 Adapter 56 JTAG SPI
BDMaster Posted - 07/07/2014 : 06:12:00
How to use it ?
I have connected to SPI line MoBo but Programmer don't listen It !
Someone can explain how to configure and use with software ?
ZLM Posted - 07/15/2014 : 14:53:40
The software does not have much setting. The only thing is the speed.
On the adapter, the you need to set the VCC mode, to select the VCC source either from programmer OR from the target board.
Connect the wires as shoot as possible.
See:
www.youtube.com/watch?v=RBLEZNL3L2Q
For the SPI, the ADP-056 is optional. You can try to direct connect your chip to the programmer ZIF socket. Unless it does not work good.
