 Help me please with TMS87C510 eprom
uferi Posted - 09/22/2014 : 05:24:54
Dear forum members/moderator,
I need your help, I'm fighting with this chip type which exist in the GQ-4X device list, but that need adapter(ADP-063 V2.0). I already ordered that but I will get to late for the current urgent project.
So my request is the next: please check with a multimeter the connection between the pins marked with red (control signals) and the adapter pins. Please note them, and also please draw a wiring sketch with the connection of the components from the adapter PCB (I'm sure they are connected on the control signal for inverting a signal for example). The rest of the signals (Data/scriptddress/Power/Vpp) I already fixed, I have problem with the marked pins.
Thank you in advance, best regards,
Feri
40.17 KB
111.35 KB
uferi Posted - 09/23/2014 : 21:40:06
Dear forum members,
the chip reading now is working but the writing isn't, that fail at the byte verify (SNAP I programming method).
Probably I have a problem at chip enable or output enable signal applied on the eprom.
The current wiring built by me is attached in the second picture.
60.26 KB
56.97 KB
Best regards,
Feri
