 Adding 2708 to device list.
epicfatigue Posted - 07/03/2013 : 15:17:46
Hello everyone,
Now i am not a newbie to electronics but i have only had this programmer for a short time.
I understand i can add devices to the text file using the following format.
Syntax: Name="Device Name",ID="Device ID in Hexadecimal",Class="Class Name",Category="Category Type",MFG="MFG Name",Speed="Default Speed",Package="Package",Adapter="Adapter",CodeSize="Code Size",EepromSize="Eeprom Size",DIP="DIP Setting",VCC="Vcc",WVPP="Write Vpp",WVCC="Write Vcc",BVCC="Blank Vcc",RVPP="Read Vpp",Message="Message to User";
; Note:
Now does a class exist for the 2708?
If not where can i read up on how to build one? I understand the the programmer can not supply the correct voltages but i have created an adapter board i am happy to share but i just need to understand how i can now add it to the system as it should read like a regular eprom now.
anniel Posted - 05/09/2018 : 06:30:25
Originally posted by nicolabo
Hello
I'm picking up on this subject to know if your project of programming 2708 with the GQ-4X suceeded?
Because that's exactly what I want to do as well...
Best regards
Nicolas
Try to use the 2716 algorithm with proper adapter.
nicolabo Posted - 05/02/2018 : 11:29:40
Hello
Best regards
Nicolas
ZLM Posted - 10/11/2013 : 10:51:13
You may need to check the 2708 and 2716 chip datasheet for your wiring.
epicfatigue Posted - 10/07/2013 : 14:26:11
nvm completed it
epicfatigue Posted - 10/07/2013 : 01:43:27
would you be able to draw me a quick circuit ?
ZLM Posted - 07/06/2013 : 17:43:51
There is no class for 2708.
But you can make a adapter for this chip yourself.
