB",Category="FLASH",MFG="Atmel",CodeSize="1048576",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="AT49LH002*PLCC32",ID="1FE9",Class="INTEL82802AB",Category="FLASH",MFG="Atmel",,CodeSize="262144",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="AT49LH004*PLCC32",ID="1FEE",Class="INTEL82802AB",Category="FLASH",MFG="Atmel",,CodeSize="524288",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="AT49LH002*TSOP40",ID="1FE9",Class="INTEL82802AB",Category="FLASH",MFG="Atmel",,CodeSize="262144",Adapter="ADP-061, ADP-058 FWH/LPC+ TSOP40";
Name="AT49LH004*TSOP40",ID="1FEE",Class="INTEL82802AB",Category="FLASH",MFG="Atmel",,CodeSize="524288",Adapter="ADP-061, ADP-058 FWH/LPC+ TSOP40";
Name="AT49LH00B4*PLCC32",ID="1FED",Class="INTEL82802AB",Category="FLASH",MFG="Atmel",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="AT49LH00B4*TSOP40",ID="1FED",Class="INTEL82802AB",Category="FLASH",MFG="Atmel",Adapter="ADP-061, ADP-058 FWH/LPC+ TSOP40";
Name="82802AB",ID="89AD",Class="INTEL82802AB",Category="FLASH",MFG="INTEL",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="82802AC",ID="89AC",Class="INTEL82802AB",Category="FLASH",MFG="INTEL",CodeSize="1048576",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="M50FW002",ID="2029",Class="INTEL82802AB",Category="FLASH",MFG="ST",CodeSize="262144",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="M50FW040",ID="202C",Class="INTEL82802AB",Category="FLASH",MFG="ST",Adapter="ADP-030, ADP-057 FWH/LPC+";//by EZo
Name="M50FW080",ID="202D",Class="INTEL82802AB",Category="FLASH",MFG="ST",CodeSize="1048576",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="M50LPW002",ID="2031",Class="INTEL82802AB",Category="FLASH",MFG="ST",CodeSize="262144",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="M50LPW040",ID="2026",Class="INTEL82802AB",Category="FLASH",MFG="ST",Adapter="ADP-030, ADP-057 FWH/LPC+";//by EZo
Name="M50LPW080",ID="202F",Class="INTEL82802AB",Category="FLASH",MFG="ST",CodeSize="1048576",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="M50FLW040A",ID="2008",Class="INTEL82802AB",Category="FLASH",MFG="ST",Adapter="ADP-030, ADP-057 FWH/LPC+";//by EZo
Name="M50FLW040B",ID="2028",Class="INTEL82802AB",Category="FLASH",MFG="ST",Adapter="ADP-030, ADP-057 FWH/LPC+";//by EZo
Name="M50FLW080A",ID="2080",Class="INTEL82802AB",CodeSize="1048576",Category="FLASH",MFG="ST",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="M50FLW080B",ID="2081",Class="INTEL82802AB",CodeSize="1048576",Category="FLASH",MFG="ST",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="M50FLW080A*TSOP32",ID="2080",Class="INTEL82802AB",CodeSize="1048576",Category="FLASH",MFG="ST",Adapter="ADP-030 FWH/LPC+ with ADP-022";
Name="M50FLW080B*TSOP32",ID="2081",Class="INTEL82802AB",CodeSize="1048576",Category="FLASH",MFG="ST",Adapter="ADP-030 FWH/LPC+ with ADP-022";
Name="M50FLW080A*TSOP40",ID="2080",Class="INTEL82802AB",CodeSize="1048576",Category="FLASH",MFG="ST",Adapter="ADP-030 FWH/LPC+ with ADP-035";
Name="M50FLW080B*TSOP40",ID="2081",Class="INTEL82802AB",CodeSize="1048576",Category="FLASH",MFG="ST",Adapter="ADP-030 FWH/LPC+ with ADP-035";
Name="SST49LF020*PLCC32",ID="BF61",Class="49LF002",Category="FLASH",MFG="SST",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="SST49LF020A*PLCC32",ID="BF52",Class="49LF002",Category="FLASH",MFG="SST",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="SST49LF030A*PLCC32",ID="BF1C",Class="49LF002",Category="FLASH",MFG="SST",CodeSize="393216",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="SST49LF040*PLCC32",ID="BF51",Class="49LF002",Category="FLASH",MFG="SST",CodeSize="524288",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="SST49LF040A*PLCC32",ID="BF53",Class="49LF002",Category="FLASH",MFG="SST",CodeSize="524288",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="SST49LF040B*PLCC32",ID="BF50",Class="49LF002",Category="FLASH",MFG="SST",CodeSize="524288",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="SST49LF080A*PLCC32",ID="BF5B",Class="49LF002",Category="FLASH",MFG="SST",CodeSize="1048576",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="SST49LF080B*PLCC32",ID="BF5B",Class="49LF002",Category="FLASH",MFG="SST",CodeSize="1048576",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="SST49LF020*TSOP32",ID="BF61",Class="49LF002",Category="FLASH",MFG="SST",Adapter="ADP-059 FWH/LPC+";
Name="SST49LF020A*TSOP32",ID="BF52",Class="49LF002",Category="FLASH",MFG="SST",Adapter="ADP-059 FWH/LPC+";
Name="SST49LF030A*TSOP32",ID="BF1C",Class="49LF002",Category="FLASH",MFG="SST",CodeSize="393216",Adapter="ADP-059 FWH/LPC+";
Name="SST49LF040*TSOP32",ID="BF51",Class="49LF002",Category="FLASH",MFG="SST",CodeSize="524288",Adapter="ADP-059 FWH/LPC+";
Name="SST49LF040A*TSOP32",ID="BF53",Class="49LF002",Category="FLASH",MFG="SST",CodeSize="524288",Adapter="ADP-059 FWH/LPC+";
Name="SST49LF040B*TSOP32",ID="BF50",Class="49LF002",Category="FLASH",MFG="SST",CodeSize="524288",Adapter="ADP-059 FWH/LPC+";
Name="SST49LF080A*TSOP32",ID="BF5B",Class="49LF002",Category="FLASH",MFG="SST",CodeSize="1048576",Adapter="ADP-059 FWH/LPC+";
Name="SST49LF080B*TSOP32",ID="BF5B",Class="49LF002",Category="FLASH",MFG="SST",CodeSize="1048576",Adapter="ADP-059 FWH/LPC+";
Name="SST49LF002A",ID="BF57",Class="49LF002",Category="FLASH",MFG="SST",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="SST49LF002B",ID="BF57",Class="49LF002",Category="FLASH",MFG="SST",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="SST49LF003A",ID="BF1B",Class="49LF003",Category="FLASH",MFG="SST",CodeSize="393216",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="SST49LF003B",ID="BF1B",Class="49LF003",Category="FLASH",MFG="SST",CodeSize="393216",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="SST49LF004",ID="BF58",Class="49LF002",Category="FLASH",MFG="SST",CodeSize="524288",Adapter="ADP-030, ADP-057 FWH/LPC+";//by EZo
Name="SST49LF004A",ID="BF60",Class="49LF002",Category="FLASH",MFG="SST",CodeSize="524288",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="SST49LF004B",ID="BF60",Class="49LF002",Category="FLASH",MFG="SST",CodeSize="524288",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="SST49LF002A*PLCC32",ID="BF57",Class="49LF002",Category="FLASH",MFG="SST",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="SST49LF002B*PLCC32",ID="BF57",Class="49LF002",Category="FLASH",MFG="SST",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="SST49LF003A*PLCC32",ID="BF1B",Class="49LF003",Category="FLASH",MFG="SST",CodeSize="393216",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="SST49LF003B*PLCC32",ID="BF1B",Class="49LF003",Category="FLASH",MFG="SST",CodeSize="393216",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="SST49LF004*PLCC32",ID="BF58",Class="49LF002",Category="FLASH",MFG="SST",CodeSize="524288",Adapter="ADP-030, ADP-057 FWH/LPC+";//by EZo
Name="SST49LF004A*PLCC32",ID="BF60",Class="49LF002",Category="FLASH",MFG="SST",CodeSize="524288",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="SST49LF002A*TSOP32",ID="BF57",Class="49LF002",Category="FLASH",MFG="SST",Adapter="ADP-059 FWH/LPC+TSOP32";
Name="SST49LF002B*TSOP32",ID="BF57",Class="49LF002",Category="FLASH",MFG="SST",Adapter="ADP-059 FWH/LPC+TSOP32";
Name="SST49LF003A*TSOP32",ID="BF1B",Class="49LF003",Category="FLASH",MFG="SST",CodeSize="393216",Adapter="ADP-059 FWH/LPC+TSOP32";
Name="SST49LF003B*TSOP32",ID="BF1B",Class="49LF003",Category="FLASH",MFG="SST",CodeSize="393216",Adapter="ADP-059 FWH/LPC+TSOP32";
Name="SST49LF004*TSOP32",ID="BF58",Class="49LF002",Category="FLASH",MFG="SST",CodeSize="524288",Adapter="ADP-059 FWH/LPC+TSOP32";//by EZo
Name="SST49LF004A*TSOP32",ID="BF60",Class="49LF002",Category="FLASH",MFG="SST",CodeSize="524288",Adapter="ADP-059 FWH/LPC+TSOP32";
Name="SST49LF004B*TSOP32",ID="BF60",Class="49LF002",Category="FLASH",MFG="SST",CodeSize="524288",Adapter="ADP-059 FWH/LPC+TSOP32";
Name="SST49LF004B*PLCC32",ID="BF60",Class="49LF002",Category="FLASH",MFG="SST",CodeSize="524288",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="SST49LF008A*PLCC32",ID="BF5A",Class="49LF002",Category="FLASH",MFG="SST",CodeSize="1048576",Adapter="ADP-030, ADP-057 FWH/LPC+V2";
Name="SST49LF008B",ID="BF5A",Class="49LF002",Category="FLASH",MFG="SST",CodeSize="1048576",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="SST49LF008A*TSOP32",ID="BF5A",Class="49LF002",Category="FLASH",MFG="SST",CodeSize="1048576",Adapter="ADP-059 FWH/LPC+TSOP32";
Name="SST49LF008A*TSOP40",ID="BF5A",Class="49LF002",Category="FLASH",MFG="SST",CodeSize="1048576",Adapter="FWH/LPC+TSOP40";
Name="PM49FL002T*PLCC32",ID="9D6D",Class="49LF002",Category="FLASH",MFG="PMC",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="PM49FL004T*PLCC32",ID="9D6E",Class="49LF002",Category="FLASH",MFG="PMC",CodeSize="524288",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="PM49FL002T*TSOP32",ID="9D6D",Class="49LF002",Category="FLASH",MFG="PMC",Adapter="ADP-059 FWH/LPC+";
Name="PM49FL004T*TSOP32",ID="9D6E",Class="49LF002",Category="FLASH",MFG="PMC",CodeSize="524288",Adapter="ADP-059 FWH/LPC+";
Name="W39V040APZ",ID="DA3D",Class="49LF002",Category="FLASH",MFG="WINBOND",Adapter="ADP-030, ADP-057 FWH/LPC+",CodeSize="524288";
Name="W39V040BPZ",ID="DA54",Class="49LF002",Category="FLASH",MFG="WINBOND",Adapter="ADP-030, ADP-057 FWH/LPC+",CodeSize="524288";
Name="W39V040FA",ID="DA34",Class="49LF002",Category="FLASH",MFG="WINBOND",Adapter="ADP-030, ADP-057 FWH/LPC+",CodeSize="524288";
Name="W39V040FB",ID="DA54",Class="49LF002",Category="FLASH",MFG="WINBOND",Adapter="ADP-030, ADP-057 FWH/LPC+",CodeSize="524288";
Name="W39V040FC",ID="DA50",Class="49LF002",Category="FLASH",MFG="WINBOND",Adapter="ADP-030, ADP-057 FWH/LPC+",CodeSize="524288";
Name="W39V080AP",ID="DAD0",Class="49LF002",Category="FLASH",MFG="WINBOND",Adapter="ADP-030, ADP-057 FWH/LPC+",CodeSize="1048576",Message="Try to slowdown the speed when erasing if erase fail.";
Name="W39V080APZ",ID="DAD0",Class="49LF002",Category="FLASH",MFG="WINBOND",Adapter="ADP-030, ADP-057 FWH/LPC+",CodeSize="1048576",Message="Try to slowdown the speed when erasing if erase fail.";
Name="W39V080AQ",ID="DAD0",Class="49LF002",Category="FLASH",MFG="WINBOND",CodeSize="1048576",Adapter="ADP-059 FWH/LPC+ TSOP32(S)";
Name="W39V080AQZ",ID="DAD0",Class="49LF002",Category="FLASH",MFG="WINBOND",CodeSize="1048576",Adapter="ADP-059 FWH/LPC+ TSOP32(S)";
Name="W39V080AT",ID="DAD0",Class="49LF002",Category="FLASH",MFG="WINBOND",CodeSize="1048576",Adapter="ADP-061 FWH/LPC+ TSOP40";
Name="W39V080ATZ",ID="DAD0",Class="49LF002",Category="FLASH",MFG="WINBOND",CodeSize="1048576",Adapter="ADP-061 FWH/LPC+ TSOP40";
Name="W49V002A",ID="DAB0",Class="49LF002",Category="Flash",MFG="WINBOND",Adapter="FWH/LCP+";//by JeanGuy
Name="W49V002FA",ID="DA32",Class="49LF002",Category="Flash",MFG="WINBOND",Adapter="FWH/LCP+";//by EZo
Name="W39V080FAP",ID="DAD3",Class="49LF002",Category="FLASH",MFG="WINBOND",Adapter="ADP-030, ADP-057 FWH/LPC+",CodeSize="1048576";
Name="W39V080FAPZ",ID="DAD3",Class="49LF002",Category="FLASH",MFG="WINBOND",Adapter="ADP-030, ADP-057 FWH/LPC+",CodeSize="1048576";
Name="W39V080FAQ",ID="DAD3",Class="49LF002",Category="FLASH",MFG="WINBOND",CodeSize="1048576",Adapter="ADP-059 FWH/LPC+ TSOP32(S)";
Name="W39V080FAQZ",ID="DAD3",Class="49LF002",Category="FLASH",MFG="WINBOND",CodeSize="1048576",Adapter="ADP-059 FWH/LPC+ TSOP32(S)";
Name="W39V080FAT",ID="DAD3",Class="49LF002",Category="FLASH",MFG="WINBOND",CodeSize="1048576",Adapter="ADP-061 FWH/LPC+ TSOP40";
Name="W39V080FATZ",ID="DAD3",Class="49LF002",Category="FLASH",MFG="WINBOND",CodeSize="1048576",Adapter="ADP-061 FWH/LPC+ TSOP40";
;Name="SST49LF160C",ID="BF4C",Class="INTEL82802AB",Category="FLASH",MFG="SST",CodeSize="2097152",Adapter="ADP-030, ADP-057 FWH/LPC+";
Name="M50FW016*TSOP40",ID="202E",Class="M50FW016",Category="FLASH",MFG="ST",CodeSize="2097152",Adapter="ADP-030 FWH/LPC+ with ADP-035";
;* FLASH - 8bit mode *
;new chip tests, not supported by GQ
;Name="MBM29F080A",ID="04D5",Class="29F040B",Category="FLASH",MFG="Fujitsu",CodeSize="1048576";//by EZo
;Name="AM29LV116DB",ID="014C",Class="29F040B",Category="FLASH",MFG="AMD",CodeSize="2097152";//by EZo
;Name="AM29LV017B",ID="01C8",Class="29F040B",Category="FLASH",MFG="AMD",CodeSize="2097152";//by EZo
Name="AM29LV002T*TSOP40",ID="0140",Class="SST39LF/VF020",Category="FLASH",MFG="AMD",DIP="100011110101",Adapter="ADP-082, TSOP40A-DIP32",VCC="3.6V",Message="GQ-3X connect A19 from Adapter to Programmer.";
Name="AM29LV002B*TSOP40",ID="01C2",Class="SST39LF/VF020",Category="FLASH",MFG="AMD",DIP="100011110101",Adapter="ADP-082, TSOP40A-DIP32",VCC="3.6V",Message="GQ-3X Connect A19 from Adapter to Programmer.";
Name="AM29LV004T*TSOP40",ID="01B5",Class="SST39LF/VF040",Category="FLASH",MFG="AMD",DIP="100011110101",Adapter="ADP-082, TSOP40A-DIP32",VCC="3.6V",Message="GQ-3X Connect A19 from Adapter to Programmer.";
Name="AM29LV004B*TSOP40",ID="01B6",Class="SST39LF/VF040",Category="FLASH",MFG="AMD",DIP="100011110101",Adapter="ADP-082, TSOP40A-DIP32",VCC="3.6V",Message="GQ-3X Connect A19 from Adapter to Programmer.";
Name="AM29LV008T*TSOP40",ID="013E",Class="SST39LF/VF040",Category="FLASH",MFG="AMD",CodeSize="1048576",DIP="100011110101",Adapter="ADP-082, TSOP40A-DIP32",VCC="3.6V",Message="GQ-3X Connect A19 from Adapter to Programmer.";
Name="AM29LV008B*TSOP40",ID="0137",Class="SST39LF/VF040",Category="FLASH",MFG="AMD",CodeSize="1048576",DIP="100011110101",Adapter="ADP-082, TSOP40A-DIP32",VCC="3.6V",Message="GQ-3X Connect A19 from Adapter to Programmer.";
Name="AM29LV008BT*TSOP40",ID="013E",Class="SST39LF/VF040",Category="FLASH",MFG="AMD",CodeSize="1048576",DIP="100011110101",Adapter="ADP-082, TSOP40A-DIP32",VCC="3.6V",Message="GQ-3X Connect A19 from Adapter to Programmer.";
Name="AM29LV008BB*TSOP40",ID="0137",Class="SST39LF/VF040",Category="FLASH",MFG="AMD",CodeSize="1048576",DIP="100011110101",Adapter="ADP-082, TSOP40A-DIP32",VCC="3.6V",Message="GQ-3X Connect A19 from Adapter to Programmer.";
Name="AM28F256",ID="01A1",Class="28F512",Category="FLASH",MFG="AMD",CodeSize="32768";
Name="AM28F512",ID="0125",Class="28F512",Category="FLASH",MFG="AMD";
Name="AM28F010",ID="01A7",Class="28F010",Category="FLASH",MFG="AMD";//by EZo
Name="AM28F020",ID="012A",Class="28F020",Category="FLASH",MFG="AMD";
Name="AM28F512*PLCC32",ID="0125",Class="28F512",Category="FLASH",MFG="AMD",Adapter="ADP-062, ADP-005 PLCC32-DIP32";
Name="AM28F010*PLCC32",ID="01A7",Class="28F010",Category="FLASH",MFG="AMD",Adapter="ADP-062, ADP-005 PLCC32-DIP32";
Name="AM28F020*PLCC32",ID="012A",Class="28F020",Category="FLASH",MFG="AMD",Adapter="ADP-062, ADP-005 PLCC32-DIP32";
Name="AM29F010",ID="0120",Class="29F010",Category="FLASH",MFG="AMD";
Name="AM29F010*PLCC32",ID="0120",Class="29F010",Category="FLASH",MFG="AMD",Adapter="ADP-062, ADP-005 PLCC32-DIP32";
Name="AM29F010B",ID="0120",Class="29F010",Category="FLASH",MFG="AMD";
Name="AM29F002BT",ID="01B0",Class="29F002",Category="FLASH",MFG="AMD",WVPP="12V",TempUnprotect="Yes";
Name="AM29F002T",ID="01B0",Class="29F002",Category="FLASH",MFG="AMD",WVPP="12V",TempUnprotect="Yes";
Name="AM29F002NT",ID="01B0",Class="29F002",Category="FLASH",MFG="AMD";
Name="AM29F002NBT",ID="01B0",Class="29F002",Category="FLASH",MFG="AMD";
Name="AM29F002B",ID="0134",Class="29F002",Category="FLASH",MFG="AMD",WVPP="12V",TempUnprotect="Yes";
Name="AM29F002BB",ID="0134",Class="29F002",Category="FLASH",MFG="AMD",WVPP="12V",TempUnprotect="Yes";
Name="AM29F002NB",ID="0134",Class="29F002",Category="FLASH",MFG="AMD";
Name="AM29F002NBB",ID="0134",Class="29F002",Category="FLASH",MFG="AMD";
Name="AM29F040B",ID="01A4",Class="29F040B",Category="FLASH",MFG="AMD";
Name="AM29F080",ID="01D5",Class="29F040B",Category="FLASH",MFG="AMD",CodeSize="1048576",DIP="100011110101",Adapter="TSOP40B-D
IP32";
Name="AM29LV010B*PLCC32",ID="016E",Class="29F040B",CodeSize="131072",Category="FLASH",MFG="AMD",VCC="3.3V",Adapter="ADP-062, ADP-005 PLCC32-DIP32";
Name="AM29LV010B*TSOP32",ID="016E",Class="29F040B",CodeSize="131072",Category="FLASH",MFG="AMD",VCC="3.3V",Adapter="TSOP32-DIP32";
Name="AM29LV020B*PLCC32",ID="XXXX",Class="29F040B",CodeSize="262144",Category="FLASH",MFG="AMD",VCC="3.3V",Adapter="ADP-062, ADP-005 PLCC32-DIP32";
Name="AM29LV020B*TSOP32",ID="XXXX",Class="29F040B",CodeSize="262144",Category="FLASH",MFG="AMD",VCC="3.3V",Adapter="TSOP32-DIP32";
Name="AM29LV040B*PLCC32",ID="014F",Class="29F040B",Category="FLASH",MFG="AMD",VCC="3.3V",Adapter="ADP-062, ADP-005 PLCC32-DIP32";
Name="AM29LV040B*TSOP32",ID="014F",Class="29F040B",Category="FLASH",MFG="AMD",VCC="3.3V",Adapter="TSOP32-DIP32";
Name="AM29LV081B*TSOP40",ID="0138",Class="SST39LF/VF040",Category="FLASH",MFG="AMD",CodeSize="1048576",DIP="100011110101",Adapter="ADP-082, TSOP40A-DIP32 adapter",VCC="3.6V",Speed="3",Message=" Set the adapter to 5V jumper position and GQ-3X connect A19 from adapter to programmer.";
Name="AM29F016B*TSOP40",ID="01AD",Class="29F040B",Category="FLASH",MFG="AMD",CodeSize="2097152",DIP="100011110101",Adapter="ADP-082 OR ADP-076 TSOP40B";
Name="AM29F032B*TSOP40",ID="0141",Class="29F040B",Category="FLASH",MFG="AMD",CodeSize="4194304",DIP="100011110101",Adapter="TSOP40B-DIP32(ADP-077 and ADP-082)";
Name="AM29F100T",ID="01D9",Class="29F100T",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F100B",ID="01DF",Class="29F100B",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F200T",ID="0151",Class="29F200T",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F200B",ID="0157",Class="29F200B",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F400T",ID="0123",Class="29F400T",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F400B",ID="01AB",Class="29F400B",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F200AT",ID="0151",Class="29F200T",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F200AB",ID="0157",Class="29F200B",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F400AT",ID="0123",Class="29F400T",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F400AB",ID="01AB",Class="29F400B",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F200BT",ID="0151",Class="29F200T",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F200BB",ID="0157",Class="29F200B",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F400BT",ID="0123",Class="29F400T",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F400BB",ID="01AB",Class="29F400B",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F800T",ID="01D6",Class="29F800T",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F800BT",ID="01D6",Class="29F800T",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F800BB",ID="0158",Class="29F800B",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F800B",ID="0158",Class="29F800B",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F200T*PSOP44",ID="0151",Class="29F200T",Category="FLASH",MFG="AMD",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F200B*PSOP44",ID="0157",Class="29F200B",Category="FLASH",MFG="AMD",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F400T*PSOP44",ID="0123",Class="29F400T",Category="FLASH",MFG="AMD",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F400B*PSOP44",ID="01AB",Class="29F400B",Category="FLASH",MFG="AMD",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F200AT*PSOP44",ID="0151",Class="29F200T",Category="FLASH",MFG="AMD",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F200AB*PSOP44",ID="0157",Class="29F200B",Category="FLASH",MFG="AMD",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F400AT*PSOP44",ID="0123",Class="29F400T",Category="FLASH",MFG="AMD",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F400AB*PSOP44",ID="01AB",Class="29F400B",Category="FLASH",MFG="AMD",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F200BT*PSOP44",ID="0151",Class="29F200T",Category="FLASH",MFG="AMD",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F200BB*PSOP44",ID="0157",Class="29F200B",Category="FLASH",MFG="AMD",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F400BT*PSOP44",ID="0123",Class="29F400T",Category="FLASH",MFG="AMD",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F400BB*PSOP44",ID="01AB",Class="29F400B",Category="FLASH",MFG="AMD",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F800T*PSOP44",ID="01D6",Class="29F800T",Category="FLASH",MFG="AMD",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F800BT*PSOP44",ID="01D6",Class="29F800T",Category="FLASH",MFG="AMD",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F800BB*PSOP44",ID="0158",Class="29F800B",Category="FLASH",MFG="AMD",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F800B*PSOP44",ID="0158",Class="29F800B",Category="FLASH",MFG="AMD",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F160BT",ID="01D2",Class="29F160T",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F160BB",ID="01D8",Class="29F160B",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F160DT",ID="01D2",Class="29F160T",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29F160DB",ID="01D8",Class="29F160B",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="AM29LV200T",ID="013B",Class="29LV200T",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AM29LV200B",ID="01bf",Class="29LV200B",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AM29LV200BT",ID="013B",Class="29LV200T",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AM29LV200BB",ID="01bf",Class="29LV200B",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AM29LV400T",ID="01B9",Class="29LV400T",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AM29LV400B",ID="01BA",Class="29LV400B",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AM29LV400BT",ID="01B9",Class="29LV400T",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AM29LV400BB",ID="01BA",Class="29LV400B",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AM29LV800T",ID="01DA",Class="29LV800T",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AM29LV800B",ID="015B",Class="29LV800B",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AM29LV800BT",ID="01DA",Class="29LV800T",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AM29LV800BB",ID="015B",Class="29LV800B",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AM29LV800DT",ID="01DA",Class="29LV800T",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AM29LV800DB",ID="015B",Class="29LV800B",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AM29LV160BT",ID="01C4",Class="29LV160T",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AM29LV160BB",ID="0149",Class="29LV160B",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AM29LV160DT",ID="01C4",Class="29LV160T",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AM29LV160DB",ID="0149",Class="29LV160B",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AM29LV160MT",ID="01C4",Class="29LV160T",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AM29LV160MB",ID="0149",Class="29LV160B",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AM29LV320DT",ID="01F6",Class="29LV320T",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AM29LV320DB",ID="01F9",Class="29LV320B",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";//by EZo
Name="AM29LV32MT",ID="01F6",Class="29LV320T",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AM29LV32MB",ID="01F9",Class="29LV320B",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";//by EZo
Name="AM29DL400B",ID="010F",Class="29LV400B",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AM29DL400T",ID="010C",Class="29LV400T",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AM29DL400BB",ID="010F",Class="29LV400B",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AM29DL400BT",ID="010C",Class="29LV400T",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AM29DL800T",ID="014A",Class="29LV800T",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AM29DL800B",ID="01CB",Class="29LV800B",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AM29DL800BT",ID="014A",Class="29LV800T",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AM29DL800BB",ID="01CB",Class="29LV800B",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AM29DL800DT",ID="014A",Class="29LV800T",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AM29DL800DB",ID="01CB",Class="29LV800B",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AM29DL323CB",ID="0153",Class="29LV320B",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position."; // by EZo
Name="AM29DL323DB",ID="0153",Class="29LV320B",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AM29DL323GB",ID="0153",Class="29LV320B",Category="FLASH",MFG="AMD",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="S29AL004D..-01",ID="01B9",Class="29LV400T",Category="FLASH",MFG="SPANSION",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="S29AL004D..-02",ID="01BA",Class="29LV400B",Category="FLASH",MFG="SPANSION",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="S29AL008D..-01",ID="01DA",Class="29LV800T",Category="FLASH",MFG="SPANSION",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";//by EZo
Name="S29AL008D..-02",ID="015B",Class="29LV800B",Category="FLASH",MFG="SPANSION",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="S29AL016D..-01",ID="01C4",Class="29LV160T",Category="FLASH",MFG="SPANSION",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="S29AL016D..-02",ID="0149",Class="29LV160B",Category="FLASH",MFG="SPANSION",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";//by EZo
Name="S29AL016M..-01/R1",ID="01C4",Class="29LV160T",Category="FLASH",MFG="SPANSION",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="S29AL016M..-02/R2",ID="0149",Class="29LV160B",Category="FLASH",MFG="SPANSION",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="S29GL016A..-R1",ID="01C4",Class="29LV160T",Category="FLASH",MFG="SPANSION",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="S29AL016A..-R2",ID="0149",Class="29LV160B",Category="FLASH",MFG="SPANSION",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="S29AL032D..-03",ID="01F6",Class="29LV320T",Category="FLASH",MFG="SPANSION",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="S29AL032D..-04",ID="01F9",Class="29LV320B",Category="FLASH",MFG="SPANSION",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="S29JL032H90TF",ID="017E",Class="29LV320T",Category="FLASH",MFG="SPANSION",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
