 93C56 SID801 Siemens ECU
KillMe3 Posted - 03/24/2013 : 12:11:12
Hello together,
i want to read out data from a 93C56 EEPROM in a SID801 ECU.
Ive a GQ-4X Programmer and im not able to read Data out of the EEPROM.
So i need help.
stevocz Posted - 06/10/2013 : 10:04:51
i have same problem. i have 93C56 chip from audi ECU. in 4X i can read this chip but i cant write. in old LPT willem i can read and write. in willem can write 16bit chip, when i try write as 8bit, verify is bad.
chip was in soic 8 adapter
after i wrote chip in lpt willem i try verify in 4X, but this read different data.
this is second (from five) chip, which i cant write in 4X but in LPT works ok.
ZLM Posted - 04/27/2013 : 18:30:20
Try to remove the chip and program it on the programmer with adapter.
