 Gq4x no driver found
tahir Posted - 12/28/2014 : 17:47:06
Hi i have a gq-4x programmer
I'm running windows 8.1 64 bit I've everything i keep getting driver not found I'm lost now i don't know what else to try could anyone please help me thanks
kennyf5 Posted - 08/20/2015 : 11:21:45
To install a driver you need to have a driver downloaded from the MCU Mall.
Once you have the correct driver right click on the windows button (bottom left of the screen).
Pick the option "device manager". Find the device that matches your item.
Somewhere in there, there should be an option for USB devices and the Device you have.
Double click on the device. On the top of the window select the "drivers" tab.
Select update drivers, and "I will choose drivers from my computer (or something similar depending on the windows version)"
Find wherever you stored the driver. Install and go.
blanketsnake Posted - 06/18/2015 : 01:47:10
I'm having the exact same issue mate. Any chance you could explain to me how you fixed it please? Cheers
tahir Posted - 12/31/2014 : 17:53:17
Hi thanks i have fixed the problem big thanks to the person who helped me even though it was the holiday season happy new year to everyone
tahir Posted - 12/29/2014 : 23:03:30
Thanks you I'm still getting driver not found could you please explain how to install the driver even in windows 7 I'm having the same problem. I would appreciate your help thanks
ZLM Posted - 12/28/2014 : 18:28:44
See this:
http://www.mcumall.com/forum/topic.asp?TOPIC_ID=4970
From Windows device manager, you should see a unknown device from the list, check the hardware ID from properties. The Id should be :
USB\VID_0547&PID_2131&REV_0004
