 I just bought my GQ4X and starting problems
akumakuja@hotmail.com Posted - 03/21/2014 : 17:22:28
So I bought my GQ4X, also Adapters for 29f032b, start recording my 29f032b and sometimes jumps mistake and not finished recording, I recording with the lower speed and finish but now does not check, I have read previous post on the same theme, it is known that by changing the voltage to 3v jumper check properly, but why does this happen? although this asset verification, my chip does not work.
ZLM Posted - 04/01/2014 : 12:28:20
If your GQ-3X works with that chip, then the adapter and the chip have no problem. Then this chip may have some compatibility problem with GQ-4X, the software algorithm for gQ-4X need to be fine tuned with this particular chip.
akumakuja@hotmail.com Posted - 03/24/2014 : 13:45:32
soo... what I can do MCUmall?? even detected the id of tsop 29f032b
akumakuja@hotmail.com Posted - 03/22/2014 : 19:05:01
YEP ALL ITS GOOD I HAVE THE GQX3 AND VERIFY PERFECT, BUT WITH THE GQ4X NO...WHAT CAN I DO?
ZLM Posted - 03/22/2014 : 08:18:47
Make sure your chip is good. Also, pin contacting.
