 29F200BA problem!
Alioth Posted - 04/12/2012 : 06:59:31
Hey,
Using a GQ-3X with the PSOP-44 adapter, I tried to ID and then read a 29F200 chip from a 2000 Miata with the adapter's jumper set for a 28F chip, and not a 29F. Now the chip just reads out all FF's.
Have I erased or damaged the chip, or is it just not fitting into the adapter's ZIF and I need to fool with it some more? I'd attempt a test write BUT I then I have no copy of the program that's supposed to be on it :/
Thanks for any input!
Alioth Posted - 05/07/2012 : 09:05:51
Yes, I figured that out before making my original post. Do you have an answer for my question, aside from the obvious answer?
ZLM Posted - 05/01/2012 : 23:29:01
29F200 chip need 29FXX setting on adapter.