;Name="S29JL032H90BF",ID="017E",Class="29LV320T",Category="FLASH",MFG="SPANSION",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="S29GL032N90TFI030",ID="017E",Class="29LV320T",Category="FLASH",MFG="SPANSION",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="S29GL064N90TFI040",ID="017E",Class="29LV320T",Category="FLASH",MFG="SPANSION",CodeSize="8388608",Adapter="ADP-003 With MOD",VCC="3.6V",Message="Set the adapter to 5V, 29F jumper position. Using ADP-003 MOD 01. See: http://www.mcumall.com/support/scriptDP-003_MOD_01.jpg";
Name="A29010",ID="37A4",Class="29F010",Category="FLASH",MFG="AMIC";
Name="A29040",ID="3786",Class="29F040B",Category="FLASH",MFG="AMIC";
Name="A29040L",ID="3786",Class="29F040B",Category="FLASH",MFG="AMIC",Adapter="ADP-062, PLCC32-DIP32";
Name="A29040V",ID="3786",Class="29F040B",Category="FLASH",MFG="AMIC",Adapter="ADP-021,TSOP32-DIP32";
Name="A29040A",ID="3786",Class="29F040B",Category="FLASH",MFG="AMIC";
Name="A29040AL",ID="3786",Class="29F040B",Category="FLASH",MFG="AMIC",Adapter="ADP-062, PLCC32-DIP32";
Name="A29040AV",ID="3786",Class="29F040B",Category="FLASH",MFG="AMIC",Adapter="ADP-021,TSOP32-DIP32";
Name="A29040B",ID="3786",Class="29F040B",Category="FLASH",MFG="AMIC";
Name="A29040BL",ID="3786",Class="29F040B",Category="FLASH",MFG="AMIC",Adapter="ADP-062, PLCC32-DIP32";
Name="A29040BV",ID="3786",Class="29F040B",Category="FLASH",MFG="AMIC",Adapter="ADP-021,TSOP32-DIP32";
Name="A290011T",ID="37A1",Class="29F002",CodeSize="131072",Category="Flash",MFG="AMIC";
Name="A290011B",ID="374C",Class="29F002",CodeSize="131072",Category="Flash",MFG="AMIC";
Name="A290021T",ID="378C",Class="29F002",Category="Flash",MFG="AMIC";
Name="A290021B",ID="370D",Class="29F002",Category="Flash",MFG="AMIC";
Name="A290011TL",ID="37A1",Class="29F002",CodeSize="131072",Category="Flash",MFG="AMIC",Adapter="ADP-062, PLCC32-DIP32";
Name="A290011BL",ID="374C",Class="29F002",CodeSize="131072",Category="Flash",MFG="AMIC",Adapter="ADP-062, PLCC32-DIP32";
Name="A290011TV",ID="37A1",Class="29F002",CodeSize="131072",Category="Flash",MFG="AMIC",Adapter="ADP-021,TSOP32-DIP32";
Name="A290011BV",ID="374C",Class="29F002",CodeSize="131072",Category="Flash",MFG="AMIC",Adapter="ADP-021,TSOP32-DIP32";
Name="A290021TL",ID="378C",Class="29F002",Category="Flash",MFG="AMIC",Adapter="ADP-062, PLCC32-DIP32";
Name="A290021BL",ID="370D",Class="29F002",Category="Flash",MFG="AMIC",Adapter="ADP-062, PLCC32-DIP32";
Name="A290021TV",ID="378C",Class="29F002",Category="Flash",MFG="AMIC",Adapter="ADP-021,TSOP32-DIP32";
Name="A290021BV",ID="370D",Class="29F002",Category="Flash",MFG="AMIC",Adapter="ADP-021,TSOP32-DIP32";
Name="A29L040",ID="3786",Class="29F040B",Category="FLASH",,VCC="3.6V",MFG="AMIC";
Name="A29L008T*TSOP40",ID="371A",Class="SST39LF/VF040",Category="FLASH",MFG="AMIC",CodeSize="1048576",DIP="100011110101",Adapter="ADP-082 TSOP40A-DIP32",VCC="3.6V",Message="GQ-3X Connect A19 from Adapter to GQ-3X Programmer.";
Name="A29L008B*TSOP40",ID="379B",Class="SST39LF/VF040",Category="FLASH",MFG="AMIC",CodeSize="1048576",DIP="100011110101",Adapter="ADP-082 TSOP40A-DIP32",VCC="3.6V",Message="GQ-3X Connect A19 from Adapter to GQ-3X Programmer.";
Name="A29L008ATV",ID="371A",Class="SST39LF/VF040",Category="FLASH",MFG="AMIC",CodeSize="1048576",DIP="100011110101",Adapter="ADP-082 TSOP40A-DIP32",VCC="3.6V",Message="GQ-3X Connect A19 from Adapter to GQ-3X Programmer.";
;Name="AC39LV080",ID="7F7F21",Class="SST39LF/VF040",Category="FLASH",MFG="ACTRANS SYSTEM",CodeSize="1048576",DIP="100011110101",Adapter="ADP-082, TSOP40A-DIP32",VCC="5V",Speed="4",Message="Open adapter Vcc jumper to 3.3V ";
Name="AT29C256",ID="1FDC",Class="AT29C256",Category="FLASH",MFG="Atmel";
Name="AT29C257",ID="1FDC",Class="AT29C256",Category="FLASH",MFG="Atmel",DIP="100011100110",PINVCC="ZIF32_PIN32",PINGROUP="NORMAL";
Name="AT29LV256",ID="1FBC",Class="AT29C256",Category="FLASH",MFG="Atmel",VCC="3.6V";
Name="AT29C256*PLCC32",ID="1FDC",Class="AT29C256",Category="FLASH",MFG="Atmel",Adapter="ADP-006, ADP-029, PLCC32-DIP28";
Name="AT29C257*PLCC32",ID="1FDC",Class="AT29C256",Category="FLASH",MFG="Atmel",DIP="100011100110",PINVCC="ZIF32_PIN32",PINGROUP="NORMAL",Adapter="ADP-005, ADP-062, PLCC32-DIP32";
Name="AT29LV256*PLCC32",ID="1FBC",Class="AT29C256",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-006, ADP-029, PLCC32-DIP28";
Name="AT29C512",ID="1F5D",Class="AT29C512",Category="FLASH",MFG="Atmel";
Name="AT29LV512",ID="1F3D",Class="AT29C512",Category="FLASH",MFG="Atmel",VCC="3.6V";
Name="AT29C010A",ID="1FD5",Class="AT29C010",Category="FLASH",MFG="Atmel";
Name="AT29LV010A",ID="1F35",Class="AT29C010",Category="FLASH",MFG="Atmel",VCC="3.6V";
Name="AT29BV010A",ID="1F35",Class="AT29C010",Category="FLASH",MFG="Atmel",VCC="3.6V";
Name="AT29C020",ID="1FDA",Class="AT29C020",Category="FLASH",MFG="Atmel";
Name="AT29LV020",ID="1FBA",Class="AT29C020",Category="FLASH",MFG="Atmel",VCC="3.6V";
Name="AT29BV020",ID="1FBA",Class="AT29C020",Category="FLASH",MFG="Atmel",VCC="3.6V";
Name="AT29C040",ID="1F5B",Class="AT29C040",Category="FLASH",MFG="Atmel";
Name="AT29LV040",ID="1F3B",Class="AT29C040",Category="FLASH",MFG="Atmel",VCC="3.6V";
Name="AT29BV040",ID="1F3B",Class="AT29C040",Category="FLASH",MFG="Atmel",VCC="3.6V";
Name="AT29C040A",ID="1FA4",Class="AT29C040A",Category="FLASH",MFG="Atmel";
Name="AT29LV040A",ID="1FC4",Class="AT29C040A",Category="FLASH",MFG="Atmel",VCC="3.6V";
Name="AT29BV040A",ID="1FC4",Class="AT29C040A",Category="FLASH",MFG="Atmel",VCC="3.6V";
Name="AT29C512*PLCC32",ID="1F5D",Class="AT29C512",Category="FLASH",MFG="Atmel",Adapter="ADP-005,ADP-062, PLCC32-DIP32";
Name="AT29LV512*PLCC32",ID="1F3D",Class="AT29C512",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-005,ADP-062, PLCC32-DIP32";
Name="AT29C010A*PLCC32",ID="1FD5",Class="AT29C010",Category="FLASH",MFG="Atmel",Adapter="ADP-005,ADP-062, PLCC32-DIP32";
Name="AT29LV010A*PLCC32",ID="1F35",Class="AT29C010",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-005,ADP-062, PLCC32-DIP32";
Name="AT29BV010A*PLCC32",ID="1F35",Class="AT29C010",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-005,ADP-062, PLCC32-DIP32";
Name="AT29C020*PLCC32",ID="1FDA",Class="AT29C020",Category="FLASH",MFG="Atmel",Adapter="ADP-005,ADP-062, PLCC32-DIP32";
Name="AT29LV020*PLCC32",ID="1FBA",Class="AT29C020",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-005,ADP-062, PLCC32-DIP32";
Name="AT29BV020*PLCC32",ID="1FBA",Class="AT29C020",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-005,ADP-062, PLCC32-DIP32";
Name="AT29C040*PLCC32",ID="1F5B",Class="AT29C040",Category="FLASH",MFG="Atmel",Adapter="ADP-005,ADP-062, PLCC32-DIP32";
Name="AT29LV040*PLCC32",ID="1F3B",Class="AT29C040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-005,ADP-062, PLCC32-DIP32";
Name="AT29BV040*PLCC32",ID="1F3B",Class="AT29C040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-005,ADP-062, PLCC32-DIP32";
Name="AT29C040A*PLCC32",ID="1FA4",Class="AT29C040A",Category="FLASH",MFG="Atmel",Adapter="ADP-005,ADP-062, PLCC32-DIP32";
Name="AT29LV040A*PLCC32",ID="1FC4",Class="AT29C040A",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-005,ADP-062, PLCC32-DIP32";
Name="AT29BV040A*PLCC32",ID="1FC4",Class="AT29C040A",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-005,ADP-062, PLCC32-DIP32";
Name="AT29C010A*TSOP32",ID="1FD5",Class="AT29C010",Category="FLASH",MFG="Atmel",Adapter="ADP-021 TSOP32-DIP32";
Name="AT29LV010A*TSOP32",ID="1F35",Class="AT29C010",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-021 TSOP32-DIP32";
Name="AT29BV010A*TSOP32",ID="1F35",Class="AT29C010",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-021 TSOP32-DIP32";
Name="AT29C020*TSOP32",ID="1FDA",Class="AT29C020",Category="FLASH",MFG="Atmel",Adapter="ADP-021 TSOP32-DIP32";
Name="AT29LV020*TSOP32",ID="1FBA",Class="AT29C020",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-021 TSOP32-DIP32";
Name="AT29BV020*TSOP32",ID="1FBA",Class="AT29C020",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-021 TSOP32-DIP32";
Name="AT29C040*TSOP32",ID="1F5B",Class="AT29C040",Category="FLASH",MFG="Atmel",Adapter="ADP-021 TSOP32-DIP32";
Name="AT29LV040*TSOP32",ID="1F3B",Class="AT29C040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-021 TSOP32-DIP32";
Name="AT29BV040*TSOP32",ID="1F3B",Class="AT29C040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-021 TSOP32-DIP32";
Name="AT29C040A*TSOP32",ID="1FA4",Class="AT29C040A",Category="FLASH",MFG="Atmel",Adapter="ADP-021 TSOP32-DIP32";
Name="AT29LV040A*TSOP32",ID="1FC4",Class="AT29C040A",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-021 TSOP32-DIP32";
Name="AT29BV040A*TSOP32",ID="1FC4",Class="AT29C040A",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-021 TSOP32-DIP32";
Name="AT49F001",ID="1F05",Class="49F002",Category="FLASH",MFG="Atmel",VCC="5V",RVPP="5V",CodeSize="131072",TempUnprotect="Yes";
Name="AT49F001A",ID="1F05",Class="49F002",Category="FLASH",MFG="Atmel",VCC="5V",RVPP="5V",CodeSize="131072",TempUnprotect="Yes";
Name="AT49F001T",ID="1F04",Class="49F002NT",Category="FLASH",MFG="Atmel",VCC="5V",RVPP="5V",CodeSize="131072",TempUnprotect="Yes";
Name="AT49F001AT",ID="1F04",Class="49F002NT",Category="FLASH",MFG="Atmel",VCC="5V",RVPP="5V",CodeSize="131072",TempUnprotect="Yes";
Name="AT49F001N",ID="1F05",Class="49F002",Category="FLASH",MFG="Atmel",VCC="5V",RVPP="5V",CodeSize="131072",TempUnprotect="Yes";
Name="AT49F00AN",ID="1F05",Class="49F002",Category="FLASH",MFG="Atmel",VCC="5V",RVPP="5V",CodeSize="131072",TempUnprotect="Yes";
Name="AT49F001NT",ID="1F04",Class="49F002NT",Category="FLASH",MFG="Atmel",VCC="5V",RVPP="5V",CodeSize="131072",TempUnprotect="Yes";
Name="AT49F001ANT",ID="1F04",Class="49F002NT",Category="FLASH",MFG="Atmel",VCC="5V",RVPP="5V",CodeSize="131072",TempUnprotect="Yes";
Name="AT49F002",ID="1F07",Class="49F002",Category="FLASH",MFG="Atmel",VCC="5V",RVPP="5V",TempUnprotect="Yes";
Name="AT49F002A",ID="1F07",Class="49F002",Category="FLASH",MFG="Atmel",VCC="5V",RVPP="5V",TempUnprotect="Yes";
Name="AT49F002N",ID="1F07",Class="49F002",Category="FLASH",MFG="Atmel",VCC="5V",RVPP="5V",TempUnprotect="Yes";
Name="AT49F002AN",ID="1F07",Class="49F002",Category="FLASH",MFG="Atmel",VCC="5V",RVPP="5V",TempUnprotect="Yes";
Name="AT49F002T",ID="1F08",Class="49F002NT",Category="FLASH",MFG="Atmel",VCC="5V",RVPP="5V",TempUnprotect="Yes";
Name="AT49F002AT",ID="1F08",Class="49F002NT",Category="FLASH",MFG="Atmel",VCC="5V",RVPP="5V",TempUnprotect="Yes";
Name="AT49F002NT",ID="1F08",Class="49F002NT",Category="FLASH",MFG="Atmel",VCC="5V",RVPP="5V",TempUnprotect="Yes";
Name="AT49F002ANT",ID="1F08",Class="49F002NT",Category="FLASH",MFG="Atmel",VCC="5V",RVPP="5V",TempUnprotect="Yes";
Name="AT49LV001",ID="1F05",Class="AT49LV001",Category="FLASH",MFG="Atmel",RVPP="5V";
Name="AT49LV001A",ID="1F05",Class="AT49LV001",Category="FLASH",MFG="Atmel",RVPP="5V";
Name="AT49LV001N",ID="1F05",Class="AT49LV001",Category="FLASH",MFG="Atmel";
Name="AT49LV00AN",ID="1F05",Class="AT49LV001",Category="FLASH",MFG="Atmel";
Name="AT49LV001T",ID="1F04",Class="AT49LV001",Category="FLASH",MFG="Atmel",RVPP="5V";
Name="AT49LV001AT",ID="1F04",Class="AT49LV001",Category="FLASH",MFG="Atmel",RVPP="5V";
Name="AT49LV001NT",ID="1F04",Class="AT49LV001",Category="FLASH",MFG="Atmel",RVPP="5V";
Name="AT49LV001ANT",ID="1F04",Class="AT49LV001",Category="FLASH",MFG="Atmel",RVPP="5V";
Name="AT49BV001",ID="1F05",Class="AT49LV001",Category="FLASH",MFG="Atmel";
Name="AT49BV001A",ID="1F05",Class="AT49LV001",Category="FLASH",MFG="Atmel";
Name="AT49BV001N",ID="1F05",Class="AT49LV001",Category="FLASH",MFG="Atmel";
Name="AT49BV001AN",ID="1F05",Class="AT49LV001",Category="FLASH",MFG="Atmel";
Name="AT49BV001T",ID="1F04",Class="AT49LV001",Category="FLASH",MFG="Atmel",RVPP="5V";
Name="AT49BV001AT",ID="1F04",Class="AT49LV001",Category="FLASH",MFG="Atmel",RVPP="5V";
Name="AT49BV001NT",ID="1F04",Class="AT49LV001",Category="FLASH",MFG="Atmel";
Name="AT49BV001ANT",ID="1F04",Class="AT49LV001",Category="FLASH",MFG="Atmel";
Name="AT49LV002",ID="1F07",Class="AT49LV001",Category="FLASH",MFG="Atmel",RVPP="5V",CodeSize="262144";
Name="AT49BV002,A",ID="1F07",Class="AT49LV001",Category="FLASH",MFG="Atmel",RVPP="5V",CodeSize="262144";
Name="AT49LV002N",ID="1F07",Class="AT49LV001",Category="FLASH",MFG="Atmel",CodeSize="262144";
Name="AT49BV002N",ID="1F07",Class="AT49LV001",Category="FLASH",MFG="Atmel",CodeSize="262144";
Name="AT49BV002AN",ID="1F07",Class="AT49LV001",Category="FLASH",MFG="Atmel",CodeSize="262144";
Name="AT49LV002T",ID="1F08",Class="AT49LV001",Category="FLASH",MFG="Atmel",RVPP="5V",CodeSize="262144";
Name="AT49BV002T",ID="1F08",Class="AT49LV001",Category="FLASH",MFG="Atmel",RVPP="5V",CodeSize="262144";
Name="AT49BV002AT",ID="1F08",Class="AT49LV001",Category="FLASH",MFG="Atmel",RVPP="5V",CodeSize="262144";
Name="AT49LV002NT",ID="1F08",Class="AT49LV001",Category="FLASH",MFG="Atmel",CodeSize="262144";
Name="AT49BV002NT",ID="1F08",Class="AT49LV001",Category="FLASH",MFG="Atmel",CodeSize="262144";
Name="AT49BV002ANT",ID="1F08",Class="AT49LV001",Category="FLASH",MFG="Atmel",CodeSize="262144";
Name="AT49F010",ID="1F17",Class="SST39LF/VF010",Category="FLASH",MFG="Atmel",VCC="5V";
Name="AT49F020",ID="1F0B",Class="SST39LF/VF020",Category="FLASH",MFG="Atmel",VCC="5V";
Name="AT49F040",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="5V";
Name="AT49LV010*PLCC32",ID="1F17",Class="SST39LF/VF010",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-062, PLCC32-DIP32";
Name="AT49LV020*PLCC32",ID="1F0B",Class="SST39LF/VF020",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-062, PLCC32-DIP32";
Name="AT49LV040*PLCC32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-062, PLCC32-DIP32";
Name="AT49LV040T*PLCC32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-062, PLCC32-DIP32";
Name="AT49LV040B*PLCC32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-062, PLCC32-DIP32";
Name="AT49LV010*TSOP32",ID="1F17",Class="SST39LF/VF010",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-021,TSOP32-DIP32";
Name="AT49LV020*TSOP32",ID="1F0B",Class="SST39LF/VF020",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-021,TSOP32-DIP32";
Name="AT49LV040*TSOP32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-021,TSOP32-DIP32";
Name="AT49LV040T*TSOP32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-021,TSOP32-DIP32";
Name="AT49LV040B*TSOP32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-021,TSOP32-DIP32";
Name="AT49LV010*VSOP32",ID="1F17",Class="SST39LF/VF010",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-022,TSOP32-DIP32(S)";
Name="AT49LV020*VSOP32",ID="1F0B",Class="SST39LF/VF020",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-022,TSOP32-DIP32(S)";
Name="AT49LV040*VSOP32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-022,TSOP32-DIP32(S)";
Name="AT49LV040T*VSOP32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-022,TSOP32-DIP32(S)";
Name="AT49LV040B*VSOP32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-022,TSOP32-DIP32(S)";
Name="AT49BV010*PLCC32",ID="1F17",Class="SST39LF/VF010",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-062, PLCC32-DIP32";
Name="AT49BV020*PLCC32",ID="1F0B",Class="SST39LF/VF020",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-062, PLCC32-DIP32";
Name="AT49BV040*PLCC32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-062, PLCC32-DIP32";
Name="AT49BV040T*PLCC32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-062, PLCC32-DIP32";
Name="AT49BV040B*PLCC32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-062, PLCC32-DIP32";
Name="AT49BV010*TSOP32",ID="1F17",Class="SST39LF/VF010",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-021,TSOP32-DIP32";
Name="AT49BV020*TSOP32",ID="1F0B",Class="SST39LF/VF020",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-021,TSOP32-DIP32";
Name="AT49BV040*TSOP32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-021,TSOP32-DIP32";
Name="AT49BV040T*TSOP32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-021,TSOP32-DIP32";
Name="AT49BV040B*TSOP32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-021,TSOP32-DIP32";
Name="AT49BV010*VSOP32",ID="1F17",Class="SST39LF/VF010",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-022,TSOP32-DIP32(S)";
Name="AT49BV020*VSOP32",ID="1F0B",Class="SST39LF/VF020",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-022,TSOP32-DIP32(S)";
Name="AT49BV040*VSOP32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-022,TSOP32-DIP32(S)";
Name="AT49BV040T*VSOP32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-022,TSOP32-DIP32(S)";
Name="AT49BV040B*VSOP32",ID="1F13",Class="SST39LF/VF040",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-022,TSOP32-DIP32(S)";
Name="AT49HBV010*PLCC32",ID="1F17",Class="SST39LF/VF010",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-062, PLCC32-DIP32";
Name="AT49HBV010*TSOP32",ID="1F17",Class="SST39LF/VF010",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-021,TSOP32-DIP32";
Name="AT49HBV010*VSOP32",ID="1F17",Class="SST39LF/VF010",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-022,TSOP32-DIP32(S)";
Name="AT49HLV010*PLCC32",ID="1F17",Class="SST39LF/VF010",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-062, PLCC32-DIP32";
Name="AT49HLV010*TSOP32",ID="1F17",Class="SST39LF/VF010",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-021,TSOP32-DIP32";
Name="AT49HLV010*VSOP32",ID="1F17",Class="SST39LF/VF010",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-022,TSOP32-DIP32(S)";
Name="AT49BV512",ID="1F03",Class="SST39LF/VF010",CodeSize="65536",Category="FLASH",MFG="Atmel",VCC="3.6V";
Name="AT49BV512*PLCC32",ID="1F03",Class="SST39LF/VF010",CodeSize="65536",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-062, PLCC32-DIP32";
Name="AT49BV512*TSOP32",ID="1F03",Class="SST39LF/VF010",CodeSize="65536",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-021,TSOP32-DIP32";
Name="AT49BV512*VSOP32",ID="1F03",Class="SST39LF/VF010",CodeSize="65536",Category="FLASH",MFG="Atmel",VCC="3.6V",Adapter="ADP-022,TSOP32-DIP32(S)";
Name="AT49LV1614",ID="1FC0",Class="29LV160B",Category="FLASH",MFG="Atmel",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AT49LV1614A",ID="1FC0",Class="29LV160T",Category="FLASH",MFG="Atmel",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AT49LV1614AT",ID="1FC2",Class="29LV160T",Category="FLASH",MFG="Atmel",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="AT49BV163DT",ID="1FC2",Class="29LV160T",Category="FLASH",MFG="Atmel",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="5V",Message="Set the adapter to 3V jumper position.";
Name="At49BV320",ID="1FC8",Class="29LV320B",Category="FLASH",MFG="Atmel",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="At49BV320T",ID="01C9",Class="29LV320B",Category="FLASH",MFG="Atmel",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="At49LV320",ID="1FC8",Class="29LV320B",Category="FLASH",MFG="Atmel",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="At49LV320T",ID="01C9",Class="29LV320B",Category="FLASH",MFG="Atmel",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="At49BV321",ID="1FC8",Class="29LV320B",Category="FLASH",MFG="Atmel",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="At49BV321T",ID="01C9",Class="29LV320B",Category="FLASH",MFG="Atmel",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="At49LV321",ID="1FC8",Class="29LV320B",Category="FLASH",MFG="Atmel",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="At49LV321T",ID="01C9",Class="29LV320B",Category="FLASH",MFG="Atmel",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
;Name="AT49BV163A",ID="1FC0",Class="29LV160T",Category="FLASH",MFG="Atmel",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="5V",Message="Set the adapter to 3V jumper position.";
;Name="AT49BV162A",ID="1FC0",Class="29LV160T",Category="FLASH",MFG="Atmel",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="5V",Message="Set the adapter to 3V jumper position.";
Name="AT49BV162AT",ID="1FC2",Class="29LV160T",Category="FLASH",MFG="Atmel",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="5V",Message="Set the adapter to 3V jumper position.";
Name="CAT28F001xI-xxB",ID="3195",Class="INTEL28F001BX-B",Category="FLASH",MFG="Catalyst",RVPP="5V",EVPP="12V",VCC="5V";
Name="CAT28F001xI-xxT",ID="3194",Class="INTEL28F001BX-T",Category="FLASH",MFG="Catalyst",RVPP="5V",EVPP="12V",VCC="5V";
Name="CAT28F512",ID="31B8",Class="28F512",Category="FLASH",MFG="Catalyst";
Name="CAT28F010",ID="31B4",Class="28F010",Category="FLASH",MFG="Catalyst";//by EZo
Name="CAT28F020",ID="31BD",Class="28F020",Category="FLASH",MFG="Catalyst";
Name="CAT28F102",ID="3151",Class="28F102",Category="FLASH",MFG="Catalyst",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";
Name="MTF39VF040",ID="XXXX",Class="SST39LF/VF040",Category="FLASH",MFG="CWI"
Name="ID39SF040",ID="XXXX",Class="SST39LF/VF040",Category="FLASH",MFG="SSTT",VCC="5V";
Name="EN29F002NT",ID="7F1C7F92",Class="29F002NT",Category="FLASH",MFG="Eon Silicon";
Name="EN29F040A",ID="7F1C7F4F",Class="29F040B",Category="FLASH",MFG="Eon Silicon";
Name="EN29LV040A",ID="XXXX",Class="29F040B",VCC="3.6V",Category="FLASH",MFG="Eon Silicon";
Name="EN29LV040A*TSOP32",ID="XXXX",Class="29F040B",VCC="3.6V",Category="FLASH",MFG="Eon Silicon",Adapter="ADP-021 TSOP32-DIP32 20mm";
Name="EN29LV800T",ID="1CDA",Class="29LV800T",Category="FLASH",MFG="Eon Silicon",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position,29FXXX.";
Name="EN29LV800B",ID="1C5B",Class="29LV800B",Category="FLASH",MFG="Eon Silicon",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position,29FXXX.";
Name="EN29LV160BT",ID="1CC4",Class="29LV160T",Category="FLASH",MFG="Eon Silicon",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position, 29FXXX.";
Name="EN29LV160BB",ID="1C49",Class="29LV160B",Category="FLASH",MFG="Eon Silicon",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position, 29FXXX.";
Name="EN29LV160AT",ID="XXXX",Class="29LV160T",Category="FLASH",MFG="Eon Silicon",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position, 29FXXX.";
Name="EN29LV160AB",ID="XXXX",Class="29LV160B",Category="FLASH",MFG="Eon Silicon",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position, 29FXXX.";
Name="EN29LV320AT",ID="1CF6",Class="29LV320T",Category="FLASH",MFG="Eon Silicon",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position, 29FXXX.";
Name="EN29LV320AB",ID="1CF9",Class="29LV320B",Category="FLASH",MFG="Eon Silicon",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position, 29FXXX.";
Name="HY29F002TC",ID="ADB0",Class="29F002NT",Category="FLASH",MFG="Hynix";
Name="HY29F040",ID="ADA4",Class="29F040B",Category="FLASH",MFG="Hynix";
Name="N(P)28F001BX-B",ID="8995",Class="INTEL28F001BX-B",Category="FLASH",MFG="INTEL",RVPP="5V",EVPP="12V",VCC="5V";
Name="N(P)28F001BX-T",ID="8994",Class="INTEL28F001BX-T",Category="FLASH",MFG="INTEL",RVPP="5V",EVPP="12V",VCC="5V";
Name="AN28F512",ID="89B8",Class="28F512",Category="FLASH",MFG="INTEL";
Name="AP28F010",ID="89B4",Class="28F010",Category="FLASH",MFG="INTEL";//by EZo
Name="AP28F020",ID="89BD",Class="28F020",Category="FLASH",MFG="INTEL";//edited by EZo
Name="AN28F010*PLCC32",ID="89B4",Class="28F010",Category="FLASH",MFG="INTEL",Adapter="ADP-062, ADP-005 PLCC32-DIP32";
Name="AN28F020*PLCC32",ID="89BD",Class="28F020",Category="FLASH",MFG="INTEL",Adapter="ADP-062, ADP-005 PLCC32-DIP32";
Name="M28F010",ID="89B4",Class="28F010",Category="FLASH",MFG="INTEL";
Name="N28F010",ID="89B4",Class="28F010",Category="FLASH",MFG="INTEL";
Name="M28F010*PLCC32",ID="89B4",Class="28F010",Category="FLASH",MFG="INTEL",Adapter="ADP-062, ADP-005 PLCC32-DIP32";
Name="N28F010*PLCC32",ID="89B4",Class="28F010",Category="FLASH",MFG="INTEL",Adapter="ADP-062, ADP-005 PLCC32-DIP32";
Name="M28F010*TSOP32*20mm",ID="89B4",Class="28F010",Category="FLASH",MFG="INTEL",Adapter="ADP-021, TSOP32-DIP32"; // by Sucuka
;Name="E28F004B5B*TSOP40",ID="8979",Class="INTEL28F400BX-B",DIP="100011110101",Category="FLASH",MFG="INTEL",Adapter="ADP-082 + ADP-077",RVPP="5V",EVPP="12V";
;Name="E28F004B5T*TSOP40",ID="8978",Class="INTEL28F400BX-B",DIP="100011110101",Category="FLASH",MFG="INTEL",Adapter="ADP-082 + ADP-077",RVPP="5V",EVPP="12V";
Name="PA28F200BX-B*PSOP44",ID="8975",Class="INTEL28F200BX-B",Category="FLASH",MFG="INTEL",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",EVPP="12V";
Name="PA28F200BX-T*PSOP44",ID="8974",Class="INTEL28F200BX-T",Category="FLASH",MFG="INTEL",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",EVPP="12V";
Name="PA28F400BX-B*PSOP44",ID="8971",Class="INTEL28F400BX-B",Category="FLASH",MFG="INTEL",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",EVPP="12V";
Name="PA28F400BX-T*PSOP44",ID="8970",Class="INTEL28F400BX-T",Category="FLASH",MFG="INTEL",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",EVPP="12V";
Name="PA28F400B5T*PSOP44",ID="8970",Class="INTEL28F400BX-T",Category="FLASH",MFG="INTEL",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",EVPP="12V";
Name="PA28F400B5B*PSOP44",ID="8971",Class="INTEL28F400BX-B",Category="FLASH",MFG="INTEL",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",EVPP="12V";
Name="PA28F800BX-B*PSOP44",ID="899D",Class="INTEL28F800BX-B",Category="FLASH",MFG="INTEL",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",EVPP="12V";
Name="PA28F800BX-T*PSOP44",ID="899C",Class="INTEL28F800BX-T",Category="FLASH",MFG="INTEL",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",EVPP="12V";
Name="AB28F200BX-B*PSOP44",ID="8975",Class="INTEL28F200BX-B",Category="FLASH",MFG="INTEL",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",EVPP="12V";
Name="AB28F200BX-T*PSOP44",ID="8974",Class="INTEL28F200BX-T",Category="FLASH",MFG="INTEL",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",EVPP="12V";
Name="AB28F400BX-B*PSOP44",ID="8971",Class="INTEL28F400BX-B",Category="FLASH",MFG="INTEL",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",EVPP="12V";
Name="AB28F400BX-T*PSOP44",ID="8970",Class="INTEL28F400BX-T",Category="FLASH",MFG="INTEL",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",EVPP="12V";
Name="AB28F800BX-B*PSOP44",ID="899D",Class="INTEL28F800BX-B",Category="FLASH",MFG="INTEL",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",EVPP="12V";
Name="AB28F800BX-T*PSOP44",ID="899C",Class="INTEL28F800BX-T",Category="FLASH",MFG="INTEL",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",EVPP="12V";
