 question about EasyPro 90B
Escher Posted - 11/24/2006 : 10:14:58
As TOP2005 the EasyPro 90B during the programming it use the pc's cpu ? is it more velocity than top2005 ?
Escher Posted - 12/24/2006 : 20:13:52
is there one correct procedure to program the ic (for example SST flash) ?
because I don't succeed to program them
ZLM Posted - 12/15/2006 : 17:27:51
Originally posted by Escher
Is there any device pin check on this programmer ?
TOP2005 has pin check.
Easy Pro B has no pin check but it has ID check. If the ID not match, then it will message.
Escher Posted - 12/14/2006 : 06:21:33
ZLM Posted - 11/26/2006 : 18:56:47
It has on board CPU in the programmer.
