 Maybe My GQ-4x Not Working Well or whats?
joelz Posted - 01/22/2015 : 04:05:48
when i back bios with my gq-4x with plan i want to change the chip with the new cips but same type end serial, but why the bios backup can't work when i flash into new chips,the power led laptop won't turn on,but if i put back the old chips led power is turn on, i flash the new chips with file bios from old chips, both chips is the same type end series,any idea?
Necrosaro420 Posted - 02/11/2015 : 11:19:00
I ordered off your ebay. But having a hell of a time getting a response with tracking info a week later.
ZLM Posted - 02/05/2015 : 00:08:55
25q80bvsig is confirmed supported chip.
If the programmer and program it and verify it, then the programmer is working fine.
Check others.
joelz Posted - 01/30/2015 : 23:02:30
Originally posted by laptech
We can not help you if we do not know the brand of chip. What are the details written on the bios chip?
its winbond 25q80bvsig but not this chips also,if i want to flash with another chip same problem too
ZLM Posted - 01/23/2015 : 19:53:43
Your data file is not correct. Get correct BIOS data file.
If you are copying chip from old chip to new chip, then verify the data with old chip. They should be verified.
laptech Posted - 01/23/2015 : 06:31:52
joelz Posted - 01/22/2015 : 23:14:17
What is the manufacturer make and model number of the bios chip, is it Winbond, SST, Eone?
same when i try to flah any brand,type end serial of chip manufacture
laptech Posted - 01/22/2015 : 05:01:43