Name="PM39LV512*PLCC32",ID="9D1B",Class="SST39LF/VF010",CodeSize="65536",Category="FLASH",MFG="PMC",VCC="3.6V",Adapter="ADP-062, PLCC32-DIP32";
Name="PM39LV010*PLCC32",ID="9D1C",Class="SST39LF/VF010",Category="FLASH",MFG="PMC",VCC="3.6V",Adapter="ADP-062, PLCC32-DIP32";
Name="PM39LV020*PLCC32",ID="9D3D",Class="SST39LF/VF020",Category="FLASH",MFG="PMC",VCC="3.6V",Adapter="ADP-062, PLCC32-DIP32";
Name="PM39LV040*PLCC32",ID="9D3E",Class="SST39LF/VF040",Category="FLASH",MFG="PMC",VCC="3.6V",Adapter="ADP-062, PLCC32-DIP32";
Name="PM39LV512*VSOP32",ID="9D1B",Class="SST39LF/VF010",CodeSize="65536",Category="FLASH",MFG="PMC",VCC="3.6V",Adapter="ADP-022, TSOP32-DIP32(S)";
Name="PM39LV010*VSOP32",ID="9D1C",Class="SST39LF/VF010",Category="FLASH",MFG="PMC",VCC="3.6V",Adapter="ADP-022, TSOP32-DIP32(S)";
Name="PM39LV020*VSOP32",ID="9D3D",Class="SST39LF/VF020",Category="FLASH",MFG="PMC",VCC="3.6V",Adapter="ADP-022, TSOP32-DIP32(S)";
Name="PM39LV040*VSOP32",ID="9D3E",Class="SST39LF/VF040",Category="FLASH",MFG="PMC",VCC="3.6V",Adapter="ADP-022, TSOP32-DIP32(S)";
Name="PM39F010",ID="9D1C",Class="SST39LF/VF010",Category="FLASH",MFG="PMC",VCC="5V";
Name="PM39F020",ID="9D4D",Class="SST39LF/VF020",Category="FLASH",MFG="PMC",VCC="5V";
Name="PM39F040",ID="9D4E",Class="SST39LF/VF040",Category="FLASH",MFG="PMC",VCC="5V";
Name="PM39F010*PLCC32",ID="9D1C",Class="SST39LF/VF010",Category="FLASH",MFG="PMC",VCC="5V",Adapter="ADP-062, PLCC32-DIP32";
Name="PM39F020*PLCC32",ID="9D4D",Class="SST39LF/VF020",Category="FLASH",MFG="PMC",VCC="5V",Adapter="ADP-062, PLCC32-DIP32";
Name="PM39F040*PLCC32",ID="9D4E",Class="SST39LF/VF040",Category="FLASH",MFG="PMC",VCC="5V",Adapter="ADP-062, PLCC32-DIP32";
Name="MBM29F040*PLCC32",ID="04A4",Class="29F040B",Category="FLASH",MFG="Fujitsu",Adapter="ADP-062, ADP-005 PLCC32-DIP32";
Name="MBM29F040*TSOP32",ID="04A4",Class="29F040B",Category="FLASH",MFG="Fujitsu",Adapter="TSOP32-DIP32";
Name="MBM29F002T*PLCC32",ID="04B0",Class="29F002",Category="FLASH",MFG="Fujitsu",Adapter="ADP-062, ADP-005 PLCC32-DIP32";
Name="MBM29F002T*TSOP32",ID="04B0",Class="29F002",Category="FLASH",MFG="Fujitsu",Adapter="TSOP32-DIP32";
Name="MBM29F002B",ID="0434",Class="29F002",Category="FLASH",MFG="Fujitsu",Adapter="PLCC32, TSOP32";
Name="MBM29F200T",ID="0451",Class="29F200T",Category="FLASH",MFG="Fujitsu",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="MBM29F200B",ID="0457",Class="29F200B",Category="FLASH",MFG="Fujitsu",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="MBM29F400T",ID="0423",Class="29F400T",Category="FLASH",MFG="Fujitsu",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="MBM29F400B",ID="04AB",Class="29F400B",Category="FLASH",MFG="Fujitsu",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="MBM29F800T",ID="04D6",Class="29F800T",Category="FLASH",MFG="Fujitsu",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="MBM29F800B",ID="0458",Class="29F800B",Category="FLASH",MFG="Fujitsu",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="MBM29F160T",ID="04D2",Class="29F160T",Category="FLASH",MFG="Fujitsu",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="MBM29F160B",ID="04D8",Class="29F160B",Category="FLASH",MFG="Fujitsu",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="MBM29F200T*PSOP44",ID="0451",Class="29F200T",Category="FLASH",MFG="Fujitsu",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="MBM29F200B*PSOP44",ID="0457",Class="29F200B",Category="FLASH",MFG="Fujitsu",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="MBM29F400T*PSOP44",ID="0423",Class="29F400T",Category="FLASH",MFG="Fujitsu",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="MBM29F400B*PSOP44",ID="04AB",Class="29F400B",Category="FLASH",MFG="Fujitsu",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="MBM29F800T*PSOP44",ID="04D6",Class="29F800T",Category="FLASH",MFG="Fujitsu",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="MBM29F800B*PSOP44",ID="0458",Class="29F800B",Category="FLASH",MFG="Fujitsu",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="MBM29LV160TE",ID="04C4",Class="29LV160T",Category="FLASH",MFG="Fujitsu",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="MBM29LV160BE",ID="0449",Class="29LV160T",Category="FLASH",MFG="Fujitsu",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="HY29F040AC*TSOP32*20mm",ID="ADA4",Class="29F040B",Category="FLASH",MFG="Hynix", Adapter="ADP-021, TSOP32-DIP32"; // by Sucuka
Name="HY29F040AC*PLCC32",ID="ADA4",Class="29F040B",Category="FLASH",MFG="Hynix", Adapter="ADP-062, ADP-005 PLCC32-DIP32"; // by Sucuka
Name="M29F200TB*PSOP44",ID="20D3",Class="29F200T",Category="FLASH",MFG="ST",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="M29F200BB*PSOP44",ID="20D4",Class="29F200B",Category="FLASH",MFG="ST",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="M29F400BT*TSOP48",ID="20D5",Class="29F400T",Category="FLASH",MFG="ST",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="M29F400BB*TSOP48",ID="20D6",Class="29F400B",Category="FLASH",MFG="ST",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="M29F400BT*PSOP44",ID="20D5",Class="29F400T",Category="FLASH",MFG="ST",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="M29F400BB*PSOP44",ID="20D6",Class="29F400B",Category="FLASH",MFG="ST",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="MX28F1000P",ID="C21A",Class="MX28F1000P",Category="FLASH",MFG="Macronix";
Name="MX28F2000P",ID="C22A",Class="MX28F2000P",Category="FLASH",MFG="Macronix";
Name="MX28F2000T",ID="C23C",Class="MX28F2000T",Category="FLASH",MFG="Macronix";
Name="MX29F001T",ID="C218",Class="49F002NT",Category="FLASH",MFG="Macronix",CodeSize="131072";// by EZo
Name="MX29F022",ID="XXXX",Class="W49F002U",Category="FLASH",MFG="Macronix";
Name="MX29F022NT",ID="C236",Class="SST39LF/VF020",Category="FLASH",MFG="Macronix",VCC="5V";
Name="MX29F022NB",ID="C237",Class="SST39LF/VF020",Category="FLASH",MFG="Macronix",VCC="5V";
Name="MX29F040",ID="C2A4",Class="MX29F040",Category="FLASH",MFG="Macronix";
Name="MX29LV040",ID="C24F",Class="MX29F040",Category="FLASH",MFG="Macronix",VCC="3.6V";
Name="MX29LV040TI*TSOP32*20mm",ID="C24F",Class="MX29F040",Category="FLASH",MFG="Macronix",VCC="3.6V", Adapter="ADP-021, TSOP32-DIP32"; // by Sucuka
Name="MX29LV040TC*TSOP32*20mm",ID="C24F",Class="MX29F040",Category="FLASH",MFG="Macronix",VCC="3.6V", Adapter="ADP-021, TSOP32-DIP32";
Name="MX29LV040QC*PLCC32",ID="C24F",Class="MX29F040",Category="FLASH",MFG="Macronix",VCC="3.6V", Adapter="ADP-062, ADP-005 PLCC32-DIP32"; // by Sucuka
Name="MX29LV040QI*PLCC32",ID="C24F",Class="MX29F040",Category="FLASH",MFG="Macronix",VCC="3.6V", Adapter="ADP-062, ADP-005 PLCC32-DIP32"; // by Sucuka
Name="MX29F004T",ID="C245",Class="MX29F040",Category="FLASH",MFG="Macronix";
Name="MX29F004B",ID="C246",Class="MX29F040",Category="FLASH",MFG="Macronix";
Name="MX29F004T*PLCC32",ID="C245",Class="MX29F040",Category="FLASH",MFG="Macronix",Adapter="ADP-062, ADP-005 PLCC32-DIP32";
Name="MX29F004B*PLCC32",ID="C246",Class="MX29F040",Category="FLASH",MFG="Macronix",Adapter="ADP-062, ADP-005 PLCC32-DIP32";
Name="MX29F004T*TSOP32",ID="C245",Class="MX29F040",Category="FLASH",MFG="Macronix",Adapter="ADP-021, TSOP32-DIP32";
Name="MX29F004B*TSOP32",ID="C246",Class="MX29F040",Category="FLASH",MFG="Macronix",Adapter="ADP-021, TSOP32-DIP32";
Name="MX29LV008B*TSOP40",ID="C237",Class="SST39LF/VF040",Category="FLASH",MFG="Macronix",CodeSize="1048576",DIP="100011110101",Adapter="ADP-082, TSOP40A-DIP32",VCC="3.6V",Message="GQ-3X Connect A19 from Adapter to Programmer.";
Name="MX29LV008T*TSOP40",ID="C23E",Class="SST39LF/VF040",Category="FLASH",MFG="Macronix",CodeSize="1048576",DIP="100011110101",Adapter="ADP-082, TSOP40A-DIP32",VCC="3.6V",Message="GQ-3X Connect A19 from Adapter to Programmer.";
Name="MX29F002NT",ID="C2B0",Class="29F002NT",Category="FLASH",MFG="Macronix";//by TOMakaJPW april 2011
Name="MX29F002NB",ID="C234",Class="29F002NT",Category="FLASH",MFG="Macronix";//by TOMakaJPW april 2011
Name="MX29F200T*PSOP44",ID="C251",Class="29F200T",Category="FLASH",MFG="Macronix",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",Speed="3",Message="Set the adapter to 5V jumper position.";
Name="M2X9F200B*PSOP44",ID="C257",Class="29F200B",Category="FLASH",MFG="Macronix",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",Speed="3",Message="Set the adapter to 5V jumper position.";
Name="MX29F400T*PSOP44",ID="C223",Class="29F400T",Category="FLASH",MFG="Macronix",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",Speed="3",Message="Set the adapter to 5V jumper position.";
Name="MX29F400B*PSOP44",ID="C2AB",Class="29F400B",Category="FLASH",MFG="Macronix",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",Speed="3",Message="Set the adapter to 5V jumper position.";
Name="MX29F800T*PSOP44",ID="C2D6",Class="29F800T",Category="FLASH",MFG="Macronix",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",Speed="3",Message="Set the adapter to 5V jumper position.";
Name="MX29F800B*PSOP44",ID="C258",Class="29F800B",Category="FLASH",MFG="Macronix",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",Speed="3",Message="Set the adapter to 5V jumper position.";
Name="MX29LV800T",ID="C2DA",Class="29LV800T",Category="FLASH",MFG="Macronix",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",TempUnprotect="Yes",Message="Set the adapter to 5V jumper position.";
Name="MX29LV800B",ID="C25B",Class="29LV800B",Category="FLASH",MFG="Macronix",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",TempUnprotect="Yes",Message="Set the adapter to 5V jumper position.";
Name="MX29LV160B",ID="C249",Class="29LV160B",Category="FLASH",MFG="Macronix",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",TempUnprotect="Yes",Message="Set the adapter to 5V jumper position.";
Name="MX29LV160AB",ID="C249",Class="29LV160B",Category="FLASH",MFG="Macronix",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",TempUnprotect="Yes",Message="Set the adapter to 5V jumper position.";
Name="MX29LV160BB",ID="C249",Class="29LV160B",Category="FLASH",MFG="Macronix",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",TempUnprotect="Yes",Message="Set the adapter to 5V jumper position.";
Name="MX29LV160CB",ID="C249",Class="29LV160B",Category="FLASH",MFG="Macronix",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",TempUnprotect="Yes",Message="Set the adapter to 5V jumper position.";
Name="MX29LV160T",ID="C2C4",Class="29LV160T",Category="FLASH",MFG="Macronix",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",RVpp="5V",TempUnprotect="Yes",Message="Set the adapter to 5V jumper position.";
Name="MX29LV160AT",ID="C2C4",Class="29LV160T",Category="FLASH",MFG="Macronix",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",TempUnprotect="Yes",Message="Set the adapter to 5V jumper position.";
Name="MX29LV160BT",ID="C2C4",Class="29LV160T",Category="FLASH",MFG="Macronix",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",TempUnprotect="Yes",Message="Set the adapter to 5V jumper position.";
Name="MX29LV160CT",ID="C2C4",Class="29LV160T",Category="FLASH",MFG="Macronix",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",TempUnprotect="Yes",Message="Set the adapter to 5V jumper position.";
Name="MX29LV160TMC*PSOP44",ID="C2C4",Class="29LV160T",Category="FLASH",MFG="Macronix",Adapter="ADP-019 V3",VCC="3.6V",RVpp="5V",Speed="3",TempUnprotect="Yes,True",Message="Set the adapter to 5V jumper position. Jumper on LV160 positions";
Name="MX29LV160BMC*PSOP44",ID="C249",Class="29LV160B",Category="FLASH",MFG="Macronix",Adapter="ADP-019 V3",VCC="3.6V",RVpp="5V",Speed="3",TempUnprotect="Yes,True",Message="Set the adapter to 5V jumper position.";
Name="MX29LV800CT",ID="C2DA",Class="29LV800T",Category="FLASH",MFG="Macronix",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",TempUnprotect="Yes",Message="Set the adapter to 5V jumper position.";
Name="MX29LV800CB",ID="C25B",Class="29LV800B",Category="FLASH",MFG="Macronix",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",TempUnprotect="Yes",Message="Set the adapter to 5V jumper position.";
Name="MX29LV320CT",ID="C2A7",Class="29LV320T",Category="FLASH",MFG="Macronix",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",TempUnprotect="Yes",Message="Set the adapter to 5V jumper position.";
Name="MX29LV320CB",ID="C2A8",Class="29LV320B",Category="FLASH",MFG="Macronix",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",TempUnprotect="Yes",Message="Set the adapter to 5V jumper position.";
Name="PM29F002T",ID="9D1D",Class="PM29F002",Category="FLASH",MFG="PMC",VCC="3.6V";
Name="PM29F002B",ID="9D2D",Class="PM29F002",Category="FLASH",MFG="PMC";
Name="SST29EE010*TSOP32*14mm",ID="BF07",Class="SST29EE010",Category="FLASH",MFG="SST",Adapter="ADP-022";
Name="SST29EE010*TSOP32*20mm",ID="BF07",Class="SST29EE010",Category="FLASH",MFG="SST",Adapter="ADP-021";
Name="SST29EE512",ID="BF5D",Class="AT29C512",Category="FLASH",MFG="SST";//by EZo , revised ID by Sucuka
Name="SST29EE010",ID="BF07",Class="SST29EE010",Category="FLASH",MFG="SST";
Name="SST29LE010",ID="BF08",Class="SST29EE010",VCC="3.6V",Category="FLASH",MFG="SST";
Name="SST29VE010",ID="BF08",Class="SST29EE010",VCC="3.6V",Category="FLASH",MFG="SST";
Name="SST29EE020",ID="BF10",Class="SST29EE020",Category="FLASH",MFG="SST";
Name="SST29VE020",ID="BF12",Class="SST29EE020",VCC="3.6V",Category="FLASH",MFG="SST";
Name="SST29LE020",ID="BF12",Class="SST29EE020",VCC="3.6V",Category="FLASH",MFG="SST";
Name="SST29EE512*TSOP32*20mm",ID="BF5D",Class="AT29C512",Category="FLASH",MFG="SST",Adapter="ADP-021, TSOP32-DIP32"; //by Sucuka
Name="SST29EE512*PLCC32",ID="BF5D",Class="AT29C512",Category="FLASH",MFG="SST",Adapter="ADP-062, ADP005 PLCC32-DIP32"; //by Sucuka
Name="SST28SF04A",ID="BF04",Class="SST28VF040A",Category="FLASH",MFG="SST";
Name="SST28VF04A",ID="BF04",Class="SST28VF040A",Category="FLASH",MFG="SST";
Name="SST39LF512*PLCC32",ID="BFD4",Class="SST39LF/VF512",Category="FLASH",MFG="SST",Adapter="ADP-062, ADP005 PLCC32-DIP32";
Name="SST39VF512*PLCC32",ID="BFD4",Class="SST39LF/VF512",Category="FLASH",MFG="SST",Adapter="ADP-062, ADP005 PLCC32-DIP32";
Name="SST39LF010*PLCC32",ID="BFD5",Class="SST39LF/VF010",Category="FLASH",MFG="SST",Adapter="ADP-062, ADP005 PLCC32-DIP32";
Name="SST39VF010*PLCC32",ID="BFD5",Class="SST39LF/VF010",Category="FLASH",MFG="SST",Adapter="ADP-062, ADP005 PLCC32-DIP32";
Name="SST39VF020*PLCC32",ID="BFD6",Class="SST39LF/VF020",Category="FLASH",MFG="SST",Adapter="ADP-062, ADP005 PLCC32-DIP32";
Name="SST39LF020*PLCC32",ID="BFD6",Class="SST39LF/VF020",Category="FLASH",MFG="SST",Adapter="ADP-062, ADP005 PLCC32-DIP32";
Name="SST39LF040*PLCC32",ID="BFD7",Class="SST39LF/VF040",Category="FLASH",MFG="SST",Adapter="ADP-062, ADP005 PLCC32-DIP32";
Name="SST39VF040*PLCC32",ID="BFD7",Class="SST39LF/VF040",Category="FLASH",MFG="SST",Adapter="ADP-062, ADP005 PLCC32-DIP32";
Name="SST39LF512*TSOP32",ID="BFD4",Class="SST39LF/VF512",Category="FLASH",MFG="SST",Adapter="ADP-022, TSOP32-DIP32 14mm";
Name="SST39VF512*TSOP32",ID="BFD4",Class="SST39LF/VF512",Category="FLASH",MFG="SST",Adapter="ADP-022, TSOP32-DIP32 14mm";
Name="SST39LF010*TSOP32",ID="BFD5",Class="SST39LF/VF010",Category="FLASH",MFG="SST",Adapter="ADP-022, TSOP32-DIP32 14mm";
Name="SST39VF010*TSOP32",ID="BFD5",Class="SST39LF/VF010",Category="FLASH",MFG="SST",Adapter="ADP-022, TSOP32-DIP32 14mm";
Name="SST39VF020*TSOP32",ID="BFD6",Class="SST39LF/VF020",Category="FLASH",MFG="SST",Adapter="ADP-022, TSOP32-DIP32 14mm";
Name="SST39LF020*TSOP32",ID="BFD6",Class="SST39LF/VF020",Category="FLASH",MFG="SST",Adapter="ADP-022, TSOP32-DIP32 14mm";
Name="SST39LF040*TSOP32",ID="BFD7",Class="SST39LF/VF040",Category="FLASH",MFG="SST",Adapter="ADP-022, TSOP32-DIP32 14mm";
Name="SST39VF040*TSOP32",ID="BFD7",Class="SST39LF/VF040",Category="FLASH",MFG="SST",Adapter="ADP-022, TSOP32-DIP32 14mm";
Name="SST39LF512",ID="BFD4",Class="SST39LF/VF512",Category="FLASH",MFG="SST";
Name="SST39VF512",ID="BFD4",Class="SST39LF/VF512",Category="FLASH",MFG="SST";
Name="SST39LF010",ID="BFD5",Class="SST39LF/VF010",Category="FLASH",MFG="SST";
Name="SST39VF010",ID="BFD5",Class="SST39LF/VF010",Category="FLASH",MFG="SST";
Name="SST39VF020",ID="BFD6",Class="SST39LF/VF020",Category="FLASH",MFG="SST";
Name="SST39LF020",ID="BFD6",Class="SST39LF/VF020",Category="FLASH",MFG="SST";
Name="SST39LF040",ID="BFD7",Class="SST39LF/VF040",Category="FLASH",MFG="SST";
Name="SST39VF040",ID="BFD7",Class="SST39LF/VF040",Category="FLASH",MFG="SST";
Name="SST39VF080",ID="BFD8",Class="SST39LF/VF040",Category="FLASH",MFG="SST",CodeSize="1048576",DIP="100011110101",Adapter="ADP-082, TSOP40A-DIP32",VCC="5V",Speed="4",Message="Open adapter Vcc jumper to 3.3V and GQ-3X connect the A19 from adapter to programmer";
Name="SST39LF080",ID="BFD8",Class="SST39LF/VF040",Category="FLASH",MFG="SST",CodeSize="1048576",DIP="100011110101",Adapter="ADP-082, TSOP40A-DIP32",VCC="5V",Message="Open adapter Vcc jumper to 3.3V and GQ-3X connect the A19 from adapter to programmer";
Name="SST39VF016",ID="BFD9",Class="SST39LF/VF040",Category="FLASH",MFG="SST",CodeSize="2097152",Adapter="ADP-082, TSOP40A-DIP32";
Name="SST39LF016",ID="BFD9",Class="SST39LF/VF040",Category="FLASH",MFG="SST",CodeSize="2097152",Adapter="ADP-082, TSOP40A-DIP32";
Name="SST39SF512",ID="BFB4",Class="SST39LF/VF512",Category="FLASH",MFG="SST",VCC="5V";//by EZo
Name="SST39SF010",ID="BFB5",Class="SST39LF/VF010",Category="FLASH",MFG="SST",VCC="5V";
Name="SST39SF020",ID="BFB6",Class="SST39LF/VF020",Category="FLASH",MFG="SST",VCC="5V";
Name="SST39SF040",ID="BFB7",Class="SST39LF/VF040",Category="FLASH",MFG="SST",VCC="5V";
Name="SST39SF020A",ID="BFB6",Class="SST39LF/VF020",Category="FLASH",MFG="SST",VCC="5V";
Name="SST39SF512*PLCC32",ID="BFB4",Class="SST39LF/VF512",Category="FLASH",MFG="SST",VCC="5V",Adapter="ADP-062, PLCC32-DIP32";//by EZo
Name="SST39SF010*PLCC32",ID="BFB5",Class="SST39LF/VF010",Category="FLASH",MFG="SST",VCC="5V",Adapter="ADP-062, PLCC32-DIP32";
Name="SST39SF010A*PLCC32",ID="BFB5",Class="SST39LF/VF010",Category="FLASH",MFG="SST",VCC="5V",Adapter="ADP-062, PLCC32-DIP32";
Name="SST39SF020*PLCC32",ID="BFB6",Class="SST39LF/VF020",Category="FLASH",MFG="SST",VCC="5V",Adapter="ADP-062, PLCC32-DIP32";
Name="SST39SF040*PLCC32",ID="BFB7",Class="SST39LF/VF040",Category="FLASH",MFG="SST",VCC="5V",Adapter="ADP-062, PLCC32-DIP32";
Name="SST39SF020A*PLCC32",ID="BFB6",Class="SST39LF/VF020",Category="FLASH",MFG="SST",VCC="5V",Adapter="ADP-062, PLCC32-DIP32";
Name="SST39SF040A*PLCC32",ID="BFB7",Class="SST39LF/VF040",Category="FLASH",MFG="SST",VCC="5V",Adapter="ADP-062, PLCC32-DIP32";
Name="SST39SF010*TSOP32",ID="BFB5",Class="SST39LF/VF010",Category="FLASH",MFG="SST",VCC="5V",Adapter="ADP-022, TSOP32-DIP32(S)";
Name="SST39SF010A*TSOP32",ID="BFB5",Class="SST39LF/VF010",Category="FLASH",MFG="SST",VCC="5V",Adapter="ADP-022, TSOP32-DIP32(S)";
Name="SST39SF020*TSOP32",ID="BFB6",Class="SST39LF/VF020",Category="FLASH",MFG="SST",VCC="5V",Adapter="ADP-022, TSOP32-DIP32(S)";
Name="SST39SF040*TSOP32",ID="BFB7",Class="SST39LF/VF040",Category="FLASH",MFG="SST",VCC="5V",Adapter="ADP-022, TSOP32-DIP32(S)";
Name="SST39SF020A*TSOP32",ID="BFB6",Class="SST39LF/VF020",Category="FLASH",MFG="SST",VCC="5V",Adapter="ADP-022, TSOP32-DIP32(S)";
Name="SST39SF040A*TSOP32",ID="BFB7",Class="SST39LF/VF040",Category="FLASH",MFG="SST",VCC="5V",Adapter="ADP-022, TSOP32-DIP32(S)";
Name="M28F512",ID="2002",Class="28F512",Category="FLASH",MFG="ST";//by EZo
Name="M28F101",ID="2007",Class="28F010",Category="FLASH",MFG="ST";//by EZo
Name="M28F102",ID="2050",Class="28F102",Category="FLASH",MFG="ST",Adapter="ADP-054, ADP-055 16 BIT EPROM ADAPTER";
Name="M28F410*PSOP44",ID="20F2",Class="INTEL28F400BX-T",Category="FLASH",MFG="ST",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",EVPP="12V";
Name="M28F420*PSOP44",ID="20FA",Class="INTEL28F400BX-B",Category="FLASH",MFG="ST",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",EVPP="12V";
Name="M29F010B",ID="2020",Class="29F010",Category="FLASH",MFG="ST";
Name="M29F040B",ID="20E2",Class="29F040B",Category="FLASH",MFG="ST";
Name="M29F010B*PLCC32",ID="2020",Class="29F010",Category="FLASH",MFG="ST",Adapter="ADP-062, PLCC32-DIP32";
Name="M29F040B*PLCC32",ID="20E2",Class="29F040B",Category="FLASH",MFG="ST",Adapter="ADP-062, PLCC32-DIP32";
Name="M29F002B",ID="2034",Class="29F002NT",Category="FLASH",MFG="ST";
Name="M29F002T",ID="20B0",Class="29F002NT",Category="FLASH",MFG="ST";
Name="M29F002NT",ID="20B0",Class="29F002NT",Category="FLASH",MFG="ST";
Name="M29F032D*TSOP40",ID="20AC",Class="29F040B",Category="FLASH",MFG="ST",CodeSize="4194304",DIP="100011110101",Adapter="TSOP40B-DIP32(ADP-077 and ADP-082)";
Name="M29F080A",ID="20F1",Class="29F040B",Category="FLASH",MFG="ST",CodeSize="1048576",DIP="100011110101",Adapter="TSOP40B-DIP32",Message="GQ-3X Connect A19 from programmer to adapter.";
Name="M29F080A*TSOP40",ID="20F1",Class="29F040B",Category="FLASH",MFG="ST",CodeSize="1048576",DIP="100011110101",Adapter="TSOP40B-DIP32",Message="GQ-3X Connect A19 from programmer to adapter.";
Name="M29F016D*TSOP40",ID="20AD",Class="29F040B",Category="FLASH",MFG="ST",CodeSize="2097152",DIP="100011110101",Adapter="TSOP40B-DIP32";
Name="M29F200T",ID="20D3",Class="29F200T",Category="FLASH",MFG="ST",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="M29F200B",ID="20D4",Class="29F200B",Category="FLASH",MFG="ST",Adapter="ADP-003 TSOP48 8 BIT Mode",RVPP="5V",Message="Set the adapter to 5V jumper position.";
Name="M29W400BT",ID="20EE",Class="29LV400B",Category="FLASH",MFG="ST",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="M29W800AT",ID="20D7",Class="29LV800T",Category="FLASH",MFG="ST",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="M29W800AB",ID="205B",Class="29LV800B",Category="FLASH",MFG="ST",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="M29W160BT",ID="20C4",Class="29LV160T",Category="FLASH",MFG="ST",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="M29W160BB",ID="2049",Class="29LV160B",Category="FLASH",MFG="ST",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="M29W320DT",ID="20CA",Class="29LV320T",Category="FLASH",MFG="ST",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="M29W320DB",ID="20CB",Class="29LV320B",Category="FLASH",MFG="ST",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="M29DW323DT",ID="205E",Class="29LV320T",Category="FLASH",MFG="ST",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="M29DW323DB",ID="205F",Class="29LV320B",Category="FLASH",MFG="ST",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="M29DW324DT",ID="205C",Class="29LV320T",Category="FLASH",MFG="ST",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="M29DW324DB",ID="205D",Class="29LV320B",Category="FLASH",MFG="ST",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="M29W320ET",ID="20CA",Class="29LV320T",Category="FLASH",MFG="ST",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="M29W160ET",ID="20C4",Class="29LV160T",Category="FLASH",MFG="ST",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="M29W160EB",ID="2049",Class="29LV160B",Category="FLASH",MFG="ST",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="F29C51002T",ID="4002",Class="29C51002T",Category="FLASH",MFG="SyncMos";
Name="F29C51004T",ID="4003",Class="29C51004T",Category="FLASH",MFG="SyncMos";
Name="F29C51002B",ID="40A2",Class="29C51002B",Category="FLASH",MFG="SyncMos";
Name="F29C51004B",ID="40A3",Class="29C51004B",Category="FLASH",MFG="SyncMos";
Name="S29C51002T",ID="4002",Class="29C51002T",Category="FLASH",MFG="SyncMos";
Name="S29C51004T",ID="4003",Class="29C51004T",Category="FLASH",MFG="SyncMos";
Name="S29C51002B",ID="40A2",Class="29C51002B",Category="FLASH",MFG="SyncMos";
Name="S29C51004B",ID="40A3",Class="29C51004B",Category="FLASH",MFG="SyncMos";
Name="V29C51000T",ID="4000",Class="29C51000T",Category="FLASH",MFG="MOSEL VITELIC";
Name="V29C51001T",ID="4001",Class="29C51001T",Category="FLASH",MFG="MOSEL VITELIC";
Name="V29C51002T",ID="4002",Class="29C51002T",Category="FLASH",MFG="MOSEL VITELIC";
Name="V29C51004T",ID="4003",Class="29C51004T",Category="FLASH",MFG="MOSEL VITELIC";
Name="V29C51000B",ID="40A0",Class="29C51000B",Category="FLASH",MFG="MOSEL VITELIC";
Name="V29C51001B",ID="40A1",Class="29C51001B",Category="FLASH",MFG="MOSEL VITELIC";
Name="V29C51002B",ID="40A2",Class="29C51002B",Category="FLASH",MFG="MOSEL VITELIC";
Name="V29C51004B",ID="40A3",Class="29C51004B",Category="FLASH",MFG="MOSEL VITELIC";
Name="TC58FVB160",ID="9843",Class="29LV160B",Category="FLASH",MFG="TOSHIBA",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="TC58FVT160",ID="98C2",Class="29LV160T",Category="FLASH",MFG="TOSHIBA",Adapter="ADP-003 TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Name="W29EE010",ID="XXXX",Class="W29EE010",Category="FLASH",MFG="Winbond";
Name="W29EE020",ID="XXXX",Class="W29EE020",Category="FLASH",MFG="Winbond";
Name="W29C020",ID="DA45",Class="SST29EE020",Category="FLASH",MFG="Winbond";//edited by EZo
Name="W29C040",ID="DA46",Class="AT29C040A",Category="FLASH",MFG="Winbond";
Name="W29EE011",ID="DAC1",Class="W29EE011",Category="FLASH",MFG="Winbond";
Name="W29C011A",ID="DAC1",Class="W29EE011",Category="FLASH",MFG="Winbond";
Name="W29EE010*PLCC32",ID="XXXX",Class="W29EE010",Category="FLASH",MFG="Winbond",Adapter="ADP-062, ADP-005 PLCC32-DIP32";
Name="W29EE020*PLCC32",ID="XXXX",Class="W29EE020",Category="FLASH",MFG="Winbond",Adapter="ADP-062, ADP-005 PLCC32-DIP32";
Name="W29C020*PLCC32",ID="DA45",Class="SST29EE020",Category="FLASH",MFG="Winbond",Adapter="ADP-062, ADP-005 PLCC32-DIP32";
Name="W29C040*PLCC32",ID="DA46",Class="AT29C040A",Category="FLASH",MFG="Winbond",Adapter="ADP-062, ADP-005 PLCC32-DIP32";
Name="W29EE011*PLCC32",ID="DAC1",Class="W29EE011",Category="FLASH",MFG="Winbond",Adapter="ADP-062, ADP-005 PLCC32-DIP32";
Name="W29C011A*PLCC32",ID="DAC1",Class="W29EE011",Category="FLASH",MFG="Winbond",Adapter="ADP-062, ADP-005 PLCC32-DIP32";
Name="AE29F1008",ID="DAC1",Class="AT29C010",Category="FLASH",MFG="ASD";
Name="AE29F2008",ID="DA45",Class="SST29EE020",Category="FLASH",MFG="ASD";
Name="AE29F2008T",ID="DA45",Class="SST29EE020",Category="FLASH",MFG="ASD";
Name="AE49F2008",ID="DA0B",Class="W49F002U",Category="FLASH",MFG="ASD";
Name="W39D040A",ID="DAD6",Class="SST39LF/VF040",Category="FLASH",MFG="WINBOND",VCC="3.6V";
