 12F629 Issue on GQ-4X - Reading different than bur
Necrosaro420 Posted - 04/28/2014 : 11:22:26
Using the GQ-4X and trying to burn 12F629. I have verified chips are in the right position. The file I am trying to burn is 609 bytes. After I burn and read it back, the file is 47.1k in size. I also get the messages below:
169.45 KB
and
ZLM Posted - 10/01/2014 : 13:39:28
This chip has no problem. Try slower speed and see if solves problem.
Make sure the chip is a good chip.
Tony2k Posted - 09/30/2014 : 23:59:43
Same problem, do you solved?
Necrosaro420 Posted - 04/28/2014 : 11:25:42
144.55 KB
139.9 KB
