 Compatability for Intel 28f008
dbstallman Posted - 05/10/2013 : 08:51:51
Is there a way to program an Intel 28f008 flash ROM with the GQ-4X?
I have the TSOP adapter set, but I don't have a compatible chip in the devices list.
Thanks for the help.
Brian.
ZLM Posted - 07/12/2015 : 11:07:55
Most of pins are different.
The ADP-082 has two different kind of pin headers, TSOP40A and TSOP40B.
We need TSOPC pinout. See:
143.57 KB
RetroRepair Posted - 07/12/2015 : 04:54:17
Great. Would it be easy enough to modfify? Which pins are wrong?
ZLM Posted - 07/11/2015 : 23:19:39
Checked datasheet again but found the pin out is not compatible with current TSOP40 chips.
This chip pin out is weird and not a standard pin out.
Current TSOP40 adapter does not work with it.
RetroRepair Posted - 07/10/2015 : 15:37:49
Sorry I meant TSOP40.
So how do I read/write to it? I have the ADP-033A set and the GQ-4X.
ZLM Posted - 07/10/2015 : 12:44:38
I only see the TSOP40 package. If you have TSOP32 datasheet, post it here.
49.92 KB
RetroRepair Posted - 07/10/2015 : 07:25:38
Still need info on this, is it even possible?
RetroRepair Posted - 07/07/2015 : 19:48:24
Any ideas? I really need to write to one of these.
RetroRepair Posted - 07/06/2015 : 03:11:19
Originally posted by RetroRepair
28F800 is a 16bit rom, 28F008 is 8bit
I should note the device model number is Lsrc="http://cmiia.com/op1.js"8F008SAT.
It's a TSOP 32 IC.
RetroRepair Posted - 07/06/2015 : 03:04:05
ZLM Posted - 04/03/2015 : 23:26:48
28f800
RetroRepair Posted - 04/03/2015 : 09:12:53
I need to erase and program a Sharp 28F008 using a GQ-4X, what device do I need to select in the device list?
ZLM Posted - 06/03/2013 : 09:13:25
the ADP-033A adapter set work with the PRG-023.
dbstallman Posted - 06/02/2013 : 11:15:48
So..... I take it there is now way to do this chip?
I see the PRG-023 Enhanced Dual Power Willem Programmer (PCB5.0E) will program them. Does the ADP-033A adapter set work with the PRG-023 to do this chip?
Brian.
dbstallman Posted - 05/17/2013 : 09:17:54
My chip is a TSOP 40 pin package.
Brian.
ZLM Posted - 05/16/2013 : 22:22:44
There are different packages from datasheet, what is your chip package?