Name="W39D040A*PLCC32",ID="DAD6",Class="SST39LF/VF040",Category="FLASH",MFG="WINBOND",VCC="3.6V",Adapter="ADP-062, ADP-005 PLCC32-DIP32";
Name="W39D040A*TSOP32",ID="DAD6",Class="SST39LF/VF040",Category="FLASH",MFG="WINBOND",VCC="3.6V",Adapter="ADP-022,TSOP32-DIP32(S)";
Name="W39L040",ID="DAB6",Class="SST39LF/VF040",Category="FLASH",MFG="WINBOND",VCC="3.6V";
;Name="W49F010",ID="DA17",Class="SST39LF/VF010",Category="FLASH",MFG="Winbond",VCC="5V";
Name="W49F020",ID="DA8C",Class="SST39LF/VF020",Category="FLASH",MFG="Winbond",VCC="5V";
;Name="W49F040",ID="DA13",Class="SST39LF/VF040",Category="FLASH",MFG="Winbond",VCC="5V";
Name="W49F002U",ID="DA0B",Class="W49F002U",Category="FLASH",MFG="Winbond",WVPP="12V",RVPP="5V";
Name="W49F002UP*PLCC32",ID="DA0B",Class="W49F002U",Category="FLASH",MFG="Winbond",WVPP="12V",RVPP="5V",Adapter="ADP-062, ADP-005 PLCC32-DIP32";
Name="TMS29F040*PLCC32",ID="01A4",Class="29F040B",Category="FLASH",MFG="TI",Adapter="ADP-062, ADP-005";
Name="TMS29F040*TSOP32",ID="01A4",Class="29F040B",Category="FLASH",MFG="TI",Adapter="ADP-021";
Name="TMS29LF040*PLCC32",ID="01A4",Class="29F040B",VCC="3.6V",Category="FLASH",MFG="TI",Adapter="ADP-062, ADP-005";
Name="TMS29LF040*TSOP32",ID="01A4",Class="29F040B",VCC="3.6V",Category="FLASH",MFG="TI",Adapter="ADP-021";
Name="TMS28F200BZ*PSOP44",ID="8975",Class="INTEL28F200BX-B",Category="FLASH",MFG="TI",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",EVPP="12V";
Name="TMS28F200AZ*PSOP44",ID="8975",Class="INTEL28F200BX-B",Category="FLASH",MFG="TI",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",EVPP="12V";
Name="TMS28F200BZT*PSOP44",ID="8974",Class="INTEL28F200BX-B",Category="FLASH",MFG="TI",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",EVPP="12V";
Name="TMS28F200BZB*PSOP44",ID="8975",Class="INTEL28F200BX-B",Category="FLASH",MFG="TI",Adapter="ADP-019 PSOP44-DIP32",RVPP="5V",EVPP="12V";
Name="TMS28F010*TSOP32*20mm",ID="89B4",Class="28F010",Category="FLASH",MFG="TI",Adapter="ADP-021, TSOP32-DIP32"; // by Sucuka
;* FLASH - 16bit mode *
Name="AM29BL802CB",ID="0181",Class="AM29BL802",Category="FLASH",MFG="AMD",Speed="5",WVPP="12V",RVpp="5V",Adapter="ADP-087",Platform="GQ-4X",Message="Set the adapter jumpers to VCC 3.6V";
Name="AM29LV160DB(16bit)",ID="012249",Class="SST39VF1601",Category="FLASH",MFG="AMD",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter jumpers to VCC 3.6V and 29FX00 position.";
Name="AM29LV160DT(16bit)",ID="0122C4",Class="SST39VF1601",Category="FLASH",MFG="AMD",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter jumpers to VCC 3.6V and 29FX00 position.";
Name="MBM29LV160B(16bit)",ID="042249",Class="SST39VF1601",Category="FLASH",MFG="AMD",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter jumpers to VCC 3.6V and 29FX00 position.";
Name="MBM29LV160T(16bit)",ID="0422C4",Class="SST39VF1601",Category="FLASH",MFG="AMD",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter jumpers to VCC 3.6V and 29FX00 position.";
Name="MX29LV160CB(16bit)",ID="C22249",Class="SST39VF1601",Category="FLASH",MFG="Macronix",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter jumpers to VCC 3.6V and 29FX00 position.";
Name="MX29LV160BB(16bit)",ID="XXXX",Class="SST39VF1601",Category="FLASH",MFG="Macronix",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter jumpers to VCC 5V and 29FX00 position.";
;Name="S29GL064N90TFI04",ID="017E10",Class="SST39VF1601",Category="FLASH",MFG="Spansion",CodeSize="8388608",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter jumpers to VCC 3.6V and 29FX00 position.";
Name="AT49LV1024",ID="1F0087",Class="SST39VF1601",Category="FLASH",MFG="Atmel",Speed="4",CodeSize="131072",Adapter="STSOP40 16 BIT Mode",Message="New adapter required";//by EZo
Name="AT49F2048",ID="1FFF82",Class="SST39VF1601",Category="FLASH",MFG="Atmel",Speed="4",CodeSize="262144",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter jumpers to VCC 5.0V and 29FX00 position.";//by EZo
Name="AT49F8192",ID="1FFFA0",Class="SST39VF1601",Category="FLASH",MFG="Atmel",Speed="4",CodeSize="1048576",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter jumpers to VCC 5.0V and 29FX00 position.";//by EZo
Name="TE28F800B3B",ID="898893",Class="TE28F160C3B",CodeSize="1048576",Category="FLASH",MFG="INTEL",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter to 3.6V jumper position."; // by Sucuka
Name="TE28F800B3TA",ID="898892",Class="TE28F160C3T",CodeSize="1048576",Category="FLASH",MFG="INTEL",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter to 3.6V jumper position."; // by Sucuka
Name="TE28F800C3B",ID="8988C1",Class="TE28F160C3B",CodeSize="1048576",Category="FLASH",MFG="INTEL",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter to 3.6V jumper position.";
Name="TE28F800C3T",ID="8988C0",Class="TE28F160C3T",CodeSize="1048576",Category="FLASH",MFG="INTEL",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter to 3.6V jumper position.";
Name="TE28F160C3B",ID="8988C3",Class="TE28F160C3B",Category="FLASH",MFG="INTEL",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter to 3.6V jumper position.";
Name="TE28F160C3T",ID="8988C2",Class="TE28F160C3T",Category="FLASH",MFG="INTEL",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter to 3.6V jumper position.";
Name="TE28F160B3T",ID="898890",Class="TE28F160C3T",Category="FLASH",MFG="INTEL",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter to 3.6V jumper position.";
Name="TE28F320C3T",ID="8988C4",Class="TE28F320C3T",CodeSize="4194304",Category="FLASH",MFG="INTEL",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter to 3.6V jumper position.";
Name="TE28F320C3B",ID="8988C5",Class="TE28F320C3B",CodeSize="4194304",VCC="3.6V",WVCC="3.6V",Category="FLASH",MFG="INTEL",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter to 3.6V jumper position.";
Name="JS28F800C3T",ID="8988C0",Class="TE28F160C3T",CodeSize="1048576",Category="FLASH",MFG="INTEL",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter to 3.6V jumper position.";
Name="JS28F800C3B",ID="8988C1",Class="TE28F160C3B",CodeSize="1048576",Category="FLASH",MFG="INTEL",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter to 3.6V jumper position.";
Name="JS28F160C3T",ID="8988C2",Class="TE28F160C3T",Category="FLASH",MFG="INTEL",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter to 3.6V jumper position.";
Name="JS28F160C3B",ID="8988C3",Class="TE28F160C3B",Category="FLASH",MFG="INTEL",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter to 3.6V jumper position.";
Name="JS28F320C3BD",ID="8988C5",Class="TE28F320C3B",CodeSize="4194304",VCC="3.6V",WVCC="3.6V",Category="FLASH",MFG="INTEL",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter to 3.6V jumper position.";
Name="JS28F320C3TD",ID="8988C4",Class="TE28F320C3T",CodeSize="4194304",Category="FLASH",MFG="INTEL",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter to 3.6V jumper position.";
Name="JS28F320C3BC",ID="8988C5",Class="TE28F320C3B",CodeSize="4194304",VCC="3.6V",WVCC="3.6V",Category="FLASH",MFG="INTEL",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter to 3.6V jumper position.";
Name="JS28F320C3TC",ID="8988C4",Class="TE28F320C3T",CodeSize="4194304",Category="FLASH",MFG="INTEL",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter to 3.6V jumper position.";
Name="JS28F320C3BA",ID="8988C5",Class="TE28F320C3B",CodeSize="4194304",VCC="3.6V",WVCC="3.6V",Category="FLASH",MFG="INTEL",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter to 3.6V jumper position.";
Name="JS28F320C3TA",ID="8988C4",Class="TE28F320C3T",CodeSize="4194304",Category="FLASH",MFG="INTEL",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter to 3.6V jumper position.";
;Name="JS28F640C3BA",ID="8988CC",Class="TE28F320C3B",CodeSize="4194304",VCC="3.6V",WVCC="3.6V",Category="FLASH",MFG="INTEL",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter to 3.6V jumper position.";
;Name="JS28F640C3TA",ID="8988CD",Class="TE28F320C3T",CodeSize="4194304",Category="FLASH",MFG="INTEL",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter to 3.6V jumper position.";
Name="M28W320FCT",ID="2088BA",Class="TE28F320C3T",CodeSize="4194304",Category="FLASH",MFG="ST",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter to 3.6V jumper position.";
Name="M28W320FCB",ID="2088BB",Class="TE28F320C3B",CodeSize="4194304",Category="FLASH",MFG="ST",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter to 3.6V jumper position.";
;Name="TE28F032J5B",ID="898897",Class="TE28F320C3B",Category="FLASH",MFG="INTEL",Speed="5",CodeSize="4194304",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter to 3.6V jumper position.";
;Name="TE28F032J5T",ID="898896",Class="TE28F320C3T",Category="FLASH",MFG="INTEL",Speed="5",CodeSize="4194304",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter to 3.6V jumper position.";
Name="LHF00L13",ID="B000A1",Class="LHF00L13",Category="FLASH",MFG="Sharp",Speed="5",VCC="3.6V",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter to 5V jumper position. Set adapter to 28FXXX position";
Name="LHF00L28",ID="B000A4",Class="TE28F160C3T",Category="FLASH",MFG="Sharp",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter to 3.6V jumper position. Set adapter to 29FXXX position";
Name="LHF00L30",ID="B000A4",Class="TE28F160C3T",Category="FLASH",MFG="Sharp",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter to 3.6V jumper position. Set adapter to 28FXXX position";//by EZo
Name="M28W160CT",ID="2088CE",Class="TE28F160C3T",Category="FLASH",MFG="ST",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter to 3.6V jumper position.";//by EZo
Name="S29AL008D..-01 16bit",ID="0122DA",Class="SST39VF1601",Category="FLASH",MFG="SPANSION",VCC="3.6V",Speed="5", CodeSize="1048576",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter jumpers to VCC 5.0V and 29FX00 position.";//by EZo
Name="S29AL016D..-02 16bit",ID="012249",Class="SST39VF1601",Category="FLASH",MFG="SPANSION",VCC="3.6V",Speed="5", Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter jumpers to VCC 5.0V and 29FX00 position.";//by EZo
Name="SST39VF100",ID="BF2788",Class="SST39VF1601",Category="FLASH",MFG="SST",Speed="4",CodeSize="131072",Adapter="STSOP40 16 BIT Mode",Message="New adapter required";
Name="SST39VF200A",ID="BF2789",Class="SST39VF1601",Category="FLASH",MFG="SST",Speed="4",CodeSize="262144",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter jumpers to VCC 3.6V and 29FX00 position.";
Name="SST39VF400A",ID="BF2780",Class="SST39VF1601",Category="FLASH",MFG="SST",Speed="4",CodeSize="524288",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter jumpers to VCC 3.6V and 29FX00 position.";
Name="SST39VF800A",ID="BF2781",Class="SST39VF1601",Category="FLASH",MFG="SST",Speed="4",CodeSize="1048576",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter jumpers to VCC 3.6V and 29FX00 position.";
Name="SST39LF200A",ID="BF2789",Class="SST39VF1601",Category="FLASH",MFG="SST",Speed="4",CodeSize="262144",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter jumpers to VCC 3.6V and 29FX00 position.";
Name="SST39LF400A",ID="BF2780",Class="SST39VF1601",Category="FLASH",MFG="SST",Speed="4",CodeSize="524288",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter jumpers to VCC 3.6V and 29FX00 position.";
Name="SST39LF800A",ID="BF2781",Class="SST39VF1601",Category="FLASH",MFG="SST",Speed="4",CodeSize="1048576",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter jumpers to VCC 3.6V and 29FX00 position.";
Name="SST39VF160",ID="BF2782",Class="SST39VF1601",Category="FLASH",MFG="SST",Speed="4",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter jumpers to VCC 5.0V and 29FX00 position.";//by EZo
Name="SST39VF1601",ID="BF234B",Class="SST39VF1601",Category="FLASH",MFG="SST",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter jumpers to VCC 3.6V and 29FX00 position.";
Name="SST39VF3201",ID="BF235B",Class="SST39VF1601",Category="FLASH",MFG="SST",Speed="5",CodeSize="4194304",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter jumpers to VCC 3.6V and 29FX00 position.";
Name="SST39VF6401",ID="BF236B",Class="SST39VF1601",Category="FLASH",MFG="SST",Speed="5",CodeSize="8388608",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter jumpers to VCC 3.6V and 29FX00 position.";
Name="SST39VF1602",ID="BF234A",Class="SST39VF1601",Category="FLASH",MFG="SST",Speed="5",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter jumpers to VCC 3.6V and 29FX00 position.";
Name="SST39VF3202",ID="BF235A",Class="SST39VF1601",Category="FLASH",MFG="SST",Speed="5",CodeSize="4194304",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter jumpers to VCC 3.6V and 29FX00 position.";
Name="SST39VF6402",ID="BF236A",Class="SST39VF1601",Category="FLASH",MFG="SST",Speed="5",CodeSize="8388608",Adapter="ADP-042 TSOP48 16 BIT Mode",Message="Set the adapter jumpers to VCC 3.6V and 29FX00 position.";
;* MCU *
Name="AT89C1051",ID="1E11",Class="AT89C2051",Category="MCU",MFG="Atmel",Adapter="ADP-015 MCS-51",CodeSize="1024";
Name="AT89C2051",ID="1E21",Class="AT89C2051",Category="MCU",MFG="Atmel",Adapter="ADP-015 MCS-51",CodeSize="2048";
Name="AT89C4051",ID="1E41",Class="AT89C2051",Category="MCU",MFG="Atmel",Adapter="ADP-015 MCS-51",CodeSize="4096";
Name="AT89C51(12V Vpp)",ID="1E51FF",Class="AT89C51",Category="MCU",MFG="Atmel",Adapter="ADP-015 MCS-51";
Name="AT89C51(5V Vpp)",ID="1E5105",Class="AT89C51",Category="MCU",MFG="Atmel",WVPP="5V",Adapter="ADP-015 MCS-51";
Name="AT89C52(12V Vpp)",ID="1E52FF",Class="AT89C51",Category="MCU",MFG="Atmel",CodeSize="8192",Adapter="ADP-015 MCS-51";;
Name="AT89C52(5V Vpp)",ID="1E5205",Class="AT89C51",Category="MCU",MFG="Atmel",WVPP="5V",CodeSize="8192",Adapter="ADP-015 MCS-51";
Name="AT89C55(12V Vpp)",ID="1E55FF",Class="AT89C51",Category="MCU",MFG="Atmel",CodeSize="20480",Adapter="ADP-015 MCS-51";
Name="AT89C55(5V Vpp)",ID="1E5505",Class="AT89C51",Category="MCU",MFG="Atmel",WVPP="5V",CodeSize="20480",Adapter="ADP-015 MCS-51";
Name="AT89C55WD",ID="1E5506",Class="AT89C55WD",Category="MCU",MFG="Atmel",CodeSize="20480",Adapter="ADP-015 MCS-51";
Name="AT89C51RC",ID="1E5107",Class="AT89C51RC",CodeSize="32768",Category="MCU",MFG="Atmel",Adapter="ADP-015 MCS-51";
Name="AT89LV55",ID="1E65FF",Class="AT89C51",Category="MCU",MFG="Atmel",CodeSize="20480",Adapter="ADP-015 MCS-51";
Name="AT89LV55*QFP44",ID="1E65FF",Class="AT89C51",Category="MCU",MFG="Atmel",CodeSize="20480",Adapter="ADP-015 MCS-51+QFP44";
Name="AT89S51",ID="1E5106",Class="AT89S51",Category="MCU",MFG="Atmel",Adapter="ADP-015 MCS-51";
Name="AT89S52",ID="1E5206",Class="AT89S51",Category="MCU",MFG="Atmel",Adapter="ADP-015 MCS-51",CodeSize="8192";
Name="AT89S53",ID="1E53",Class="AT89S53",Category="MCU",MFG="Atmel",Adapter="ADP-015 MCS-51",CodeSize="12288"; 12K Code size
Name="HD6475328",ID="XXXX",Class="HD6475348",Category="MCU",MFG="HITACHI",Adapter="MCU-PLCC84-DIP-01";
Name="HD6475348",ID="XXXX",Class="HD6475348",Category="MCU",MFG="HITACHI",Adapter="MCU-PLCC84-DIP-01"
Name="HD6475368",ID="XXXX",Class="HD6475368",Category="MCU",MFG="HITACHI",Adapter="MCU-PLCC84-DIP-01";
Name="P87C51X2",ID="1592",Class="P87C5X",Category="MCU",MFG="Philips(NXP)",Adapter="ADP-015 MCS-51";
Name="P87C52X2",ID="1597",Class="P87C5X",CodeSize="8192",Category="MCU",MFG="Philips(NXP)",Adapter="ADP-015 MCS-51";
Name="P87C54X2",ID="15BB",Class="P87C5X",CodeSize="16384",Category="MCU",MFG="Philips(NXP)",Adapter="ADP-015 MCS-51";
Name="P87C58X2",ID="15BD",Class="P87C5X",CodeSize="32768",Category="MCU",MFG="Philips(NXP)",Adapter="ADP-015 MCS-51";
Name="P87C51RB+4A",ID="15CB",Class="P87C5X",CodeSize="16384",Category="MCU",MFG="Philips(NXP)",Adapter="ADP-015 MCS-51";
Name="87C51FB",ID="8958",Class="P87C5X",CodeSize="16384",Category="MCU",MFG="Intel",Adapter="ADP-015 MCS-51";
;All PIC MCU must add 29 prefix as MFG code, and no chip revision data in ID
;COMMAND value in hex, put empty value if it does not needed. eg. ENDPRG_COMMAND=""
Name="PIC12C505",ID="XXXX",Class="PIC12F508",Category="MCU",MFG="Microchip",CodeSize="2046",EepromSize="0",Package="DIP14",ENDPRG_COMMAND="0E",PRG_MODE="0",CFGByteLabel="CP CP CP CP CP CP MCLRE CP WDTE FOSC2 FOSC1 FOSC0";//codesize is reserved 2 bytes for OSCCAL value
Name="PIC12C508",ID="XXXX",Class="PIC12F508",Category="MCU",MFG="Microchip",Package="DIP8",ENDPRG_COMMAND="0E",PRG_MODE="0"; No ID device need ID="XXXX"
Name="PIC12C508A",ID="XXXX",Class="PIC12F508",Category="MCU",MFG="Microchip",CodeSize="1022",CFGAddress(Hex)="FFF",Package="DIP8",ENDPRG_COMMAND="0E",PRG_MODE="0"; No ID device need ID="XXXX"
Name="PIC12C509",ID="XXXX",Class="PIC12F508",Category="MCU",MFG="Microchip",CodeSize="2046",CFGAddress(Hex)="FFF",Package="DIP8",ENDPRG_COMMAND="0E",PRG_MODE="0"; No ID device need ID="XXXX"
Name="PIC12C509A",ID="XXXX",Class="PIC12F508",Category="MCU",MFG="Microchip",CodeSize="2046",CFGAddress(Hex)="FFF",Package="DIP8",ENDPRG_COMMAND="0E",PRG_MODE="0"; No ID device need ID="XXXX"
;Name="PIC16C73A",ID="2901A",Class="PIC16C73A",Category="MCU",MFG="Microchip",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16C73A",ID="XXXX",Class="PIC16F872",Category="MCU",MFG="Microchip",CodeSize="4096",EepromSize="0",Package="DIP28",Speed="5",BEGPRG_COMMAND="8",ENDPRG_COMMAND="E",BEGERASECHIP_COMMAND="",PRG_MODE="0",Platform="GQ-4X",DeviceFile="PIC16C73A.dev";
;Name="PIC16C72A",ID="XXXX",Class="PIC16F872",Category="MCU",MFG="Microchip",CodeSize="4096",EepromSize="0",Package="DIP28",Speed="5",BEGPRG_COMMAND="8",ENDPRG_COMMAND="E",BEGERASECHIP_COMMAND="",PRG_MODE="0",Platform="GQ-4X",DeviceFile="PIC16C72A.dev";
Name="PIC12F508",ID="XXXX",Class="PIC12F508",Category="MCU",MFG="Microchip",Package="DIP8",ENDPRG_COMMAND="0E",BEGERASECHIP_COMMAND="",PRG_MODE="0",OSCCALAddress(Decimal)="516"; No ID device need ID="XXXX"
Name="PIC12F509",ID="XXXX",Class="PIC12F508",Category="MCU",MFG="Microchip",CodeSize="1024",Package="DIP8",ENDPRG_COMMAND="0E",BEGERASECHIP_COMMAND="",PRG_MODE="0",OSCCALAddress(Decimal)="1028"; No ID device need ID="XXXX"
Name="PIC12F615",ID="29218",Class="PIC16FXXX",Category="MCU",MFG="Microchip",CodeSize="2048",Package="DIP8",Speed="5",BEGPRG_COMMAND="18",ENDPRG_COMMAND="A",BEGERASECHIP_COMMAND="9",PRG_MODE="1",CFGByteLabel="- - - - BOREN1 BOREN0 IOSCFS CP MCLRE PWRTE WDTE FOSC2 FOSC1 FOSC0";
Name="PIC16F1826",ID="292780",Class="PIC16FXXX",Category="MCU",VPP="9V",WVPP="9V",Package="DIP18",MFG="Microchip",CFGAddress(Hex)="8007",CodeSize="4096",EepromSize="256",Package="DIP18",BEGPRG_COMMAND="8",ENDPRG_COMMAND="0A",BEGERASECHIP_COMMAND="9",ERASECHIP_COMMAND="",EEPROMHexFileAddress(Hex)="1E000",CFGHexFileAddress(Hex)="1000E",UserIDHexFileAddress(Hex)="10000",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F1827",ID="2927A0",Class="PIC16FXXX",Category="MCU",VPP="9V",WVPP="9V",Package="DIP18",MFG="Microchip",CFGAddress(Hex)="8007",CodeSize="4096",EepromSize="256",Package="DIP18",BEGPRG_COMMAND="8",ENDPRG_COMMAND="0A",BEGERASECHIP_COMMAND="9",ERASECHIP_COMMAND="",EEPROMHexFileAddress(Hex)="1E000",CFGHexFileAddress(Hex)="1000E",UserIDHexFileAddress(Hex)="10000",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC12F1822",ID="2927A0",Class="PIC16FXXX",Category="MCU",VPP="9V",WVPP="9V",MFG="Microchip",CFGAddress(Hex)="8007",CodeSize="4096",EepromSize="256",Package="DIP8",BEGPRG_COMMAND="8",ENDPRG_COMMAND="0A",BEGERASECHIP_COMMAND="9",ERASECHIP_COMMAND="",EEPROMHexFileAddress(Hex)="1E000",CFGHexFileAddress(Hex)="1000E",UserIDHexFileAddress(Hex)="10000",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F1823",ID="2927A0",Class="PIC16FXXX",Category="MCU",VPP="9V",WVPP="9V",MFG="Microchip",CFGAddress(Hex)="8007",CodeSize="4096",EepromSize="256",Package="DIP14",BEGPRG_COMMAND="8",ENDPRG_COMMAND="0A",BEGERASECHIP_COMMAND="9",ERASECHIP_COMMAND="",EEPROMHexFileAddress(Hex)="1E000",CFGHexFileAddress(Hex)="1000E",UserIDHexFileAddress(Hex)="10000",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F1824",ID="2927A0",Class="PIC16FXXX",Category="MCU",VPP="9V",WVPP="9V",MFG="Microchip",CFGAddress(Hex)="8007",CodeSize="4096",EepromSize="256",Package="DIP14",BEGPRG_COMMAND="8",ENDPRG_COMMAND="0A",BEGERASECHIP_COMMAND="9",ERASECHIP_COMMAND="",EEPROMHexFileAddress(Hex)="1E000",CFGHexFileAddress(Hex)="1000E",UserIDHexFileAddress(Hex)="10000",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F1825",ID="2927A0",Class="PIC16FXXX",Category="MCU",VPP="9V",WVPP="9V",MFG="Microchip",CFGAddress(Hex)="8007",CodeSize="4096",EepromSize="256",Package="DIP18",BEGPRG_COMMAND="8",ENDPRG_COMMAND="0A",BEGERASECHIP_COMMAND="9",ERASECHIP_COMMAND="",EEPROMHexFileAddress(Hex)="1E000",CFGHexFileAddress(Hex)="1000E",UserIDHexFileAddress(Hex)="10000",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F1828",ID="2927A0",Class="PIC16FXXX",Category="MCU",VPP="9V",WVPP="9V",MFG="Microchip",CFGAddress(Hex)="8007",CodeSize="4096",EepromSize="256",Package="DIP20",BEGPRG_COMMAND="8",ENDPRG_COMMAND="0A",BEGERASECHIP_COMMAND="9",ERASECHIP_COMMAND="",EEPROMHexFileAddress(Hex)="1E000",CFGHexFileAddress(Hex)="1000E",UserIDHexFileAddress(Hex)="10000",Adapter="ICSP/PIC adapter+";
Name="PIC16F1829",ID="2927A0",Class="PIC16FXXX",Category="MCU",VPP="9V",WVPP="9V",MFG="Microchip",CFGAddress(Hex)="8007",CodeSize="4096",EepromSize="256",Package="DIP20",BEGPRG_COMMAND="8",ENDPRG_COMMAND="0A",BEGERASECHIP_COMMAND="9",ERASECHIP_COMMAND="",EEPROMHexFileAddress(Hex)="1E000",CFGHexFileAddress(Hex)="1000E",UserIDHexFileAddress(Hex)="10000",Adapter="ICSP/PIC adapter+";
Name="PIC12LF1822",ID="2928A0",Class="PIC16FXXX",Category="MCU",VCC="3.6V",VPP="9V",WVPP="9V",MFG="Microchip",CFGAddress(Hex)="8007",CodeSize="4096",EepromSize="256",Package="DIP8",BEGPRG_COMMAND="8",ENDPRG_COMMAND="0A",BEGERASECHIP_COMMAND="9",ERASECHIP_COMMAND="",EEPROMHexFileAddress(Hex)="1E000",CFGHexFileAddress(Hex)="1000E",UserIDHexFileAddress(Hex)="10000",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16LF1823",ID="2928A0",Class="PIC16FXXX",Category="MCU",VCC="3.6V",VPP="9V",WVPP="9V",MFG="Microchip",CFGAddress(Hex)="8007",CodeSize="4096",EepromSize="256",Package="DIP14",BEGPRG_COMMAND="8",ENDPRG_COMMAND="0A",BEGERASECHIP_COMMAND="9",ERASECHIP_COMMAND="",EEPROMHexFileAddress(Hex)="1E000",CFGHexFileAddress(Hex)="1000E",UserIDHexFileAddress(Hex)="10000",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16LF1824",ID="2928A0",Class="PIC16FXXX",Category="MCU",VCC="3.6V",VPP="9V",WVPP="9V",MFG="Microchip",CFGAddress(Hex)="8007",CodeSize="4096",EepromSize="256",Package="DIP14",BEGPRG_COMMAND="8",ENDPRG_COMMAND="0A",BEGERASECHIP_COMMAND="9",ERASECHIP_COMMAND="",EEPROMHexFileAddress(Hex)="1E000",CFGHexFileAddress(Hex)="1000E",UserIDHexFileAddress(Hex)="10000",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16LF1825",ID="2928A0",Class="PIC16FXXX",Category="MCU",VCC="3.6V",VPP="9V",WVPP="9V",MFG="Microchip",CFGAddress(Hex)="8007",CodeSize="4096",EepromSize="256",Package="DIP18",BEGPRG_COMMAND="8",ENDPRG_COMMAND="0A",BEGERASECHIP_COMMAND="9",ERASECHIP_COMMAND="",EEPROMHexFileAddress(Hex)="1E000",CFGHexFileAddress(Hex)="1000E",UserIDHexFileAddress(Hex)="10000",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16LF1826",ID="2928A0",Class="PIC16FXXX",Category="MCU",VCC="3.6V",VPP="9V",WVPP="9V",MFG="Microchip",CFGAddress(Hex)="8007",CodeSize="4096",EepromSize="256",Package="DIP18",BEGPRG_COMMAND="8",ENDPRG_COMMAND="0A",BEGERASECHIP_COMMAND="9",ERASECHIP_COMMAND="",EEPROMHexFileAddress(Hex)="1E000",CFGHexFileAddress(Hex)="1000E",UserIDHexFileAddress(Hex)="10000",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16LF1827",ID="2928A0",Class="PIC16FXXX",Category="MCU",VCC="3.6V",VPP="9V",WVPP="9V",MFG="Microchip",CFGAddress(Hex)="8007",CodeSize="4096",EepromSize="256",Package="DIP18",BEGPRG_COMMAND="8",ENDPRG_COMMAND="0A",BEGERASECHIP_COMMAND="9",ERASECHIP_COMMAND="",EEPROMHexFileAddress(Hex)="1E000",CFGHexFileAddress(Hex)="1000E",UserIDHexFileAddress(Hex)="10000",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16LF1828",ID="2928A0",Class="PIC16FXXX",Category="MCU",VCC="3.6V",VPP="9V",WVPP="9V",MFG="Microchip",CFGAddress(Hex)="8007",CodeSize="4096",EepromSize="256",Package="DIP20",BEGPRG_COMMAND="8",ENDPRG_COMMAND="0A",BEGERASECHIP_COMMAND="9",ERASECHIP_COMMAND="",EEPROMHexFileAddress(Hex)="1E000",CFGHexFileAddress(Hex)="1000E",UserIDHexFileAddress(Hex)="10000",Adapter="ICSP/PIC adapter+";
Name="PIC16LF1829",ID="2928A0",Class="PIC16FXXX",Category="MCU",VCC="3.6V",VPP="9V",WVPP="9V",MFG="Microchip",CFGAddress(Hex)="8007",CodeSize="4096",EepromSize="256",Package="DIP20",BEGPRG_COMMAND="8",ENDPRG_COMMAND="0A",BEGERASECHIP_COMMAND="9",ERASECHIP_COMMAND="",EEPROMHexFileAddress(Hex)="1E000",CFGHexFileAddress(Hex)="1000E",UserIDHexFileAddress(Hex)="10000",Adapter="ICSP/PIC adapter+";
Name="PIC12F629",ID="290F80",Class="PIC16FXXX",Category="MCU",MFG="Microchip",CodeSize="2046",Package="DIP8",Speed="5",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",BEGERASECHIP_COMMAND="",PRG_MODE="1",OSCCALAddress(Decimal)="1023",CFGByteLabel="BG1 BG0 - - - CPD CP BODEN MCLRE PWRTE WDTE FOSC2 FOSC1 FOSC0",Message="Short the pin1 & pin4 by a 1K-100K resistor to help erase the chip. if CFG bit MCLRE been set to 0."; //codesize is reserved 2 bytes for OSCCAL value
Name="PIC12F675",ID="290FC",Class="PIC16FXXX",Category="MCU",MFG="Microchip",CodeSize="2046",Package="DIP8",Speed="5",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",BEGERASECHIP_COMMAND="",PRG_MODE="1",OSCCALAddress(Decimal)="1023",CFGByteLabel="BG1 BG0 - - - CPD CP BODEN MCLRE PWRTE WDTE FOSC2 FOSC1 FOSC0",Message="Short the pin1 & pin4 by a 1K-100K resistor to help erase the chip. if CFG bit MCLRE been set to 0."; //codesize is reserved 2 bytes for OSCCAL value
Name="PIC12F630",ID="2910D",Class="PIC16FXXX",Category="MCU",MFG="Microchip",CodeSize="2046",Package="DIP14",Speed="5",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",BEGERASECHIP_COMMAND="",PRG_MODE="1",OSCCALAddress(Decimal)="1023",CFGByteLabel="BG1 BG0 - - - CPD CP BODEN MCLRE PWRTE WDTE FOSC2 FOSC1 FOSC0",Message="Short the pin1 & pin4 by a 1K-100K resistor to help erase the chip. if CFG bit MCLRE been set to 0."; //codesize is reserved 2 bytes for OSCCAL value
