 Problem copying 27C020 ROM...
wolfievtec Posted - 02/28/2013 : 15:29:36
Today I got the GQ-4X Programmer. I have a good data chip (AM27C020) that I need to copy. I placed the chip in the burner (selected my chip), and did a chip read. Then I saved the data as a .BIN file. I then put in my new chip (selected my chip)and did a blank check - (OK). I then did a write. It wrote and verified but when I try it in my motherboard I get nothing. What am I missing? I've tried writing to several chips and the same thing happens. All pass the blank chip test before burning.
ZLM Posted - 03/06/2013 : 20:16:38
If you known the good checksum, then the programmed chip must be same checksum.
Select the device type and then read the orginal chip.
wolfievtec Posted - 03/03/2013 : 07:09:49
When I read my original chip I get a good checksum. When I put in the blank chip and change the device type, the checksum changes and I get a bad burn. I was able to get 2 good burns out of about 12 chips. What might be the problem with the bad checksums?
ZLM Posted - 02/28/2013 : 21:51:07
Are you sure your original chip is working?
I think the data is not read correctly. Make multiple read and make sure all checksums are the same, then save it.
Also, try to use slowest speed and/or an external power if the original chip is a old chip.
