 Windows 8.1 and GQ-4x
valleytek Posted - 10/21/2013 : 15:43:08
It appears that the 8.1 Windows upgrade broke the programmer software.I have version 6.23. The software loads properly and the USB driver seems to work, at least I get the sound of it starting. The problem is that the right hand pane of the interface is blank or near blank as some parts are visible such as the DIP graphic. If you re-size it you can briefly see the normal screen to the rear of the white. It did work on Windows 8 but not 8.1. I've tried it on several 8.1 machines with same results. They all have the latest drivers. I tried downgrading the video driver with no luck so it is definitely something done differently in 8.1. Is there a fix coming as it is unusable this way.
vicz Posted - 01/30/2014 : 20:22:33
I have solved this problem by looking at Sticky: Windows 8 installation.
vicz Posted - 01/30/2014 : 19:43:09
Originally posted by vicz
I have just purchased a GQ-4X.
I am running Windows 8.1 64bit.
I have installed v 6.26. (although the latest software on the download page is 6.23.
The driver has not installed correctly as I have an Unknown device in the device manager.
The hardware is not detected when running USBPrg.
Request assistance.
I have also tried updating the driver to 20.1_32_64bit I get this message.
The 3rd party INF does not contain digital signature.
I am not given the option to override this.
vicz Posted - 01/30/2014 : 18:51:14
Request assistance.
ZLM Posted - 10/30/2013 : 21:29:37
Thank you.
kafji Posted - 10/30/2013 : 16:15:04
Try this new build:
http://www.mcumall.com/download/TrueUSBWillem/USBPrgSetup6.26.exe
34.79 KB
The new build seems ok on Windows 8.1. Program/verify ok as well.
ZLM Posted - 10/27/2013 : 23:51:18
Try this new build:
ZLM Posted - 10/27/2013 : 11:23:17
we are still trying to get a Win 8.1 for fixing the problem.
valleytek Posted - 10/25/2013 : 12:37:40
I haven't heard anything back yet but hope they are working on it.
valleytek Posted - 10/23/2013 : 15:52:07
John, If you are reading this, I can't reach you at your support email as it says your mail box is full. Please respond.
valleytek Posted - 10/21/2013 : 15:56:41
Here's what it looks like.
145.84 KB