Name="PIC12F676",ID="2910F",Class="PIC16FXXX",Category="MCU",MFG="Microchip",CodeSize="2046",Package="DIP14",Speed="5",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",BEGERASECHIP_COMMAND="",PRG_MODE="1",OSCCALAddress(Decimal)="1023",CFGByteLabel="BG1 BG0 - - - CPD CP BODEN MCLRE PWRTE WDTE FOSC2 FOSC1 FOSC0",Message="Short the pin1 & pin4 by a 1K-100K resistor to help erase the chip. if CFG bit MCLRE been set to 0."; //codesize is reserved 2 bytes for OSCCAL value
Name="PIC12F683",ID="29046",Class="PIC16FXXX",Category="MCU",MFG="Microchip",CodeSize="4096",Package="DIP8",Speed="5",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",BEGERASECHIP_COMMAND="",PRG_MODE="1",CFGByteLabel="- - FCMEN IESO BODEN1 BODEN0 CPD CP MCLRE PWRTE WDTE FOSC2 F0SC1 F0SC0";
Name="PIC12F635",ID="290FA",Class="PIC16FXXX",Category="MCU",MFG="Microchip",CodeSize="2048",Package="DIP8",Speed="5",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",BEGERASECHIP_COMMAND="",PRG_MODE="1",CFGByteLabel="- WURE FCMEN IESO BOREN1 BOREN0 CPD CP MCLRE PWRTE WDTE FOSC2 F0SC1 F0SC0";
Name="PIC16F631",ID="29142",Class="PIC16FXXX",Category="MCU",MFG="Microchip",CodeSize="2048",Package="DIP8",Speed="5",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",BEGERASECHIP_COMMAND="",PRG_MODE="1",CFGByteLabel="- - FCMEN IESO BODEN1 BODEN0 CPD CP MCLRE PWRTE WDTE FOSC2 F0SC1 F0SC0",Adapter="ICSP/PIC adapter+";
Name="PIC16F636",ID="2910A",Class="PIC16FXXX",Category="MCU",MFG="Microchip",CodeSize="4096",Package="DIP14",Speed="5",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",BEGERASECHIP_COMMAND="",PRG_MODE="1",CFGByteLabel="- WURE FCMEN IESO BOREN1 BOREN0 CPD CP MCLRE PWRTE WDTE FOSC2 F0SC1 F0SC0",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F639*DIP20",ID="2910A",Class="PIC16FXXX",Category="MCU",MFG="Microchip",CodeSize="4096",ChipMode="ICSP",Package="DIP8",Speed="5",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",BEGERASECHIP_COMMAND="",PRG_MODE="1",CFGByteLabel="- WURE FCMEN IESO BOREN1 BOREN0 CPD CP MCLRE PWRTE WDTE FOSC2 F0SC1 F0SC0",Adapter="ICSP/PIC adapter+";
Name="PIC16F677*DIP20",ID="29144",Class="PIC16FXXX",Category="MCU",MFG="Microchip",CodeSize="4096",ChipMode="ICSP",EepromSize="256",Package="DIP8",Speed="5",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",BEGERASECHIP_COMMAND="",PRG_MODE="1",CFGByteLabel="- - FCMEN IESO BODEN1 BODEN0 CPD CP MCLRE PWRTE WDTE FOSC2 F0SC1 F0SC0",Adapter="ICSP/PIC adapter+";
Name="PIC16F684",ID="29108",Class="PIC16FXXX",Category="MCU",MFG="Microchip",CodeSize="4096",EepromSize="256",Package="DIP14",Speed="5",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",BEGERASECHIP_COMMAND="",PRG_MODE="1",CFGByteLabel="- - FCMEN IESO BODEN1 BODEN0 CPD CP MCLRE PWRTE WDTE FOSC2 F0SC1 F0SC0",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F685*DIP20",ID="2904A",Class="PIC16FXXX",Category="MCU",MFG="Microchip",CodeSize="8192",ChipMode="ICSP",EepromSize="256",Package="DIP8",Speed="5",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",BEGERASECHIP_COMMAND="",PRG_MODE="1",CFGByteLabel="- - FCMEN IESO BODEN1 BODEN0 CPD CP MCLRE PWRTE WDTE FOSC2 F0SC1 F0SC0",Adapter="ICSP/PIC adapter+";
Name="PIC16F687*DIP20",ID="29132",Class="PIC16FXXX",Category="MCU",MFG="Microchip",CodeSize="4096",ChipMode="ICSP",EepromSize="256",Package="DIP8",Speed="5",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",BEGERASECHIP_COMMAND="",PRG_MODE="1",CFGByteLabel="- - FCMEN IESO BODEN1 BODEN0 CPD CP MCLRE PWRTE WDTE FOSC2 F0SC1 F0SC0",Adapter="ICSP/PIC adapter+";
Name="PIC16F688",ID="29118",Class="PIC16FXXX",Category="MCU",MFG="Microchip",CodeSize="8192",EepromSize="256",Package="DIP14",Speed="5",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",BEGERASECHIP_COMMAND="",PRG_MODE="1",CFGByteLabel="- - FCMEN IESO BODEN1 BODEN0 CPD CP MCLRE PWRTE WDTE FOSC2 F0SC1 F0SC0",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F689*DIP20",ID="29134",Class="PIC16FXXX",Category="MCU",MFG="Microchip",CodeSize="8192",ChipMode="ICSP",EepromSize="256",Package="DIP8",Speed="5",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",BEGERASECHIP_COMMAND="",PRG_MODE="1",CFGByteLabel="- - FCMEN IESO BODEN1 BODEN0 CPD CP MCLRE PWRTE WDTE FOSC2 F0SC1 F0SC0",Adapter="ICSP/PIC adapter+";
Name="PIC16F690*DIP20",ID="29140",Class="PIC16FXXX",Category="MCU",MFG="Microchip",CodeSize="8192",ChipMode="ICSP",EepromSize="256",Package="DIP8",Speed="5",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",BEGERASECHIP_COMMAND="",PRG_MODE="1",CFGByteLabel="- - FCMEN IESO BODEN1 BODEN0 CPD CP MCLRE PWRTE WDTE FOSC2 F0SC1 F0SC0",Adapter="ICSP/PIC adapter+";
Name="PIC16F737",ID="290BA",Class="PIC16F872",Category="MCU",MFG="Microchip",CodeSize="4096",EepromSize="0",Package="DIP28",Speed="5",BEGPRG_COMMAND="8",ENDPRG_COMMAND="E",BEGERASECHIP_COMMAND="",PRG_MODE="0",ERASECHIP_COMMAND="9",CFGByteLabel="CP CCPMX RESV - - BORV1 BORV0 BOREN MCLRE F0SC2 PWRTEN WDTEN F0SC1 F0SC0",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F747",ID="290BE",Class="PIC16FXXX",Category="MCU",MFG="Microchip",CodeSize="4096",EepromSize="0",Package="DIP40",Speed="5",BEGPRG_COMMAND="8",ENDPRG_COMMAND="E",BEGERASECHIP_COMMAND="",PRG_MODE="0",ERASECHIP_COMMAND="9",CFGByteLabel="CP CCPMX RESV - - BORV1 BORV0 BOREN MCLRE F0SC2 PWRTEN WDTEN F0SC1 F0SC0",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F767",ID="290EA",Class="PIC16F872",Category="MCU",MFG="Microchip",CodeSize="8192",EepromSize="0",Package="DIP28",Speed="5",BEGPRG_COMMAND="8",ENDPRG_COMMAND="E",BEGERASECHIP_COMMAND="",PRG_MODE="0",ERASECHIP_COMMAND="9",CFGByteLabel="CP CCPMX RESV - - BORV1 BORV0 BOREN MCLRE F0SC2 PWRTEN WDTEN F0SC1 F0SC0",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F777",ID="290DE",Class="PIC16FXXX",Category="MCU",MFG="Microchip",CodeSize="8192",EepromSize="0",Package="DIP40",Speed="5",BEGPRG_COMMAND="8",ENDPRG_COMMAND="E",BEGERASECHIP_COMMAND="",PRG_MODE="0",ERASECHIP_COMMAND="9",CFGByteLabel="CP CCPMX RESV - - BORV1 BORV0 BOREN MCLRE F0SC2 PWRTEN WDTEN F0SC1 F0SC0",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F84",ID="XXXX",Class="PIC16F84A",Category="MCU",MFG="Microchip",ENDPRG_COMMAND="",SKIP_WRITE_BLANK="0",BEGERASECHIP_COMMAND="8",Speed="4",Message="To erase this chip: Fill buffer with all FF and then write to chip."; no ENDPRG command is needed on this device
Name="PIC16F84A",ID="29056",Class="PIC16F84A",Category="MCU",MFG="Microchip",ENDPRG_COMMAND="",BEGERASECHIP_COMMAND="8"; no ENDPRG command is needed on this device
Name="PIC16F627A",ID="29104",Class="PIC16F628A",Category="MCU",MFG="Microchip",ENDPRG_COMMAND="",CodeSize="2048",BEGERASECHIP_COMMAND="";
Name="PIC16F628A",ID="29106",Class="PIC16F628A",Category="MCU",MFG="Microchip",ENDPRG_COMMAND="",BEGERASECHIP_COMMAND="",DeviceFile="PIC16F628A.dev";
;Name="PIC16F627",ID="2907A0",Class="PIC16F628A",Category="MCU",MFG="Microchip",ENDPRG_COMMAND="",BEGERASECHIP_COMMAND="8",DeviceFile="PIC16F627.dev";
;Name="PIC16LF627",ID="2907A0",Class="PIC16F628A",Category="MCU",MFG="Microchip",ENDPRG_COMMAND="",BEGERASECHIP_COMMAND="8",DeviceFile="PIC16F627.dev";
Name="PIC16F628",ID="2907C0",Class="PIC16F628A",Category="MCU",MFG="Microchip",ENDPRG_COMMAND="",BEGERASECHIP_COMMAND="8",DeviceFile="PIC16F628.dev";
Name="PIC16LF628",ID="2907C0",Class="PIC16F628A",Category="MCU",MFG="Microchip",ENDPRG_COMMAND="",BEGERASECHIP_COMMAND="8",DeviceFile="PIC16F628.dev";
Name="PIC16F818",ID="29106",Class="PIC16F628A",Category="MCU",MFG="Microchip",CodeSize="2048",EepromSize="128",BEGPRG_COMMAND="18",ENDPRG_COMMAND="17",BEGERASECHIP_COMMAND="",PRG_MODE="0",ERASECHIP_COMMAND="1F";
Name="PIC16F819",ID="2904E0",Class="PIC16F628A",Category="MCU",MFG="Microchip",CodeSize="4096",EepromSize="256",BEGPRG_COMMAND="18",ENDPRG_COMMAND="17",BEGERASECHIP_COMMAND="",PRG_MODE="0",ERASECHIP_COMMAND="1F";
Name="PIC16LF628A",ID="29106",Class="PIC16F628A",Category="MCU",MFG="Microchip",ENDPRG_COMMAND="",BEGERASECHIP_COMMAND="",DeviceFile="PIC16F628.dev";
Name="PIC16F648A",ID="29104",Class="PIC16F628A",Category="MCU",MFG="Microchip",ENDPRG_COMMAND="",BEGERASECHIP_COMMAND="",CodeSize="8192",EepromSize="256";
Name="PIC16F716",ID="29114",Class="PIC16F628A",,CodeSize="4096",EepromSize="0",Package="DIP18",Category="MCU",MFG="Microchip",BEGPRG_COMMAND="18",ENDPRG_COMMAND="0E",BEGERASECHIP_COMMAND="",CFGByteLabel="CP - - - - - BORV BOREN - - PWRTE WDTE FOSC1 FOSC0";
Name="PIC16F630",ID="2910C",Class="PIC16FXXX",Category="MCU",MFG="Microchip",CodeSize="2046",EepromSize="128",Package="DIP14",Speed="5",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",BEGERASECHIP_COMMAND="",PRG_MODE="1",OSCCALAddress(Decimal)="1023",CFGByteLabel="BG1 BG0 - - - CPD CP BODEN MCLRE PWRTE WDTE FOSC2 FOSC1 FOSC0"; //codesize is reserved 2 bytes for OSCCAL value
Name="PIC16F676",ID="2900E",Class="PIC16FXXX",Category="MCU",MFG="Microchip",CodeSize="2046",EepromSize="128",Package="DIP14",Speed="5",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",BEGERASECHIP_COMMAND="",PRG_MODE="1",OSCCALAddress(Decimal)="1023",CFGByteLabel="BG1 BG0 - - - CPD CP BODEN MCLRE PWRTE WDTE FOSC2 FOSC1 FOSC0"; //codesize is reserved 2 bytes for OSCCAL value
Name="PIC16F873A",ID="290e4",Class="PIC16F877A",Category="MCU",MFG="Microchip",CodeSize="8192",EepromSize="128",Package="DIP28",PRG_MODE="0",BEGPRG_COMMAND="8",ENDPRG_COMMAND="17",ERASECHIP_COMMAND="1F",BEGERASECHIP_COMMAND="8",PAGE_WRITE_SIZE="8",CFG_PAGE_WRITE_SIZE="4",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F874A",ID="290e6",Class="PIC16F877A",Category="MCU",MFG="Microchip",CodeSize="8192",EepromSize="128",Package="DIP40",PRG_MODE="0",BEGPRG_COMMAND="8",ENDPRG_COMMAND="17",ERASECHIP_COMMAND="1F",BEGERASECHIP_COMMAND="8",PAGE_WRITE_SIZE="8",CFG_PAGE_WRITE_SIZE="4",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F876A",ID="290e0",Class="PIC16F877A",Category="MCU",MFG="Microchip",CodeSize="16384",EepromSize="256",Package="DIP40",PRG_MODE="0",BEGPRG_COMMAND="8",ENDPRG_COMMAND="17",ERASECHIP_COMMAND="1F",BEGERASECHIP_COMMAND="8",PAGE_WRITE_SIZE="8",CFG_PAGE_WRITE_SIZE="4",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F877A",ID="290e2",Class="PIC16F877A",Category="MCU",MFG="Microchip",CodeSize="16384",EepromSize="256",Package="DIP40",PRG_MODE="0",BEGPRG_COMMAND="8",ENDPRG_COMMAND="17",ERASECHIP_COMMAND="1F",BEGERASECHIP_COMMAND="8",PAGE_WRITE_SIZE="8",CFG_PAGE_WRITE_SIZE="4",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F876A*DIP28",ID="290e0",Class="PIC16F877A",Category="MCU",MFG="Microchip",CodeSize="16384",EepromSize="256",Package="DIP28",PRG_MODE="0",BEGPRG_COMMAND="8",ENDPRG_COMMAND="17",ERASECHIP_COMMAND="1F",BEGERASECHIP_COMMAND="8",PAGE_WRITE_SIZE="8",CFG_PAGE_WRITE_SIZE="4",PINVCC="ZIF32_PIN28",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F877A*ICSP",ID="290e2",Class="PIC16F877A",Category="MCU",MFG="Microchip",CodeSize="16384",EepromSize="256",Package="DIP40",PRG_MODE="0",BEGPRG_COMMAND="8",ENDPRG_COMMAND="17",ERASECHIP_COMMAND="1F",BEGERASECHIP_COMMAND="8",PAGE_WRITE_SIZE="8",CFG_PAGE_WRITE_SIZE="4",ChipMode="ICSP",Adapter="ICSP/PIC adapter+, no adapter required on GQ-3X";
Name="PIC16F72",ID="290A0",Class="PIC16F872",Category="MCU",MFG="Microchip",CodeSize="4096",EepromSize="0",Package="DIP28",Speed="5",BEGPRG_COMMAND="8",ENDPRG_COMMAND="E",BEGERASECHIP_COMMAND="",ERASECHIP_COMMAND="9",PRG_MODE="0",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F73",ID="29060",Class="PIC16F872",Category="MCU",MFG="Microchip",CodeSize="4096",EepromSize="0",Package="DIP28",Speed="5",BEGPRG_COMMAND="8",ENDPRG_COMMAND="E",BEGERASECHIP_COMMAND="",ERASECHIP_COMMAND="9",PRG_MODE="0",CFGByteLabel="- - - - - - - BODEN - CP0 PWRTE WDTE F0SC1 F0SC0",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F74",ID="29061",Class="PIC16FXXX",Category="MCU",MFG="Microchip",CodeSize="4096",EepromSize="0",Package="DIP40",Speed="5",BEGPRG_COMMAND="8",ENDPRG_COMMAND="E",BEGERASECHIP_COMMAND="",ERASECHIP_COMMAND="9",PRG_MODE="0",CFGByteLabel="- - - - - - - BODEN - CP0 PWRTE WDTE F0SC1 F0SC0",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F76",ID="29062",Class="PIC16F872",Category="MCU",MFG="Microchip",CodeSize="8192",EepromSize="0",Package="DIP28",Speed="5",BEGPRG_COMMAND="8",ENDPRG_COMMAND="E",BEGERASECHIP_COMMAND="",ERASECHIP_COMMAND="9",PRG_MODE="0",CFGByteLabel="- - - - - - - BODEN - CP0 PWRTE WDTE F0SC1 F0SC0",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F77",ID="29063",Class="PIC16FXXX",Category="MCU",MFG="Microchip",CodeSize="8192",EepromSize="0",Package="DIP40",Speed="5",BEGPRG_COMMAND="8",ENDPRG_COMMAND="E",BEGERASECHIP_COMMAND="",ERASECHIP_COMMAND="9",PRG_MODE="0",CFGByteLabel="- - - - - - - BODEN - CP0 PWRTE WDTE F0SC1 F0SC0",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F87",ID="29072",Class="PIC16FXXX",Category="MCU",MFG="Microchip",CodeSize="8192",EepromSize="256",Package="DIP18",Speed="5",BEGPRG_COMMAND="18",ENDPRG_COMMAND="17",BEGERASECHIP_COMMAND="8",ERASECHIP_COMMAND="1F",PRG_MODE="0",CFGByteLabel="CP CCPMX DEBUG WRT1 WRT0 CPD LVP BOREN MCLRE FOSC2 PWRTEN WDTEN FOSC1 FOSC0";
Name="PIC16F88",ID="29076",Class="PIC16FXXX",Category="MCU",MFG="Microchip",CodeSize="8192",EepromSize="256",Package="DIP18",Speed="5",BEGPRG_COMMAND="18",ENDPRG_COMMAND="17",BEGERASECHIP_COMMAND="8",ERASECHIP_COMMAND="1F",PRG_MODE="0",CFGByteLabel="CP CCPMX DEBUG WRT1 WRT0 CPD LVP BOREN MCLRE FOSC2 PWRTEN WDTEN FOSC1 FOSC0";
Name="PIC16F870",ID="290D0",Class="PIC16F872",Category="MCU",MFG="Microchip",CodeSize="4096",EepromSize="64",Package="DIP28",PRG_MODE="0",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",ERASECHIP_COMMAND="1F",BEGERASECHIP_COMMAND="8",PAGE_WRITE_SIZE="1",CFG_PAGE_WRITE_SIZE="1",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F872",ID="2908E",Class="PIC16F872",Category="MCU",MFG="Microchip",CodeSize="4096",EepromSize="64",Package="DIP28",PRG_MODE="0",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",ERASECHIP_COMMAND="1F",BEGERASECHIP_COMMAND="8",PAGE_WRITE_SIZE="1",CFG_PAGE_WRITE_SIZE="1",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F872*TSSP28",ID="2908E",Class="PIC16F872",Category="MCU",MFG="Microchip",CodeSize="4096",EepromSize="64",Package="DIP28",PRG_MODE="0",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",ERASECHIP_COMMAND="1F",BEGERASECHIP_COMMAND="8",PAGE_WRITE_SIZE="1",CFG_PAGE_WRITE_SIZE="1",Adapter="ADP-068 CNV-SSOP-34";
Name="PIC16F873",ID="29096",Class="PIC16F872",Category="MCU",MFG="Microchip",CodeSize="8192",EepromSize="128",Package="DIP28",PRG_MODE="0",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",ERASECHIP_COMMAND="1F",BEGERASECHIP_COMMAND="8",PAGE_WRITE_SIZE="1",CFG_PAGE_WRITE_SIZE="1",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F876",ID="2909E",Class="PIC16F872",Category="MCU",MFG="Microchip",CodeSize="16384",EepromSize="256",Package="DIP28",PRG_MODE="0",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",ERASECHIP_COMMAND="1F",BEGERASECHIP_COMMAND="8",PAGE_WRITE_SIZE="1",CFG_PAGE_WRITE_SIZE="1",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F871",ID="290D2",Class="PIC16F872",Category="MCU",MFG="Microchip",CodeSize="4096",EepromSize="64",Package="DIP40",PRG_MODE="0",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",ERASECHIP_COMMAND="1F",BEGERASECHIP_COMMAND="8",PAGE_WRITE_SIZE="1",CFG_PAGE_WRITE_SIZE="1",CFGByteLabel="CP1 CP0 RESV - WRT CPD LVP BODEN CP1 CP0 PWRTE WDTE F0SC1 F0SC0",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F874",ID="29092",Class="PIC16F872",Category="MCU",MFG="Microchip",CodeSize="8192",EepromSize="128",Package="DIP40",PRG_MODE="0",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",ERASECHIP_COMMAND="1F",BEGERASECHIP_COMMAND="8",PAGE_WRITE_SIZE="1",CFG_PAGE_WRITE_SIZE="1",CFGByteLabel="CP1 CP0 RESV - WRT CPD LVP BODEN CP1 CP0 PWRTE WDTE F0SC1 F0SC0",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F877",ID="2909A",Class="PIC16F872",Category="MCU",MFG="Microchip",CodeSize="16384",EepromSize="256",Package="DIP40",PRG_MODE="0",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",ERASECHIP_COMMAND="1F",BEGERASECHIP_COMMAND="8",PAGE_WRITE_SIZE="1",CFG_PAGE_WRITE_SIZE="1",CFGByteLabel="CP1 CP0 RESV - WRT CPD LVP BODEN CP1 CP0 PWRTE WDTE F0SC1 F0SC0",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F882",ID="29200",Class="PIC16F872",Category="MCU",MFG="Microchip",CodeSize="4096",EepromSize="128",Package="DIP28",PRG_MODE="0",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",ERASECHIP_COMMAND="1F",BEGERASECHIP_COMMAND="8",PAGE_WRITE_SIZE="1",CFG_PAGE_WRITE_SIZE="1",CFGByteLabel="DEBUG LVP FCMEN IESO BOREN1 BOREN0 CPD CP MCLRE PWRTE WDTEN FOSC2 FOSC1 FOSC0",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F883",ID="29202",Class="PIC16F872",Category="MCU",MFG="Microchip",CodeSize="8192",EepromSize="256",Package="DIP28",PRG_MODE="0",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",ERASECHIP_COMMAND="1F",BEGERASECHIP_COMMAND="8",PAGE_WRITE_SIZE="1",CFG_PAGE_WRITE_SIZE="1",CFGByteLabel="DEBUG LVP FCMEN IESO BOREN1 BOREN0 CPD CP MCLRE PWRTE WDTEN FOSC2 FOSC1 FOSC0",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F886",ID="29206",Class="PIC16F872",Category="MCU",MFG="Microchip",CodeSize="16384",EepromSize="256",Package="DIP28",PRG_MODE="0",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",ERASECHIP_COMMAND="1F",BEGERASECHIP_COMMAND="8",PAGE_WRITE_SIZE="1",CFG_PAGE_WRITE_SIZE="1",CFGByteLabel="DEBUG LVP FCMEN IESO BOREN1 BOREN0 CPD CP MCLRE PWRTE WDTEN FOSC2 FOSC1 FOSC0",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F884",ID="29204",Class="PIC16F872",Category="MCU",MFG="Microchip",CodeSize="8192",EepromSize="256",Package="DIP40",PRG_MODE="0",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",ERASECHIP_COMMAND="1F",BEGERASECHIP_COMMAND="8",PAGE_WRITE_SIZE="1",CFG_PAGE_WRITE_SIZE="1",CFGByteLabel="DEBUG LVP FCMEN IESO BOREN1 BOREN0 CPD CP MCLRE PWRTE WDTEN FOSC2 FOSC1 FOSC0",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F887",ID="29208",Class="PIC16F872",Category="MCU",MFG="Microchip",CodeSize="16384",EepromSize="256",Package="DIP40",PRG_MODE="0",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",ERASECHIP_COMMAND="1F",BEGERASECHIP_COMMAND="8",PAGE_WRITE_SIZE="1",CFG_PAGE_WRITE_SIZE="1",CFGByteLabel="DEBUG LVP FCMEN IESO BOREN1 BOREN0 CPD CP MCLRE PWRTE WDTEN FOSC2 FOSC1 FOSC0",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F913",ID="2913E",Class="PIC16F872",Category="MCU",MFG="Microchip",CodeSize="8192",EepromSize="256",Package="DIP28",PRG_MODE="0",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",ERASECHIP_COMMAND="1F",BEGERASECHIP_COMMAND="8",PAGE_WRITE_SIZE="1",CFG_PAGE_WRITE_SIZE="1",CFGByteLabel="- DEBUG FCMEN IESO BOREN1 BOREN0 CPD CP MCLRE PWRTE WDTE FOSC2 FOSC1 FOSC0",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F914",ID="2913C",Class="PIC16F872",Category="MCU",MFG="Microchip",CodeSize="8192",EepromSize="256",Package="DIP40",PRG_MODE="0",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",ERASECHIP_COMMAND="1F",BEGERASECHIP_COMMAND="8",PAGE_WRITE_SIZE="1",CFG_PAGE_WRITE_SIZE="1",CFGByteLabel="- DEBUG FCMEN IESO BOREN1 BOREN0 CPD CP MCLRE PWRTE WDTE FOSC2 FOSC1 FOSC0",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F916",ID="2913A",Class="PIC16F872",Category="MCU",MFG="Microchip",CodeSize="16384",EepromSize="256",Package="DIP28",PRG_MODE="0",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",ERASECHIP_COMMAND="1F",BEGERASECHIP_COMMAND="8",PAGE_WRITE_SIZE="1",CFG_PAGE_WRITE_SIZE="1",CFGByteLabel="- DEBUG FCMEN IESO BOREN1 BOREN0 CPD CP MCLRE PWRTE WDTE FOSC2 FOSC1 FOSC0",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F917",ID="29138",Class="PIC16F872",Category="MCU",MFG="Microchip",CodeSize="16384",EepromSize="256",Package="DIP40",PRG_MODE="0",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",ERASECHIP_COMMAND="1F",BEGERASECHIP_COMMAND="8",PAGE_WRITE_SIZE="1",CFG_PAGE_WRITE_SIZE="1",CFGByteLabel="- DEBUG FCMEN IESO BOREN1 BOREN0 CPD CP MCLRE PWRTE WDTE FOSC2 FOSC1 FOSC0",Adapter="ICSP/PIC adapter+, no adapter required on GQ-4X";
Name="PIC16F946",ID="29146",Class="PIC16F872",Category="MCU",MFG="Microchip",CodeSize="16384",EepromSize="256",Package="QFP64",PRG_MODE="0",BEGPRG_COMMAND="8",ENDPRG_COMMAND="",ERASECHIP_COMMAND="1F",BEGERASECHIP_COMMAND="8",PAGE_WRITE_SIZE="1",CFG_PAGE_WRITE_SIZE="1",CFGByteLabel="- DEBUG FCMEN IESO BOREN1 BOREN0 CPD CP MCLRE PWRTE WDTE FOSC2 FOSC1 FOSC0",Adapter="ICSP Programming";
Name="PIC18F2320*DIP28",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP28",Platform="GQ-4X (>Re1.30)",PINVCC="ZIF32_PIN28";
Name="PIC18F2221*DIP28",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP28",Platform="GQ-4X (>Re1.30)",PINVCC="ZIF32_PIN28";
Name="PIC18F2321*DIP28",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP28",Platform="GQ-4X (>Re1.30)",PINVCC="ZIF32_PIN28";
Name="PIC18F2410*DIP28",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP28",Platform="GQ-4X (>Re1.30)",PINVCC="ZIF32_PIN28";
Name="PIC18F2420*DIP28",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP28",Platform="GQ-4X (>Re1.30)",PINVCC="ZIF32_PIN28";
Name="PIC18F2423*DIP28",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP28",Platform="GQ-4X (>Re1.30)",PINVCC="ZIF32_PIN28";
Name="PIC18F2450*DIP28",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP28",Platform="GQ-4X (>Re1.30)",PINVCC="ZIF32_PIN28";
Name="PIC18F2455*DIP28",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP28",Platform="GQ-4X (>Re1.30)",PINVCC="ZIF32_PIN28";
Name="PIC18F2458*DIP28",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP28",Platform="GQ-4X (>Re1.30)",PINVCC="ZIF32_PIN28";
Name="PIC18F2480*DIP28",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP28",Platform="GQ-4X (>Re1.30)",PINVCC="ZIF32_PIN28";
Name="PIC18F2510*DIP28",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP28",Platform="GQ-4X (>Re1.30)",PINVCC="ZIF32_PIN28";
Name="PIC18F2515*DIP28",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP28",Platform="GQ-4X (>Re1.30)",PINVCC="ZIF32_PIN28";
Name="PIC18F2520*DIP28",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP28",Platform="GQ-4X (>Re1.30)",PINVCC="ZIF32_PIN28";
Name="PIC18F2523*DIP28",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP28",Platform="GQ-4X (>Re1.30)",PINVCC="ZIF32_PIN28";
Name="PIC18F2525*DIP28",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP28",Platform="GQ-4X (>Re1.30)",PINVCC="ZIF32_PIN28";
Name="PIC18F2550*DIP28",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP28",Platform="GQ-4X (>Re1.30)",PINVCC="ZIF32_PIN28";
Name="PIC18F2553*DIP28",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP28",Platform="GQ-4X (>Re1.30)",PINVCC="ZIF32_PIN28";
Name="PIC18F2580*DIP28",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP28",Platform="GQ-4X (>Re1.30)",PINVCC="ZIF32_PIN28";
Name="PIC18F2585*DIP28",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP28",Platform="GQ-4X (>Re1.30)",PINVCC="ZIF32_PIN28";
Name="PIC18F2610*DIP28",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP28",Platform="GQ-4X (>Re1.30)",PINVCC="ZIF32_PIN28";
Name="PIC18F2620*DIP28",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP28",Platform="GQ-4X (>Re1.30)",PINVCC="ZIF32_PIN28";
Name="PIC18F2680*DIP28",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP28",Platform="GQ-4X (>Re1.30)",PINVCC="ZIF32_PIN28";
Name="PIC18F2682*DIP28",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP28",Platform="GQ-4X (>Re1.30)",PINVCC="ZIF32_PIN28";
Name="PIC18F2685*DIP28",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP28",Platform="GQ-4X (>Re1.30)",PINVCC="ZIF32_PIN28";
;PIC18F23K20
;PIC18F24K20
;PIC18F25K20
;PIC18F26K20
;PIC18F43K20
;PIC18F44K20
;IC18F45K20
;IC18F46K20
Name="PIC18F26K20*DIP28",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP28",VPP="9V",VCC="3.6V",WVPP="9V",WVCC="3.6V",Platform="GQ-4X (>Re1.30)",PINVCC="ZIF32_PIN28";
Name="PIC18F4221*DIP40",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4321*DIP40",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4410*DIP40",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4420*DIP40",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4423*DIP40",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4450*DIP40",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4455*DIP40",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4458*DIP40",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4480*DIP40",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4510*DIP40",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4515*DIP40",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4520*DIP40",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4523*DIP40",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4525*DIP40",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4550*DIP40",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4553*DIP40",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4580*DIP40",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4585*DIP40",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4610*DIP40",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4620*DIP40",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4680*DIP40",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4682*DIP40",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4685*DIP40",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",Platform="GQ-4X (>Re1.30)";
Name="PIC18FL4550*DIP40",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",Platform="GQ-4X (>Re1.30)";
Name="PIC18F242*DIP28",ID="XXXX",Class="PIC18FXX2_XX8",Category="MCU",MFG="Microchip",Package="DIP28",Platform="GQ-4X (>Re1.30)";
Name="PIC18F248*DIP28",ID="XXXX",Class="PIC18FXX2_XX8",Category="MCU",MFG="Microchip",Package="DIP28",Platform="GQ-4X (>Re1.30)";
Name="PIC18F252*DIP28",ID="XXXX",Class="PIC18FXX2_XX8",Category="MCU",MFG="Microchip",Package="DIP28",Platform="GQ-4X (>Re1.30)";
Name="PIC18F258*DIP28",ID="XXXX",Class="PIC18FXX2_XX8",Category="MCU",MFG="Microchip",Package="DIP28",Platform="GQ-4X (>Re1.30)";
Name="PIC18F442*DIP40",ID="XXXX",Class="PIC18FXX2_XX8",Category="MCU",MFG="Microchip",Package="DIP40",Platform="GQ-4X (>Re1.30)";
Name="PIC18F448*DIP40",ID="XXXX",Class="PIC18FXX2_XX8",Category="MCU",MFG="Microchip",Package="DIP40",Platform="GQ-4X (>Re1.30)";
Name="PIC18F452*DIP40",ID="XXXX",Class="PIC18FXX2_XX8",Category="MCU",MFG="Microchip",Package="DIP40",Platform="GQ-4X (>Re1.30)";
Name="PIC18F458*DIP40",ID="XXXX",Class="PIC18FXX2_XX8",Category="MCU",MFG="Microchip",Package="DIP40",Platform="GQ-4X (>Re1.30)";
