 verify M93C56
ricampr Posted - 04/30/2010 : 12:49:47
Hello.
I have an eprom M93C56.
read ok
write ok
verify failed
which may be the problem?
thanks
ZLM Posted - 07/01/2010 : 09:50:01
use slower speed.
See:
www.youtube.com/watch?v=ibd910i48CE
brchip Posted - 06/27/2010 : 16:39:21
I already did, but it always gives an error in the verification.
ZLM Posted - 06/27/2010 : 06:32:34
I recommend you to remove the chip from PCB and put it in the adapter to read and write.
That way is the standard programming way.
brchip Posted - 06/27/2010 : 04:40:09
Tried both ways. Reads and writes but verifiy gives error.
I tried 8 bit and 16. Is there a way to know which is the correct?
ZLM Posted - 06/26/2010 : 21:33:23
Are you doing it while the chip on the PCB?
brchip Posted - 06/26/2010 : 16:56:49
Same here. I'm usng 3M clip with sw v4.01. Should I upgrade to the latest sw?
I tried different speeds and devices (8 and 16 bits) but no luck.
Any ideas?
brchip Posted - 06/26/2010 : 16:48:24
I'm having the same problem. I'm using 3M soic8 clip. I used this clip for other chips and it worked fine.
Please help.
ZLM Posted - 05/06/2010 : 16:21:45
What adapter you used?
Check pin contact.
