 GQ-4X not support 25vf064C?
tomcat801 Posted - 07/01/2013 : 15:25:12
bought GQ-4X to read and erase SPI flash sst25vf064c,because I found it support "25 series". But after installed everything, I could not find it in the device list. GQ-4x does not support it?
if so, I have to return it.
ZLM Posted - 05/07/2015 : 08:39:37
There should be no different on old version software.
lapkritis Posted - 05/07/2015 : 07:08:48
Yes, ID is ok. I have no problems with other chips. Chip which I'm trying to write is brand new, and I have two of them. So it should be the software.
line in devices.txt is:
Name="SST25VF064C",ID="BF254B",Class="SST25VF040B",CodeSize="8388608",VCC="3.6V",Category="SERIAL_EPROM",Adapter="SOIC8-DIP or ADP-081 adapter",MFG="SST",Platform="GQ-4X"
software version is 6.34. should i try to install older version?
ZLM Posted - 05/07/2015 : 06:43:15
Does programmer detect the chip ID correctly?
If the ID is not correct, then do you have any other SPI chips for testing? Just want to make sure the programmer is working.
If the programmer is working, then we only need to concentrate on the software.
lapkritis Posted - 05/07/2015 : 01:30:52
no, it fails on first line. chip remains empty after writing
ZLM Posted - 05/06/2015 : 16:53:59
does it pass the verification process?
lapkritis Posted - 05/06/2015 : 04:04:24
hello,
i have this line added to devices.txt, but still can not write tjis chip. process goeas to 100% with no errors, but chip remains empty. any ideas?
ZLM Posted - 07/05/2013 : 16:14:33
Try to add following line into devices.txt:
Name="SST25VF064C",ID="BF254B",Class="SST25VF040B",CodeSize="8388608",VCC="3.6V",Category="SERIAL_EPROM",Adapter="SOIC8-DIP or ADP-081 adapter",MFG="SST",Platform="GQ-4X";