Name="PIC18F13K50*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",WVCC="3.6V",MFG="Microchip",Package="DIP20",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)",Message="Connect VUSB pin to VDD pin on chip";
Name="PIC18F14K50*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",WVCC="3.6V",MFG="Microchip",Package="DIP20",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)",Message="Connect VUSB pin to VDD pin on chip";
Name="PIC18F1220*DIP18",ID="XXXX",Class="PIC18FX220_X320",Category="MCU",WVCC="5V",MFG="Microchip",Package="DIP18",Platform="GQ-4X (>Re1.30)";
Name="PIC18F1320*DIP18",ID="XXXX",Class="PIC18FX220_X320",Category="MCU",WVCC="5V",MFG="Microchip",Package="DIP18",Platform="GQ-4X (>Re1.30)";
Name="PIC18F1220*ICSP",ID="XXXX",Class="PIC18FX220_X320",Category="MCU",WVCC="3.6V",MFG="Microchip",Package="DIP20",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F1320*ICSP",ID="XXXX",Class="PIC18FX220_X320",Category="MCU",WVCC="3.6V",MFG="Microchip",Package="DIP20",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F2220*DIP28",ID="XXXX",Class="PIC18FX220_X320",Category="MCU",MFG="Microchip",Package="DIP28",Platform="GQ-4X (>Re1.30)";
Name="PIC18F2320*DIP28",ID="XXXX",Class="PIC18FX220_X320",Category="MCU",MFG="Microchip",Package="DIP28",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4220*DIP40",ID="XXXX",Class="PIC18FX220_X320",Category="MCU",MFG="Microchip",Package="DIP40",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4320*DIP40",ID="XXXX",Class="PIC18FX220_X320",Category="MCU",MFG="Microchip",Package="DIP40",Platform="GQ-4X (>Re1.30)";
//PIC18F2XXX_4XXX ICSP
Name="PIC18F2221*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F2321*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F2410*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F2420*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F2423*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F2450*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F2455*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F2458*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F2480*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F2510*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F2515*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F2520*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F2523*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F2525*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F2550*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F2553*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F2580*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F2585*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F2610*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F2620*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F2680*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F2682*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F2685*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4221*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4321*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4410*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4420*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4423*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4450*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4455*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4458*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4480*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4510*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4515*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4520*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4523*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4525*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4550*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4553*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4580*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4585*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4610*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4620*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4680*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4682*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F4685*ICSP",ID="XXXX",Class="PIC18F2XXX_4XXX",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Adapter="ICSP/PIC adapter+",Platform="GQ-4X (>Re1.30)";
Name="PIC18F97J60*ISCP",ID="XXXX",Class="PIC18F66J60_97J60",VCC="3.6V",WVCC="3.6V",Category="MCU",MFG="Microchip",Package="DIP40",ChipMode="ICSP",Platform="GQ-4X (>Re1.30)",Adapter="ADP-056 ICSP Programming Only";
Name="ATTINY13 (Serial Mode)",ID="1E9007",Class="ATTINY2313",Category="MCU",MFG="Atmel",CodeSize="1024",EepromSize="64",Package="DIP8",FuseLabel="- - - SELFPRGEN DWEN BODLEVEL1 BODLEVEL0 RSTDISBL SPIEN EESAVE WDTON CKDIV8 SUT1 SUT0 CKSEL1 CKSEL0 -",Platform="GQ-4X",Message="Please config the fuse bit to internal Clock. Otherwise you need lower the speed.";
Name="ATTINY13*ISP",ID="1E9007",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="1024",EepromSize="64",Package="DIP8",ChipMode="AVRISP",FuseLabel="- - - SELFPRGEN DWEN BODLEVEL1 BODLEVEL0 RSTDISBL SPIEN EESAVE WDTON CKDIV8 SUT1 SUT0 CKSEL1 CKSEL0 -",Platform="GQ-4X",Adapter="AVRISP connection.",Message="Power on target device is required.";
Name="ATTINY13A (Serial Mode)",ID="1E9007",Class="ATTINY2313",Category="MCU",MFG="Atmel",CodeSize="1024",EepromSize="64",Package="DIP8",FuseLabel="- - - SELFPRGEN DWEN BODLEVEL1 BODLEVEL0 RSTDISBL SPIEN EESAVE WDTON CKDIV8 SUT1 SUT0 CKSEL1 CKSEL0 -",Platform="GQ-4X",Message="Please config the fuse bit to internal Clock. Otherwise you need lower the speed.";
Name="ATTINY13A*ISP",ID="1E9007",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="1024",EepromSize="64",Package="DIP8",ChipMode="AVRISP",FuseLabel="- - - SELFPRGEN DWEN BODLEVEL1 BODLEVEL0 RSTDISBL SPIEN EESAVE WDTON CKDIV8 SUT1 SUT0 CKSEL1 CKSEL0 -",Platform="GQ-4X",Adapter="AVRISP connection.",Message="Power on target device is required.";
Name="ATTINY13*SOIC8 (Serial Mode)",ID="1E9007",Class="ATTINY2313",Category="MCU",MFG="Atmel",CodeSize="1024",EepromSize="64",Package="DIP8",FuseLabel="- - - SELFPRGEN DWEN BODLEVEL1 BODLEVEL0 RSTDISBL SPIEN EESAVE WDTON CKDIV8 SUT1 SUT0 CKSEL1 CKSEL0 -",Platform="GQ-4X",Adapter="SOIC8-DIP8",Message="Please config the fuse bit to internal Clock. Otherwise you need lower the speed.";
Name="ATTINY13A*SOIC8 (Serial Mode)",ID="1E9007",Class="ATTINY2313",Category="MCU",MFG="Atmel",CodeSize="1024",EepromSize="64",Package="DIP8",FuseLabel="- - - SELFPRGEN DWEN BODLEVEL1 BODLEVEL0 RSTDISBL SPIEN EESAVE WDTON CKDIV8 SUT1 SUT0 CKSEL1 CKSEL0 -",Platform="GQ-4X",Adapter="SOIC8-DIP8",Message="Please config the fuse bit to internal Clock. Otherwise you need lower the speed.";
Name="AT90S1200 (Serial Mode)",ID="1E9001",Class="AT90S1200",Category="MCU",MFG="Atmel",CodeSize="1024",EepromSize="64",Speed="4",Message="Please use speed +1 or lower.";
Name="AT90S2313 (Serial Mode)",ID="1E9101",Class="AT90S2313",Category="MCU",MFG="Atmel",CodeSize="2048",EepromSize="128",Speed="4",Message="Please use speed +1 or lower.";
Name="ATTINY2313 (Serial Mode)",ID="1E910A",Class="ATTINY2313",Category="MCU",MFG="Atmel",CodeSize="2048",EepromSize="128",Message="Please config the fuse bit to internal Clock. Otherwise you need lower the speed.";
Name="ATTINY2313V (Serial Mode)",ID="1E910A",Class="ATTINY2313",Category="MCU",MFG="Atmel",CodeSize="2048",EepromSize="128",Message="Please config the fuse bit to internal Clock. Otherwise you need lower the speed.";
Name="ATTINY2313*ISP",ID="1E910A",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="2048",EepromSize="128",ChipMode="AVRISP",FuseLabel="DWEN EESAVE SPIEN WDTON BODLEVEL2 BODLEVEL1 BODLEVEL0 RSTDISBL CKDIV8 CKOUT SUT1 SUT0 CKSEL3 CKSEL2 CKSEL1 CKSEL0 - - - - - - - SELFPRGEN -",Adapter="AVRISP connection.",Message="Power on target device is required.";
Name="ATTINY2313V*ISP",ID="1E910A",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="2048",EepromSize="128",ChipMode="AVRISP",FuseLabel="DWEN EESAVE SPIEN WDTON BODLEVEL2 BODLEVEL1 BODLEVEL0 RSTDISBL CKDIV8 CKOUT SUT1 SUT0 CKSEL3 CKSEL2 CKSEL1 CKSEL0 - - - - - - - SELFPRGEN -",Adapter="AVRISP connection.",Message="Power on target device is required.";
Name="ATmega48*ISP",ID="1E9205",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="4096",EepromSize="256",ChipMode="AVRISP",FuseLabel="RSTDISBL DWEN SPIEN WDTON EESAVE BODLEVEL2 BODLEVEL1 BODLEVEL0 CKDIV8 CKOUT SUT1 SUT0 CKSEL3 CKSEL2 CKSEL1 CKSEL0 - - - - - - - SELFPRGEN -",Adapter="AVRISP connection.",Message="Power on target device is required.";
Name="ATmega48V*ISP",ID="1E9205",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="4096",EepromSize="256",ChipMode="AVRISP",FuseLabel="RSTDISBL DWEN SPIEN WDTON EESAVE BODLEVEL2 BODLEVEL1 BODLEVEL0 CKDIV8 CKOUT SUT1 SUT0 CKSEL3 CKSEL2 CKSEL1 CKSEL0 - - - - - - - SELFPRGEN -",Adapter="AVRISP connection.",Message="Power on target device is required.";
Name="ATmega88*ISP",ID="1E930A",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="8192",EepromSize="512",ChipMode="AVRISP",FuseLabel="RSTDISBL DWEN SPIEN WDTON EESAVE BODLEVEL2 BODLEVEL1 BODLEVEL0 CKDIV8 CKOUT SUT1 SUT0 CKSEL3 CKSEL2 CKSEL1 CKSEL0 - - - - - BOOTSZ1 BOOTSZ0 BOOTRST -",Adapter="AVRISP connection.",Message="Power on target device is required.";
Name="ATmega88V*ISP",ID="1E930A",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="8192",EepromSize="512",ChipMode="AVRISP",FuseLabel="RSTDISBL DWEN SPIEN WDTON EESAVE BODLEVEL2 BODLEVEL1 BODLEVEL0 CKDIV8 CKOUT SUT1 SUT0 CKSEL3 CKSEL2 CKSEL1 CKSEL0 - - - - - BOOTSZ1 BOOTSZ0 BOOTRST -",Adapter="AVRISP connection.",Message="Power on target device is required.";
Name="ATmega88PA*ISP",ID="1E930F",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="8192",EepromSize="512",ChipMode="AVRISP",FuseLabel="RSTDISBL DWEN SPIEN WDTON EESAVE BODLEVEL2 BODLEVEL1 BODLEVEL0 CKDIV8 CKOUT SUT1 SUT0 CKSEL3 CKSEL2 CKSEL1 CKSEL0 - - - - - BOOTSZ1 BOOTSZ0 BOOTRST -",Adapter="AVRISP connection.",Message="Power on target device is required.";
Name="ATmega168*ISP",ID="1E9406",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="16384",EepromSize="512",ChipMode="AVRISP",FuseLabel="RSTDISBL DWEN SPIEN WDTON EESAVE BODLEVEL2 BODLEVEL1 BODLEVEL0 CKDIV8 CKOUT SUT1 SUT0 CKSEL3 CKSEL2 CKSEL1 CKSEL0 - - - - - BOOTSZ1 BOOTSZ0 BOOTRST -",Adapter="AVRISP connection.",Message="Power on target device is required.";
Name="ATmega168V*ISP",ID="1E9406",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="16384",EepromSize="512",ChipMode="AVRISP",FuseLabel="RSTDISBL DWEN SPIEN WDTON EESAVE BODLEVEL2 BODLEVEL1 BODLEVEL0 CKDIV8 CKOUT SUT1 SUT0 CKSEL3 CKSEL2 CKSEL1 CKSEL0 - - - - - BOOTSZ1 BOOTSZ0 BOOTRST -",Adapter="AVRISP connection.",Message="Power on target device is required.";
Name="ATmega328*ISP",ID="1E950F",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="32768",EepromSize="1024",ChipMode="AVRISP",FuseLabel="RSTDISBL DWEN SPIEN WDTON EESAVE BOOTSZ1 BOOTSZ0 BOOTRST CKDIV8 CKOUT SUT1 SUT0 CKSEL3 CKSEL2 CKSEL1 CKSEL0 - - - - - BODLEVEL2 BODLEVEL1 BODLEVEL0 -",Adapter="AVRISP connection.",Message="Power on target device is required.";
Name="ATmega8*ISP",ID="1E9307",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="8192",EepromSize="512",ChipMode="AVRISP",FuseLabel="RSTDISBL WDTON SPIEN CKOPT EESAVE BOOTSZ1 BOOTSZ0 BOOTRST BODLEVEL BODEN SUT1 SUT0 CKSEL3 CKSEL2 CKSEL1 CKSEL0 - - - - - - - -",Adapter="AVRISP connection.",Message="Power on target device is required.";
Name="ATmega8L*ISP",ID="1E9307",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="8192",EepromSize="512",ChipMode="AVRISP",FuseLabel="RSTDISBL WDTON SPIEN CKOPT EESAVE BOOTSZ1 BOOTSZ0 BOOTRST BODLEVEL BODEN SUT1 SUT0 CKSEL3 CKSEL2 CKSEL1 CKSEL0 - - - - - - - -",Adapter="AVRISP connection.",Message="Power on target device is required.";
Name="ATmega16*ISP",ID="1E9403",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="16384",EepromSize="512",ChipMode="AVRISP",FuseLabel="OCDEN JTAGEN SPIEN CKOPT EESAVE BOOTSZ1 BOOTSZ0 BOOTRST BODLEVEL BODEN SUT1 SUT0 CKSEL3 CKSEL2 CKSEL1 CKSEL0 - - - - - - - -",Adapter="AVRISP connection.",Message="Power on target device is required.";
Name="ATmega164P*ISP",ID="1E940A",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="16384",EepromSize="512",ChipMode="AVRISP",FuseLabel="OCDEN JTAGEN SPIEN WDTON EESAVE BOOTSZ1 BOOTSZ0 BOOTRST CKDIV8 CKOUT SUT1 SUT0 CKSEL3 CKSEL2 CKSEL1 CKSEL0 - - - - - - - -",Adapter="AVRISP connection.",Message="Power on target device is required.";
Name="ATmega16L*ISP",ID="1E9403",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="16384",EepromSize="512",ChipMode="AVRISP",FuseLabel="OCDEN JTAGEN SPIEN CKOPT EESAVE BOOTSZ1 BOOTSZ0 BOOTRST BODLEVEL BODEN SUT1 SUT0 CKSEL3 CKSEL2 CKSEL1 CKSEL0 - - - - - - - -",Adapter="AVRISP connection.",Message="Power on target device is required.";
Name="ATmega32A*ISP",ID="1E9502",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="32768",EepromSize="1024",ChipMode="AVRISP",FuseLabel="OCDEN JTAGEN SPIEN CKOPT EESAVE BOOTSZ1 BOOTSZ0 BOOTRST BODLEVEL BODEN SUT1 SUT0 CKSEL3 CKSEL2 CKSEL1 CKSEL0 - - - - - - - - -",Adapter="AVRISP connection.",Message="Power on target device is required.";
Name="ATmega32*ISP",ID="1E9502",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="32768",EepromSize="1024",ChipMode="AVRISP",FuseLabel="OCDEN JTAGEN SPIEN CKOPT EESAVE BOOTSZ1 BOOTSZ0 BOOTRST BODLEVEL BODEN SUT1 SUT0 CKSEL3 CKSEL2 CKSEL1 CKSEL0 - - - - - - - - -",Adapter="AVRISP connection.",Message="Power on target device is required.";
Name="ATmega32L*ISP",ID="1E9502",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="32768",EepromSize="1024",ChipMode="AVRISP",FuseLabel="OCDEN JTAGEN SPIEN CKOPT EESAVE BOOTSZ1 BOOTSZ0 BOOTRST BODLEVEL BODEN SUT1 SUT0 CKSEL3 CKSEL2 CKSEL1 CKSEL0 - - - - - - - - -",Adapter="AVRISP connection.",Message="Power on target device is required.";
Name="ATmega324PA*ISP",ID="1E9511",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="32768",EepromSize="1024",ChipMode="AVRISP",FuseLabel="OCDEN JTAGEN SPIEN WDTON EESAVE BOOTSZ1 BOOTSZ0 BOOTRST CKDIV8 CKOUT SUT1 SUT0 CKSEL3 CKSEL2 CKSEL1 CKSEL0 - - - - - BODLEVEL2 BODLEVEL1 BODLEVEL0 -",Adapter="AVRISP connection.",Message="Power on target device is required.";
Name="ATmega324P*ISP",ID="1E9508",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="32768",EepromSize="1024",ChipMode="AVRISP",FuseLabel="OCDEN JTAGEN SPIEN WDTON EESAVE BOOTSZ1 BOOTSZ0 BOOTRST CKDIV8 CKOUT SUT1 SUT0 CKSEL3 CKSEL2 CKSEL1 CKSEL0 - - - - - BODLEVEL2 BODLEVEL1 BODLEVEL0 -",Adapter="AVRISP connection.",Message="Power on target device is required.";
Name="ATmega64*ISP",ID="1E9602",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="65536",EepromSize="2048",ChipMode="AVRISP",FuseLabel="OCDEN JTAGEN SPIEN CKOPT EESAVE BOOTSZ1 BOOTSZ0 BOOTRST BODLEVEL BODEN SUT1 SUT0 CKSEL3 CKSEL2 CKSEL1 CKSEL0 - - - - - - M103C WDTON",Adapter="AVRISP connection.",Message="Power on target device is required.";
Name="ATmega644*ISP",ID="1E960A",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="65536",EepromSize="2048",ChipMode="AVRISP",FuseLabel="OCDEN JTAGEN SPIEN WDTON EESAVE BOOTSZ1 BOOTSZ0 BOOTRST CKDIV8 CKOUT SUT1 SUT0 CKSEL3 CKSEL2 CKSEL1 CKSEL0 - - - - - BODLEVEL2 BODLEVEL1 BODLEVEL0 -",Adapter="AVRISP connection.",Message="Power on target device is required.";
Name="ATmega64L*ISP",ID="1E9602",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="65536",EepromSize="2048",ChipMode="AVRISP",FuseLabel="OCDEN JTAGEN SPIEN CKOPT EESAVE BOOTSZ1 BOOTSZ0 BOOTRST BODLEVEL BODEN SUT1 SUT0 CKSEL3 CKSEL2 CKSEL1 CKSEL0 - - - - - - M103C WDTON",Adapter="AVRISP connection.",Message="Power on target device is required.";
Name="ATmega128*ISP",ID="1E9702",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="131072",EepromSize="4096",ChipMode="AVRISP",FuseLabel="OCDEN JTAGEN SPIEN CKOPT EESAVE BOOTSZ1 BOOTSZ0 BOOTRST BODLEVEL BODEN SUT1 SUT0 CKSEL3 CKSEL2 CKSEL1 CKSEL0 - - - - - - M103C WDTON",Adapter="AVRISP connection.",Message="Power on target device is required.";
Name="ATmega128L*ISP",ID="1E9702",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="131072",EepromSize="4096",ChipMode="AVRISP",FuseLabel="OCDEN JTAGEN SPIEN CKOPT EESAVE BOOTSZ1 BOOTSZ0 BOOTRST BODLEVEL BODEN SUT1 SUT0 CKSEL3 CKSEL2 CKSEL1 CKSEL0 - - - - - - M103C WDTON",Adapter="AVRISP connection.",Message="Power on target device is required.";
Name="ATmega8515*ISP",ID="1E9306",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="8192",EepromSize="512",ChipMode="AVRISP",FuseLabel="S8515C WDTON SPIEN CKOPT EESAVE BOOTSZ1 BOOTSZ0 BOOTRST BODLEVEL BODEN SUT1 SUT0 CKSEL3 CKSEL2 CKSEL1 CKSEL0 - - - - - - - -",Adapter="AVRISP connection.",Message="Power on target device is required.";
Name="ATmega8515L*ISP",ID="1E9306",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="8192",EepromSize="512",ChipMode="AVRISP",FuseLabel="S8515C WDTON SPIEN CKOPT EESAVE BOOTSZ1 BOOTSZ0 BOOTRST BODLEVEL BODEN SUT1 SUT0 CKSEL3 CKSEL2 CKSEL1 CKSEL0 - - - - - - - -",Adapter="AVRISP connection.",Message="Power on target device is required.";
Name="ATmega8535*ISP",ID="1E9308",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="8192",EepromSize="512",ChipMode="AVRISP",FuseLabel="S8535C WDTON SPIEN CKOPT EESAVE BOOTSZ1 BOOTSZ0 BOOTRST BODLEVEL BODEN SUT1 SUT0 CKSEL3 CKSEL2 CKSEL1 CKSEL0 - - - - - - - -",Adapter="AVRISP connection.",Message="Power on target device is required.";
Name="ATmega8535L*ISP",ID="1E9308",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="8192",EepromSize="512",ChipMode="AVRISP",FuseLabel="S8535C WDTON SPIEN CKOPT EESAVE BOOTSZ1 BOOTSZ0 BOOTRST BODLEVEL BODEN SUT1 SUT0 CKSEL3 CKSEL2 CKSEL1 CKSEL0 - - - - - - - -",Adapter="AVRISP connection.",Message="Power on target device is required.";
;Name="AT90S1200*ISP",ID="1E9001",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="1024",EepromSize="64",ChipMode="AVRISP",Adapter="AVRISP connection.";
Name="ATmega8U2*ISP",ID="1E9389",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="8192",EepromSize="256",ChipMode="AVRISP",FuseLabel="DWEN RSTDSBL SPIEN WDTON EESAVE BOOTSZ1 BOOTSZ0 BOOTRST CKDIV8 CKOUT SUT1 SUT0 CKSEL3 CKSEL2 CKSEL1 CKSEL0 - - - - HWBE BODLEVEL2 BODLEVEL1 BODLEVEL0 -",Adapter="AVRISP connection.",Message="Power on target device is required.";
Name="ATmega16U2*ISP",ID="1E9489",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="16384",EepromSize="512",ChipMode="AVRISP",FuseLabel="DWEN RSTDSBL SPIEN WDTON EESAVE BOOTSZ1 BOOTSZ0 BOOTRST CKDIV8 CKOUT SUT1 SUT0 CKSEL3 CKSEL2 CKSEL1 CKSEL0 - - - - HWBE BODLEVEL2 BODLEVEL1 BODLEVEL0 -",Adapter="AVRISP connection.",Message="Power on target device is required.";
Name="ATmega32U2*ISP",ID="1E958A",Class="AVRISP",Category="MCU",MFG="Atmel",CodeSize="32768",EepromSize="1024",ChipMode="AVRISP",FuseLabel="DWEN RSTDSBL SPIEN WDTON EESAVE BOOTSZ1 BOOTSZ0 BOOTRST CKDIV8 CKOUT SUT1 SUT0 CKSEL3 CKSEL2 CKSEL1 CKSEL0 - - - - HWBE BODLEVEL2 BODLEVEL1 BODLEVEL0 -",Adapter="AVRISP connection.",Message="Power on target device is required.";
;* Serial EEPROM *
Name="AT24LC00",ID="XXXX",Class="24C00",Category="SERIAL_EPROM",MFG="Atmel";
Name="AT24LC01",ID="XXXX",Class="24C01",Category="SERIAL_EPROM",MFG="Atmel";
Name="AT24C02",ID="XXXX",Class="24C02",Category="SERIAL_EPROM",MFG="Atmel";
Name="AT24C02A",ID="XXXX",Class="24C02",Category="SERIAL_EPROM",MFG="Atmel";
Name="AT24C04",ID="XXXX",Class="24C04",Category="SERIAL_EPROM",MFG="Atmel";
Name="AT24C08",ID="XXXX",Class="24C08",Category="SERIAL_EPROM",MFG="Atmel";
Name="AT24C16",ID="XXXX",Class="24C16",Category="SERIAL_EPROM",MFG="Atmel";
Name="AT24C32",ID="XXXX",Class="24C32",Category="SERIAL_EPROM",MFG="Atmel";
Name="AT24C64",ID="XXXX",Class="24C64",Category="SERIAL_EPROM",MFG="Atmel";
Name="AT24C1024",ID="XXXX",Class="24C1024",Category="SERIAL_EPROM",MFG="Atmel";
Name="AT24C1024 SOIC8",ID="XXXX",Class="24C1024",Category="SERIAL_EPROM",MFG="Atmel",Adapter="ADP-027";
Name="AT24C164",ID="XXXX",Class="24C16",Category="SERIAL_EPROM",MFG="Atmel";
Name="AT24C256B",ID="XXXX",Class="24C256",Category="SERIAL_EPROM",MFG="Atmel",VCC="3.6V";
Name="AT24C256B*SOIC8",ID="XXXX",Class="24C256",Category="SERIAL_EPROM",MFG="Atmel",VCC="3.6V",Adapter="ADP-081";
Name="AT25010",ID="XXXX",Class="25C010",Category="SERIAL_EPROM",MFG="Atmel";
Name="AT25020",ID="XXXX",Class="25C020",Category="SERIAL_EPROM",MFG="Atmel";
Name="AT25040",ID="XXXX",Class="25C040",Category="SERIAL_EPROM",MFG="Atmel";
Name="AT25080",ID="XXXX",Class="25C080",Category="SERIAL_EPROM",MFG="Atmel";
Name="AT25160",ID="XXXX",Class="25C160",Category="SERIAL_EPROM",MFG="Atmel";
Name="AT25320",ID="XXXX",Class="25C320",Category="SERIAL_EPROM",MFG="Atmel";
Name="AT25010A",ID="XXXX",Class="25C010",Category="SERIAL_EPROM",MFG="Atmel";
Name="AT25020A",ID="XXXX",Class="25C020",Category="SERIAL_EPROM",MFG="Atmel",Vcc="3.6V";
Name="AT25040A",ID="XXXX",Class="25C040",Category="SERIAL_EPROM",MFG="Atmel",Vcc="3.6V";
Name="AT25080A",ID="XXXX",Class="25C080",Category="SERIAL_EPROM",MFG="Atmel",Vcc="3.6V";
Name="AT25160A",ID="XXXX",Class="25C160",Category="SERIAL_EPROM",MFG="Atmel",Vcc="3.6V";
Name="AT25320A",ID="XXXX",Class="25C320",Category="SERIAL_EPROM",MFG="Atmel",Vcc="3.6V";
Name="AT25640",ID="XXXX",Class="25C640",Category="SERIAL_EPROM",MFG="Atmel",Vcc="3.6V";
Name="AT25640A",ID="XXXX",Class="25C640",Category="SERIAL_EPROM",MFG="Atmel",Vcc="3.6V";
Name="AT25HP256",ID="XXXX",Class="AT25HP256",Category="SERIAL_EPROM",MFG="Atmel";
Name="AT25HP512",ID="XXXX",Class="AT25HP512",Category="SERIAL_EPROM",MFG="Atmel";
Name="AT25128",ID="XXXX",Class="AT25128",Category="SERIAL_EPROM",MFG="Atmel";
Name="AT25256",ID="XXXX",Class="AT25256",Category="SERIAL_EPROM",MFG="Atmel";
Name="AT25128A",ID="XXXX",Class="AT25128",Category="SERIAL_EPROM",MFG="Atmel";
Name="AT25256A",ID="XXXX",Class="AT25256",Category="SERIAL_EPROM",MFG="Atmel";
Name="AT25F512",ID="1F65",Class="AT25F512",Category="SERIAL_EPROM",MFG="Atmel",Vcc="3.6V";
Name="AT25F1024",ID="1F60",Class="AT25F1024",Category="SERIAL_EPROM",MFG="Atmel",Vcc="3.6V";
Name="AT25F2048",ID="1F63",Class="AT25F2048",Category="SERIAL_EPROM",MFG="Atmel",Vcc="3.6V";
Name="AT25F4096",ID="1F64",Class="AT25F4096",Category="SERIAL_EPROM",MFG="Atmel",Vcc="3.6V",CodeSize="524288";
Name="AT25FS010",ID="1F6601",Class="AT25FS010",Category="SERIAL_EPROM",MFG="Atmel",Vcc="3.6V";
Name="AT25FS040",ID="1F6604",Class="AT25FS010",Category="SERIAL_EPROM",MFG="Atmel",Vcc="3.6V",CodeSize="524288";
Name="AT25DF041A",ID="1F4401",Class="AT25DF041A",CodeSize="524288",VCC="3.6V",Category="SERIAL_EPROM",Adapter="ADP-004 SOIC8-DIP adapter",MFG="Atmel";
Name="AT25DF081A",ID="1F4500",Class="AT25DF041A",CodeSize="1048576",VCC="3.6V",Category="SERIAL_EPROM",Adapter="ADP-081, ADP-027 SOIC20",MFG="Atmel",Platform="GQ-4X";
Name="AT25DF161A",ID="1F4600",Class="AT25DF041A",CodeSize="2097152",VCC="3.6V",Category="SERIAL_EPROM",Adapter="ADP-081, ADP-027 SOIC20",MFG="Atmel",Platform="GQ-4X";
Name="AT25DF321A",ID="1F4700",Class="AT25DF041A",CodeSize="4194304",VCC="3.6V",Category="SERIAL_EPROM",Adapter="ADP-081, ADP-027 SOIC20",MFG="Atmel",Platform="GQ-4X";
Name="AT26DF041A",ID="1F4400",Class="AT25DF041A",CodeSize="524288",VCC="3.6V",Category="SERIAL_EPROM",Adapter="SOIC8-DIP adapter",MFG="Atmel",Platform="GQ-4X";
Name="AT26DF081A (SlowMode)",ID="1F4501",Class="AT25DF041A",CodeSize="1048576",VCC="3.6V",Category="SERIAL_EPROM",Adapter="ADP-081, ADP-027 SOIC20",MFG="Atmel";
Name="AT26DF081A",ID="1F4501",Class="AT25DF041A",CodeSize="1048576",VCC="3.6V",Category="SERIAL_EPROM",Adapter="ADP-081, ADP-027 SOIC20",MFG="Atmel",Platform="GQ-4X";
Name="AT26DF161A",ID="1F4601",Class="AT25DF041A",CodeSize="2097152",VCC="3.6V",Category="SERIAL_EPROM",Adapter="ADP-081, ADP-027 SOIC20",MFG="Atmel",Platform="GQ-4X";
Name="AT26DF321A",ID="1F4701",Class="AT25DF041A",CodeSize="4194304",VCC="3.6V",Category="SERIAL_EPROM",Adapter="ADP-081, ADP-027 SOIC20",MFG="Atmel",Platform="GQ-4X";
Name="AT25DF161A-SH",ID="1F4600",Class="AT25DF041A",CodeSize="2097152",VCC="3.6V",Category="SERIAL_EPROM",Adapter="ADP-081, ADP-027 SOIC20",MFG="Atmel",Platform="GQ-4X";
Name="ATMLH624",ID="XXXX",Class="24C02",Category="SERIAL_EPROM",MFG="Atmel";
Name="ATMLH942",ID="XXXX",Class="ATMLH942",Category="SERIAL_EPROM",MFG="Atmel";
Name="ATMLU824-04B",ID="XXXX",Class="24C04",Category="SERIAL_EPROM",MFG="Atmel";
Name="ATMLH822-04B",ID="XXXX",Class="24C04",Category="SERIAL_EPROM",MFG="Atmel",Adapter="ADP-004 SOIC8-DIP adapter";
Name="ATMLH828-08B",ID="XXXX",Class="24C08",Category="SERIAL_EPROM",MFG="Atmel",Adapter="ADP-004 SOIC8-DIP adapter";
Name="H830-08B1",ID="XXXX",Class="24C08",Category="SERIAL_EPROM",MFG="Atmel",Adapter="TSSOP8-DIP adapter";
Name="ATMLU828",ID="XXXX",Class="24C256",Category="SERIAL_EPROM",MFG="Atmel";
Name="ATMLH830-2EB",ID="XXXX",Class="24C256",Category="SERIAL_EPROM",MFG="Atmel",Adapter="ADP-004 SOIC8-DIP adapter";
Name="ATMLH818-2EB",ID="XXXX",Class="24C256",Category="SERIAL_EPROM",MFG="Atmel",Adapter="ADP-081 SOIC8-DIP adapter";
Name="ATMLH840-2GB",ID="XXXX",Class="24C1024",Category="SERIAL_EPROM",MFG="Atmel",Adapter="ADP-004 SOIC8-DIP adapter";
Name="ATMLH844-2GB",ID="XXXX",Class="24C1024",Category="SERIAL_EPROM",MFG="Atmel",Adapter="ADP-004 SOIC8-DIP adapter";
Name="ATMLU746-2GB",ID="XXXX",Class="24C1024",Category="SERIAL_EPROM",MFG="Atmel";
Name="ATMLU836-2GB",ID="XXXX",Class="24C1024",Category="SERIAL_EPROM",MFG="Atmel";
Name="ATMLH818-2GB",ID="XXXX",Class="24C1024",Category="SERIAL_EPROM",MFG="Atmel",Adapter="ADP-081 SOIC8-DIP adapter";
Name="H812-2GB",ID="XXXX",Class="24C1024",Category="SERIAL_EPROM",MFG="Atmel",Adapter="TSSOP8-DIP adapter";
Name="H814-2GB",ID="XXXX",Class="24C1024",Category="SERIAL_EPROM",MFG="Atmel",Adapter="TSSOP8-DIP adapter";
Name="AT25F1024*SOIC8",ID="1F60",Class="AT25F1024",Category="SERIAL_EPROM",MFG="Atmel",Vcc="3.6V",Adapter="SOIC8-DIP adapter";
Name="AT34C02",ID="XXXX",Class="24C02",Category="SERIAL_EPROM",MFG="Atmel";
Name="ATMEL24RF08",ID="XXXX",Class="AT24RF08",Category="SERIAL_EPROM",MFG="Atmel",VCC="5V",Message="Check protection bit if set before read the chip in Data section."
Name="M35080",ID="XXXX",Class="25C080",Category="SERIAL_EPROM",MFG="ST",Adapter="ADP-088",Message="Pin connection see: http://www.mcumall.com/support/scriptDP-088_Connection.html";
Name="M95010",ID="XXXX",Class="25C010",Category="SERIAL_EPROM",MFG="ST";
Name="M95020",ID="XXXX",Class="25C020",Category="SERIAL_EPROM",MFG="ST";
Name="M95040",ID="XXXX",Class="25C040",Category="SERIAL_EPROM",MFG="ST";
Name="M95080",ID="XXXX",Class="25C080",Category="SERIAL_EPROM",MFG="ST";
Name="M95160",ID="XXXX",Class="25C160",Category="SERIAL_EPROM",MFG="ST";
Name="M95320",ID="XXXX",Class="25C320",Category="SERIAL_EPROM",MFG="ST";
Name="M95640",ID="XXXX",Class="25C640",Category="SERIAL_EPROM",MFG="ST";
Name="M95128",ID="XXXX",Class="AT25128",Category="SERIAL_EPROM",MFG="ST";
;Name="M95256",ID="XXXX",Class="AT25256",Category="SERIAL_EPROM",MFG="ST";
Name="M95010W",ID="XXXX",Class="25C010",Category="SERIAL_EPROM",MFG="ST",VCC="3.6V";
Name="M95020W",ID="XXXX",Class="25C020",Category="SERIAL_EPROM",MFG="ST",VCC="3.6V";
Name="M95040W",ID="XXXX",Class="25C040",Category="SERIAL_EPROM",MFG="ST",VCC="3.6V";
Name="M95080W",ID="XXXX",Class="25C080",Category="SERIAL_EPROM",MFG="ST",VCC="3.6V";
Name="M95160W",ID="XXXX",Class="25C160",Category="SERIAL_EPROM",MFG="ST",VCC="3.6V";
Name="M95320W",ID="XXXX",Class="25C320",Category="SERIAL_EPROM",MFG="ST",VCC="3.6V";
Name="M95640W",ID="XXXX",Class="25C640",Category="SERIAL_EPROM",MFG="ST",VCC="3.6V";
Name="M95128W",ID="XXXX",Class="AT25128",Category="SERIAL_EPROM",MFG="ST",VCC="3.6V";
Name="M95010R",ID="XXXX",Class="25C010",Category="SERIAL_EPROM",MFG="ST",VCC="3.6V";
Name="M95020R",ID="XXXX",Class="25C020",Category="SERIAL_EPROM",MFG="ST",VCC="3.6V";
Name="M95040R",ID="XXXX",Class="25C040",Category="SERIAL_EPROM",MFG="ST",VCC="3.6V";
Name="M95080R",ID="XXXX",Class="25C080",Category="SERIAL_EPROM",MFG="ST",VCC="3.6V";
Name="M95160R",ID="XXXX",Class="25C160",Category="SERIAL_EPROM",MFG="ST",VCC="3.6V";
Name="M95320R",ID="XXXX",Class="25C320",Category="SERIAL_EPROM",MFG="ST",VCC="3.6V";
Name="M95640R",ID="XXXX",Class="25C640",Category="SERIAL_EPROM",MFG="ST",VCC="3.6V";
Name="M95128R",ID="XXXX",Class="AT25128",Category="SERIAL_EPROM",MFG="ST",VCC="3.6V";
Name="5P08C3",ID="XXXX",Class="ST95P08",Category="SERIAL_EPROM",MFG="ST";
Name="M95P08",ID="XXXX",Class="ST95P08",Category="SERIAL_EPROM",MFG="ST";
Name="ST95P08",ID="XXXX",Class="ST95P08",Category="SERIAL_EPROM",MFG="ST";
Name="95P08",ID="XXXX",Class="ST95P08",Category="SERIAL_EPROM",MFG="ST";
Name="RA66",ID="XXXX",Class="93C66A_8Bit",Category="SERIAL_EPROM",MFG="ST";
Name="M24C08",ID="XXXX",Class="24C08",Category="SERIAL_EPROM",MFG="ST";
Name="M25C08",ID="XXXX",Class="24C08",Category="SERIAL_EPROM",MFG="ST";
Name="M24C16",ID="XXXX",Class="24C16",Category="SERIAL_EPROM",MFG="ST";
Name="M25C16",ID="XXXX",Class="24C16",Category="SERIAL_EPROM",MFG="ST";
Name="BR24L01A",ID="XXXX",Class="24C01",Category="SERIAL_EPROM",MFG="ROHM";
Name="BR24L02",ID="XXXX",Class="24C02",Category="SERIAL_EPROM",MFG="ROHM";
Name="BR24L08",ID="XXXX",Class="24C08",Category="SERIAL_EPROM",MFG="ROHM",VCC="3.6V";
Name="BR24L16",ID="XXXX",Class="24C16",Category="SERIAL_EPROM",MFG="ROHM",VCC="3.6V";
Name="BR24L32",ID="XXXX",Class="24C32",Category="SERIAL_EPROM",MFG="ROHM",VCC="3.6V";
Name="BR24L64",ID="XXXX",Class="24C64",Category="SERIAL_EPROM",MFG="ROHM",VCC="3.6V";
Name="BR24L128",ID="XXXX",Class="24C128",Category="SERIAL_EPROM",MFG="ROHM",VCC="3.6V";
Name="BR95010",ID="XXXX",Class="25C010",Category="SERIAL_EPROM",MFG="ROHM";
Name="BR95020",ID="XXXX",Class="25C020",Category="SERIAL_EPROM",MFG="ROHM";
Name="BR95040",ID="XXXX",Class="25C040",Category="SERIAL_EPROM",MFG="ROHM";
Name="BR95080",ID="XXXX",Class="25C080",Category="SERIAL_EPROM",MFG="ROHM";
Name="BR95160",ID="XXXX",Class="25C160",Category="SERIAL_EPROM",MFG="ROHM";
Name="BR95320",ID="XXXX",Class="25C320",Category="SERIAL_EPROM",MFG="ROHM";
Name="L160",ID="XXXX",Class="25C160",Category="SERIAL_EPROM",MFG="ROHM";
Name="L320",ID="XXXX",Class="25C320",Category="SERIAL_EPROM",MFG="ROHM";
Name="BR9010",ID="XXXX",Class="BR9010",VCC="3.6V",Category="SERIAL_EPROM",MFG="ROHM",Platform="GQ-4X(>RE1.40)";;
Name="BR9020",ID="XXXX",Class="BR9010",CodeSize="256",VCC="3.6V",Category="SERIAL_EPROM",MFG="ROHM",Platform="GQ-4X(>RE1.40)";;
Name="BR9040",ID="XXXX",Class="BR9010",CodeSize="512",VCC="3.6V"Category="SERIAL_EPROM",MFG="ROHM",Platform="GQ-4X(>RE1.40)";;
Name="BR9010F",ID="XXXX",Class="BR9010",VCC="3.6V",Category="SERIAL_EPROM",MFG="ROHM",Adapter="ADP-088",Platform="GQ-4X(>RE1.40)",Message="Pin connection see: http://www.mcumall.com/support/scriptDP-088_Connection.html";;
Name="BR9020F",ID="XXXX",Class="BR9010",CodeSize="256",VCC="3.6V",Category="SERIAL_EPROM",MFG="ROHM",Adapter="ADP-088",Platform="GQ-4X(>RE1.40)",Message="Pin connection see: http://www.mcumall.com/support/scriptDP-088_Connection.html";
Name="BR9040F",ID="XXXX",Class="BR9010",CodeSize="512",VCC="3.6V"Category="SERIAL_EPROM",MFG="ROHM",Adapter="ADP-088",Platform="GQ-4X(>RE1.40)",Message="Pin connection see: http://www.mcumall.com/support/scriptDP-088_Connection.html";
;Name="AT59C11(8Bit)",ID="XXXX",Class="16951_8BIT",Category="SERIAL_EPROM",MFG="ATMEL",Speed="4";
Name="AT59C11(16Bit)",ID="XXXX",Class="16951_16BIT",Category="SERIAL_EPROM",MFG="ATMEL";
;Name="MSM16951(8Bit)",ID="XXXX",Class="16951_8BIT",Category="SERIAL_EPROM",MFG="OKI",Speed="4";
;Name="MSM16951(16Bit)",ID="XXXX",Class="16951_16BIT",Category="SERIAL_EPROM",MFG="OKI";
Name="93LC46 (8Bit)",ID="XXXX",Class="93C46A_8Bit",Category="SERIAL_EPROM",MFG="Microchip",Speed="4";
Name="93LC46A (8Bit)",ID="XXXX",Class="93C46A_8Bit",Category="SERIAL_EPROM",MFG="Microchip",Speed="4";
Name="93C46B (16Bit)",ID="XXXX",Class="93C46B_16Bit",Category="SERIAL_EPROM",MFG="Microchip";
Name="93LC46B (16Bit)",ID="XXXX",Class="93C46B_16Bit",Category="SERIAL_EPROM",MFG="Microchip";
Name="93LC56A (8Bit)",ID="XXXX",Class="93C56A_8Bit",Category="SERIAL_EPROM",MFG="Microchip";
Name="93LC56B (16Bit)",ID="XXXX",Class="93C56B_16Bit",Category="SERIAL_EPROM",MFG="Microchip",Speed="3";
Name="93C56B (16Bit)",ID="XXXX",Class="93C56B_16Bit",Category="SERIAL_EPROM",MFG="Microchip",Speed="4";
Name="93C56C (8Bit)",ID="XXXX",Class="93C56A_8Bit",Category="SERIAL_EPROM",MFG="Microchip";
Name="93LC56C (8Bit)",ID="XXXX",Class="93C56A_8Bit",Category="SERIAL_EPROM",MFG="Microchip";
Name="93LC66 (8Bit)",ID="XXXX",Class="93C66A_8Bit",Category="SERIAL_EPROM",MFG="Microchip";
Name="93LC66A (8Bit)",ID="XXXX",Class="93C66A_8Bit",Category="SERIAL_EPROM",MFG="Microchip";
Name="93LC66B (16Bit)",ID="XXXX",Class="93C66B_16Bit",Category="SERIAL_EPROM",MFG="Microchip",Speed="3",VCC="3.6V";
Name="93C66B (16Bit)",ID="XXXX",Class="93C66B_16Bit",Category="SERIAL_EPROM",MFG="Microchip";
Name="93AA66 (8Bit)",ID="XXXX",Class="93C66A_8Bit",Category="SERIAL_EPROM",MFG="Microchip",Speed="3";
Name="93AA66C (8Bit)",ID="XXXX",Class="93C66A_8Bit",Category="SERIAL_EPROM",MFG="Microchip",Speed="3";
Name="93C76C (8Bit)",ID="XXXX",Class="93C76A_8Bit",Category="SERIAL_EPROM",MFG="Microchip";
Name="93C76C (16Bit)",ID="XXXX",Class="93C76B_16Bit",Category="SERIAL_EPROM",MFG="Microchip";
Name="93LC76C (8Bit)",ID="XXXX",Class="93C76A_8Bit",Category="SERIAL_EPROM",MFG="Microchip";
Name="93C86C (8Bit)",ID="XXXX",Class="93C86A_8Bit",Category="SERIAL_EPROM",MFG="Microchip";
Name="93C86C (16Bit)",ID="XXXX",Class="93C86B_16Bit",Category="SERIAL_EPROM",MFG="Microchip";
Name="93LC86C (8Bit)",ID="XXXX",Class="93C86A_8Bit",Category="SERIAL_EPROM",MFG="Microchip";
Name="93LC86C (16Bit)",ID="XXXX",Class="93C86B_16Bit",Category="SERIAL_EPROM",MFG="Microchip";
Name="24LC01B",ID="XXXX",Class="24C01",Category="SERIAL_EPROM",MFG="Microchip";
Name="24LC02B",ID="XXXX",Class="24C02",Category="SERIAL_EPROM",MFG="Microchip";
Name="24LC04B",ID="XXXX",Class="24C04",Category="SERIAL_EPROM",MFG="Microchip";
Name="24LC08B",ID="XXXX",Class="24C08",Category="SERIAL_EPROM",MFG="Microchip",VCC="3.6V";
Name="24LC16B",ID="XXXX",Class="24C16",Category="SERIAL_EPROM",MFG="Microchip",VCC="3.6V";
Name="24LC32A",ID="XXXX",Class="24C32",Category="SERIAL_EPROM",MFG="Microchip",VCC="3.6V";
Name="24LC64",ID="XXXX",Class="24C64",Category="SERIAL_EPROM",MFG="Microchip",VCC="3.6V";
Name="24LC128",ID="XXXX",Class="24C128",Category="SERIAL_EPROM",MFG="Microchip",VCC="3.6V";
Name="24LC256",ID="XXXX",Class="24C256",Category="SERIAL_EPROM",MFG="Microchip",VCC="3.6V";
Name="24LC512",ID="XXXX",Class="24C512",Category="SERIAL_EPROM",MFG="Microchip",VCC="3.6V";
Name="24LC1024",ID="XXXX",Class="24C1024",Category="SERIAL_EPROM",MFG="Microchip",VCC="3.6V";
Name="24LC1025",ID="XXXX",Class="24AA1025",Category="SERIAL_EPROM",MFG="Microchip",VCC="3.6V";
Name="24AA02(4H)",ID="XXXX",Class="24C01",Category="SERIAL_EPROM",MFG="Microchip",VCC="3.6V";
Name="24AA32A",ID="XXXX",Class="24C32",Category="SERIAL_EPROM",MFG="Microchip",VCC="3.6V";
Name="24AA64",ID="XXXX",Class="24C64",Category="SERIAL_EPROM",MFG="Microchip",VCC="3.6V";
Name="24AA128",ID="XXXX",Class="24C128",Category="SERIAL_EPROM",MFG="Microchip",VCC="3.6V";
Name="24AA256",ID="XXXX",Class="24C256",Category="SERIAL_EPROM",MFG="Microchip",VCC="3.6V";
Name="24AA512",ID="XXXX",Class="24C512",Category="SERIAL_EPROM",MFG="Microchip",VCC="3.6V";
Name="24AA1025",ID="XXXX",Class="24AA1025",Category="SERIAL_EPROM",MFG="Microchip",VCC="3.6V";
Name="24FC1025",ID="XXXX",Class="24AA1025",Category="SERIAL_EPROM",MFG="Microchip",VCC="3.6V";
Name="25C020",ID="XXXX",Class="25C020",Category="SERIAL_EPROM",MFG="Microchip";
Name="25LC020",ID="XXXX",Class="25C020",Category="SERIAL_EPROM",MFG="Microchip",Vcc="3.6V";
Name="25C040",ID="XXXX",Class="25C040",Category="SERIAL_EPROM",MFG="Microchip";
Name="25LC040",ID="XXXX",Class="25C040",Category="SERIAL_EPROM",MFG="Microchip",Vcc="3.6V";
Name="25C080",ID="XXXX",Class="25C080",Category="SERIAL_EPROM",MFG="Microchip";
Name="25LC080",ID="XXXX",Class="25C080",Category="SERIAL_EPROM",MFG="Microchip",Vcc="3.6V";
Name="25C160",ID="XXXX",Class="25C160",Category="SERIAL_EPROM",MFG="Microchip";
Name="25LC160",ID="XXXX",Class="25C160",Category="SERIAL_EPROM",MFG="Microchip",Vcc="3.6V";
Name="25C320",ID="XXXX",Class="25C320",Category="SERIAL_EPROM",MFG="Microchip";
Name="25AA320",ID="XXXX",Class="25C320",Category="SERIAL_EPROM",MFG="Microchip",Vcc="3.6V";
Name="25LC320",ID="XXXX",Class="25C320",Category="SERIAL_EPROM",MFG="Microchip",Vcc="3.6V";
Name="25C640",ID="XXXX",Class="25C640",Category="SERIAL_EPROM",MFG="Microchip";
Name="25LC640",ID="XXXX",Class="25C640",Category="SERIAL_EPROM",MFG="Microchip",Vcc="3.6V";
Name="25AA640",ID="XXXX",Class="25C640",Category="SERIAL_EPROM",MFG="Microchip",Vcc="3.6V";
Name="25C256",ID="XXXX",Class="AT25256",Category="SERIAL_EPROM",MFG="Microchip";
Name="25LC256",ID="XXXX",Class="AT25256",Category="SERIAL_EPROM",MFG="Microchip";
Name="25AA256",ID="XXXX",Class="AT25256",Category="SERIAL_EPROM",MFG="Microchip";
Name="25C512",ID="XXXX",Class="AT25256",Category="SERIAL_EPROM",MFG="Microchip";
Name="25LC512",ID="XXXX",Class="AT25256",Category="SERIAL_EPROM",MFG="Microchip";
Name="25AA512",ID="XXXX",Class="AT25256",Category="SERIAL_EPROM",MFG="Microchip";
Name="25AA1024",ID="XXXX",Class="AT25F1024",Codesize="131072";Category="SERIAL_EPROM",MFG="Microchip",Vcc="3.6V";
;Name="FM25L256",ID="XXXX",Class="AT25256",Category="SERIAL_EPROM",MFG="Ramtron",Adapter="ADP-004";
Name="24AA512_001",ID="XXXX",Class="AT24C512_Address001",Category="SERIAL_EPROM",MFG="Microchip",Vcc="3.6V";
Name="F-24U09",ID="XXXX",Class="24C08",Category="SERIAL_EPROM",MFG="Fairchild";
Name="F-24U09*SOIC8",ID="XXXX",Class="24C08",Category="SERIAL_EPROM",MFG="Fairchild";
Name="F-24U17",ID="XXXX",Class="24C16",Category="SERIAL_EPROM",MFG="Fairchild";
Name="F-24U17*SOIC8",ID="XXXX",Class="24C16",Category="SERIAL_EPROM",MFG="Fairchild";
Name="F-93C56",ID="XXXX",Class="93C56B_16Bit",Category="SERIAL_EPROM",MFG="Fairchild",Speed="3";
Name="L56R (8Bit)",ID="XXXX",Class="L56RA",Category="SERIAL_EPROM",MFG="ALL(Generic)";
Name="L56R (16Bit)",ID="XXXX",Class="L56RB",Category="SERIAL_EPROM",MFG="ALL(Generic)",Speed="3";
Name="RA57",ID="XXXX",Class="RA57",Category="SERIAL_EPROM",MFG="ALL(Generic)",Speed="3";
Name="S24CS01A",ID="XXXX",Class="24C01",Category="SERIAL_EPROM",MFG="SII";
Name="S24CS02A",ID="XXXX",Class="24C02",Category="SERIAL_EPROM",MFG="SII";
Name="S24CS04A",ID="XXXX",Class="24C04",Category="SERIAL_EPROM",MFG="SII";
Name="S24CS08A",ID="XXXX",Class="24C08",Category="SERIAL_EPROM",MFG="SII";
Name="CAT24C01",ID="XXXX",Class="24C01",Category="SERIAL_EPROM",MFG="Catalyst";
Name="CAT24C02",ID="XXXX",Class="24C02",Category="SERIAL_EPROM",MFG="Catalyst";
Name="CAT24C04",ID="XXXX",Class="24C04",Category="SERIAL_EPROM",MFG="Catalyst";
Name="CAT24C05",ID="XXXX",Class="24C04",Category="SERIAL_EPROM",MFG="Catalyst";
Name="CAT24C08",ID="XXXX",Class="24C08",Category="SERIAL_EPROM",MFG="Catalyst";
Name="CAT24C16",ID="XXXX",Class="24C16",Category="SERIAL_EPROM",MFG="Catalyst";
Name="CAT24C32",ID="XXXX",Class="24C32",Category="SERIAL_EPROM",MFG="Catalyst";
Name="CAT24C64",ID="XXXX",Class="24C64",Category="SERIAL_EPROM",MFG="Catalyst";
Name="CAT25C01",ID="XXXX",Class="AT25128",CodeSize="128" Category="SERIAL_EPROM",MFG="Catalyst";
Name="CAT25C02",ID="XXXX",Class="AT25128",CodeSize="256" Category="SERIAL_EPROM",MFG="Catalyst";
Name="CAT25C04",ID="XXXX",Class="AT25128",CodeSize="512" Category="SERIAL_EPROM",MFG="Catalyst";
Name="CAT25C08",ID="XXXX",Class="AT25128",CodeSize="1024" Category="SERIAL_EPROM",MFG="Catalyst";
Name="CAT25C16",ID="XXXX",Class="AT25128",CodeSize="2048" Category="SERIAL_EPROM",MFG="Catalyst";
Name="CAT25C128",ID="XXXX",Class="AT25128",Category="SERIAL_EPROM",MFG="Catalyst";
Name="CAT25C256",ID="XXXX",Class="AT25256",Category="SERIAL_EPROM",MFG="Catalyst";
Name="CAT25010",ID="XXXX",Class="25C010",Category="SERIAL_EPROM",MFG="Catalyst";
Name="CAT25020",ID="XXXX",Class="25C020",Category="SERIAL_EPROM",MFG="Catalyst";
Name="CAT25040",ID="XXXX",Class="25C040",Category="SERIAL_EPROM",MFG="Catalyst",Vcc="3.6V";
Name="CAT25080",ID="XXXX",Class="25C080",Category="SERIAL_EPROM",MFG="Catalyst",Vcc="3.6V";
Name="CAT25160",ID="XXXX",Class="25C160",Category="SERIAL_EPROM",MFG="Catalyst",Vcc="3.6V";
Name="CAT25080L",ID="XXXX",Class="25C080",Category="SERIAL_EPROM",MFG="Catalyst",Vcc="3.6V";
Name="CAT25160L",ID="XXXX",Class="25C160",Category="SERIAL_EPROM",MFG="Catalyst",Vcc="3.6V";
Name="CAT25080V*SOIC8",ID="XXXX",Class="25C080",Category="SERIAL_EPROM",MFG="Catalyst",Vcc="3.6V",Adapter="ADP-070 TSSOP8-DIP8";
Name="CAT25160V*SOIC8",ID="XXXX",Class="25C160",Category="SERIAL_EPROM",MFG="Catalyst",Vcc="3.6V",Adapter="ADP-070 TSSOP8-DIP8";
Name="CAT25080Y*TSSOP8",ID="XXXX",Class="25C080",Category="SERIAL_EPROM",MFG="Catalyst",Vcc="3.6V",Adapter="ADP-070 TSSOP8-DIP8";
Name="CAT25160Y*TSSOP8",ID="XXXX",Class="25C160",Category="SERIAL_EPROM",MFG="Catalyst",Vcc="3.6V",Adapter="ADP-070 TSSOP8-DIP8";
Name="FM25L16",ID="XXXX",Class="25C160",Category="SERIAL_EPROM",MFG="Ramtron",Vcc="3.6V";
Name="HT93LC46 (8Bit)",ID="XXXX",Class="93C46A_8Bit",Category="SERIAL_EPROM",MFG="Holtek",Speed="4";
Name="HT93LC46 (16Bit)",ID="XXXX",Class="93C46B_16Bit",Category="SERIAL_EPROM",MFG="Holtek",Speed="4";
Name="HT93LC56 (16Bit)",ID="XXXX",Class="93C56B_16Bit",Category="SERIAL_EPROM",MFG="Holtek",Speed="3";
Name="AT93C46(8Bit)",ID="XXXX",Class="93C46A_8Bit",Category="SERIAL_EPROM",MFG="Atmel",Speed="4";
Name="AT93C46(16Bit)",ID="XXXX",Class="93C46B_16Bit",Category="SERIAL_EPROM",MFG="Atmel";
Name="AT93C46A(16Bit)",ID="XXXX",Class="93C46B_16Bit",Category="SERIAL_EPROM",MFG="Atmel";
Name="AT93C56(8Bit)",ID="XXXX",Class="93C56A_8Bit",Category="SERIAL_EPROM",MFG="Atmel";
Name="AT93C56A(8Bit)",ID="XXXX",Class="93C56A_8Bit",Category="SERIAL_EPROM",MFG="Atmel";
Name="AT93C66 (8Bit)",ID="XXXX",Class="93C66A_8Bit",Category="SERIAL_EPROM",MFG="Atmel";
Name="AT93C86 (8Bit)",ID="XXXX",Class="93C86A_8Bit",Category="SERIAL_EPROM",MFG="Atmel";
Name="IS24C02",ID="XXXX",Class="24C02",Category="SERIAL_EPROM",MFG="ISSI";
Name="IS24C04",ID="XXXX",Class="24C04",Category="SERIAL_EPROM",MFG="ISSI";
Name="IS24C08",ID="XXXX",Class="24C08",Category="SERIAL_EPROM",MFG="ISSI";
Name="IS24C16",ID="XXXX",Class="24C16",Category="SERIAL_EPROM",MFG="ISSI";
Name="IS24C32",ID="XXXX",Class="24C32",Category="SERIAL_EPROM",MFG="ISSI";
Name="IS24C64",ID="XXXX",Class="24C64",Category="SERIAL_EPROM",MFG="ISSI";
Name="IS24C02*TSSOP8",ID="XXXX",Class="24C02",Category="SERIAL_EPROM",MFG="ISSI",Adapter="ADP-070";
Name="IS24C04*TSSOP8",ID="XXXX",Class="24C04",Category="SERIAL_EPROM",MFG="ISSI",Adapter="ADP-070";
Name="IS24C08*TSSOP8",ID="XXXX",Class="24C08",Category="SERIAL_EPROM",MFG="ISSI",Adapter="ADP-070";
Name="IS24C16*TSSOP8",ID="XXXX",Class="24C16",Category="SERIAL_EPROM",MFG="ISSI",Adapter="ADP-070";
Name="IS24C32*TSSOP8",ID="XXXX",Class="24C32",Category="SERIAL_EPROM",MFG="ISSI",Adapter="ADP-070";
Name="IS24C64*TSSOP8",ID="XXXX",Class="24C64",Category="SERIAL_EPROM",MFG="ISSI",Adapter="ADP-070";
Name="IS24C16A-2ZLI",ID="XXXX",Class="24C16",Category="SERIAL_EPROM",MFG="ISSI",Adapter="ADP-070";
Name="M24C01",ID="XXXX",Class="24C01",Category="SERIAL_EPROM",MFG="ST";
Name="M24C02",ID="XXXX",Class="24C02",Category="SERIAL_EPROM",MFG="ST";
Name="M24C04",ID="XXXX",Class="24C04",Category="SERIAL_EPROM",MFG="ST";
Name="M24C32",ID="XXXX",Class="24C32",Category="SERIAL_EPROM",MFG="ST";
Name="M24C64",ID="XXXX",Class="24C64",Category="SERIAL_EPROM",MFG="ST";
Name="ST24C01",ID="XXXX",Class="24C01",Category="SERIAL_EPROM",MFG="ST";
Name="ST24C02",ID="XXXX",Class="24C02",Category="SERIAL_EPROM",MFG="ST";
Name="ST24C04",ID="XXXX",Class="24C04",Category="SERIAL_EPROM",MFG="ST";
Name="ST24C08",ID="XXXX",Class="24C08",Category="SERIAL_EPROM",MFG="ST";
Name="ST24C16",ID="XXXX",Class="24C16",Category="SERIAL_EPROM",MFG="ST";
Name="ST24C32",ID="XXXX",Class="24C32",Category="SERIAL_EPROM",MFG="ST";
Name="ST24C64",ID="XXXX",Class="24C64",Category="SERIAL_EPROM",MFG="ST";
Name="M93C56",ID="XXXX",Class="93C56A_8Bit",Category="SERIAL_EPROM",MFG="ST";
Name="M93C66 (8Bit)",ID="XXXX",Class="93C66A_8Bit",VCC="3.6V",Category="SERIAL_EPROM",MFG="ST";
Name="M93C76W6 (8Bit)",ID="XXXX",Class="93C76A_8Bit",Category="SERIAL_EPROM",MFG="ST";
Name="M93C86 (8Bit)",ID="XXXX",Class="93C86A_8Bit",VCC="3.6V",Category="SERIAL_EPROM",MFG="ST";
Name="M93S46",ID="XXXX",Class="M93S46",Category="SERIAL_EPROM",MFG="ST",VCC="3.6V";
Name="M93S46WP",ID="XXXX",Class="M93S46",Category="SERIAL_EPROM",MFG="ST",VCC="3.6V";
Name="M93S56",ID="XXXX",Class="M93S56",Category="SERIAL_EPROM",MFG="ST",VCC="3.6V";
Name="M93S66",ID="XXXX",Class="M93S56",CodeSize="512",Category="SERIAL_EPROM",MFG="ST",VCC="3.6V";
Name="M93S66WP",ID="XXXX",Class="M93S56",CodeSize="512",Category="SERIAL_EPROM",MFG="ST",VCC="3.6V";
Name="S29430A",ID="XXXX",Class="93C76B_16Bit",Category="SERIAL_EPROM",MFG="Seiko",VCC="3.6V";
Name="CSI24C01",ID="XXXX",Class="24C01",Category="SERIAL_EPROM",MFG="LSI/CSI",Speed="3";
Name="CSI24C01B",ID="XXXX",Class="24C01",Category="SERIAL_EPROM",MFG="LSI/CSI",Speed="3";
Name="CSI24C02",ID="XXXX",Class="24C02",Category="SERIAL_EPROM",MFG="LSI/CSI";
Name="CSI24C04",ID="XXXX",Class="24C04",Category="SERIAL_EPROM",MFG="LSI/CSI";
Name="CSI24C05",ID="XXXX",Class="24C04",Category="SERIAL_EPROM",MFG="LSI/CSI";
Name="CSI24C08",ID="XXXX",Class="24C08",Category="SERIAL_EPROM",MFG="LSI/CSI";
Name="CSI24C16",ID="XXXX",Class="24C16",Category="SERIAL_EPROM",MFG="LSI/CSI";
Name="CSI24C32",ID="XXXX",Class="24C32",Category="SERIAL_EPROM",MFG="LSI/CSI";
Name="CSI24C64",ID="XXXX",Class="24C64",Category="SERIAL_EPROM",MFG="LSI/CSI";
Name="X24C02PI",ID="XXXX",Class="24C02",Category="SERIAL_EPROM",MFG="Xicor";
Name="X24C01",ID="XXXX",Class="24C01",Category="SERIAL_EPROM",MFG="Xicor",Speed="2";
Name="X24C00P",ID="XXXX",Class="X24C00",Category="SERIAL_EPROM",MFG="Xicor",Speed="2",Platform="GQ-4X";
Name="CSI93C46 (8Bit)",ID="XXXX",Class="93C46A_8Bit",Category="SERIAL_EPROM",MFG="LSI/CSI",Speed="4";
Name="CSI93C46 (16Bit)",ID="XXXX",Class="93C46B_16Bit",Category="SERIAL_EPROM",MFG="LSI/CSI",Speed="4";
Name="CSI93C57 (8Bit)",ID="XXXX",Class="93C57A_8Bit",Category="SERIAL_EPROM",MFG="LSI/CSI";
Name="CSI93C57 (16Bit)",ID="XXXX",Class="93C57B_16Bit",Category="SERIAL_EPROM",MFG="LSI/CSI";
Name="CSI93C66 (8Bit)",ID="XXXX",Class="93C66A_8Bit",Category="SERIAL_EPROM",MFG="LSI/CSI",Speed="4";
Name="CSI93C86L (8Bit)",ID="XXXX",Class="93C86A_8Bit",Category="SERIAL_EPROM",MFG="LSI/CSI";
Name="CSI25160",ID="XXXX",Class="25C160",Category="SERIAL_EPROM",MFG="LSI/CSI";
Name="CSI25C128",ID="XXXX",Class="AT25128",Category="SERIAL_EPROM",MFG="LSI/CSI";
Name="CSI25C256",ID="XXXX",Class="AT25256",Category="SERIAL_EPROM",MFG="LSI/CSI";
Name="CSI25010",ID="XXXX",Class="25C010",Category="SERIAL_EPROM",MFG="LSI/CSI";
Name="CSI25020",ID="XXXX",Class="25C020",Category="SERIAL_EPROM",MFG="LSI/CSI";
Name="S93C46D",ID="XXXX",Class="93C46B_16Bit",Category="SERIAL_EPROM",MFG="Seiko";
Name="S93C56D",ID="XXXX",Class="93C56B_16Bit",Category="SERIAL_EPROM",MFG="Seiko";
;Name="A25L05P",ID="7F372011",Class="W25X10",Category="SERIAL_EPROM",MFG="AMIC",Vcc="3.6V",CodeSize="65536";
;Name="A25L10P",ID="7F372012",Class="W25X10",Category="SERIAL_EPROM",MFG="AMIC",Vcc="3.6V",CodeSize="131072";
;Name="A25L20P",ID="7F372012",Class="W25X10",Category="SERIAL_EPROM",MFG="AMIC",Vcc="3.6V",CodeSize="262144";
;Name="A25L40P",ID="7F372013",Class="W25X10",Category="SERIAL_EPROM",MFG="AMIC",Vcc="3.6V",CodeSize="524288";
;Name="A25L80P",ID="7F370213",Class="W25X10",Category="SERIAL_EPROM",MFG="AMIC",Vcc="3.6V",CodeSize="1048576";
Name="A25L05P",ID="7F3720",Class="W25X10",Category="SERIAL_EPROM",MFG="AMIC",Vcc="3.6V",CodeSize="65536";
Name="A25L10P",ID="7F3720",Class="W25X10",Category="SERIAL_EPROM",MFG="AMIC",Vcc="3.6V",CodeSize="131072";
Name="A25L20P",ID="7F3720",Class="W25X10",Category="SERIAL_EPROM",MFG="AMIC",Vcc="3.6V",CodeSize="262144";
Name="A25L40P",ID="7F3720",Class="W25X10",Category="SERIAL_EPROM",MFG="AMIC",Vcc="3.6V",CodeSize="524288";
Name="A25L80P",ID="7F3720",Class="W25X10",Category="SERIAL_EPROM",MFG="AMIC",Vcc="3.6V",CodeSize="1048576";
Name="A25L016M",ID="373015",Class="W25X10_FAST",CodeSize="2097152",VCC="3.6V",Category="SERIAL_EPROM",Adapter="SOIC8-DIP or ADP-081 adapter",MFG="AMIC",Platform="GQ-4X";
Name="A25L080-F",ID="373014",Class="W25X10",Category="SERIAL_EPROM",MFG="AMIC",Vcc="3.6V",CodeSize="1048576"; //by bis0n
Name="EN25F20",ID="1C3112",Class="W25X10",CodeSize="262144",VCC="3.6V",Category="SERIAL_EPROM",MFG="Eon Silicon";
Name="EN25F40",ID="1C3113",Class="W25X10",CodeSize="524288",VCC="3.6V",Category="SERIAL_EPROM",MFG="Eon Silicon";
Name="EN25F80*SOIC8",ID="1C3114",Class="W25X10",CodeSize="1048576",VCC="3.6V",Category="SERIAL_EPROM",Adapter="ADP-081, ADP-027 SOIC20",MFG="Eon Silicon";
Name="EN25F80",ID="1C3114",Class="W25X10",CodeSize="1048576",VCC="3.6V",Category="SERIAL_EPROM",MFG="Eon Silicon";
Name="EN25D80",ID="1C3014",Class="W25X10",CodeSize="1048576",VCC="3.6V",Category="SERIAL_EPROM",MFG="Eon Silicon";
Name="EN25D16",ID="1C3015",Class="W25X10",CodeSize="2097152",VCC="3.6V",Category="SERIAL_EPROM",MFG="Eon Silicon";
Name="EN25D16(FastMode)",ID="1C3015",Class="W25X10_FAST",CodeSize="2097152",VCC="3.6V",Category="SERIAL_EPROM",MFG="Eon Silicon",Platform="GQ-4X";
Name="EN25F16",ID="1C3115",Class="W25X10",CodeSize="2097152",VCC="3.6V",Category="SERIAL_EPROM",MFG="Eon Silicon",Platform="GQ-4X";
Name="EN25F16(FastMode)",ID="1C3115",Class="W25X10_FAST",Category="SERIAL_EPROM",MFG="Eon Silicon",CodeSize="2097152",Platform="GQ-4X";
Name="EN25F64",ID="1C3117",Class="W25X10",CodeSize="8388608",VCC="3.6V",Category="SERIAL_EPROM",MFG="Eon Silicon",Platform="GQ-4X";
Name="PM25LV512",ID="9D7B7F",Class="Pm25LV512",Category="SERIAL_EPROM",MFG="PMC",Vcc="3.6V",CodeSize="65536",Platform="GQ-4X",Adapter="SOIC8-DIP8, ADP-004";
Name="PM25LV010",ID="7F9D7C",Class="AT25FS010",Category="SERIAL_EPROM",MFG="PMC",Vcc="3.6V",CodeSize="131072",Adapter="SOIC8-DIP8, ADP-004";
Name="PM25LV020",ID="7F9D7D",Class="AT25FS010",Category="SERIAL_EPROM",MFG="PMC",Vcc="3.6V",CodeSize="262144";
Name="PM25LV040",ID="7F9D7E",Class="AT25FS010",Category="SERIAL_EPROM",MFG="PMC",Vcc="3.6V",CodeSize="524288";
Name="PM25LV080",ID="7F9D13",Class="W25X10",Category="SERIAL_EPROM",MFG="PMC",Vcc="3.6V",CodeSize="1048576";
Name="W25X10",ID="EF3011",Class="W25X10",Category="SERIAL_EPROM",MFG="Winbond",Vcc="3.6V";
Name="W25X20",ID="EF3012",Class="W25X10",Category="SERIAL_EPROM",MFG="Winbond",Vcc="3.6V",CodeSize="262144";
Name="W25X40",ID="EF3013",Class="W25X10",Category="SERIAL_EPROM",MFG="Winbond",Vcc="3.6V",CodeSize="524288";
Name="W25X80",ID="EF3014",Class="W25X10",Category="SERIAL_EPROM",MFG="Winbond",Vcc="3.6V",CodeSize="1048576";
Name="W25X80(FastMode)",ID="EF3014",Class="W25X10_FAST",Category="SERIAL_EPROM",MFG="Winbond",Vcc="3.6V",CodeSize="1048576",Platform="GQ-4X";
Name="W25X16",ID="EF3015",Class="W25X10_FAST",Category="SERIAL_EPROM",MFG="Winbond",Vcc="3.6V",CodeSize="2097152",Platform="GQ-4X";
Name="W25X32",ID="EF3016",Class="W25X10_FAST",Category="SERIAL_EPROM",MFG="Winbond",Vcc="3.6V",CodeSize="4194304",Adapter="ADP-081, ADP-027 adapter",Platform="GQ-4X";
Name="W25X32VS",ID="EF3016",Class="W25X10_FAST",Category="SERIAL_EPROM",MFG="Winbond",Vcc="3.6V",CodeSize="4194304",Adapter="ADP-081, ADP-027 adapter",Platform="GQ-4X";
Name="W25Q64CV",ID="EF4017",Class="W25X10_FAST",Category="SERIAL_EPROM",MFG="Winbond",Vcc="3.6V",CodeSize="8388608",Adapter="ADP-081, ADP-027 adapter",Platform="GQ-4X";
Name="W25Q80B",ID="EF4014",Class="W25X10",Category="SERIAL_EPROM",MFG="Winbond",Vcc="3.6V",CodeSize="1048576";
Name="W25Q80*SOIC8",ID="EF4014",Class="W25X10",Category="SERIAL_EPROM",MFG="Winbond",Vcc="3.6V",CodeSize="1048576",Adapter="ADP-081, ADP-027 adapter";
Name="W25Q16",ID="EF4015",Class="W25X10_FAST",Category="SERIAL_EPROM",MFG="Winbond",Vcc="3.6V",CodeSize="2097152",Adapter="ADP-081, ADP-027 adapter",Platform="GQ-4X";
Name="W25Q32",ID="EF4016",Class="W25X10_FAST",Category="SERIAL_EPROM",MFG="Winbond",Vcc="3.6V",CodeSize="4194304",Adapter="ADP-081, ADP-027 adapter",Platform="GQ-4X";
Name="W25Q64",ID="EF4017",Class="W25X10_FAST",Category="SERIAL_EPROM",MFG="Winbond",Vcc="3.6V",CodeSize="8388608",Adapter="ADP-081, ADP-027 adapter",Platform="GQ-4X";
Name="W25X10VSSIG",ID="EF3011",Class="W25X10",Category="SERIAL_EPROM",MFG="Winbond",Vcc="3.6V",Adapter="ADP-004 adapter";
Name="W25X20VSSIG",ID="EF3012",Class="W25X10",Category="SERIAL_EPROM",MFG="Winbond",Vcc="3.6V",CodeSize="262144",Adapter="ADP-004 adapter";
Name="W25X40VSSIG",ID="EF3013",Class="W25X10",Category="SERIAL_EPROM",MFG="Winbond",Vcc="3.6V",CodeSize="524288", Adapter="ADP-081, ADP-027 adapter";
Name="W25X80VSSIG",ID="EF3014",Class="W25X10",Category="SERIAL_EPROM",MFG="Winbond",Vcc="3.6V",CodeSize="1048576", Adapter="ADP-081, ADP-027 adapter";
Name="W25X16VSSIG",ID="EF3015",Class="W25X10_FAST",Category="SERIAL_EPROM",MFG="Winbond",Vcc="3.6V",CodeSize="2097152",Platform="GQ-4X", Adapter="ADP-081, ADP-027 adapter";
Name="W25X10*SOIC8",ID="EF3011",Class="W25X10",Category="SERIAL_EPROM",MFG="Winbond",Vcc="3.6V",Adapter="ADP-004 adapter";
Name="W25X20*SOIC8",ID="EF3012",Class="W25X10",Category="SERIAL_EPROM",MFG="Winbond",Vcc="3.6V",CodeSize="262144",Adapter="ADP-004 adapter";
Name="W25X40*SOIC8",ID="EF3013",Class="W25X10",Category="SERIAL_EPROM",MFG="Winbond",Vcc="3.6V",CodeSize="524288", Adapter="ADP-081, ADP-027 adapter";
Name="W25X80*SOIC8",ID="EF3014",Class="W25X10",Category="SERIAL_EPROM",MFG="Winbond",Vcc="3.6V",CodeSize="1048576", Adapter="ADP-081, ADP-027 adapter";
Name="W25X16*SOIC8",ID="EF3015",Class="W25X10_FAST",Category="SERIAL_EPROM",MFG="Winbond",Vcc="3.6V",CodeSize="2097152",Platform="GQ-4X", Adapter="ADP-081, ADP-027 adapter";
Name="25P05",ID="202010",Class="W25X10",Category="SERIAL_EPROM",MFG="ST",Vcc="3.6V",CodeSize="65536",Adapter="SOIC8-DIP8, ADP-004";
Name="25P10",ID="202011",Class="W25X10",Category="SERIAL_EPROM",MFG="ST",Vcc="3.6V",Adapter="SOIC8-DIP8, ADP-004";
Name="25P20",ID="202012",Class="W25X10",Category="SERIAL_EPROM",MFG="ST",Vcc="3.6V",CodeSize="262144",Adapter="SOIC8-DIP8, ADP-004";
Name="25P40",ID="202013",Class="W25X10",Category="SERIAL_EPROM",MFG="ST",Vcc="3.6V",CodeSize="524288",Adapter="SOIC8-DIP8, ADP-004";
Name="25P80",ID="202014",Class="W25X10",Category="SERIAL_EPROM",MFG="ST",Vcc="3.6V",CodeSize="1048576",Adapter="ADP-081, ADP-027";
Name="25P16",ID="202015",Class="W25X10_FAST",Category="SERIAL_EPROM",MFG="ST",Vcc="3.6V",CodeSize="2097152",Adapter="SOIC16-DIP8",Platform="GQ-4X";;
Name="25PE80",ID="208014",Class="W25X10",Category="SERIAL_EPROM",MFG="ST",Vcc="3.6V",CodeSize="1048576",Adapter="ADP-081, ADP-027";
Name="M25P05",ID="202010",Class="W25X10",Category="SERIAL_EPROM",MFG="ST",Vcc="3.6V",CodeSize="65536",Adapter="SOIC8-DIP8, ADP-004";
Name="M25P10",ID="202011",Class="W25X10",Category="SERIAL_EPROM",MFG="ST",Vcc="3.6V",Adapter="SOIC8-DIP8, ADP-004";
Name="M25P20",ID="202012",Class="W25X10",Category="SERIAL_EPROM",MFG="ST",Vcc="3.6V",CodeSize="262144",Adapter="SOIC8-DIP8, ADP-004";
Name="M25P40",ID="202013",Class="W25X10",Category="SERIAL_EPROM",MFG="ST",Vcc="3.6V",CodeSize="524288",Adapter="SOIC8-DIP8, ADP-004";
Name="M25P80",ID="202014",Class="W25X10",Category="SERIAL_EPROM",MFG="ST",Vcc="3.6V",CodeSize="1048576",Adapter="ADP-081, ADP-027";
Name="M25P16",ID="202015",Class="W25X10_FAST",Category="SERIAL_EPROM",MFG="ST",Vcc="3.6V",CodeSize="2097152",Adapter="SOIC16-DIP8",Platform="GQ-4X";;
Name="M25PX32*SOIC8",ID="207116",Class="W25X10_FAST",Category="SERIAL_EPROM",MFG="ST",Vcc="3.6V",CodeSize="4194304",Adapter="ADP-081, ADP-027",Platform="GQ-4X";
Name="MX25L1005MI",ID="C22011",Class="W25X10",Category="FLASH",MFG="Macronix",Vcc="3.6V",CodeSize="131072",Adapter="SOIC8-DIP8, ADP-004"; merci quand meme
Name="MX25L1005MC",ID="C22011",Class="AT25FS010",Category="SERIAL_EPROM",MFG="Macronix",Vcc="3.6V",CodeSize="131072",Adapter="ADP-004";
Name="MX25L2005MC",ID="C22012",Class="AT25FS010",Category="SERIAL_EPROM",MFG="Macronix",Vcc="3.6V",CodeSize="262144",Adapter="ADP-004";
Name="MX25L4005M",ID="C22013",Class="W25X10",Category="SERIAL_EPROM",MFG="Macronix",Vcc="3.6V",CodeSize="524288",Adapter="ADP-004";
Name="MX25L4005M2",ID="C22013",Class="W25X10",Category="SERIAL_EPROM",MFG="Macronix",Vcc="3.6V",CodeSize="524288",Adapter="ADP-081";
Name="MX25L4005AP",ID="C22013",Class="W25X10",Category="SERIAL_EPROM",MFG="Macronix",Vcc="3.6V",CodeSize="524288";
Name="MX25L4005MC",ID="C22013",Class="W25X10",Category="SERIAL_EPROM",MFG="Macronix",Vcc="3.6V",CodeSize="524288",Adapter="ADP-004";
Name="MX25L8005M",ID="C22014",Class="W25X10",Category="SERIAL_EPROM",MFG="Macronix",Vcc="3.6V",CodeSize="1048576",Adapter="ADP-004";
Name="MX25L8005M2",ID="C22014",Class="W25X10",Category="SERIAL_EPROM",MFG="Macronix",Vcc="3.6V",CodeSize="1048576",Adapter="ADP-081";
Name="MX25L8005AP",ID="C22014",Class="W25X10",Category="SERIAL_EPROM",MFG="Macronix",Vcc="3.6V",CodeSize="1048576";
Name="MX25L8005MC",ID="C22014",Class="W25X10",Category="SERIAL_EPROM",MFG="Macronix",Vcc="3.6V",CodeSize="1048576",Adapter="ADP-081";
Name="MX25L8005PC",ID="C22014",Class="W25X10",Category="SERIAL_EPROM",MFG="Macronix",Vcc="3.6V",CodeSize="1048576";
Name="MX25L1605(Slow mode)",ID="C22015",Class="W25X10",Category="SERIAL_EPROM",MFG="Macronix",Vcc="3.6V",CodeSize="2097152",Adapter="ADP-081";
Name="MX25L1605",ID="C22015",Class="W25X10_FAST",Category="SERIAL_EPROM",MFG="Macronix",Vcc="3.6V",CodeSize="2097152",Adapter="ADP-081",Platform="GQ-4X";
Name="MX25L3205",ID="C22016",Class="W25X10_FAST",Category="SERIAL_EPROM",MFG="Macronix",Vcc="3.6V",CodeSize="4194304",Adapter="ADP-081",Platform="GQ-4X";
Name="MX25L6405",ID="C22017",Class="W25X10_FAST",Category="SERIAL_EPROM",MFG="Macronix",Vcc="3.6V",CodeSize="8388608",Adapter="SOP16-DIP8",Platform="GQ-4X";
Name="MX25L3206EM2",ID="C22016",Class="W25X10_FAST",Category="SERIAL_EPROM",MFG="Macronix",Vcc="3.6V",CodeSize="4194304",Adapter="ADP-081",Platform="GQ-4X";
Name="MX25L3206EPI",ID="C22016",Class="W25X10_FAST",Category="SERIAL_EPROM",MFG="Macronix",Vcc="3.6V",CodeSize="4194304",Platform="GQ-4X";
Name="MX25L6406E",ID="C22017",Class="W25X10_FAST",Category="SERIAL_EPROM",MFG="Macronix",Vcc="3.6V",CodeSize="8388608",Adapter="SOP16-DIP8",Platform="GQ-4X";
Name="MX25L8006EP",ID="C22014",Class="W25X10_FAST",Category="SERIAL_EPROM",MFG="Macronix",Vcc="3.6V",CodeSize="1048576",Platform="GQ-4X";
Name="MX25L8006EM1",ID="C22014",Class="W25X10_FAST",Category="SERIAL_EPROM",MFG="Macronix",Vcc="3.6V",CodeSize="1048576",Adapter="ADP-004",Platform="GQ-4X";
Name="MX25L8006EM2",ID="C22014",Class="W25X10_FAST",Category="SERIAL_EPROM",MFG="Macronix",Vcc="3.6V",CodeSize="1048576",Adapter="ADP-0081",Platform="GQ-4X";
Name="MX25L1606EP",ID="C22015",Class="W25X10_FAST",Category="SERIAL_EPROM",MFG="Macronix",Vcc="3.6V",CodeSize="2097152",Platform="GQ-4X";
Name="MX25L1606EM1",ID="C22015",Class="W25X10_FAST",Category="SERIAL_EPROM",MFG="Macronix",Vcc="3.6V",CodeSize="2097152",Adapter="ADP-004",Platform="GQ-4X";
Name="MX25L1606EM2",ID="C22015",Class="W25X10_FAST",Category="SERIAL_EPROM",MFG="Macronix",Vcc="3.6V",CodeSize="2097152",Adapter="ADP-081",Platform="GQ-4X";
Name="F25L008A",ID="8C2014",Class="W25X10",Category="SERIAL_EPROM",MFG="ESMT",Vcc="3.6V",CodeSize="1048576";
Name="PCF8582C",ID="XXXX",Class="PCF8582",Category="SERIAL_EPROM",MFG="Philips";
Name="PCF8594C",ID="XXXX",Class="PCF8594",CodeSize="512",Category="SERIAL_EPROM",MFG="Philips";
Name="PCF8598C",ID="XXXX",Class="PCF8594",CodeSize="1024",Category="SERIAL_EPROM",MFG="Philips",VCC="5V";
Name="S25FL008A*SOIC8",ID="010213",Class="W25X10_FAST",Category="SERIAL_EPROM",MFG="Spansion",Vcc="3.6V",CodeSize="1048576",Adapter="ADP-027",Platform="GQ-4X";
Name="S25FL016A*SOIC8",ID="010214",Class="W25X10_FAST",Category="SERIAL_EPROM",MFG="Spansion",Vcc="3.6V",CodeSize="2097152",Adapter="ADP-027",Platform="GQ-4X";
Name="S25FL032A*SOIC8",ID="010215",Class="W25X10_FAST",Category="SERIAL_EPROM",MFG="Spansion",Vcc="3.6V",CodeSize="4194304",Adapter="ADP-027",Platform="GQ-4X";
Name="SST25VF512",ID="BF48",Class="SST25VF020",CodeSize="65536",VCC="3.6V",Category="SERIAL_EPROM",MFG="SST",Adapter="SOIC8-DIP or ADP-081 adapter";
Name="SST25VF010",ID="BF49",Class="SST25VF020",CodeSize="131072",VCC="3.6V",Category="SERIAL_EPROM",MFG="SST",Adapter="SOIC8-DIP or ADP-081 adapter";
Name="SST25VF020",ID="BF43",Class="SST25VF020",VCC="3.6V",Category="SERIAL_EPROM",MFG="SST",Adapter="SOIC8-DIP or ADP-081 adapter";
Name="SST25VF040",ID="BF44",Class="SST25VF020",CodeSize="524288",VCC="3.6V",Category="SERIAL_EPROM",MFG="SST",Adapter="SOIC8-DIP or ADP-081 adapter";
Name="SST25LF020",ID="BF43",Class="SST25VF020",VCC="3.6V",Category="SERIAL_EPROM",MFG="SST",Adapter="SOIC8-DIP or ADP-081 adapter";
Name="SST25LF040",ID="BF44",Class="SST25VF020",CodeSize="524288",VCC="3.6V",Category="SERIAL_EPROM",MFG="SST",Adapter="SOIC8-DIP or ADP-081 adapter";
Name="SST25VF040B",ID="BF258D",Class="SST25VF040B",CodeSize="524288",VCC="3.6V",Category="SERIAL_EPROM",Adapter="SOIC8-DIP or ADP-081 adapter",MFG="SST",Platform="GQ-4X";
Name="SST25VF080B",ID="BF258E",Class="SST25VF040B",CodeSize="1048576",VCC="3.6V",Category="SERIAL_EPROM",Adapter="SOIC8-DIP or ADP-081 adapter",MFG="SST",Platform="GQ-4X";
Name="SST25VF016B",ID="BF2541",Class="SST25VF040B",CodeSize="2097152",VCC="3.6V",Category="SERIAL_EPROM",Adapter="SOIC8-DIP or ADP-081 adapter",MFG="SST",Platform="GQ-4X";
Name="SST25VF032B",ID="BF254A",Class="SST25VF040B",CodeSize="4194304",VCC="3.6V",Category="SERIAL_EPROM",Adapter="SOIC8-DIP or ADP-081 adapter",MFG="SST",Platform="GQ-4X";
Name="SST25VF040B(Slow mode)",ID="BF258D",Class="SST25VF040B",CodeSize="524288",VCC="3.6V",Category="SERIAL_EPROM",MFG="SST",Speed="5",Adapter="SOIC8-DIP or ADP-081 adapter",Message="To get fast operation, please upgrade to GQ-4X";
Name="SST25VF080B(Slow mode)",ID="BF258E",Class="SST25VF040B",CodeSize="1048576",VCC="3.6V",Category="SERIAL_EPROM",MFG="SST",Speed="5",Adapter="SOIC8-DIP or ADP-081 adapter",Message="To get fast operation, please upgrade to GQ-4X";
Name="SST25VF016B(Slow mode)",ID="BF2541",Class="SST25VF040B",CodeSize="2097152",VCC="3.6V",Category="SERIAL_EPROM",MFG="SST",Speed="5",Adapter="SOIC8-DIP or ADP-081 adapter",Message="To get fast operation, please upgrade to GQ-4X";
;* SRAM *
Name="M48Z02",ID="XXXX",Class="M48Z02",Category="SRAM",MFG="ST",VCC="5V";
Name="M48Z12",ID="XXXX",Class="M48Z02",Category="SRAM",MFG="ST",VCC="5V";
Name="M48Z58",ID="XXXX",Class="DS1230Y",CodeSize="8192",Category="SRAM",MFG="ST",VCC="5V";
Name="M48Z58Y",ID="XXXX",Class="DS1230Y",CodeSize="8192",Category="SRAM",MFG="ST",VCC="5.5V";
Name="M48Z35Y",ID="XXXX",Class="DS1230Y",Category="SRAM",MFG="ST",VCC="5.5V";
Name="M48Z35AY",ID="XXXX",Class="DS1230Y",Category="SRAM",MFG="ST",VCC="5.5V";
Name="M48Z35AV",ID="XXXX",Class="DS1230Y",Category="SRAM",MFG="ST",VCC="5.5V";
Name="M48Z128Y",ID="XXXX",Class="BQ4015",Category="SRAM",MFG="ST",VCC="5V",PINVCC="ZIF32_PIN32",CodeSize="131072",Package="DIP32";
Name="M48T129Y",ID="XXXX",Class="BQ4015",Category="SRAM",MFG="ST",VCC="5V",PINVCC="ZIF32_PIN32",CodeSize="131072",Package="DIP32",Speed=3;
Name="M48Z129V",ID="XXXX",Class="BQ4015",Category="SRAM",MFG="ST",VCC="3.6V",PINVCC="ZIF32_PIN32",CodeSize="131072",Package="DIP32",Speed=3;
Name="M48Z129Y",ID="XXXX",Class="BQ4015",Category="SRAM",MFG="ST",VCC="5V",PINVCC="ZIF32_PIN32",CodeSize="131072",Package="DIP32",Speed=3;
Name="M48Z512A",ID="XXXX",Class="BQ4015",Category="SRAM",MFG="ST",VCC="5.5V",PINVCC="ZIF32_PIN32",CodeSize="524288",Package="DIP32";
Name="M48Z512AY",ID="XXXX",Class="BQ4015",Category="SRAM",MFG="ST",VCC="5.5V",PINVCC="ZIF32_PIN32",CodeSize="524288",Package="DIP32";
Name="M48T58Y",ID="XXXX",Class="BQ4015",Category="SRAM",MFG="TI",VCC="5.5V",PINVCC="ZIF32_PIN30",CodeSize="8192",Package="DIP28",Message="Short chip pin 26 and 28";
;Name="DS1486",ID="XXXX",Class="DS1230Y",Category="SRAM",MFG="Dallas",VCC="5.5V",PINVCC="ZIF32_PIN32",CodeSize="131072";
Name="DS1220Y",ID="XXXX",Class="M48Z02",Category="SRAM",MFG="Dallas",VCC="5V";
Name="DS1225Y",ID="XXXX",Class="DS1230Y",CodeSize="8192",Category="SRAM",MFG="Dallas",VCC="5.5V";
Name="DS1230AB",ID="XXXX",Class="DS1230Y",Category="SRAM",MFG="Dallas",VCC="5.5V";
Name="DS1230Y",ID="XXXX",Class="DS1230Y",Category="SRAM",MFG="Dallas",VCC="5.5V";
;Name="DS1230W",ID="XXXX",Class="DS1230Y",Category="SRAM",MFG="Dallas",VCC="3.6V";
Name="DS1235Y",ID="XXXX",Class="BQ4015",Category="SRAM",MFG="Dallas",VCC="5.5V",PINVCC="ZIF32_PIN30",CodeSize="32768",Package="DIP28";
Name="DS1235AB",ID="XXXX",Class="BQ4015",Category="SRAM",MFG="Dallas",VCC="5V",PINVCC="ZIF32_PIN30",CodeSize="32768",Package="DIP28";
Name="DS1245AB",ID="XXXX",Class="BQ4015",Category="SRAM",MFG="Dallas",VCC="5.5V",PINVCC="ZIF32_PIN32",CodeSize="131072",Package="DIP32";
Name="DS1245Y",ID="XXXX",Class="BQ4015",Category="SRAM",MFG="Dallas",VCC="5.5V",PINVCC="ZIF32_PIN32",CodeSize="131072",Package="DIP32";
Name="DS1250Y",ID="XXXX",Class="BQ4015",Category="SRAM",MFG="Dallas",VCC="5.5V",PINVCC="ZIF32_PIN32",CodeSize="524288",Package="DIP32";
Name="DS1650Y",ID="XXXX",Class="BQ4015",Category="SRAM",MFG="Dallas",VCC="5.5V",PINVCC="ZIF32_PIN32",CodeSize="524288",Package="DIP32";
;Name="BQ4011",ID="XXXX",Class="DS1230Y",Category="SRAM",MFG="TI",VCC="5.5V";
;Name="BQ4011Y",ID="XXXX",Class="DS1230Y",Category="SRAM",MFG="TI",VCC="5.5V";
Name="62256",ID="XXXX",Class="DS1230Y",Category="SRAM",MFG="SAMSUNG",VCC="5.5V",Message="Uncheck the verify, only use Write to test ";
Name="BQ4010",ID="XXXX",Class="BQ4015",Category="SRAM",MFG="TI",VCC="5.5V",PINVCC="ZIF32_PIN30",CodeSize="8192",Package="DIP28";
Name="BQ4010Y",ID="XXXX",Class="BQ4015",Category="SRAM",MFG="TI",VCC="5.5V",PINVCC="ZIF32_PIN30",CodeSize="8192",Package="DIP28";
Name="BQ4011",ID="XXXX",Class="BQ4015",Category="SRAM",MFG="TI",VCC="5.5V",PINVCC="ZIF32_PIN30",CodeSize="32768",Package="DIP28";
Name="BQ4011Y",ID="XXXX",Class="BQ4015",Category="SRAM",MFG="TI",VCC="5.5V",PINVCC="ZIF32_PIN30",CodeSize="32768",Package="DIP28";
Name="BQ4013",ID="XXXX",Class="BQ4015",Category="SRAM",MFG="TI",VCC="5.5V",PINVCC="ZIF32_PIN32",CodeSize="131072",Package="DIP32";
Name="BQ4013Y",ID="XXXX",Class="BQ4015",Category="SRAM",MFG="TI",VCC="5.5V",PINVCC="ZIF32_PIN32",CodeSize="131072",Package="DIP32";
Name="BQ4014",ID="XXXX",Class="BQ4015",Category="SRAM",MFG="TI",VCC="5.5V",PINVCC="ZIF32_PIN32",CodeSize="262144",Package="DIP32";
Name="BQ4014Y",ID="XXXX",Class="BQ4015",Category="SRAM",MFG="TI",VCC="5.5V",PINVCC="ZIF32_PIN32",CodeSize="262144",Package="DIP32";
Name="BQ4015",ID="XXXX",Class="BQ4015",Category="SRAM",MFG="TI",VCC="5.5V",PINVCC="ZIF32_PIN32",CodeSize="524288",Package="DIP32";
Name="BQ4015Y",ID="XXXX",Class="BQ4015",Category="SRAM",MFG="TI",VCC="5.5V",PINVCC="ZIF32_PIN32",CodeSize="524288",Package="DIP32";
Name="MB85R256",ID="XXXX",Class="DS1230Y",Category="SRAM",MFG="FUJITSU",VCC="3.6V";
Name="K6T1008C2E",ID="XXXX",Class="BQ4015",Category="SRAM",MFG="SAMSUNG",VCC="5.5V",PINVCC="ZIF32_PIN32",CodeSize="131072",Package="DIP32",Message="Short the chip pin 32 and pin 30 by a 10K resistor or a wire.To keep CS2 pin high"
;Name="X24C44",ID="XXXX",Class="X24C44",Category="SRAM",MFG="Xicor",Platform="GQ-4X";
;* GAL/CPLD *
Name="EPM3032A",ID="XXXX",Class="ALTERA_CPLD_JTAG",Category="GAL/CPLD",MFG="ALTERA",VCC="3.6V",Platform="GQ-4X",Adapter="JTAG";
Name="EPM3064A",ID="XXXX",Class="ALTERA_CPLD_JTAG",Category="GAL/CPLD",MFG="ALTERA",VCC="3.6V",Platform="GQ-4X",Adapter="JTAG";
Name="EPM3128A",ID="XXXX",Class="ALTERA_CPLD_JTAG",Category="GAL/CPLD",MFG="ALTERA",VCC="3.6V",Platform="GQ-4X",Adapter="JTAG";
Name="EPM3256A",ID="XXXX",Class="ALTERA_CPLD_JTAG",Category="GAL/CPLD",MFG="ALTERA",VCC="3.6V",Platform="GQ-4X",Adapter="JTAG";
Name="EPM3512A",ID="XXXX",Class="ALTERA_CPLD_JTAG",Category="GAL/CPLD",MFG="ALTERA",VCC="3.6V",Platform="GQ-4X",Adapter="JTAG";
Name="EPM7032AE",ID="XXXX",Class="ALTERA_CPLD_JTAG",Category="GAL/CPLD",MFG="ALTERA",VCC="5V",Platform="GQ-4X",Adapter="JTAG";
Name="EPM7064AE",ID="XXXX",Class="ALTERA_CPLD_JTAG",Category="GAL/CPLD",MFG="ALTERA",VCC="5V",Platform="GQ-4X",Adapter="JTAG";
Name="EPM7128AE",ID="XXXX",Class="ALTERA_CPLD_JTAG",Category="GAL/CPLD",MFG="ALTERA",VCC="5V",Platform="GQ-4X",Adapter="JTAG";
Name="EPM7256AE",ID="XXXX",Class="ALTERA_CPLD_JTAG",Category="GAL/CPLD",MFG="ALTERA",VCC="5V",Platform="GQ-4X",Adapter="JTAG";
Name="EPM7512AE",ID="XXXX",Class="ALTERA_CPLD_JTAG",Category="GAL/CPLD",MFG="ALTERA",VCC="5V",Platform="GQ-4X",Adapter="JTAG";
Name="EPM7032B",ID="XXXX",Class="ALTERA_CPLD_JTAG",Category="GAL/CPLD",MFG="ALTERA",VCC="5V",Platform="GQ-4X",Adapter="JTAG";
Name="EPM7064B",ID="XXXX",Class="ALTERA_CPLD_JTAG",Category="GAL/CPLD",MFG="ALTERA",VCC="5V",Platform="GQ-4X",Adapter="JTAG";
Name="EPM7128B",ID="XXXX",Class="ALTERA_CPLD_JTAG",Category="GAL/CPLD",MFG="ALTERA",VCC="5V",Platform="GQ-4X",Adapter="JTAG";
Name="EPM7256B",ID="XXXX",Class="ALTERA_CPLD_JTAG",Category="GAL/CPLD",MFG="ALTERA",VCC="5V",Platform="GQ-4X",Adapter="JTAG";
Name="EPM7512B",ID="XXXX",Class="ALTERA_CPLD_JTAG",Category="GAL/CPLD",MFG="ALTERA",VCC="5V",Platform="GQ-4X",Adapter="JTAG";
Name="EPM7032S",ID="XXXX",Class="ALTERA_CPLD_JTAG",Category="GAL/CPLD",MFG="ALTERA",VCC="5V",Platform="GQ-4X",Adapter="JTAG";
Name="EPM7064S",ID="XXXX",Class="ALTERA_CPLD_JTAG",Category="GAL/CPLD",MFG="ALTERA",VCC="5V",Platform="GQ-4X",Adapter="JTAG";
Name="EPM7128S",ID="XXXX",Class="ALTERA_CPLD_JTAG",Category="GAL/CPLD",MFG="ALTERA",VCC="5V",Platform="GQ-4X",Adapter="JTAG";
Name="EPM7160S",ID="XXXX",Class="ALTERA_CPLD_JTAG",Category="GAL/CPLD",MFG="ALTERA",VCC="5V",Platform="GQ-4X",Adapter="JTAG";
Name="EPM7192S",ID="XXXX",Class="ALTERA_CPLD_JTAG",Category="GAL/CPLD",MFG="ALTERA",VCC="5V",Platform="GQ-4X",Adapter="JTAG";
Name="EPM7256S",ID="XXXX",Class="ALTERA_CPLD_JTAG",Category="GAL/CPLD",MFG="ALTERA",VCC="5V",Platform="GQ-4X",Adapter="JTAG";
Name="XC9536",ID="XXXX",Class="Xilinx_CPLD_JTAG",Category="GAL/CPLD",MFG="Xilinx",VCC="5V",Platform="GQ-4X",Adapter="JTAG";
Name="XC9572",ID="XXXX",Class="Xilinx_CPLD_JTAG",Category="GAL/CPLD",MFG="Xilinx",VCC="5V",Platform="GQ-4X",Adapter="JTAG";
Name="XC95108",ID="XXXX",Class="Xilinx_CPLD_JTAG",Category="GAL/CPLD",MFG="Xilinx",VCC="5V",Platform="GQ-4X",Adapter="JTAG";
Name="XC95144",ID="XXXX",Class="Xilinx_CPLD_JTAG",Category="GAL/CPLD",MFG="Xilinx",VCC="5V",Platform="GQ-4X",Adapter="JTAG";
Name="XC95216",ID="XXXX",Class="Xilinx_CPLD_JTAG",Category="GAL/CPLD",MFG="Xilinx",VCC="5V",Platform="GQ-4X",Adapter="JTAG";
Name="XC95288",ID="XXXX",Class="Xilinx_CPLD_JTAG",Category="GAL/CPLD",MFG="Xilinx",VCC="5V",Platform="GQ-4X",Adapter="JTAG";
Name="XC9536XL",ID="XXXX",Class="Xilinx_CPLD_JTAG",Category="GAL/CPLD",MFG="Xilinx",VCC="3.6V",Platform="GQ-4X",Adapter="JTAG";
Name="XC9572XL",ID="XXXX",Class="Xilinx_CPLD_JTAG",Category="GAL/CPLD",MFG="Xilinx",VCC="3.6V",Platform="GQ-4X",Adapter="JTAG";
Name="XC95144XL",ID="XXXX",Class="Xilinx_CPLD_JTAG",Category="GAL/CPLD",MFG="Xilinx",VCC="3.6V",Platform="GQ-4X",Adapter="JTAG";
Name="XC95288XL",ID="XXXX",Class="Xilinx_CPLD_JTAG",Category="GAL/CPLD",MFG="Xilinx",VCC="3.6V",Platform="GQ-4X",Adapter="JTAG";
Name="XC9536XV",ID="XXXX",Class="Xilinx_CPLD_JTAG",Category="GAL/CPLD",MFG="Xilinx",VCC="3.6V",Platform="GQ-4X",Adapter="JTAG";
Name="XC9572XV",ID="XXXX",Class="Xilinx_CPLD_JTAG",Category="GAL/CPLD",MFG="Xilinx",VCC="3.6V",Platform="GQ-4X",Adapter="JTAG";
Name="XC95144XV",ID="XXXX",Class="Xilinx_CPLD_JTAG",Category="GAL/CPLD",MFG="Xilinx",VCC="3.6V",Platform="GQ-4X",Adapter="JTAG";
Name="XC95288XV",ID="XXXX",Class="Xilinx_CPLD_JTAG",Category="GAL/CPLD",MFG="Xilinx",VCC="3.6V",Platform="GQ-4X",Adapter="JTAG";
;* CMOS/TTL *
ZLM Posted - 12/10/2012 : 19:53:18
connect this pin with pin 4 (ground) this will disable the hardware write protection.
If your put it inot the programmer ZIF socket, this WP should automatically put to low.
Marin Posted - 12/08/2012 : 20:31:35
Can you please explain my question above?
What do you mean pull WP pin Low?
Marin Posted - 11/27/2012 : 22:28:46
WP = write protection???
ZLM Posted - 11/27/2012 : 18:54:40
read the datasheet. It seems the 24C17U have a extra WP pin than 24C16 only.
If you pull this WP pin low, then the chip will works same as 24C16. Read and write.
Marin Posted - 11/25/2012 : 18:15:35
Anyone???
Marin Posted - 11/22/2012 : 22:18:50
24C17 should be same.It looks like it is same as 24C16 but has write protect.
Open second PDF that says
"Abstract: 1 NC 2 TSSOP Package (MT8) 8 VCC WP 1 7 WP VCC 2 24C17 8 SCL 7 SDA 24C17 NC 3 6 SCL NC 3 6 VSS VSS 4 5 SDA NC ..."
www.datasheetarchive.com/24C17-datasheet.html
ZLM Posted - 11/21/2012 : 12:14:41
any datasheet?
Generated in 1.54 sec. Snitz Forums 2000
